Brickdoctor Posted September 7, 2016 Author Posted September 7, 2016 My modded LL version: [snip] In perfect scale with cavegod's AT-AT btw ;) Yeah, that won't work as well with my design because of the SNOT wings. It also looks like the wings on that speeder slope downwards at closer to 45 degrees, and that gives a little more vertical space. (Which is not necessarily a bad thing; I know mine don't slope quite enough, but I stuck with the angle of the 1x2x2 slope on the inner side of the gun mount so that it'd line up nicely.) Quote
makoy Posted September 8, 2016 Posted September 8, 2016 I like the overall smoothness and that studded wedges at the front... reminding me that it is LEGO. Good job with the vignette as well! Quote
Bricksnaps Posted October 21, 2016 Posted October 21, 2016 Perfect. And perfect color. I now want one. Quote
JJtorres501 Posted December 26, 2016 Posted December 26, 2016 On 8/24/2016 at 0:51 AM, Brickdoctor said: Indeed, and make sure to use the four-toothed 'a' variant, not the two-toothed 'b'; the two-toothed one will be almost impossible to center around the flex tubing. Would you happen to have a parts list for this? Thinking of brick linking this. Quote
Green Rey Posted December 26, 2016 Posted December 26, 2016 Love how you got the colors just right. I don't understand when people make lego snowspeeders with white. Quote
All in the Reflexes Posted December 26, 2016 Posted December 26, 2016 1 hour ago, Green Rey said: Love how you got the colors just right. I don't understand when people make lego snowspeeders with white. But they aren't grey either, they are a dirty mix that's hard to equate with lego colours :) Quote
VaderFan2187 Posted January 10, 2017 Posted January 10, 2017 On 27/12/2016 at 9:29 AM, All in the Reflexes said: But they aren't grey either, they are a dirty mix that's hard to equate with lego colours :) Maybe that's why they're made white. After a while they'll yellow and become a dirty white color Quote
lostcarpark Posted May 19, 2017 Posted May 19, 2017 I built a version of this over the last two days... T-47 Snowspeeder by James Shields, on Flickr T-47 snowspeeder by James Shields, on Flickr T-47 snowspeeder (rear) by James Shields, on Flickr I wanted it for a show this weekend, so I had to make do with parts I had to hand, so there's a few changes. In particular, I have no pneumatic tubing, so I had to improvise the guns with regular bars. I may revise it later. It's gone a little wrong, and I get a bit of a gap in front of the canopy. I hope I can figure out what's causing it and fix later. It's currently on display with a pair of Roskilnikov AT-ATs in Naas Library, Kildare, Ireland, and has received a lot of praise. T-47 Snowspeeder and Plus Size AT-ATs by James Shields, on Flickr I prefer my snowspeeders in white, but I don't think either white or grey is completely correct. Thanks again for sharing. James Quote
rmoore Posted May 20, 2017 Posted May 20, 2017 This thing is incredible. I built LL's version and I love it (despite it's fragility), but yours just takes it to another level. Bravo! Quote
GBaron Posted October 7, 2017 Posted October 7, 2017 Stumbled onto this build/post a few months back. Firstly, absolutely awesome. All the lines and angles are perfect. Does anyone have any pics of the undercarriage or have any LXF files been posted somewhere? I’ve been mashing bricks together for the past few months but just can’t work it out. Need this build on a shelf in my life! ? Quote
27Wilson93 Posted June 2, 2019 Posted June 2, 2019 On 8/25/2016 at 1:08 AM, Brickdoctor said: Just for you, mortesv! This is as close as it's going to get, I think: Parts in red need to be substituted with parts that aren't in LDD. You'll need at least: Two of the 8L pneumatic tubing. I just bought one 17L piece and cut it down to size. Two of those tabless, removable hose bases. Two of the old Technic bushing-pulley combo pieces. Four of the metal train axles. Roughly 10L flex tubing. Two of the toothed half bushings; make sure to get the ones with four inner teeth instead of two. Two red rubber bands, either Technic or the ones off of the flanged drivers. One string that's wedged between the ¾ pin and the 3L flex tubing of the harpoon gun and run through the radiator to somewhere in the cockpit There are also some part and color variations that are probably ignorable. For example, I've used two styles of the 1x1 tiles with clips, depending on how much friction I wanted for the particular connection. Also note that some of the dark bley inserts for the repulsorlift housing are just 'floating', held in by friction. If you buy new pneumatic tubing, you might need some lubrication to get the train axles in; I just used canola oil and washed the assembly off with a bit of soap afterwards. T-47.lxf I know its been quite a while but I love your version of the snowspeeder and i'd really like to rebuild it . Would you consider uploading it again?:) Quote
27Wilson93 Posted September 8, 2019 Posted September 8, 2019 Does probably any of the others still have the file? I would love to build i! :) Quote
Cylo Posted September 8, 2019 Posted September 8, 2019 Just now, 27Wilson93 said: Does probably any of the others still have the file? I would love to build i! :) The file still works perfectly. What do you mean? Quote
27Wilson93 Posted September 8, 2019 Posted September 8, 2019 Just now, Reaper said: The file still works perfectly. What do you mean? True! The last tfew imes i checked it didn't and i thought without any new comment here it wouldn't silently work again. I'm so glad! :D Thanks for the headsup and thanks a lot to brickdoctor for reuploading it :) Quote
Xelveki Posted September 8, 2019 Posted September 8, 2019 I think that's the best looking snow speeder I've seen. Quote
Neophyte_brickie Posted August 10, 2022 Posted August 10, 2022 @Brickdoctor, what part have you used for the tip of the laser cannons? It looks like a different part than the 1 x 1 cone that's shown in your 'exploded' render. Beautiful moc, btw! Quote
icm Posted August 10, 2022 Posted August 10, 2022 (edited) On 8/22/2016 at 10:29 PM, Brickdoctor said: The front portion of the guns are pneumatic tubing stiffened by two train axles apiece. (You can just barely see the divot in the middle where the two axles meet.) The exposed ends of the axles are fed into flex tubing to be clipped or inserted into a Technic pin. Quoted from the first post Dunno if that helps or if it refers to the very tips of the guns at all Edited August 10, 2022 by icm Quote
Kdapt-Preacher Posted August 10, 2022 Posted August 10, 2022 5 hours ago, Neophyte_brickie said: @Brickdoctor, what part have you used for the tip of the laser cannons? It looks like a different part than the 1 x 1 cone that's shown in your 'exploded' render. Beautiful moc, btw! I’m not BrickDoctor, but I believe that’s this piece: https://www.bricklink.com/v2/catalog/catalogitem.page?P=752#T=C Quote
Neophyte_brickie Posted August 10, 2022 Posted August 10, 2022 9 hours ago, Kdapt-Preacher said: I’m not BrickDoctor, but I believe that’s this piece: https://www.bricklink.com/v2/catalog/catalogitem.page?P=752#T=C That looks like it! Thanks. Quote
Wonderpants Posted August 6, 2023 Posted August 6, 2023 Did Brickdoctor or anyone else ever do a LDD/stud.io file for this? Would like one to go with my UCS at-at Quote
