Hi Everyone.
Today I want to show You my latest and the most expanded MOC, a farm tractor with equipmnet.
Specifications of tractor:
Length: 38 cm
Width: 17 cm
Height: 21 cm
Weight: 1350g
Motors:
-XL for drive
-M for steering
-M for handling rear linkage
This is a type of articulated tractor. When I building it I take pattern on a Case tractors.
Under the bonnet are a BaterryBox and XL motor for propulsion the tractor. Ratio is 1:4.2.
For steering serve a 2 big turnable driven by M motor with 1.93:1 ratio.
Rear linkage is opertted by 2 small linear acctuators which are driven by M motor with 1;3 ratio. His capacity is satisfactory.
On the rear is also a PTO.
Model has a driver cabin equipment and openable door. The IR receivers are placed on two sides of tractor, behind the front wheels.
Generally I'm pleased from workin and look of my tractor.
Dump trailer
Dimentions of bath:
Lenght: 30cm
Width: 15cm
Height: 6cm
For the dumping serve a 2 pneumatic actuators and mechanic pump. Capacity of trailer is little.
Tedder Grass
Tedder grass a serve for shake the mown grass that be faster dry.
My tedder has a 2 arms with 2 carousels on arm. For lifting/ lowering arms serve 2 big linear actuators. Working range is about 37cm.
Tedder is propeled from tractor. Ratio 4.5:1.
Grass Mower
My grass mower is one piece with 2 blades. Is propeled from tractor PTO. Ratio 8.3:1.
Mower working ably. Working range is 20cm.
Farm Plow
Plow has a 5 chunks. Lenght is 28 cm.
It's light and strong.
I'm waiting for your comments :)
Brickshlef gallery: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=566790
Flick gallery: https://www.flickr.com/photos/124730997@N05/albums/72157676085839866
Edited by damjan97PL
Looks good,  a solid little unit!  I really like all the little attachments and how the all seem to function smoothly :)  well done!
Very very nice.
I am a fan of 'Theme' series of models and this is an excellent example.
Well thought out.
Very nice.  The attachments are a excellent touch.  The body would almost work if you recreated it into a Quadtrac.
Excellent build, damjan97PL!
This tractor is amazingly realistic, both in appearance and in functionality!  I am amazed that such a clean appearance could be achieved with technic parts while also making each attachment functional!
It seems like farmers here in America would NEVER consider attaching a green or yellow implement to a red tractor, but farmers like that are just too stuck on a single brand for equipment! :tongue:  (though it does make purchasing parts simpler, as there may be only one company involved)
I think it makes the MOC even more appealing with color variations between tractor and implements.
Now make it RC, and you are all set for miniature farming! :wink:
Me and Grum like this a lot. I like the tractor and the grass mower and Grum likes the tractor and the ploughs.
From Jake
It looks great and has a lot of playability. Maybe it's just me to feel its wheels are a bit too smaller.
2 hours ago, Kmuffin said:
Nice moc! Nice attachments but what is eupment?
It was supposed to be EQUiPMENT
This is a really nice MOC. Especially the attachments all look really good. The tractor itself looks a bit out of proportion to me, maybe it's mainly the wheels that seems too small. The Xerion tires might help. Also the hitch in the back doesn't look too sturdy but other than that it the functions look great :thumbup:
Nice attachments. I am literally in the middle of doing a very similar project! I'm cheating a bit though and using the 8063 tractor. Luckily I have a plan for a different attachment, so no copy catting.
