Jim Posted August 31, 2016 Author Posted August 31, 2016 I just meant the normal cylinders with two port. But instead of actuating them by a valve, I want to use them to generate a vacuum for a gripper. In order to do so I have to drive them by a motor, just as you would do with a pump, but this time a cylinder is extended and compressed by the pf motor. So in this case the cylinder is used as a pump, however it is generating the vacuum. I think I'm getting where you are going with this. Correct me if I'm wrong. You are using the PF to power the Cylinder, which will operate the gripper. In other words; you will use PF to operate the gripper (technically). This is NOT allowed. PF can't be used to operate functions, even if there's a cylinder in between. (although I do like the idea) Quote
KvM Posted August 31, 2016 Posted August 31, 2016 (edited) no its still a bit different. I tested this idea before. The motor revolves a cylinder and at the same time a valve is switched. If you connect the tubes correctly and switch the valve when changing the direction of motion of the cylinder you can create a vacuum. See a device i made which is used to make pavements: http://www.brickshelf.com/cgi-bin/gallery.cgi?i=5731642 I was able to lift my Samsung s4 by using this technique. It just reverses the process of a pump. Edited August 31, 2016 by KvM Quote
KamalMYafi Posted August 31, 2016 Posted August 31, 2016 (edited) http://www.brickshel....cgi?i=5731642. FTFY! Because you had a 'dot' on the end of the link. And it's bring me to an error page. BTW, here is the full gallery! Edited August 31, 2016 by KamalMYafi Quote
Alex Ilea Posted August 31, 2016 Posted August 31, 2016 so we are not allowed to operate a motor that drives a pump with a remote and a recever ? Quote
Milan Posted August 31, 2016 Posted August 31, 2016 so we are not allowed to operate a motor that drives a pump with a remote and a recever ? No IR receivers. Quote
BachAddict Posted August 31, 2016 Posted August 31, 2016 You can start before the weekend (or do you need all your LEGO for the weekend?) Well, I'm in Germany at the moment but my LEGO is at home in New Zealand! All I brought with me was a small Technic R2D2 that arrived in the mail as I was leaving. Quote
Milan Posted August 31, 2016 Posted August 31, 2016 Why :( ? Because this is Pneumatic contest, not Power Functions contest. Focus should be on Pneumatic functions. Quote
efferman Posted September 1, 2016 Posted September 1, 2016 (edited) Is it allowed to power a mechanical pto when the same motor powers at the same time a compressor? Edited September 1, 2016 by efferman Quote
kolbjha Posted September 1, 2016 Posted September 1, 2016 A couple of questions related to PF. Is it allowed to use PF Switch to control motor? Lights may be used in combination with motorized pumps. Does it mean that lights only can be powered at the same time as motors? Is it allowed to use PF extension cables, for example in umbilical? Quote
Milan Posted September 1, 2016 Posted September 1, 2016 Is it allowed to power a mechanical pto when the same motor powers at the same time a compressor? Hi Michael, sorry, but motor can only be used for a compressor. Quote
ScaleCarModels Posted September 2, 2016 Posted September 2, 2016 Hi Michael, sorry, but motor can only be used for a compressor. Thanks for clarification I was wondering same thing. Quote
Jim Posted September 2, 2016 Author Posted September 2, 2016 Anyone ever seen this? http://www.youtechnic.com/home.html Quote
jorgeopesi Posted September 2, 2016 Posted September 2, 2016 Anyone ever seen this? http://www.youtechnic.com/home.html Nothing to see for me. Quote
KamalMYafi Posted September 2, 2016 Posted September 2, 2016 Anyone ever seen this? http://www.youtechnic.com/home.html Me? not! But, isn't 3rd party part not allowed? Quote
Jim Posted September 2, 2016 Author Posted September 2, 2016 But, isn't 3rd party part not allowed? True. 3rd party is not allowed. Maybe I should post it somewhere else. Quote
JJ2 Posted September 2, 2016 Posted September 2, 2016 Anyone ever seen this? http://www.youtechnic.com/home.html I have seen something like it, this one seems higher quality though Quote
KvM Posted September 3, 2016 Posted September 3, 2016 Can I get a final answer on whether it is allowed to create a vacuum by driving a normal cylinder? Otherwise I have to come up with something else. Quote
Milan Posted September 3, 2016 Posted September 3, 2016 Can I get a final answer on whether it is allowed to create a vacuum by driving a normal cylinder? Otherwise I have to come up with something else. No, sorry, it is not allowed. Motors can only be used to drive a compressor.. Your idea is great and unique, but it does not fit the contest rules. Quote
Alex Ilea Posted September 3, 2016 Posted September 3, 2016 Are we allowed to use the PF swich to control the motor that drives the pump ? Quote
KvM Posted September 3, 2016 Posted September 3, 2016 OK, if someone is interested, I can build a test setup to make the idea clear and allow you to test the vacuum system yourself. For the contest I will find something else. Quote
Captainowie Posted September 4, 2016 Posted September 4, 2016 you will use PF to operate the gripper (technically). This is NOT allowed. PF can't be used to operate functions, even if there's a cylinder in between. I don't think this argument is valid - I mean, a compressor is nothing but a cylinder with a valve instead of a top port. It is certainly possible to construct a compressor from a normal cylinder and some switches (as I posted about a decade ago! http://news.lugnet.com/technic/?n=15434) - this construction also would be outlawed under the current ruling, even though it's functionally identical to (if vastly bulkier and less efficient than) a normal compressor. In any case, KvM, I'd like to see what you were planning. Owen. Quote
KvM Posted September 4, 2016 Posted September 4, 2016 (edited) Well yeah thats basically it. Although I made a version which contains only 1 switch. A pneumatic engine (LPE) is allowed to be used when operated by a hand pump? Edited September 4, 2016 by KvM Quote
Appie Posted September 4, 2016 Posted September 4, 2016 Are we allowed to use the PF swich to control the motor that drives the pump ? Considering the alternative would be to have every entry with a battery box in the open or at least the battery box switch in the open, I would hope so? At least I personally wouldn't like it if I couldn't turn off the compressor in an easy to get to place, might break something. Quote
Milan Posted September 5, 2016 Posted September 5, 2016 (edited) Are we allowed to use the PF swich to control the motor that drives the pump ? Yes, switch for compressor motor is allowed. A pneumatic engine (LPE) is allowed to be used when operated by a hand pump? LPE is allowed, sure! You can power it with hand pump, or with a compressor. Just don't copy design from someone else 1:1. Edited September 5, 2016 by Milan Quote
