  • Replies 134
12 minutes ago, Superkalle said:
Look at the image I posted above to see if it's there.
Thanks for telling me, but its not there. Those all look like newer pieces, so maybe it got added in a past update and I just can't find it!
34 minutes ago, suenkachun said:
OK, but at least the Speedometer is back in the correct place.
There are 6 new images: 2 faces (Faun and Jewel Thief of CMF15) and torsos (for Jewel Thief (and back), and Shark Suit Guy) and something I can’t identify.
30 minutes ago, joeyl19 said:
Does the update add the new tie fighter cockpit piece? If so, where can I find it?
Nope. No new cockpit. Look at Superkalle’s post.
Dang it! I really need it for my First Order TIE Fighter MOC. Oh well, thanks for finding out.
Just now, SylvainLS said:
You’re happy the ball was removed?
:wink::tongue::grin:
:tongue: Finally LDD has an update!
There's a new 2017 piece in there.. ooooh..
38 minutes ago, SylvainLS said:
Which one?
I think he's referring to the helmet with the two snake heads as horns. I think that might be for the Hands of Time wave for Ninjago.
18675 has been in since the previous update, I think.  You can't decorate it, though.
Has anyone else had trouble accessing the Lego server? It took several tries to get everything to download, and now that it has, I still can't access the server. I have everything, but am stuck running in offline mode.
Really? If so, where is it located?
5 minutes ago, CM4Sci said:
Thanks so much. Which version of LDD is this? Regular or extended. Sorry I'm not too familiar with LDD.
Just checked LDD, went on extended and regular, no piece found.
Edited by joeyl19
Extended. They tend to have more pieces than regular ones.
3 minutes ago, CM4Sci said:
Extended.
(Who the heck uses normal mode? :tongue: )
I'm on extended but it's not showing up in that window. I just updated it this morning.
Then just type in the ID. There's no possible way you don't have it if you updated today.
 I typed in 18675 but all that came up was plate w. bows 2x3 1/2.
Edited by joeyl19
Then you’re not in Extended. Check that the tool box is brown, not blue.
If you loaded a “normal LDD” file, you have to change the mode again. (The mode of the file overrides the current mode.)
Edited by SylvainLS
stupidity
3 minutes ago, SylvainLS said:
Then your not in Extended. Check that the tool box is brown, not blue.
How do I check the color of the toolbox? Also, how do I change the mode? Sorry that I have no idea what I'm doing :tongue:
By “color of the tool box,” I mean the background color on top, below the menu, where the tools icons are.
To change mode: menu View / New themes / LDD Extended.
HTH.
HTH.
Thank you so much. You solved the problem! Very grateful for people like you!
