Didumos69 Posted May 17, 2017 Author Posted May 17, 2017 (edited) I asked @Milan to merge the two topics, which he did. It was a bad idea to have separate WIP and MOC topics. Edited May 17, 2017 by Didumos69 Quote
zux Posted May 17, 2017 Posted May 17, 2017 Can't wait to have time to build it! Looking forward the learning experience this model delivers. Quote
Victor Imaginator Posted May 18, 2017 Posted May 18, 2017 @Didumos69 Thanks for all of your hard work) I will definitely build this car as soon as i can. Quote
Didumos69 Posted May 18, 2017 Author Posted May 18, 2017 18 hours ago, BusterHaus said: A couple of things that I learned during this project: @SylvainLS maintains a more up-to-date ldraw.xml file that does a much better job of converting models from LDD to LDR than the one stock one. Submodels should be built aligned with the main grid for a consistent look and rotated on the main model. LDCad can be used in a way that doesn't take that into consideration, but aligning submodels is the more logical way. I'm now a big fan of callouts, even for single parts, as they show you exactly where the part should go on a complicated model. They can often be used instead of buffer exchanges. To add to that: What I have learned from this, is that it is probably better to start with the instructions only after the model is finished, especially when the designer is not making the instructions himself. Or, to put it differently, it is probably better to stop adding features to the model once you decided to work out the instructions. 17 hours ago, Blakbird said: I've built a LOT of Technic supercars and I can easily say this is one of my favorite. I think I can safely say it has the smoothest gear system I've ever seen. The durability is also really impressive. There won't be any parts falling off when you handle this model. Hearing this form someone who has built so many Technic supercars, means a lot to me. I'm very happy you wanted to build it and got involved! 15 hours ago, M5Technic said: This is very exciting news!! 11 hours ago, zux said: Can't wait to have time to build it! Looking forward the learning experience this model delivers. 4 hours ago, Victor Imaginator said: @Didumos69 Thanks for all of your hard work) I will definitely build this car as soon as i can. Good to know! I hope you guys will be able to build it soon. I just discovered that the 42056 Porsche set covers 53.7% of the parts of this build, which is more than I expected. @zux, I tried to take your experience with torsion bars into account as good as possible. I only used torsion bars in the back and made sure they are not stressed much under the vehicle own weight. Thanks again for sharing your experience. Quote
legolijntje Posted May 18, 2017 Posted May 18, 2017 1 hour ago, Didumos69 said: To add to that: What I have learned from this, is that it is probably better to start with the instructions only after the model is finished, especially when the designer is not making the instructions himself. Or, to put it differently, it is probably better to stop adding features to the model once you decided to work out the instructions. Haha, I agree, that's very true! Quote
davebarrett Posted May 18, 2017 Posted May 18, 2017 Bricks and Pieces order is in. @Didumos69 Why did you go with black 3L pins instead of blue? This seems to be a frequent occurrence with MOCs, and I'm a bit worried that with the more common blue pins it'll look quite different. Quote
BusterHaus Posted May 18, 2017 Posted May 18, 2017 @davebarrett Here is a copy of the car with only blue pins. Just save the code as an LDR file. Spoiler 0 Rugged supercar 0 Author: LEGO Digital Designer 4.3 1 72 -39.985446929931641 -122.38367462158203 570.0885009765625 -1 0 0 0 1 0 0 0 -1 18947.dat 1 0 -261.40231323242187 -101.83338928222656 -49.974655151367188 0 0 1 0 0.99999994039535522 0 -1 0 0 58088.dat 1 0 203.15499877929687 -102.1356201171875 709.98663330078125 0 0 -1 0 0.99999994039535522 0 1 0 0 2902.dat 1 0 -239.12110900878906 -102.13475036621094 710.01226806640625 0 0 1 0 0.99999994039535522 0 -1 0 0 2902.dat 1 0 -275.1209716796875 -102.13477325439453 710.01226806640625 0 0 1 0 0.99999994039535522 0 -1 0 0 2902.dat 1 15 8.0147037506103516 -124.61509704589844 424.13824462890625 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 85543.dat 1 71 119.98865509033203 -209.53195190429687 195.72064208984375 1 0 0 0 0.96000725030899048 -0.27997514605522156 0 0.27997514605522156 0.96000725030899048 32123a.dat 1 0 203.41897583007812 -101.83228302001953 -49.972461700439453 0 0 -1 0 0.99999994039535522 0 1 0 0 2902.dat 1 72 60.007987976074219 -124.32756042480469 50.025535583496094 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 72 75.00848388671875 -124.32661437988281 50.026142120361328 0 1 0 1 0 0 0 0 -1 6632.dat 1 0 99.80810546875 -124.12528991699219 10.040653228759766 1 0 0 0 -1 0 0 0 -1 3705.dat 1 72 85.008529663085937 -124.32666015625 50.026142120361328 0 1 0 1 0 0 0 0 -1 6632.dat 1 71 0.0079989433288574219 -124.32799530029297 -49.974639892578125 1 1.4297448615252506E-005 0 1.4297448615252506E-005 -1 0 0 0 -1 64178.dat 1 72 -59.992122650146484 -124.32842254638672 50.025344848632813 -1 0 0 0 0 1 0 1 0 11214.dat 1 72 -74.991706848144531 -124.32948303222656 50.024806976318359 0 1 0 1 0 0 0 0 -1 6632.dat 1 72 -84.991744995117187 -124.32944488525391 50.024806976318359 0 1 0 1 0 0 0 0 -1 6632.dat 1 0 -99.991928100585938 -124.33050537109375 10.025178909301758 -1 0 0 0 -1 0 0 0 1 3705.dat 1 0 -119.79191589355469 -124.13023376464844 10.040070533752441 -1.4701277905260213E-005 1 0 1 1.4801516954321414E-005 0 0 0 -1 15100.dat 1 72 99.8079833984375 -104.32577514648437 -9.9591140747070312 -1.4532691238855477E-005 1.0000001192092896 0 1.0000001192092896 1.4801516954321414E-005 0 0 0 -1 10197.dat 1 0 -0.19228886067867279 -104.12735748291016 10.040414810180664 -1 0 0 0 -1 0 0 0 1 64781.dat 1 72 -99.992324829101563 -104.32868957519531 -9.9596700668334961 0 0 -1 1 1.471700488764327E-005 0 1.4697382539452519E-005 -1 0 10197.dat 1 0 99.808052062988281 -114.32577514648437 -9.9592437744140625 -1.4701277905260213E-005 1 0 1 1.4801516954321414E-005 0 0 0 -1 6628.dat 1 0 100.15069580078125 -124.96665954589844 -9.9726543426513672 0 -0.22496554255485535 0.97436678409576416 -1.0462456884852145E-005 0.97436678409576416 0.22496554255485535 -1.0000001192092896 -1.0442156053613871E-005 0 32005.dat 1 0 197.44683837890625 -91.861137390136719 -9.97259521484375 0 1 0 1 0 0 0 0 -1 6628.dat 1 4 217.44334411621094 -121.82996368408203 -9.9738988876342773 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 41678.dat 1 0 217.44325256347656 -101.8299560546875 -9.9737405776977539 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 3705.dat 1 0 217.44326782226562 -81.8299560546875 -9.9737415313720703 0 0 -1 0 0.99999994039535522 0 1 0 0 60483.dat 1 0 217.44308471679687 -126.8299560546875 -49.973735809326172 -1 0 0 0 1 0 0 0 -1 11478.dat 1 0 217.44326782226562 -116.82997131347656 -49.973735809326172 -1 0 0 0 1 0 0 0 -1 11478.dat 1 4 217.44334411621094 -81.8299560546875 -9.9738988876342773 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 41678.dat 1 0 217.44346618652344 -131.83001708984375 -49.9735107421875 0 -2.232996848761104E-005 1 1 0 0 0 1 2.234257772215642E-005 6628.dat 1 71 120.00910186767578 -164.32614135742187 -49.972976684570313 0.22487398982048035 0 -0.97438788414001465 -0.97438788414001465 0 -0.22487393021583557 0 1 0 32316.dat 1 72 158.98506164550781 -155.33106994628906 -24.973588943481445 -0.22487609088420868 0 -0.97438746690750122 0.97438746690750122 0 -0.22487612068653107 0 -1.0000001192092896 0 6632.dat 1 0 120.00952911376953 -164.32612609863281 -59.973590850830078 0 -0.2248748242855072 0.9743877649307251 0 0.97438782453536987 0.2248748242855072 -1.0000001192092896 0 0 3707.dat 1 72 158.98466491699219 -155.33134460449219 -74.973434448242188 0.22487416863441467 0 -0.97438782453536987 -0.97438782453536987 0 -0.22487413883209229 0 1 0 6632.dat 1 14 120.00955200195312 -164.32609558105469 -129.97358703613281 0.974387526512146 -0.22487540543079376 0 0.22487540543079376 0.974387526512146 0 0 0 1 6590.dat 1 71 158.98478698730469 -155.33139038085937 -49.97381591796875 0 -0.22487452626228333 0.97438770532608032 0 0.97438770532608032 0.22487452626228333 -1 0 0 4519.dat 1 72 120.00936126708984 -164.32630920410156 -49.973590850830078 0 -0.22487588226795197 -0.974387526512146 0 0.974387526512146 -0.22487588226795197 1.0000001192092896 0 0 57515.dat 1 72 120.00528717041016 -144.32804870605469 -149.97866821289062 0 1 0 0 0 -1 -1 0 0 32523.dat 1 1 100.00529479980469 -124.32805633544922 -149.97866821289062 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 120.00830078125 -139.32644653320312 -129.97554016113281 0 0 -1 0 0.99999994039535522 0 1 0 0 41677.dat 1 4 120.00830078125 -134.32647705078125 -129.97552490234375 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32062.dat 1 72 120.00830078125 -129.326416015625 -129.97554016113281 0 0 -1 0 0.99999994039535522 0 1 0 0 41677.dat 1 4 100.00822448730469 -134.32644653320312 -129.97554016113281 0 -1 0 1 0 0 0 0 0.99999994039535522 32062.dat 1 72 100.00826263427734 -134.32643127441406 -129.97561645507812 0 -1 0 1 0 0 0 0 0.99999994039535522 41678.dat 1 72 120.00826263427734 -134.326416015625 -129.97544860839844 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 41678.dat 1 72 100.00830078125 -124.32643127441406 -109.97564697265625 -1 0 0 0 0 1 0 1 0 11214.dat 1 72 80.005294799804687 -124.32805633544922 -109.97869873046875 0 -1 0 -1 0 0 0 0 -1 32140.dat 1 71 100.00852203369141 -124.32767486572266 -109.96182250976562 1 0 0 0 1.7599262719159015E-005 1 0 -1 1.7599262719159015E-005 14720.dat 1 72 60.004936218261719 -144.32711791992187 -149.97808837890625 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 0 100.00529479980469 -144.32804870605469 -149.97866821289062 0.99999994039535522 0 0 0 0 1 0 -1 0 32054.dat 1 0 40.004901885986328 -144.32711791992187 -69.978424072265625 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 72 100.00868225097656 -144.32701110839844 30.026880264282227 -1 0 0 0 -0.60000151395797729 0.799998939037323 0 0.799998939037323 0.60000169277191162 11214.dat 1 0 60.008716583251953 -144.32620239257812 30.026086807250977 -1 0 0 0 -0.60000133514404297 0.79999905824661255 0 0.79999905824661255 0.60000169277191162 32054.dat 1 1 119.99024963378906 -63.733230590820313 110.12055969238281 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 130.00616455078125 -96.325645446777344 66.025527954101563 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 120.00616455078125 -64.324798583984375 150.02554321289062 0 1 0 -1 0 1.7146232494269498E-005 1.7146232494269498E-005 0 0.99999994039535522 32316.dat 1 72 120.00613403320312 -64.325874328613281 190.02505493164062 0.99999994039535522 0 0 0 0 -1 0 1 0 11214.dat 1 72 140.00605773925781 -64.324356079101563 190.02511596679687 0 -1 0 -1 0 0 0 0 -1 6629.dat 1 1 130.00613403320312 -112.32554626464844 54.025089263916016 1 0 0 0 -0.79999864101409912 0.60000181198120117 0 -0.60000181198120117 -0.79999864101409912 43093.dat 1 72 120.00864410400391 -112.32564544677734 54.025650024414063 0 1.0000001192092896 0 -0.59998679161071777 0 0.80000996589660645 0.80000996589660645 0 0.59998685121536255 32316.dat 1 72 160.02488708496094 -64.32733154296875 130.02507019042969 -1 0 0 0 -1 0 0 0 1 6536.dat 1 1 150.02487182617188 -64.329078674316406 130.02507019042969 0.99999994039535522 0 0 0 0 -1 0 1 0 43093.dat 1 72 160.02140808105469 -84.32733154296875 150.02394104003906 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 72 160.02389526367187 -84.329368591308594 170.02128601074219 0 0 -1 -0.00017512137128505856 0.99999994039535522 0 1 0.00017512137128505856 0 6536.dat 1 72 140.00965881347656 -84.324752807617187 150.02645874023437 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32524.dat 1 0 180.0096435546875 -84.324752807617187 130.02645874023437 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 72 180.00616455078125 -64.324745178222656 130.02542114257812 1 0.00017512141494080424 0 0.00017512141494080424 -1 0 0 0 -1 6536.dat 1 1 190.00617980957031 -64.326507568359375 130.02545166015625 -1 0 0 0 0 -1 0 -1 0 43093.dat 1 4 239.99996948242187 -84.414192199707031 330.06826782226562 1 0 0 0 -1 0 0 0 -1 32525.dat 1 0 239.99996948242187 -94.414176940917969 210.06829833984375 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 4 239.9864501953125 -104.41536712646484 250.06913757324219 1 0 0 0 -1 0 0 0 -1 32525.dat 1 4 159.99996948242187 -84.414176940917969 210.06825256347656 0 0 1 0 0.99999994039535522 0 -1 0 0 32526.dat 1 0 180.00595092773437 -74.326072692871094 210.02545166015625 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 1 200.0010986328125 -64.4141845703125 310.06881713867187 -1 0 0 0 -1 0 0 0 1 6558.dat 1 1 239.99996948242187 -84.414199829101562 330.06829833984375 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 0 210.00613403320312 -64.326507568359375 290.02548217773437 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 200.00093078613281 -64.415451049804688 190.06898498535156 -1 0 0 0 -1 0 0 0 1 6558.dat 1 28 199.99168395996094 -64.326690673828125 390.04449462890625 -1 0 0 0 -1 -5.0210957851959392E-005 0 -5.0210957851959392E-005 1 6587.dat 1 4 219.9923095703125 -64.326751708984375 390.04605102539062 0 1 0 -1 0 0 0 0 0.99999994039535522 6629.dat 1 4 229.99224853515625 -112.32685852050781 526.04443359375 -1 0 0 0 0.8000030517578125 -0.59999579191207886 0 -0.59999579191207886 -0.80000311136245728 32062.dat 1 4 239.99240112304688 -112.32524871826172 526.04388427734375 -1 0 0 0 -0.7999994158744812 0.60000085830688477 0 0.60000085830688477 0.7999996542930603 6536.dat 1 0 199.99267578125 -64.327308654785156 430.04513549804687 0 1 -1.1828546121250838E-005 -1 0 2.1485571778612211E-005 2.1485571778612211E-005 1.1828546121250838E-005 0.99999994039535522 41239.dat 1 71 179.99169921875 -104.32627105712891 410.04415893554687 0 -0.99999994039535522 0 0 0 -0.99999994039535522 0.99999994039535522 0 0 14720.dat 1 72 159.99226379394531 -64.326187133789063 470.0455322265625 0 -1 0 -1 0 0 0 0 -1 32525.dat 1 28 200.00617980957031 -64.326156616210938 270.02545166015625 -1 0 0 0 -1 -2.077818317047786E-005 0 -2.077818317047786E-005 1 6587.dat 1 4 220.00103759765625 -144.41387939453125 390.0675048828125 0 -1 0 -0.60000109672546387 0 0.79999923706054688 -0.79999923706054688 0 -0.60000109672546387 6629.dat 1 72 199.99168395996094 -144.32632446289062 390.04339599609375 1 0 0 0 -0.60000085830688477 0.79999935626983643 0 -0.79999935626983643 -0.60000085830688477 11214.dat 1 0 200.00613403320312 -64.326484680175781 210.02545166015625 0 -1 0 -1 0 0 0 0 -1 40490.dat 1 71 139.9921875 -64.326789855957031 270.04507446289062 1 1.4297442248789594E-005 0 1.4297442248789594E-005 -1 0 0 0 -1 64178.dat 1 72 160.00515747070312 -84.325309753417969 230.02650451660156 0 0 -1 4.8228146624751389E-005 0.99999994039535522 0 1 -4.8228146624751389E-005 0 6536.dat 1 71 160.00515747070312 -84.325790405273438 250.02653503417969 0 0 1 0 1 0 -1 0 0 4519.dat 1 72 160.00611877441406 -84.326438903808594 260.02499389648437 0 -4.8880607209866866E-005 1 -4.9004240281647071E-005 -1 -4.8880603571888059E-005 1 -4.9004236643668264E-005 0 6536.dat 1 72 160.00614929199219 -84.325935363769531 260.02505493164062 0 -1 0 -2.0990393750253133E-005 0 -1 1 0 -2.0972491256543435E-005 41678.dat 1 4 240.00151062011719 -112.41364288330078 134.07298278808594 1 0 0 0 -0.7999996542930603 0.60000044107437134 0 -0.60000044107437134 -0.7999996542930603 6536.dat 1 0 220.00093078613281 -112.41537475585937 134.06903076171875 0.99999994039535522 0 0 0 -0.79999953508377075 0.60000061988830566 0 -0.60000061988830566 -0.79999953508377075 18651.dat 1 28 200.00614929199219 -64.3253173828125 230.02552795410156 -1 0 0 0 -1 4.8685073124943301E-005 0 4.8685073124943301E-005 1 6587.dat 1 4 220.00091552734375 -64.415313720703125 230.06900024414062 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 32348.dat 1 0 209.99272155761719 -64.327041625976563 430.04513549804687 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 179.99226379394531 -64.326042175292969 410.0450439453125 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 200.00018310546875 -144.41317749023437 470.06893920898437 -1 0 0 0 0 1 0 1 0 11214.dat 1 0 180.00019836425781 -144.41317749023437 470.0689697265625 0.99999994039535522 0 0 0 0 1 0 -1 0 6536.dat 1 1 80.00616455078125 -64.326789855957031 370.02468872070312 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 80.006088256835938 -64.326789855957031 370.02468872070312 0 1 0 1 0 0 0 0 -1 18654.dat 1 72 60.005996704101563 -64.326789855957031 310.024658203125 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 0 69.990478515625 -64.327606201171875 390.03924560546875 -1 0 0 0 -1 0 0 0 1 2780.dat 1 72 79.990432739257813 -64.327606201171875 530.0391845703125 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 1 59.991012573242188 -64.32708740234375 670.0399169921875 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 39.991016387939453 -64.32708740234375 710.03997802734375 0 -1 0 -1 0 0 0 0 -1 40490.dat 1 1 59.991012573242188 -64.32708740234375 730.03997802734375 -1 0 0 0 1 0 0 0 -1 6558.dat 1 71 60.016857147216797 -84.623779296875 709.988525390625 0 0 -1 0 0.99999994039535522 0 1 0 0 4519.dat 1 72 60.016845703125 -84.623779296875 689.98846435546875 0 0 -1 0 0.99999994039535522 0 1 0 0 6536.dat 1 72 90.016891479492188 -84.622535705566406 704.98858642578125 