efferman Posted September 15, 2016 Posted September 15, 2016 My Truck sucks.....not. This is a function which i can not replicate Picture Source I am building these things since 6 years in real and the new double length pneumatic actuators now make it possible to build a lego one. Quote
jono rocky Posted September 15, 2016 Posted September 15, 2016 You have me curios, I've seen these vacuum trucks in action and looking forward to yours. Quote
grum64 Posted September 15, 2016 Posted September 15, 2016 Unlike jono.rocky I've not seen one these before so I'm particularly curious. I'll be following its build with great interest. Quote
2LegoOrNot2Lego... Posted September 16, 2016 Posted September 16, 2016 This is an amazing piece of machinery. Didn't see on either... Sure excited about how this will look like, you got me curious too... Do I get you right: you build these things as your daily job? Quote
AFOLegofan66 Posted September 16, 2016 Posted September 16, 2016 this should be very interesting...looking forward to check out the progress!! Quote
Imanol BB Posted September 16, 2016 Posted September 16, 2016 Hi Effe, first of all i want to say that all the projects that choose are always unique, as well as your building techniques; this truck that you are building looks really complex but interesting, many moving parts, lots of functions, it would be really cool if lego could make a vacuum pump, so models like these (and many other models out there) could be created with a lot more realism, this project looks very promising and i will love to see it finished, i hope you luck in the building and the contest. Quote
steph77 Posted September 16, 2016 Posted September 16, 2016 (edited) Hi effe, You said your truck couln't suck. I think that witt the very first pneumatic system and the special 4X2 briks with the one way valve integrated in it, it could be possible EDIT: as the pneumatic cylinders work with only one entry it must suck air at one moment :) visble here: https://en.wikipedia..._components.JPG Edited September 16, 2016 by steph77 Quote
efferman Posted September 16, 2016 Author Posted September 16, 2016 (edited) Steph, this sucking is a little bit minimalistic against this one edit: the opening sequence Edited September 16, 2016 by efferman Quote
efferman Posted September 17, 2016 Author Posted September 17, 2016 (edited) some progress hopefully the 1x11 cylinders are strong enough for the upper shell Edited September 17, 2016 by efferman Quote
2LegoOrNot2Lego... Posted September 17, 2016 Posted September 17, 2016 I'm always amazed how swift and clean you build...the progress is phenomenal! Quote
efferman Posted September 18, 2016 Author Posted September 18, 2016 (edited) First Pictures in motion. the lift needs not much force on the pump, seems there is enough power to lift some payload edit: the opening sequence in motion Edited September 18, 2016 by efferman Quote
Imanol BB Posted September 18, 2016 Posted September 18, 2016 That is really amazing Effer, everything works very good, even when it seems to have a very complex system it works smoothly, it is looking very nice. Quote
2LegoOrNot2Lego... Posted September 19, 2016 Posted September 19, 2016 I can tell you work at the real thing as well... ...excellent, you really are doing a great job ...but what else could we expect from you... Quote
efferman Posted September 25, 2016 Author Posted September 25, 2016 this is harder than i thought. The fake suction hose has arrived yesterday and it is to long. The longest hose on the mts suction excavators is 7.8meters long. The fake hose, two times this part, is in scale nearly 8.8m in length. with 7.8 it would look nearly like this with 8.8 something like this, but this is very unstable in the actual configuration. unfortunately cutting this hose is not allowed Quote
efferman Posted September 28, 2016 Author Posted September 28, 2016 it seems i have found a solution which allows nearly the same flexibility in movement in combination with flexibility in length Quote
bonox Posted September 28, 2016 Posted September 28, 2016 well that's novel. I had to build it myself just to have a play :) Quote
efferman Posted September 30, 2016 Author Posted September 30, 2016 some progress with the preliminary hose routing Quote
Milan Posted September 30, 2016 Posted September 30, 2016 I am really sad that the real Lego hose cant fit properly...You wont experiment any more to try to make it work with the hose? Quote
efferman Posted September 30, 2016 Author Posted September 30, 2016 hm, no. The lego Hose is to much out of scale to fit it properly to a 19 wide truck. The diameter, even when it is 6mm to thick, is ok, but the length without cutting is a big problem. And you know, cutting on this hose is not permitted by the rules Quote
Tommy Styrvoky Posted September 30, 2016 Posted September 30, 2016 What about using the same technique that was used on Barman's V8 exhaust manifold, it would be adjustable to length, and still be somewhat flexible /round Quote
efferman Posted September 30, 2016 Author Posted September 30, 2016 2x2 round plates with a string inside? Quote
2LegoOrNot2Lego... Posted September 30, 2016 Posted September 30, 2016 Clever solutions! Cool... Quote
Tommy Styrvoky Posted September 30, 2016 Posted September 30, 2016 25 minutes ago, efferman said: 2x2 round plates with a string inside? or use 2x2 round tiles with a hole in the center, and put a flex axle through it. Quote
