Thank you for all the kind words above. :blush:
Which tracks will you use?
I think I'll use the 5L wide track, seems that fits the scale better. Having not decided the color of the track yet. :wink:
Edited by falconluan
Try smaller ones.
the scale looks pretty good. I know it is hard to fit functions is such a machine. Look at Sheo's RH400.
Thanks and a little update:
Undercarriage is almost done. Now only details and the auto compressor are left to be done.
Considering the scale of the treads, I chose the 5L treads finally. I think both its width and length fits better here. What do you think?
For the tread color, I think black looks better, as it is consistent with other part of the undercarriage as the real thing.
Also, for the right side of the super structure, I use the LBG 5x11 panel for two reasons:
1. I don't have enough white ones. :grin:
2. I try to present the shutters.
Again, what do you think? Should I use grey? White? or build some real shutters?
Thanks for watching
I'm starting to like this model more and more. Great work, also on the color scheme and detailing.
But I don't like the gray 5 x 7 frame on top of the cabin. I think you could do with some black here, and achieve better detail with smaller parts.
Also, I wouldn't go with the inverted gray 5 x 11 panels. They might "fit" your reference model, but they just look wrong. Rathre than trying to follow the reference, I'd just try to build a nice model. Just a suggestion: use white panels, and replace the top two panels by 3 x 11 ones. This leaves a gap of 2 x 22 studs. Try to fill this with white grill tiles. (although I'm not sure about having a single studded detail only. You might want to use studded pieces elsewhere to make it more coherent). The other alternative is to fill it with white round pin joiners, or 1 x 2 x 0.5 beams placed vertically on black axles with small spaces between. Then you hvae a fully studless solution that breaks the huge white side with some detailing without having to resort to inverted gray panels :)
Thank you very much for your great suggestions.
I'll try building something to replace the frame on the top of the cabin.
Yes, you are right that I am trying to achieve a "pure" technic solution here. A pile of white 2412b tiles may fit better on the right side but I think they are a little bit fragile. Aside from what you proposed, I'll try to use some combination of white beams and grey axles.
Thanks again for your suggestion and encourage.
  • 5 weeks later...
Looks really good. Great job. I like your solution for the shutters and nice details with the ladders. Model looks great in scale with the mining truck from 42055.
One minor thing though, I am not sure I like the hoses on top of the arm, any chance that they could be hidden in the the arm?
Glad you like it. :classic:
You mean the hoses on the top of the boom? or in front of the stick? I put the hoses there to reflect the real thing's set up. Though the hoses are too HUGE speaking of scales.
The hoses around the stick are a bit off from the real one's set up.  They can be put inside the 5x11 frame and stick out from the side holes, but the hoses will need to be cut shorter. I'd say I prefer to stay the current setup more. Anyway, thank you for your advice. :thumbup:
Ah ok, makes sense to have them in the same place as the real one. One minor suggestion for that would be that I'd put them (the point where you use the T-pieces) on the turning point of the boom then (edge of 5x11 frame) at the top. I think the whole boom will look a little more fluid then. Again it's a minor thing on a really cool model, so no worries.
Yes, agreed that may look better, I'll have a try. Thanks again :wink:
This turned out great. I love the size and scale. I look forward to the video.
Also, those joystick controls are pretty awesome.
Edited by Thirdwigg
People offen complain that the pnuematic switches are hard to use, especially the downward movement. I tried to improve this by the following structure:
It was inspired by the controlling mechnism of 42040.  The longer control arm provides more precise controlling and it is much easier to use.
There is some overlap between range of the two linkages' movement. However, the interference is totally acceptable.
I tried to align the control setup the same as real world's excavators despites it seems that the opening of the bucket is via a button on the real ones.
Thanks and here is the video :blush:
27 minutes ago, Lego2016Lego said:
If you take better pics the lego car blog may blog this.
Thanks for your invitation. :blush:
I'll try to take some more clearer pictures at this weekend. Hope it is not too late by then.