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 32449.dat 1 72 120.01554870605469 -84.626029968261719 720 0 0 -1 0 0.99999994039535522 0 1 0 0 55013.dat 1 72 60.016845703125 -84.623779296875 729.9884033203125 0 0 -1 0 0.99999994039535522 0 1 0 0 6536.dat 1 72 90.017082214355469 -84.622703552246094 714.9884033203125 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 32449.dat 1 72 120.01726531982422 -84.622718811035156 689.98846435546875 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 72 120.01726531982422 -84.622726440429688 729.9884033203125 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 19 120.01726531982422 -104.62271881103516 709.98828125 0 0.13910017907619476 0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 -1.0000001192092896 0 0 32556.dat 1 71 158.9927978515625 -95.62774658203125 709.98846435546875 0.224874347448349 0 0.97438788414001465 -0.97438788414001465 0 0.22487427294254303 0 -1.0000001192092896 0 32316.dat 1 19 158.991455078125 -95.630172729492187 709.98699951171875 0 -0.13910017907619476 -0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 1.0000001192092896 0 0 32556.dat 1 0 158.991455078125 -95.629989624023437 689.98724365234375 -0.70819282531738281 0.70601910352706909 0 0.70601910352706909 0.70819300413131714 0 0 0 -1 4254.dat 1 4 81.325668334960938 -173.53228759765625 689.98724365234375 -0.70819294452667236 0.70601898431777954 0 0.70601898431777954 0.70819300413131714 0 0 0 -1 4255.dat 1 19 81.328407287597656 -173.53218078613281 709.9871826171875 0 -0.13910017907619476 -0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 1.0000001192092896 0 0 32556.dat 1 71 129.76092529296875 -162.3765869140625 704.98687744140625 0.22495129704475403 0 0.97437012195587158 -0.97437012195587158 0 0.22495120763778687 0 -1.0000001192092896 0 32063.dat 1 14 120.01739501953125 -164.62776184082031 629.9869384765625 0 -0.97438693046569824 -0.22487843036651611 0 -0.22487834095954895 0.97438693046569824 -1.0000001192092896 0 0 6553.dat 1 71 120.01739501953125 -164.6278076171875 709.98699951171875 0 -0.22487905621528625 -0.97438675165176392 0 0.97438681125640869 -0.22487905621528625 1.0000001192092896 0 0 60485.dat 1 72 158.99211120605469 -155.62980651855469 684.98699951171875 0.2248741090297699 0 -0.97438794374465942 -0.97438794374465942 0 -0.22487397491931915 0 1.0000001192092896 0 6632.dat 1 72 158.99214172363281 -155.6298828125 694.98681640625 0.2248741090297699 0 -0.97438794374465942 -0.97438794374465942 0 -0.22487397491931915 0 1.0000001192092896 0 6632.dat 1 72 158.99208068847656 -155.62971496582031 724.9869384765625 0.2248741090297699 0 -0.97438794374465942 -0.97438794374465942 0 -0.22487397491931915 0 1.0000001192092896 0 6632.dat 1 72 158.99212646484375 -155.629638671875 734.98699951171875 0.2248741090297699 0 -0.97438794374465942 -0.97438794374465942 0 -0.22487397491931915 0 1.0000001192092896 0 6632.dat 1 71 158.99221801757812 -155.62971496582031 709.98699951171875 0 -0.22487415373325348 0.97438782453536987 0 0.97438782453536987 0.22487415373325348 -1 0 0 4519.dat 1 71 129.7611083984375 -162.37806701660156 714.98687744140625 0.22495129704475403 0 0.97437012195587158 -0.97437012195587158 0 0.22495120763778687 0 -1.0000001192092896 0 32063.dat 1 72 0.01678466796875 -164.62628173828125 669.999755859375 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32278.dat 1 0 -99.985298156738281 -164.6241455078125 660.0010986328125 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 71 -99.984771728515625 -124.6241455078125 650.00091552734375 -1 1.2637154213734902E-005 -1.2513518413470592E-005 1.2513519322965294E-005 0 -1 -1.2637152394745499E-005 -1 0 14720.dat 1 1 -79.984458923339844 -84.626289367675781 629.99981689453125 0 0 -1 0 0.99999994039535522 0 1 0 0 6558.dat 1 72 -79.961013793945313 -104.90336608886719 510.01187133789062 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 60483.dat 1 71 -79.980865478515625 -104.62330627441406 530.0015869140625 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 -79.975700378417969 -104.90301513671875 610.02569580078125 0 0 1 0 1 0 -1 0 0 18651.dat 1 71 -79.975685119628906 -104.90300750732422 570.0255126953125 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 32034.dat 1 72 -79.980850219726563 -104.62330627441406 530.00164794921875 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 72 -79.984458923339844 -104.62629699707031 609.99981689453125 -1 0 0 0 0 1 0 1 0 60483.dat 1 0 -99.961082458496094 -104.90299224853516 500.04000854492187 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 2780.dat 1 71 -99.961082458496094 -104.90298461914062 550.02557373046875 0 1 0 -1 0 0 0 0 0.99999994039535522 64179.dat 1 0 -99.961090087890625 -124.90298461914062 500.03994750976563 0 0 1 0 1 0 -1 0 0 2780.dat 1 72 0.017201900482177734 -124.62522888183594 510.01467895507812 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 0 100.01718139648437 -124.62520599365234 500.01458740234375 0 0 1 0 1 0 -1 0 0 2780.dat 1 71 99.990478515625 -104.32759857177734 550.039306640625 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 64179.dat 1 0 89.990364074707031 -144.32762145996094 570.0391845703125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 79.990432739257813 -144.32762145996094 530.0391845703125 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 0 69.990447998046875 -144.32762145996094 390.03924560546875 1 0 0 0 1 0 0 0 1 2780.dat 1 72 40.007534027099609 -144.32746887207031 370.02487182617187 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 72 60.007537841796875 -144.32746887207031 370.02487182617187 0 1 0 -1 0 0 0 0 0.99999994039535522 32140.dat 1 1 60.006923675537109 -104.32756042480469 40.025382995605469 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 72 60.006923675537109 -104.32756042480469 50.025386810302734 0 0 -1 0 -1 0 -1 0 0 6536.dat 1 1 40.007530212402344 -144.32757568359375 150.025146484375 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 40.007640838623047 -144.32757568359375 230.02490234375 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 72 20.00749397277832 -144.32785034179687 130.02488708496094 0 -1 0 1 0 0 0 0 0.99999994039535522 32140.dat 1 71 0.0076472759246826172 -144.32757568359375 130.02525329589844 1 0 0 0 1 0 0 0 1 32073.dat 1 72 -19.99189567565918 -144.32806396484375 130.0252685546875 0 -1 0 1 0 0 0 0 0.99999994039535522 32140.dat 1 71 0.0076092779636383057 -144.32757568359375 130.0252685546875 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6590.dat 1 72 -39.991901397705078 -144.32835388183594 230.02510070800781 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 71 0.0081002712249755859 -144.32835388183594 330.0247802734375 0 0 -0.99999994039535522 -0.99999994039535522 0 0 0 0.99999994039535522 0 48989.dat 1 72 20.007572174072266 -144.32728576660156 290.02569580078125 0 1 0 -1 0 0 0 0 0.99999994039535522 32140.dat 1 72 -19.991817474365234 -144.32835388183594 290.02471923828125 0 1 0 -1 0 0 0 0 0.99999994039535522 32140.dat 1 1 30.007684707641602 -144.32757568359375 290.02493286132812 -1 0 0 0 0 -1 0 -1 0 43093.dat 1 1 -29.991817474365234 -144.32835388183594 290.02511596679688 0.99999994039535522 0 0 0 0 -1 0 1 0 43093.dat 1 0 30.007684707641602 -144.32728576660156 330.02490234375 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 72 -19.985065460205078 -164.62214660644531 350.00094604492187 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 71 20.007648468017578 -164.3272705078125 350.02557373046875 0.99999994039535522 0 0 0 0 1 0 -1 0 32054.dat 1 72 -39.985031127929688 -164.622802734375 390.00094604492187 0 -1 -1.6248903193627484E-005 -1 0 1.6372536265407689E-005 -1.6372536265407689E-005 1.6248901374638081E-005 -1 32316.dat 1 1 -39.985023498535156 -164.62344360351562 430.0009765625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 -39.991863250732422 -144.32856750488281 370.02487182617187 -1 0 0 0 0 1 0 1 0 11214.dat 1 72 -59.985107421875 -144.6240234375 370.0008544921875 0 1 0 -1 0 0 0 0 0.99999994039535522 32140.dat 1 0 -69.985076904296875 -144.6240234375 390.00091552734375 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 -79.985008239746094 -144.6240234375 530.0008544921875 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 1 -79.985115051269531 -144.6240234375 650.0009765625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 71 -59.982254028320313 -104.62330627441406 650.00164794921875 0 1.0000001192092896 -1.4382368135557044E-005 0 -1.4260476746130735E-005 -1.0000001192092896 -1.0000001192092896 0 0 14720.dat 1 1 -59.982933044433594 -144.62887573242187 630.00128173828125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 138.425537109375 -124.62880706787109 878.80230712890625 0 0.0020423589739948511 -0.99999791383743286 -1 0 0 0 0.99999791383743286 0.0020423256792128086 6558.dat 