How to connect two copies of the bridge from Spiderman Web Wariors Ultimate Bridge Battle?
Being a big Spider-Man fan, I purchased two copies of the Spider-Man Web Warriors Bridge Battle.  I'm wondering if there's any way I can connect the two bridges into one long bridge, and if so, how I should go about doing that.
I'm talking more technical here - like what connectors to use - that kind of thing.
Actor builder is right. But if you need a specific example, I believe the easiest way to connect two bridges is to stop the build after step 148 and not add the front section with the crumbling street. Instead, stick some black Technic pins on the end, connect the two bridges so that the towers are on the outer ends, fill any holes in the street with tiles, and done. If you like, you can still build the crumbling street sections and stick them on the outer ends. I hope this helps.
