16 hours ago, Offroadcreat1ons said:
Wow!
I can tell. You did a great job!
Many thanks!
13 minutes ago, filsawgood said:
This's great MOC! Really well-designed! True off-road! I like it!:thumbup:
Thank you! I knew that you would appreciate it! ;)
To prevent gears from slipping use this solution. You should use this part: Pin with Friction Ridges Lengthwise WITHOUT Center Slots (Item No: 4459).
But... Universal Joint 3L (Item No: 62520c01) may explode:)
To prevent gears from slipping use this solution. You should use this part: Pin with Friction Ridges Lengthwise WITHOUT Center Slots (Item No: 4459).To prevent gears from slipping use this solution. You should use this part: Pin with Friction Ridges Lengthwise WITHOUT Center Slots (Item No: 4459).
Hello, guys! Today I want to show you lifted version with third party tires. This tires can be found here: http://www.ebay.de/itm/162198869442
Also I made "Updated" instruction with some improvements in both axles. Gears are changed, now it's faster but has less torque. http://bricksafe.com/pages/NikolayFX
Technic Axles 5.5 with Stop were cutted to 5.
LEGO Chevrolet K5 Blazer LiftedLEGO Chevrolet K5 Blazer LiftedLEGO Chevrolet K5 Blazer Lifted
This is the perfect scale, looks amazing! :thumbup::thumbup:
Didn't You changed Your mind about a video (raw footage is fine too)? :wink:
Thanks, this is my lovely version. About video: it'll look like climbing turtle, well... a bit quicker:))
Those tires look perfect on your model, about the video, i don´t care too much about the time, for me its better late than never :wink:.
Totally agree! Guys, I hear you:)
  • 3 years later...
Hello Team Enthusiast!
My name is Evan, I think the Chevrolet K5 Blazer Silverado V8 1984 is one of the best-looking Lego models I have seen in a while! Most of the Lego truck models I see with the 62.4x20 Lego wheels do not look realistic. The suspension looks great! I have made some models but I cannot seem to make them strong enough at this scale. I have made a good amount of Lego creations, but about half of them I did not finish as I started with to many ideas to implement. Thank you for making instructions for the model!
Evan Mitchell
e3mitchell@protonmail.com
Edited by Evan-Eleven the Engineer