1 4 -19.977119445800781 -124.62963104248047 829.99639892578125 -0.6000024676322937 0 -0.79999810457229614 0 -1 0 -0.79999810457229614 0 0.60000228881835938 6629.dat 1 0 -19.976486206054688 -124.629638671875 829.99676513671875 0 0.60000032186508179 -0.79999977350234985 -1 0 0 0 0.79999977350234985 0.60000032186508179 18651.dat 1 1 -157.57456970214844 -114.62893676757813 873.20196533203125 0 -0.27999788522720337 -0.96000063419342041 -1 0 0 0 0.96000063419342041 -0.27999791502952576 43093.dat 1 0 -176.77487182617187 -104.62945556640625 867.6029052734375 0.27992928028106689 0 0.96002060174942017 0 1 0 -0.96002060174942017 0 0.27992928028106689 32524.dat 1 71 0.017333030700683594 -104.6295166015625 850.0013427734375 -1 0 0 0 1 0 0 0 -1 44294.dat 1 72 20.017667770385742 -104.62949371337891 850.00140380859375 -1 0 0 0 1 0 0 0 -1 32291.dat 1 72 65.0177001953125 -104.62945556640625 850.00115966796875 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 71 0.017768144607543945 -104.62947845458984 870.001220703125 -1 0 0 0 1 0 0 0 -1 60485.dat 1 72 -39.982311248779297 -104.62947082519531 870.0010986328125 0 -1 0 -1 0 0 0 0 -1 32140.dat 1 72 -64.982635498046875 -104.62947845458984 850.00140380859375 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 72 -19.982412338256836 -104.62949371337891 850.0013427734375 -1 0 0 0 1 0 0 0 -1 32291.dat 1 72 -54.982437133789063 -104.62947845458984 850.00140380859375 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 72 40.017665863037109 -104.62944793701172 870.0010986328125 0 -1 0 -1 0 0 0 0 -1 32140.dat 1 0 0.03018113411962986 -104.62947082519531 850.0052490234375 0.99999994039535522 -0.00017592438962310553 0 0 0 1 -0.00017592438962310553 -1 0 63869.dat 1 0 80.022369384765625 -104.62936401367187 870.004638671875 -0.99999994039535522 0.00017582708096597344 0.00017595071403775364 0.00017595071403775364 0 0.99999994039535522 0.00017582708096597344 0.99999994039535522 0 63869.dat 1 0 -79.977294921875 -104.62932586669922 870.0047607421875 -0.99999994039535522 0.00017580323037691414 0.00017592686344869435 0.00017592686344869435 0 0.99999994039535522 0.00017580323037691414 0.99999994039535522 0 63869.dat 1 72 55.01763916015625 -104.62945556640625 850.00164794921875 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 72 25.021944046020508 -144.62887573242187 850.0352783203125 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 71 0.022268295288085938 -144.62937927246094 850.03521728515625 1 0 0 0 1 0 0 0 1 32073.dat 1 72 -24.978034973144531 -144.62889099121094 850.0352783203125 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 71 0.022029876708984375 -144.62889099121094 870.03533935546875 1 0 0 0 1 0 0 0 1 60485.dat 1 0 0.026134645566344261 -144.629638671875 849.9930419921875 0.99999994039535522 -0.00017474175547249615 0 0 0 1 -0.00017474175547249615 -1 0 63869.dat 1 0 0.022107362747192383 -164.6239013671875 870.03533935546875 1 0 0 0 1 0 0 0 1 92907.dat 1 0 -79.9775390625 -144.62892150878906 870.0047607421875 -0.99999994039535522 0.00017475371714681387 0.00017487735021859407 0.00017487735021859407 0 0.99999994039535522 0.00017475371714681387 0.99999994039535522 0 63869.dat 1 0 80.021797180175781 -144.62893676757812 870.004638671875 -0.99999994039535522 0.0001747442438500002 0.00017486789147369564 0.00017486789147369564 0 0.99999994039535522 0.0001747442438500002 0.99999994039535522 0 63869.dat 1 72 -39.984054565429688 -144.62603759765625 750.00140380859375 0 1 -1.154931123892311E-005 -1 0 2.4268561901408248E-005 2.4268561901408248E-005 1.154931123892311E-005 0.99999994039535522 41239.dat 1 72 40.023387908935547 -144.6317138671875 750.0347900390625 0 1 -1.1591046131798066E-005 -1 0 2.4226845198427327E-005 2.4226845198427327E-005 1.1591046131798066E-005 0.99999994039535522 41239.dat 1 71 0.016316771507263184 -124.62662506103516 809.998779296875 0 0 1 0 1 0 -1 0 0 32034.dat 1 0 50.017536163330078 -124.63121032714844 809.999755859375 1 0 0 0 1 0 0 0 1 3705.dat 1 72 100.01687622070312 -124.62673187255859 789.99957275390625 -1 0 0 0 0 1 0 1 0 11214.dat 1 0 80.017539978027344 -124.63121032714844 789.99969482421875 0 -1 0 1 0 0 0 0 0.99999994039535522 33299a.dat 1 0 -49.982318878173828 -124.62947082519531 810.0010986328125 1 0 0 0 1 0 0 0 1 3705.dat 1 72 -99.983085632324219 -124.62908172607422 790.000732421875 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 0 -79.982254028320313 -124.62917327880859 790.0006103515625 0 1 0 -1 0 0 0 0 0.99999994039535522 33299a.dat 1 72 -79.985466003417969 -144.62763977050781 830.0179443359375 0 -1 0 0 0 -1 1 0 0 60483.dat 1 0 -59.984786987304687 -144.62420654296875 830.0018310546875 -1 0 0 0 -1 0 0 0 1 18651.dat 1 72 -59.982532501220703 -144.62905883789062 830.0010986328125 0 1 0 0 0 1 1 0 0 32140.dat 1 72 60.01739501953125 -144.63108825683594 830.00042724609375 0 1 0 0 0 1 1 0 0 32140.dat 1 0 60.017402648925781 -144.63111877441406 830.00042724609375 1 0 0 0 -1 0 0 0 -1 18651.dat 1 72 80.017402648925781 -144.63111877441406 830.00042724609375 0 -1 0 0 0 -1 1 0 0 60483.dat 1 71 -119.98338317871094 -144.62899780273437 810.0015869140625 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 4519.dat 1 71 -119.9833984375 -159.62899780273438 810.0015869140625 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 32123a.dat 1 71 -119.9833984375 -129.62899780273438 810.0015869140625 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 32123a.dat 1 72 -119.98342132568359 -134.62899780273437 810.00091552734375 0 -1 0 1 0 0 0 0 0.99999994039535522 41678.dat 1 72 -119.98341369628906 -154.62899780273437 810.00177001953125 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 41678.dat 1 72 120.01654815673828 -134.62667846679687 810.00048828125 0 -1 0 1 0 0 0 0 0.99999994039535522 41678.dat 1 71 120.01654815673828 -144.62669372558594 810.0006103515625 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 4519.dat 1 71 120.01651763916016 -129.62666320800781 810.0006103515625 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 32123a.dat 1 72 120.01641845703125 -154.62664794921875 810.0006103515625 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 41678.dat 1 71 120.01654815673828 -159.62666320800781 810.00048828125 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 32123a.dat 1 71 100.01697540283203 -124.626708984375 789.9996337890625 -1 1.2637195140996482E-005 -1.2513559340732172E-005 1.2513560250226874E-005 0 -1 -1.263719423150178E-005 -1 0 14720.dat 1 71 -99.982246398925781 -124.624267578125 789.999755859375 0.99999994039535522 0 0 0 -1.7805896277423017E-005 -1 0 1 -1.7805896277423017E-005 14720.dat 1 1 157.62533569335937 -114.62889862060547 873.201171875 0 0.27999910712242126 -0.96000033617019653 -1.0000001192092896 0 0 0 0.96000033617019653 0.27999916672706604 43093.dat 1 4 20.025732040405273 -124.62891387939453 830.0023193359375 0.60000014305114746 0 0.7999998927116394 0 1 0 -0.7999998927116394 0 0.60000014305114746 6629.dat 1 0 20.024402618408203 -124.62892150878906 830.00128173828125 0 0.60000091791152954 -0.79999947547912598 1.0000001192092896 0 0 0 -0.79999947547912598 -0.60000073909759521 18651.dat 1 0 176.82585144042969 -104.62960052490234 867.59796142578125 0.27993097901344299 0 0.96002012491226196 0 -1 0 0.96002012491226196 0 -0.27993097901344299 32524.dat 1 1 -99.974472045898437 -124.62879180908203 890.00823974609375 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 1 234.4276123046875 -124.62879180908203 850.80938720703125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 0 215.22724914550781 -124.62879180908203 856.407958984375 0.27977859973907471 0 0.96006441116333008 0 -1 0 0.96006441116333008 0 -0.27977877855300903 32523.dat 1 1 196.02679443359375 -124.62879180908203 862.006591796875 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 36 176.82640075683594 -124.62881469726562 877.60516357421875 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 6141.dat 1 0 176.82640075683594 -124.62881469726562 867.6051025390625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 87082.dat 1 1 -138.37474060058594 -124.62879180908203 878.80145263671875 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 0 176.82638549804687 -144.62879943847656 867.6051025390625 0.27992945909500122 0 0.96002048254013062 0 -1 0 0.96002048254013062 0 -0.27992954850196838 32524.dat 1 1 -195.974609375 -124.62879180908203 862.00140380859375 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 1 -119.17472076416016 -124.62879180908203 884.4014892578125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 1 100.02517700195312 -124.62881469726562 890.001220703125 0 0.0020423589739948511 -0.99999791383743286 -1 0 0 0 0.99999791383743286 0.0020423256792128086 6558.dat 1 1 119.22514343261719 -124.62881469726562 884.40106201171875 0 0.0020423589739948511 -0.99999791383743286 -1 0 0 0 0.99999791383743286 0.0020423256792128086 6558.dat 1 0 0.014143864624202251 -164.62715148925781 860.0177001953125 0 0 1 0 1 0 -1 0 0 2780.dat 1 4 30.016279220581055 -164.62838745117187 849.98968505859375 -1 0 0 0 1 0 0 0 -1 32062.dat 1 0 40.016277313232422 -164.62838745117187 849.98968505859375 0 1 0 1 0 0 0 0 -1 60483.dat 1 0 0.014144182205200195 -164.62715148925781 850.01763916015625 0 0 -1 0 0.99999994039535522 0 1 0 0 32034.dat 1 4 -29.985857009887695 -164.62715148925781 850.01763916015625 -1 0 0 0 1 0 0 0 -1 32062.dat 1 0 -39.985855102539062 -164.62715148925781 850.01763916015625 0 1 0 1 0 0 0 0 -1 60483.dat 1 71 -79.985885620117188 -164.6273193359375 830.01776123046875 -1 0 0 0 0.96814781427383423 -0.25037968158721924 0 -0.25037968158721924 -0.96814775466918945 44294.dat 1 71 -99.98590087890625 -164.62724304199219 830.01776123046875 0 0 1.0000001192092896 0.968147873878479 0.25037938356399536 0 -0.25037932395935059 0.968147873878479 0 6590.dat 1 4 0.01633763313293457 -164.62806701660156 829.989501953125 0 0 -1 0.25037872791290283 0.96814799308776855 0 0.96814793348312378 -0.25037872791290283 0 26287.dat 1 71 80.016258239746094 -164.62843322753906 829.98980712890625 -1 0 0 0 0.96814781427383423 -0.25037968158721924 0 -0.25037968158721924 -0.96814775466918945 44294.dat 1 71 140.01617431640625 -172.13957214355469 800.945556640625 0 0 -1 0.25037965178489685 0.96814775466918945 0 0.96814769506454468 -0.25037965178489685 0 2736.dat 1 14 140.016357421875 -169.63618469238281 810.62744140625 1 0 0 0 -0.96814769506454468 -0.25037968158721924 0 0.25037968158721924 -0.96814769506454468 32039.dat 1 71 100.01627349853516 -164.62841796875 829.98980712890625 0 0 -1 -0.96814799308776855 0.25037872791290283 0 0.25037872791290283 0.96814799308776855 0 6590.dat 1 14 -139.98583984375 -169.63499450683594 810.65509033203125 1 0 0 0 -0.96814769506454468 -0.25037968158721924 0 0.25037968158721924 -0.96814769506454468 32039.dat 1 71 -139.98583984375 -172.13871765136719 800.973388671875 0 0 -1 0.25037965178489685 0.96814775466918945 0 0.96814769506454468 -0.25037965178489685 0 2736.dat 1 0 -139.90773010253906 -174.96743774414062 788.58489990234375 -0.92270398139953613 0.0078543229028582573 -0.38542920351028442 -0.34542557597160339 0.42706894874572754 0.83563971519470215 0.17116813361644745 0.90418517589569092 -0.39134484529495239 32005.dat 1 0 -178.44580078125 -91.13665771484375 740.01531982421875 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 6628.dat 1 71 -178.44580078125 -111.13666534423828 730.01531982421875 -1 0 0 0 0 -1 0 -1 0 32316.dat 1 19 -178.44418334960937 -71.129570007324219 710.01220703125 0 0.13910017907619476 0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 -1.0000001192092896 0 0 32556.dat 1 72 -178.44419860839844 -71.129570007324219 710.01220703125 -0.22487430274486542 0 -0.97438782453536987 -0.97438782453536987 0 0.22487440705299377 0 1.0000001192092896 0 32316.dat 1 72 -139.46760559082031 -80.126953125 690.01214599609375 -0.22495868802070618 0 -0.97436827421188354 -0.97436827421188354 0 0.2249586433172226 0 0.99999994039535522 0 60483.dat 1 71 -139.46714782714844 -80.125419616699219 710.01226806640625 0 0.22495852410793304 -0.9743683934211731 0 0.97436833381652832 0.22495852410793304 1 0 0 32073.dat 1 72 -139.46925354003906 -80.123268127441406 670.010498046875 0.2249586284160614 0 0.97436845302581787 0.97436845302581787 0 -0.22495850920677185 0 1.0000001192092896 0 60483.dat 1 72 -139.46922302246094 -80.123260498046875 750.01043701171875 0.2249586284160614 0 0.97436845302581787 0.97436845302581787 0 -0.22495850920677185 0 1.0000001192092896 0 60483.dat 1 72 -139.46769714355469 -80.127029418945313 730.01226806640625 -0.22495843470096588 0 -0.97436833381652832 -0.97436833381652832 0 0.22495843470096588 0 0.99999994039535522 0 60483.dat 1 1 -158.95632934570312 -75.62701416015625 710.0123291015625 0 -0.87757188081741333 0.47944512963294983 0 -0.47944512963294983 -0.87757188081741333 1 0 0 6558.dat 1 71 -217.41961669921875 -102.13446807861328 710.01226806640625 0 0 1 0 0.99999994039535522 0 -1 0 0 11950.dat 1 71 -217.41961669921875 -82.134536743164062 695.01220703125 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 28 -217.41961669921875 -82.134536743164062 710.01226806640625 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 15462.dat 1 0 -217.41961669921875 -62.134517669677734 690.01226806640625 -1 0 0 0 0 -1 0 -1 0 33299a.dat 1 71 -217.41961669921875 -62.134605407714844 710.01214599609375 0 0 -1 0 0.99999994039535522 0 1 0 0 4519.dat 1 71 -217.41961669921875 -82.134544372558594 725.0123291015625 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 0 -217.41943359375 -122.13452911376953 755.01220703125 -1 0 0 0 0 1 0 1 0 6632.dat 1 28 -217.41961669921875 -122.134521484375 710.01226806640625 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 15462.dat 1 0 -217.41961669921875 -122.13452911376953 745.01239013671875 -1 0 0 0 0 1 0 1 0 6632.dat 1 0 -217.41961669921875 -62.134529113769531 730.01220703125 0.99999994039535522 0 0 0 0 -1 0 1 0 33299a.dat 1 4 -237.41963195800781 -112.13448333740234 670.01214599609375 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 41678.dat 1 0 -237.41970825195312 -102.13453674316406 670.01226806640625 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 3705.dat 1 4 -237.41970825195312 -67.134544372558594 670.01226806640625 0 0 1 0 -1 0 1 0 0 41677.dat 1 4 -237.41970825195312 -112.13453674316406 670.01226806640625 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 6590.dat 1 4 -237.41970825195312 -137.134521484375 670.01226806640625 0 0 1 0 -1 0 1 0 0 41677.dat 1 4 -237.41970825195312 -82.134475708007812 670.01324462890625 0 1 0 -1 0 0 0 0 0.99999994039535522 6536.dat 1 72 -247.16970825195312 -102.13514709472656 710.01226806640625 0 -2.266062620037701E-005 1 0 0.99999994039535522 2.266062620037701E-005 -1 0 0 92909.dat 1 71 -169.92010498046875 -113.09587097167969 710.00042724609375 0.97437036037445068 0.22494977712631226 0 -0.22494977712631226 0.97437036037445068 0 0 0 1 4519.dat 1 71 -217.42105102539062 -102.129638671875 710.00042724609375 0.22494976222515106 0 0.97437036037445068 0.97437036037445068 0 -0.22494979202747345 0 1 0 32494.dat 1 71 -119.9840087890625 -124.62471771240234 710.00042724609375 0.22494988143444061 0 -0.97437036037445068 0.97437036037445068 0 0.22494988143444061 0 -1 0 32494.dat 1 4 -69.984207153320313 -124.62467956542969 710.00048828125 0 0 -1 0 0.99999994039535522 0 1 0 0 59443.dat 1 72 -119.98387908935547 -124.62467956542969 710.00048828125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 92906.dat 1 71 -39.983875274658203 -124.62467956542969 710.00048828125 -1 0 0 0 1 0 0 0 -1 4519.dat 1 19 -16.98381233215332 -124.62467956542969 710.00030517578125 0 -1.3776033483736683E-005 1 1 0 0 0 1 1.3773647879133932E-005 6589.dat 1 71 0.018507242202758789 -124.62518310546875 709.99853515625 1 0 0 0 -1 0 0 0 -1 64179.dat 1 0 -39.983348846435547 -114.62442779541016 690.0003662109375 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 2780.dat 1 0 -59.983242034912109 -104.62545013427734 650.00048828125 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 71 -59.983222961425781 -104.62545013427734 710.00042724609375 0 0 -1 0 0.99999994039535522 0 1 0 0 32073.dat 1 71 -79.983200073242188 -104.62546539306641 710.00042724609375 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 42003.dat 1 71 -59.983242034912109 -104.62546539306641 690.0003662109375 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 6536.dat 1 71 -59.983242034912109 -104.62546539306641 730.00054931640625 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 6536.dat 1 72 -59.983207702636719 -124.62439727783203 750.0003662109375 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 42003.dat 1 0 -99.983848571777344 -124.62422943115234 710.00042724609375 1.4738240679434966E-005 -1 0 1 1.4738240679434966E-005 0 0 0 1 15100.dat 1 0 -39.983348846435547 -114.62442779541016 730.00030517578125 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 2780.dat 1 0 -49.983280181884766 -124.62440490722656 750.0003662109375 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 0.017082691192626953 -104.62522888183594 629.98565673828125 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 41239.dat 1 1 -119.98155975341797 -104.62739562988281 640.01226806640625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 71 -119.98155975341797 -124.62738800048828 650.01214599609375 0 0 1 0 -1 0 1 0 0 32184.dat 1 19 -119.98155975341797 -144.62739562988281 660.01214599609375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 6562.dat 1 0 -158.95719909667969 -135.63186645507812 670.01220703125 -0.22487439215183258 0 -0.9743877649307251 -0.9743877649307251 0 