technic_addict Posted February 28, 2017 Posted February 28, 2017 On 11/11/2016 at 3:56 PM, technic_addict said: I may also build this in white. It looks quite good IMO. On 11/12/2016 at 2:12 PM, Thorsten50 said: Complet white? Oh. You will get some problems. 1.) Page 92-94 +40x Beam 1x2 Half (41677) only red Version 2.) Page 132 Step 6 3.) page 133 Step 6 4.) Page 138 Step 3 and 3 TLG has made the 1x2 beam with pin hole and axle hole in white now so this set is possible to build in white now with a few small changes. I believe only one area requires both through holes for the flex axles so it would need to be omitted there. Any takers? Quote
ndm1306 Posted June 10, 2017 Posted June 10, 2017 Hi, Mine can't run and both Cv joints at rear got damaged! I guess it's too heavy, why yours can run so smoothly? Please help! Quote
ndm1306 Posted June 10, 2017 Posted June 10, 2017 Just now, LvdH said: Maybe they didn't get damaged, but they disconnected. Did you check that already? Yes, Disconnected, if I still run, CV joint axle (92906) got damaged, because CV joint (32494) rotate and harder 92906.How to solve that problem? I don't want it for display only. Sorry for my bad english. Quote
Lox Lego Posted June 10, 2017 Author Posted June 10, 2017 58 minutes ago, ndm1306 said: Yes, Disconnected, if I still run, CV joint axle (92906) got damaged, because CV joint (32494) rotate and harder 92906.How to solve that problem? I don't want it for display only. Sorry for my bad english. Hi, The best solution for this issue is to place a single bushing in between the CV joint and the black axle adapter in this photo: https://goo.gl/photos/jQhfm9vN2CmAZYuw8 This will provide more rigidity to the axle holding the CV joint. I hope this helps... Quote
Aventador2004 Posted June 10, 2017 Posted June 10, 2017 3 hours ago, Lox Lego said: Hi, The best solution for this issue is to place a single bushing in between the CV joint and the black axle adapter in this photo: This will provide more rigidity to the axle holding the CV joint. I hope this helps... This works great for me and I use it frequently in my builds. Quote
ndm1306 Posted June 11, 2017 Posted June 11, 2017 (edited) 10 hours ago, Lox Lego said: Hi, The best solution for this issue is to place a single bushing in between the CV joint and the black axle adapter in this photo: https://goo.gl/photos/jQhfm9vN2CmAZYuw8 This will provide more rigidity to the axle holding the CV joint. I hope this helps... Hi again, You meant like this ? Ask for sure because i have no more CV joint Axel. Thanks https://goo.gl/photos/TvcXqSV7iRyuYyoP8 Edited June 11, 2017 by ndm1306 Quote
Lox Lego Posted June 11, 2017 Author Posted June 11, 2017 9 hours ago, ndm1306 said: Hi again, You meant like this ? Ask for sure because i have no more CV joint Axel. Thanks https://goo.gl/photos/TvcXqSV7iRyuYyoP8 Yes, just like that. Quote
ndm1306 Posted June 11, 2017 Posted June 11, 2017 49 minutes ago, Lox Lego said: Yes, just like that. Hi, It's can't help I tried, because this 18654 rotates freely between CV joint and 59443, can't make CV joint more rigid. Quote
Lox Lego Posted June 11, 2017 Author Posted June 11, 2017 34 minutes ago, ndm1306 said: Hi, It's can't help I tried, because this 18654 rotates freely between CV joint and 59443, can't make CV joint more rigid. @DugaldIC designed the framework. Dug, do you have any other ideas? Quote
ndm1306 Posted June 11, 2017 Posted June 11, 2017 I don't know why the one from Thorsten runs like hell? Quote
technic_addict Posted June 11, 2017 Posted June 11, 2017 32 minutes ago, ndm1306 said: I don't know why the one from Thorsten runs like hell? I found if I don't reverse when driving forward and let car stop on its own it's ok. Quote
ndm1306 Posted June 11, 2017 Posted June 11, 2017 So, how to solve this issue or we have to accept this, for display only? Thank you for your reply. Quote
Lox Lego Posted June 11, 2017 Author Posted June 11, 2017 Just now, ndm1306 said: So, how to solve this issue or we have to accept this, for display only? Thank you for your reply. Hi, Why don't you replace the CV joint for a universal joint? Just on the one side were you are having trouble. Quote
ndm1306 Posted June 11, 2017 Posted June 11, 2017 Hi, I tried but another problem happened, the small tan gears 6589 in the differential get damaged, 2 XL motor sound very noisy, maybe all gears slipped inside it. its rear is quite heavy and too much torque form 2 XL motors, I think that's teh problem when playing forward and suddenly reverse. Quote
Lox Lego Posted June 11, 2017 Author Posted June 11, 2017 (edited) 6 minutes ago, ndm1306 said: Hi, I tried but another problem happened, the small tan gears 6589 in the differential get damaged, 2 XL motor sound very noisy, maybe all gears slipped inside it. its rear is quite heavy and too much torque form 2 XL motors, I think that's teh problem when playing forward and suddenly reverse. Try changing the 2x 20 teeth gears to 2x 12 teeth gears, and the 12 tooth bevel gear to a 12 tooth thicker black gear. (see here https://goo.gl/photos/qnh44DztV85jrE9t6) THis will easily gear it down, and not allow skipping. Edited June 11, 2017 by Lox Lego Quote
ndm1306 Posted June 11, 2017 Posted June 11, 2017 Thank you Lox lego, now I have to disassembly it and change all gears as you said. But I still don't know why his car runs too good, nothing happens until I follow his instruction? Quote
DugaldIC Posted June 11, 2017 Posted June 11, 2017 I'm not too sure, the only time I saw an issue was when you tried to go straight from reverse into drive or vise versa. I might have to revisit the design and see if I can't make a simple fix. Gearing it down would definitely help though. Quote
ndm1306 Posted June 14, 2017 Posted June 14, 2017 I tried many ways to make it running smoothly but no use... Quote
