namioik Posted October 25, 2016 Posted October 25, 2016 Could someone take a picture of the cafe corner linked next to the fire brigade for height comparison? Lego details said both the green grocer and the fire brigade was sitting at 35 cm and I know for sure green grocer is shorter so I haven't trusted lego's measurements since. Thank you Quote
LegoSjaak Posted October 25, 2016 Posted October 25, 2016 8 minutes ago, namioik said: Could someone take a picture of the cafe corner linked next to the fire brigade for height comparison? Lego details said both the green grocer and the fire brigade was sitting at 35 cm and I know for sure green grocer is shorter so I haven't trusted lego's measurements since. Thank you With some zooming, you might find your answer in this picture..: Quote
namioik Posted October 25, 2016 Author Posted October 25, 2016 It seems that you may have added a couple of bricks to the original build though Quote
deraven Posted October 25, 2016 Posted October 25, 2016 GIS gives you a lot to work with pretty quickly, but perhaps this straight-on shot of the modulars from the recent Designer video in particular will give you the comparison that you need: Quote
LEGO Guy Bri Posted October 26, 2016 Posted October 26, 2016 I believe LegoSjaak just widened the Fire Station with a 2nd one. It still remains as high as the single set. Either way the Fire Station is only a few plates taller, at most, a full brick Quote
LegoSjaak Posted October 26, 2016 Posted October 26, 2016 10 hours ago, namioik said: It seems that you may have added a couple of bricks to the original build though As far as i remember, i only widened it....not raised the height....Maybe these pictures show more.. On the first picture, both buildings are in the original sizes! (I found the first picture later...) Quote