0.22487445175647736 0 1 0 32316.dat 1 0 -197.93197631835937 -126.63548278808594 755.01220703125 0.22495795786380768 0 0.97436845302581787 0.97436845302581787 0 -0.22495797276496887 0 1 0 41677.dat 1 28 -178.44493103027344 -131.13446044921875 710.01226806640625 0 0.22495830059051514 0.97436845302581787 0 0.97436851263046265 -0.22495830059051514 -1.0000001192092896 0 0 15462.dat 1 28 -197.93193054199219 -126.63334655761719 710.01226806640625 0 0.22495810687541962 0.97436845302581787 0 0.97436851263046265 -0.22495810687541962 -1 0 0 15462.dat 1 0 -197.931884765625 -126.63385772705078 710.01220703125 0.22495563328266144 0 0.97436904907226563 0.97436904907226563 0 -0.22495560348033905 0 1 0 60483.dat 1 0 -197.93202209472656 -126.63328552246094 690.01214599609375 -0.22495889663696289 0 -0.97436827421188354 -0.97436827421188354 0 0.22495889663696289 0 1 0 60483.dat 1 0 -197.93183898925781 -126.63333129882812 730.01226806640625 -0.22495889663696289 0 -0.97436827421188354 -0.97436827421188354 0 0.22495889663696289 0 1 0 60483.dat 1 0 -158.95722961425781 -135.6314697265625 745.01220703125 0.22495417296886444 0 0.97436940670013428 0.97436940670013428 0 -0.22495414316654205 0 1 0 11478.dat 1 19 -119.98204040527344 -144.63340759277344 760.01385498046875 0 -0.97436976432800293 0.22495272755622864 0 0.22495275735855103 0.97436976432800293 -1.0000001192092896 0 0 6562.dat 1 28 -139.47036743164062 -140.13249206542969 710.01226806640625 0 0.22495810687541962 0.97436845302581787 0 0.97436851263046265 -0.22495810687541962 -1 0 0 15462.dat 1 0 -139.46882629394531 -140.13638305664062 755.013916015625 0.22495783865451813 0 0.97436869144439697 0.97436869144439697 0 -0.22495771944522858 0 1.0000001192092896 0 41677.dat 1 72 0.016174823045730591 -164.62849426269531 749.99945068359375 2.4347207727259956E-005 1.1786941286118235E-005 1.0000001192092896 -1.0000001192092896 0 2.4278699129354209E-005 0 -1.0000001192092896 1.1855452612508088E-005 41239.dat 1 1 60.015151977539063 -164.62477111816406 760.000732421875 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 72 60.014961242675781 -164.618896484375 769.9888916015625 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32140.dat 1 1 -59.984676361083984 -164.62477111816406 760.00079345703125 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 72 -59.984676361083984 -164.62477111816406 770.0006103515625 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 32140.dat 1 1 -99.983970642089844 -164.62348937988281 770.00189208984375 0 0.87757194042205811 -0.47944509983062744 0 -0.47944504022598267 -0.87757194042205811 -1.0000001192092896 0 0 6558.dat 1 1 80.016151428222656 -164.62565612792969 770.00152587890625 0 0.87757200002670288 -0.47944507002830505 0 -0.47944498062133789 -0.87757200002670288 -1.0000001192092896 0 0 6558.dat 1 1 100.01604461669922 -164.62606811523437 770.000732421875 0 0.87757194042205811 -0.47944509983062744 0 -0.47944504022598267 -0.87757194042205811 -1.0000001192092896 0 0 6558.dat 1 72 -158.95761108398438 -155.62815856933594 695.01220703125 -0.22487403452396393 0 0.97438782453536987 -0.97438782453536987 0 -0.22487398982048035 0 -0.99999994039535522 0 6632.dat 1 71 -119.98136901855469 -164.623779296875 710.0120849609375 0 0.22487905621528625 0.97438669204711914 0 0.97438675165176392 -0.22487905621528625 -1 0 0 60485.dat 1 72 -158.95735168457031 -155.62863159179687 685.01214599609375 -0.22487393021583557 0 0.97438794374465942 -0.97438794374465942 0 -0.22487401962280273 0 -1.0000001192092896 0 6632.dat 1 72 -158.95706176757812 -155.62890625 725.0120849609375 -0.22487393021583557 0 0.97438788414001465 -0.97438788414001465 0 -0.22487396001815796 0 -1 0 6632.dat 1 71 -158.95693969726562 -155.62910461425781 710.011962890625 0 0.22487398982048035 -0.97438782453536987 0 0.97438782453536987 0.22487398982048035 1 0 0 4519.dat 1 72 -158.95767211914063 -155.628173828125 735.01214599609375 -0.22487398982048035 0 0.97438794374465942 -0.97438794374465942 0 -0.22487407922744751 0 -1.0000001192092896 0 6632.dat 1 14 -119.98133850097656 -164.623779296875 630.01214599609375 0 0.97438675165176392 0.22487881779670715 0 -0.22487874329090118 0.97438675165176392 1 0 0 6553.dat 1 71 -129.72624206542969 -162.38005065917969 715.012451171875 -0.22495125234127045 0 -0.97437006235122681 -0.97437006235122681 0 0.22495131194591522 0 1.0000001192092896 0 32063.dat 1 71 -129.72648620605469 -162.38236999511719 705.01239013671875 -0.22495095431804657 0 -0.97437012195587158 -0.97437012195587158 0 0.22495101392269135 0 1 0 32063.dat 1 19 -178.44302368164062 -151.1279296875 710.01251220703125 0 0.13910017907619476 0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 -1.0000001192092896 0 0 32556.dat 1 71 -178.44697570800781 -111.1383056640625 690.01495361328125 -1 0 0 0 0 -1 0 -1 0 32316.dat 1 1 -139.47027587890625 -160.12591552734375 710.011962890625 0 -0.87757194042205811 0.47944509983062744 0 -0.47944504022598267 -0.87757194042205811 1.0000001192092896 0 0 6558.dat 1 19 -81.293861389160156 -173.53044128417969 710.00146484375 0 0.13910019397735596 0.99027842283248901 0 0.99027842283248901 -0.13910019397735596 -1.0000001192092896 0 0 32556.dat 1 0 -158.95709228515625 -95.628250122070313 730.00140380859375 0.70819294452667236 -0.70601892471313477 0 0.70601892471313477 0.70819294452667236 0 0 0 1 4254.dat 1 4 -81.289962768554687 -173.53060913085937 730.00140380859375 0.70819306373596191 -0.70601880550384521 0 0.70601880550384521 0.70819306373596191 0 0 0 1 4255.dat 1 19 -158.957275390625 -95.629066467285156 710.011962890625 0 0.13910017907619476 0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 -1.0000001192092896 0 0 32556.dat 1 71 -158.9586181640625 -95.626632690429688 710.010498046875 -0.22487430274486542 0 -0.97438782453536987 -0.97438782453536987 0 0.22487440705299377 0 1.0000001192092896 0 32316.dat 1 19 -119.98232269287109 -104.62205505371094 709.99920654296875 0 0.13910017907619476 0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 -1.0000001192092896 0 0 32556.dat 1 72 -119.98270416259766 -84.621551513671875 730 -1 0 0 0 0 -1 0 -1 0 60483.dat 1 72 -119.98442077636719 -84.623893737792969 720.00091552734375 0 0 -1 0 0.99999994039535522 0 1 0 0 55013.dat 1 72 -89.982521057128906 -84.621536254882812 705 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32449.dat 1 72 -119.98270416259766 -84.621559143066406 690 -1 0 0 0 0 -1 0 -1 0 60483.dat 1 71 -59.982276916503906 -84.622032165527344 709.99896240234375 0 0 -1 0 0.99999994039535522 0 1 0 0 4519.dat 1 72 -59.982288360595703 -84.622032165527344 689.99908447265625 0 0 1 0 0.99999994039535522 0 -1 0 0 6536.dat 1 72 -59.982288360595703 -84.622024536132812 729.9990234375 0 0 1 0 0.99999994039535522 0 -1 0 0 6536.dat 1 72 -89.982330322265625 -84.621368408203125 714.9998779296875 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32449.dat 1 1 -59.984821319580078 -64.628791809082031 730.001708984375 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 -79.984817504882813 -64.628791809082031 710.00177001953125 0 1 0 -1 0 0 0 0 0.99999994039535522 6629.dat 1 1 -59.984821319580078 -64.628791809082031 770.00177001953125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 -39.984817504882813 -64.628791809082031 710.001708984375 0 -1 0 -1 0 0 0 0 -1 40490.dat 1 1 -59.983314514160156 -64.622039794921875 669.99932861328125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 -79.928550720214844 -64.62542724609375 530.0133056640625 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 1 -149.98316955566406 -112.62590026855469 626.0001220703125 1 0 0 0 0.79999923706054688 0.60000097751617432 0 -0.60000097751617432 0.79999923706054688 43093.dat 1 72 -139.98309326171875 -64.625740051269531 489.9998779296875 0 1 0 -1 0 0 0 0 0.99999994039535522 6629.dat 1 0 -99.961410522460938 -64.903549194335937 490.0252685546875 0.99999994039535522 0 0 0 0 1 0 -1 0 32054.dat 1 4 -129.96107482910156 -64.903572082519531 490.02484130859375 -1 0 0 0 1 0 0 0 -1 32062.dat 1 72 -159.98324584960937 -112.62649536132812 626.00006103515625 0 -1.0000001192092896 0 -0.59998828172683716 0 0.80000889301300049 -0.80000889301300049 0 -0.59998822212219238 32316.dat 1 0 -149.9832763671875 -80.625572204589844 602.0006103515625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 -159.98324584960937 -64.625732421875 510.00042724609375 -1 0 0 0 0 1 0 1 0 11214.dat 1 72 -179.98309326171875 -64.623985290527344 510.00042724609375 -1 0 0 0 -1 0 0 0 1 6536.dat 1 1 -179.98321533203125 -64.625732421875 370.00045776367187 -1 0 0 0 -1 0 0 0 1 6558.dat 1 1 -199.99253845214844 -64.328857421875 190.02491760253906 -1 0 0 0 -1 0 0 0 1 6558.dat 1 1 -199.99234008789063 -64.329185485839844 310.0250244140625 1 0 0 0 1 0 0 0 1 6558.dat 1 1 -189.99221801757812 -64.328857421875 130.02488708496094 0.99999994039535522 