25. Vermeer TS44A Tree Spade Trailer (1:13)
A tree spade is a specialized machine that mechanizes the transplanting of large plants, including large bushes and small or medium trees. The machine consists of a number of blades that encircle the tree, digging into the ground and then lifting the entire tree, including its roots and soil, out of the ground and replanting or transplanting the whole tree in the designated area.
Discussion Topic
Scale: 1:13
Main functions:
  •  Adjustable trailer coupler, left and right, when stand next to tree, this movement rotate a bit the whole trailer left and right, allowing precise positioning of the blades around the three,
  •  Adjustable trailer coupler, extend and retract, this movement push or pull a bit the whole trailer closer or further from the tree, allowing precise positioning of the blades around the three,
  •  Outrigger up/down, single outrigger feet secure the trailer at the back, between the tires/ Front part of the trailer is securely hooked to the driving vehicle,
  •  Spade section tilt to vertical position
  •  Spade section lower to the ground level
  •  Spade section "hugging" the tree
  •  Blades dig in/retract
Real machine:
Pictures:
Video:
26. Telescopic wheelloader
Pneumatic functions:
  • Raise/lower boom
  • Extending boom
  • Control function on attachment
Other functions:
  • Steering
  • Four wheel drive
  • Fake 4 cilinder engine
  • Tipping bucket
Link to discussion topic Here
Video:
Pictures:
27. Man TGS 6x4 With Container Hook
Functions:
Truck:
-Hog front wheel steering.
-Inline 6 engine driven by the 2 rear axles.
-Manual tilting of the cab and opening of the doors.
-Leaf springs on all axles
-PPTO on the back and on the front of the cargo.
-2x 2*11 cylinders to move the Hook arm.
-1x 2*7 cylindersto extend the Hook arm.
-1x 1*5 cylinder to switch function of the Hook arm.
Trailer:
-1x 2*7 cylinder to move the transition rail.
-1x 2*7 cylinder to move the pusher on the rear.
-1x 1*5 cylinder to lock the container.
More pictures:
Video:
Link to the discussion topic:
28. Car Transporter
Platform #1 Elevation/Lowering
Platform #2 Elevation/Lowering
Platform #3 Elevation/Lowering
Manual functions:
HOG Steering
Working V6 engine
Truck Ramp Extending/Retracting
Trailer Ramp Elevation/Lowering
Swiveling Chairs
Some Photos:
Topic:
Missing video and Link to discussion topic.
29. Small robust compressor
pneumatic functions:
provides constant supply of air
can be powered by a motor or hand cranked
other functions:
very compact design
robust, can be dropped on the floor without it breaking
uses a minimal amount of parts
pictures
30. Pneumatic Rock Loader
Lego Technic Pneumatic Rock Loader
Transport dimensions: 88 x 25 x 27 cm, total weight – 5 kg.
- Clearance adjustment, left and right independent (six large cylinders);
- Outriggers deployment (four small 11L cylinders);
- Outriggers (eight large cylinders);
- Superstructure rotation (+-90 degrees, two large cylinders);
- Boom lifting (two large 11L cylinders);
- Boom extension (two large 11L cylinders);
- Bucket unloading (two large cylinders).
Mechanical functions:
- Independent suspension;
- 4x6 normal steering;
- 6x6 crab steering;
- bucket self-leveling system;
- Expander (four large pumps).
Video:
Link to the discussion topic.
31. Concept Bulldozer
Functions:
  • Manual
    • 16 Cylinder Engine
    • Suspension
    • Opening Driver Door and Control Panel
  • Pneumatic
    • Compressor (PF M, 8878 Battery Box)
    • Blade Lift
    • Blade Tilt
    • Blade Angle
    • Opening Hood
    • Ripper
Images:
Video:
Discussion Topic:
32. 4-8-2 Pneumatic Locomotive
Functions:
This entry has only one function, conversion of linear energy into rotational energy, also known as driving the wheels.  This model comes with added bonus of sounding like an old steam train too.
Images:
Video:
33. Heavy Lift Telehandler
Functions:
- Extending the boom
- Steering
- Raising the arm
- Cabin lift
- Attachment leveling
- Extra function (Claws)
uviHan91V1HrGOnKMRonW7czbuvDodJqnT-URLqG
ZJGpsVxnxOcEci924e2tBhlaBX_LeTPSjZJWjskP
-rx5vCAxc8A6UvAHTWrt7HnIIl_DmiebiMQDGwRC
I-f2qBf0KZnzHXuCCvz9tZJftxbrIvXkyXLpF4Sf
Video:
34. Mini Underground Mining Loader
Functions:
  • Pneumatic bucket tilting
  • Pneumatic bucket lifting
  • 4x4 drivetrain
  • 2 cylinder piston engine
  • HOG steering
It's a 9 stud wide model, close to minifig scale. I tried to use as many yellow parts, as possible, to give the "all yellow" look.
Photos:
Video:
Discussion topic:
35. Genie Man Lift
Manual Features:
4 wheel steer
rotating structure
Pneumatic Features:
Power Functions pump
Main Parallel Lift
Secondary Lift
Cage Lift
All valves located in the basket.
Lego genie manlift
Lego genie manlift
Discussion Topic:
36. Pneumatic Classic Locomotive
This model tries to simulate the steam pressure in classic locomotives using LEGO pneumatic system. It also tries to model the looks of a classic locomotive.
Functions:
  • Compressor (1 big + 2 small pumps all coupled together)
  • Pneumatic Engine using 2 cylinders, 2 switches, and connected to 4 LEGO large bike wheels. The drive is achieved by semi-alternative push of the wheels by each cylinder. Deadlocks are prevented by using only 90 degrees difference among the cylinders and by connecting the switches of each side to the other side. This is illustrated below.
  • Locomotive Headlight
Pictures
The Pneumatic Compressor. The large pump puts most of the power, I added 2 small pumps and this seems the maximum using 2 XL motors and a single battery box.
Otherwise the pressure could be increased but the model has to be much larger.
This diagram illustrates how everything is connected to achieve drive.
Note that the phase shift among the cylinders is 90 degrees and the leading cylinder receives reversed air connections.
Video
Discussion Topic Link
[TC10] Classic Locomotive
37. Log Skidder
- Articulated steering
- Pendular fron suspension
- Fake 4 cylinder engine
- Boom section 1 up/down
- Boom Section 2 up/down
- Claw open/close
- Front blade up/down
Thanks and good luck to all contestants!
01e
Link to entry post
Video
  • Jim locked this topic
  • Jim unpinned this topic
