Phoxtane Posted September 23, 2016 Posted September 23, 2016 As above: How big is the 'standard' modular city block? I was thinking of going with a 3x3 block, which would give me an equal number of corner and not-corner modular buildings. Quote
supertruper1988 Posted September 23, 2016 Posted September 23, 2016 I think its more dependent on your display area and layout size. There is no standard "block". Even in real life a New York City "block" isnt the same as a Chicago "block" or a San Francisco "block" . Hope that helps! Quote
Rick Posted September 25, 2016 Posted September 25, 2016 TLG seems to have a 4 x 4 block in mind with it's release pattern of one corner building for every 2 straight buildings. Quote
sebitsena Posted September 25, 2016 Posted September 25, 2016 CC+GG+FB GE+PS+TH PC+PR+DO BB+... but if you want an equal number of corner and not corner buildings : CC+GG GE+FB PC+PS BB+PR you can replace GG/FB/PS/PR by TH or DO ;) Quote
nikhkin Posted September 25, 2016 Posted September 25, 2016 You can go as small as 4 corner buildings together. This would be 64 studs x 64 studs, or 25cm x 25cm After that you can start adding additional buildings between the corner buildings (25cm wide each, or 12.5cm in the case of the pet shop and townhouse). For the full set of available modulars you have 4 corners and 7 standard buildings. To make it even you'd need to separate out the 2 halves of the Pet Shop set. Quote
1980-Something-Space-Guy Posted September 25, 2016 Posted September 25, 2016 I would go for whatever looks right for my layout. You're supposed to be able to do whatever you want with Lego. Quote