0 0 0 0 -1 0 1 0 43093.dat 1 72 -179.99249267578125 -64.330612182617188 130.02488708496094 1 0.00017512140038888901 0 0.00017512140038888901 -1 0 0 0 -1 6536.dat 1 1 -179.98414611816406 -64.632644653320312 410.00289916992187 -1 0 0 0 -1 0 0 0 1 6558.dat 1 28 -199.99253845214844 -64.328018188476562 230.02615356445312 1 0 0 0 1 0 0 0 1 6587.dat 1 4 -220.00587463378906 -64.330101013183594 230.02641296386719 0 -1 0 -1 0 0 0 0 -1 32348.dat 1 0 -220.00587463378906 -112.33005523681641 134.02684020996094 -1 0 0 0 -0.6000019907951355 0.79999852180480957 0 0.79999852180480957 0.60000211000442505 18651.dat 1 4 -239.99789428710937 -112.40437316894531 134.06976318359375 1 0 0 0 -0.79999935626983643 0.60000085830688477 0 -0.60000085830688477 -0.79999935626983643 6536.dat 1 71 -139.99238586425781 -64.328536987304688 270.02557373046875 1 1.4297418601927347E-005 0 1.4297418601927347E-005 -1 0 0 0 -1 64178.dat 1 0 -199.9925537109375 -64.328590393066406 210.02574157714844 0 -1 0 -1 0 0 0 0 -1 40490.dat 1 72 -159.99261474609375 -84.328956604003906 260.02618408203125 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 41678.dat 1 71 -159.99360656738281 -84.328521728515625 250.02708435058594 0 0 1 0 1 0 -1 0 0 4519.dat 1 72 -159.99360656738281 -84.328041076660156 230.02705383300781 0 0 -1 4.8263922508340329E-005 0.99999994039535522 0 1 -4.8263922508340329E-005 0 6536.dat 1 28 -199.9925537109375 -64.328987121582031 270.02645874023437 1 0 0 0 1 0 0 0 1 6587.dat 1 4 -219.99235534667969 -144.328857421875 390.02542114257812 0 -1 0 -0.60000085830688477 0 0.79999935626983643 -0.79999935626983643 0 -0.60000085830688477 6629.dat 1 72 -199.98333740234375 -144.62429809570312 390.0003662109375 -1 0 0 0 0.60000121593475342 0.79999923706054688 0 0.79999923706054688 -0.60000109672546387 11214.dat 1 4 -240.01467895507812 -112.23854827880859 526.0001220703125 -1 0 0 0 -0.79999905824661255 0.60000133514404297 0 0.60000133514404297 0.7999994158744812 6536.dat 1 4 -229.98530578613281 -112.63005828857422 526.00335693359375 1 0 0 0 0.80000114440917969 0.59999847412109375 0 -0.59999847412109375 0.80000114440917969 32062.dat 1 4 -219.98532104492187 -64.629600524902344 390.0040283203125 0 1 0 -1 0 0 0 0 0.99999994039535522 6629.dat 1 28 -199.98329162597656 -64.62567138671875 390.00198364257812 1 0 0 0 1 0 0 0 1 6587.dat 1 0 -199.98452758789062 -64.63134765625 430.00234985351562 0 1 -1.1804653695435263E-005 -1 0 2.077031422231812E-005 2.077031422231812E-005 1.1804653695435263E-005 0.99999994039535522 41239.dat 1 72 -159.983642578125 -64.625389099121094 470.00222778320312 0 -1 0 -1 0 0 0 0 -1 32525.dat 1 71 -179.98394775390625 -104.62448883056641 410.00051879882812 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 14720.dat 1 0 -209.98483276367187 -64.631195068359375 470.00311279296875 1 0 0 0 1 0 0 0 1 2780.dat 1 1 -180.01353454589844 -63.724796295166016 170.11601257324219 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 -160.01066589355469 -83.728294372558594 150.11949157714844 -5.8533198171062395E-005 0.00017501834372524172 1 0.00017514199134893715 -0.99999994039535522 0.00017502861737739295 1 0.00017515223589725792 5.8635043387766927E-005 11214.dat 1 72 -160.01240539550781 -83.72479248046875 170.11944580078125 0 0 1 -0.00017504161223769188 0.99999994039535522 0 -1 -0.00017504161223769188 0 6536.dat 1 72 -140.00912475585937 -83.733558654785156 150.11943054199219 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32524.dat 1 0 -120.00912475585937 -83.733558654785156 140.11944580078125 0 0 1 0 1 0 -1 0 0 2780.dat 1 71 -120.01020812988281 -123.7330322265625 130.12020874023437 -1 1.2637156032724306E-005 -1.2513521141954698E-005 1.2513522051449399E-005 0 -1 -1.2637155123229604E-005 -1 0 14720.dat 1 1 -100.00971221923828 -83.733291625976562 110.12005615234375 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 71 -99.992515563964844 -104.32881164550781 110.024658203125 0 1.0000001192092896 0 -1.2653533303819131E-005 0 1.0000001192092896 1.0000001192092896 0 1.2792693269148003E-005 14720.dat 1 0 -99.992561340332031 -124.32893371582031 100.02445983886719 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 72 0.0053346157073974609 -124.32746887207031 90.038429260253906 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 0 0.0078977830708026886 -124.32774353027344 110.03945922851562 -0.70710694789886475 0.70710659027099609 0 -0.70710659027099609 -0.70710694789886475 0 0 0 1 32270.dat 1 0 0.0080218343064188957 -124.3280029296875 60.025341033935547 0 -0.7071068286895752 0.70710688829421997 0 0.70710694789886475 0.7071068286895752 -1.0000001192092896 0 0 3707.dat 1 0 0.0080515649169683456 -124.32798004150391 -9.9746608734130859 -0.70710694789886475 0.70710659027099609 0 -0.70710659027099609 -0.70710694789886475 0 0 0 1 18575.dat 1 72 40.007801055908203 -84.32672119140625 10.026070594787598 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 72 0.0078052282333374023 -84.32672119140625 25.026029586791992 -1 0 0 0 0 -1.0000001192092896 0 -1.0000001192092896 0 2905.dat 1 72 -39.992122650146484 -84.328689575195313 10.02492618560791 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 72 0.0078052282333374023 -84.32672119140625 35.026065826416016 -1 0 0 0 0 -1.0000001192092896 0 -1.0000001192092896 0 2905.dat 1 72 0.00782012939453125 -84.32672119140625 -9.9739179611206055 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 72 -79.992118835449219 -84.329154968261719 10.024847030639648 1.1539619663381018E-005 0 1.0000001192092896 -1.0000001192092896 0 1.142246946983505E-005 0 -1.0000001192092896 0 32316.dat 1 72 80.007728576660156 -84.3270263671875 10.025800704956055 1.1539619663381018E-005 0 1.0000001192092896 -1.0000001192092896 0 1.142246946983505E-005 0 -1.0000001192092896 0 32316.dat 1 1 100.00765228271484 -84.326751708984375 10.026031494140625 0 0.87757194042205811 -0.47944504022598267 0 0.47944507002830505 0.87757194042205811 1 0 0 6558.dat 1 1 -79.992088317871094 -84.329132080078125 10.02473258972168 0 -0.87758052349090576 0.47942951321601868 0 0.47942963242530823 0.87758052349090576 -1.0000001192092896 0 0 6558.dat 1 0 -119.99104309082031 -164.32891845703125 40.025096893310547 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 71 -24.990470886230469 -184.32931518554687 30.025459289550781 0 0 1 0 0.99999994039535522 0 -1 0 0 32123a.dat 1 0 -79.990509033203125 -184.32931518554687 30.025476455688477 -1 0 0 0 1 0 0 0 -1 3706.dat 1 0 -119.99101257324219 -164.32891845703125 50.025093078613281 -1 0 0 0 -1 0 0 0 1 92907.dat 1 71 -59.990489959716797 -184.32931518554687 30.025459289550781 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 6590.dat 1 71 -99.99151611328125 -124.32867431640625 30.025117874145508 -1 0 0 0 0 1 0 1 0 14720.dat 1 72 -99.993576049804688 -144.32655334472656 30.038505554199219 0.99999994039535522 0 0 0 -0.79999881982803345 0.60000157356262207 0 -0.60000157356262207 -0.79999881982803345 11214.dat 1 0 -59.993614196777344 -144.32685852050781 30.037057876586914 1 0 0 0 0.60000091791152954 0.79999929666519165 0 -0.79999929666519165 0.60000091791152954 32054.dat 1 71 -59.993541717529297 -104.32747650146484 90.038253784179688 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 64179.dat 1 1 -59.992515563964844 -64.328292846679687 110.02500152587891 1 0 0 0 -1 0 0 0 -1 6558.dat 1 71 0.0074565410614013672 -64.328269958496094 180.010498046875 -1 0 0 0 -1 0 0 0 1 32039.dat 1 72 0.0060147647745907307 -64.326789855957031 227.02471923828125 0 0 -1 0 0.99999994039535522 0 1 0 0 32209.dat 1 4 10.007451057434082 -64.328269958496094 160.01051330566406 1 0 0 0 -1 0 0 0 -1 32062.dat 1 71 20.007450103759766 -64.328269958496094 160.010498046875 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6590.dat 1 72 40.006004333496094 -64.326789855957031 190.02473449707031 -1 0 0 0 0 1 0 1 0 11214.dat 1 71 20.006010055541992 -64.326789855957031 190.02473449707031 0 0 1 0 0.99999994039535522 0 -1 0 0 32126.dat 1 71 0.0074446201324462891 -64.328292846679687 150.02493286132812 1 0 0 0 -1 0 0 0 -1 64179.dat 1 1 60.006046295166016 -64.326789855957031 150.02476501464844 1 0 0 0 -1 0 0 0 -1 6558.dat 1 71 60.005588531494141 -104.32746124267578 90.038444519042969 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 64179.dat 1 1 60.006046295166016 -64.326789855957031 110.02481079101562 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 80.0411376953125 -64.621940612792969 90.013679504394531 0 -1 1.1663751138257794E-005 1 0 -2.423294608888682E-005 2.423294608888682E-005 1.1663751138257794E-005 0.99999994039535522 41239.dat 1 1 80.006118774414063 -64.326789855957031 170.02542114257812 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 90.006004333496094 -64.326789855957031 90.024742126464844 -1 0 0 0 1 0 0 0 -1 2780.dat 1 71 99.990249633789063 -103.73323059082031 110.12109375 0 -1.0000001192092896 0 -1.2544988749141339E-005 0 1.0000001192092896 -1.0000001192092896 0 -1.2469203284126706E-005 14720.dat 1 0 109.99024963378906 -143.73321533203125 130.12153625488281 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 71 119.99050140380859 -123.73336791992187 130.12153625488281 -1 1.2637156032724306E-005 -1.2513521141954698E-005 1.2513522051449399E-005 0 -1 -1.2637155123229604E-005 -1 0 14720.dat 1 1 119.99051666259766 -123.73299407958984 130.12158203125 -1 0 0 0 -0.99984771013259888 0.017452307045459747 0 0.017452307045459747 0.9998476505279541 6558.dat 1 14 99.990501403808594 -117.25653076171875 137.74098205566406 0 -1.0000001192092896 0 -0.76193892955780029 0 -0.64764899015426636 0.64764899015426636 0 -0.76193886995315552 43857.dat 1 1 109.99050140380859 -110.77984619140625 145.36044311523437 1 0 0 0 0.57877719402313232 0.81548571586608887 0 -0.81548571586608887 0.57877719402313232 4274.dat 1 14 139.99050903320312 -117.25650787353516 137.74098205566406 0 -1.0000001192092896 0 -0.76193892955780029 0 -0.64764899015426636 0.64764899015426636 0 -0.76193886995315552 43857.dat 1 1 129.99052429199219 -110.77977752685547 145.36044311523437 -1 1.012041320791468E-005 0 1.0200654287473299E-005 0.57877737283706665 0.81548547744750977 0 0.81548547744750977 -0.5787774920463562 4274.dat 1 0 119.99044799804687 -163.73336791992187 110.12155914306641 -1.4363714399223682E-005 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 1.4433986507356167E-005 0 15100.dat 1 72 90.007789611816406 -164.32066345214844 110.04254913330078 1 0 0 0 1 0 0 0 1 55013.dat 1 0 140.00154113769531 -164.41456604003906 110.07359313964844 0 -1 0 0 0 1 -1 0 0 60483.dat 1 71 100.00775909423828 -164.32064819335938 110.04255676269531 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6590.dat 1 4 0.0077664852142333984 -164.32063293457031 110.04255676269531 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 32034.dat 1 72 -89.992233276367188 -164.32064819335938 110.04254913330078 -1 0 0 0 1 0 0 0 -1 55013.dat 1 71 -99.992240905761719 -164.32064819335938 110.04252624511719 0 0 1 -1 0 0 0 -1 0 6590.dat 1 0 -139.99224853515625 -164.32064819335938 110.04253387451172 0 -1 0 0 0 1 -1 0 0 60483.dat 1 0 0.0078364629298448563 -164.32078552246094 90.042404174804687 0 1.4805104001425207E-005 1 1.46814700201503E-005 -1 1.4805103091930505E-005 1 1.4681468201160897E-005 0 15100.dat 1 0 0.0078225648030638695 -214.32072448730469 90.042671203613281 0.70710688829421997 -0.70710688829421997 0 0 0 1.0000001192092896 -0.70710688829421997 -0.7071068286895752 0 59443.dat 1 4 0.0077928025275468826 -234.32075500488281 90.042686462402344 0 -0.70710700750350952 0.70710670948028564 -1.0000001192092896 0 0 0 -0.70710670948028564 -0.70710688829421997 32062.dat 1 72 0.0077995406463742256 -174.32078552246094 90.042671203613281 0 0.70710700750350952 -0.70710664987564087 1 0 0 0 -0.70710664987564087 -0.70710694789886475 87083.dat 1 71 0.008301696740090847 -149.32075500488281 90.042587280273438 -0.7071068286895752 -0.70710676908493042 0 0 0 -1.0000001192092896 0.70710676908493042 -0.70710694789886475 0 32123a.dat 1 0 0.0078232698142528534 -244.32077026367188 90.042671203613281 -0.70710676908493042 -0.70710676908493042 0 0 0 1 -0.70710676908493042 0.70710676908493042 0 32270.dat 1 19 0.0083903633058071136 -181.32077026367187 90.042587280273438 0.70710688829421997 -0.70710670948028564 0 0 0 1 -0.70710670948028564 -0.70710688829421997 0 6589.dat 1 0 0.0078442888334393501 -164.32080078125 60.042659759521484 -1 0 0 0 0 -1.0000001192092896 0 -1.0000001192092896 0 48496.dat 1 72 0.0078369854018092155 -124.32081604003906 50.04266357421875 0.99999994039535522 0 0 0 0 -1 0 1 0 32524.dat 1 0 0.0078317327424883842 -64.320526123046875 60.042469024658203 0 0 1 0 1 0 -1 0 0 2780.dat 1 71 0.007724761962890625 -64.320526123046875 70.042549133300781 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32523.dat 1 0 -19.992242813110352 -64.320526123046875 80.042549133300781 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 20.007717132568359 -64.320526123046875 80.042549133300781 0 0 1 0 1 0 -1 0 0 2780.dat 1 19 0.0091731548309326172 -164.32620239257812 73.026222229003906 0 -1 0 1 0 0 0 0 0.99999994039535522 6589.dat 1 0 0.0095357894897460938 -164.32623291015625 20.026147842407227 0 0 1 0 1 0 -1 0 0 3706.dat 1 4 0.0095476312562823296 -164.32623291015625 -39.973861694335938 1 0 0 0 -1 0 0 0 -1 59443.dat 1 0 0.0095546245574951172 -164.32623291015625 30.026182174682617 -1 0 0 0 -1 0 0 0 1 32270.dat 1 28 0.0079001979902386665 -164.33332824707031 -89.976715087890625 0 0 1 0 0.99999994039535522 0 -1 0 0 15462.dat 1 19 0.0079132160171866417 -164.33332824707031 -102.97671508789062 1 0 0 0 -1 0 0 0 -1 6589.dat 1 1 20.009002685546875 -164.32574462890625 0.026400387287139893 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 0.0096142292022705078 -164.32623291015625 0.026702880859375 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 87408.dat 1 1 -19.990942001342773 -164.32672119140625 0.026018917560577393 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 72 0.0089865028858184814 -164.32623291015625 -9.973780632019043 2.4347207727259956E-005 1.1786941286118235E-005 1.0000001192092896 -1.0000001192092896 0 2.4278699129354209E-005 0 -1.0000001192092896 1.1855452612508088E-005 41239.dat 1 1 -99.99102783203125 -164.32867431640625 10.025077819824219 0 0.87757194042205811 -0.47944504022598267 0 0.47944507002830505 0.87757194042205811 1 0 0 6558.dat 1 72 -79.990974426269531 -164.32954406738281 10.02503776550293 1.1539619663381018E-005 0 1.0000001192092896 -1.0000001192092896 0 1.142246946983505E-005 0 -1.0000001192092896 0 32316.dat 1 0 -39.990776062011719 -164.32907104492187 0.025038421154022217 -1.003228135232348E-005 -1.0000001192092896 2.2746955437469296E-005 0 -2.2627422367804684E-005 -1.0000001192092896 1.0000001192092896 -1.0151818059966899E-005 0 2780.dat 1 0 -79.990951538085938 -164.32986450195312 20.025114059448242 0 -1.5939151126076467E-005 1.0000001192092896 -1.6062786016846076E-005 -1 -1.5939145669108257E-005 1.0000001192092896 -1.6062780559877865E-005 0 2780.dat 1 71 -119.99284362792969 -164.32795715332031 -49.962985992431641 -0.2248740941286087 0 0.97438782453536987 -0.97438782453536987 0 -0.22487406432628632 0 -1 0 32316.dat 1 72 -119.99308013916016 -164.3277587890625 -49.963516235351563 0 0.22487574815750122 0.974387526512146 0 0.97438758611679077 -0.22487574815750122 -1.0000001192092896 0 0 57515.dat 1 71 -158.96841430664062 -155.33283996582031 -49.962909698486328 0 0.22487415373325348 -0.97438782453536987 0 0.97438782453536987 0.22487415373325348 1 0 0 4519.dat 1 72 -158.96847534179687 -155.33291625976562 -24.963289260864258 -0.22487422823905945 0 0.97438788414001465 -0.97438788414001465 0 -0.22487431764602661 0 -1.0000001192092896 0 6632.dat 1 72 -158.96879577636719 -155.33255004882812 -74.963516235351563 0.22487585246562958 0 0.974387526512146 0.974387526512146 0 -0.22487577795982361 0 1.0000001192092896 0 6632.dat 1 0 -119.99333190917969 -164.32759094238281 -59.963520050048828 0 0.22487536072731018 0.97438758611679077 0 0.97438758611679077 -0.22487536072731018 -1 0 0 3707.dat 1 14 -119.99330139160156 -164.32759094238281 -129.96353149414062 0.97438764572143555 0.22487488389015198 0 -0.22487488389015198 0.97438764572143555 0 0 0 1 6590.dat 1 72 -120.00734710693359 -143.7386474609375 -149.87928771972656 0 1 0 0 0 -1 -1 0 0 32523.dat 1 1 -100.00733947753906 -123.7386474609375 -149.87928771972656 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 -99.991790771484375 -129.32914733886719 -129.97401428222656 0 0 -1 0 0.99999994039535522 0 1 0 0 41677.dat 1 4 -119.99168395996094 -134.32914733886719 -129.9739990234375 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32062.dat 1 4 -99.991600036621094 -134.32919311523437 -129.96884155273437 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32062.dat 1 72 -119.99172210693359 -134.32914733886719 -129.97392272949219 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 41678.dat 1 72 -99.99176025390625 -134.32919311523437 -129.96894836425781 0 -1 0 1 0 0 0 0 0.99999994039535522 41678.dat 1 72 -99.991790771484375 -139.32917785644531 -129.97381591796875 0 0 -1 0 0.99999994039535522 0 1 0 0 41677.dat 1 72 -99.991691589355469 -124.32914733886719 -109.97412109375 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 72 -79.992019653320312 -124.32928466796875 -109.97469329833984 0 -1 0 -1 0 0 0 0 -1 32140.dat 1 71 -99.99188232421875 -124.32916259765625 -109.97402954101562 1 0 0 0 1.7599262719159015E-005 1 0 -1 1.7599262719159015E-005 14720.dat 1 72 -60.007011413574219 -143.73771667480469 -149.87986755371094 -1 0 0 0 0 1 0 1 0 11214.dat 1 0 -100.00736999511719 -143.7386474609375 -149.87928771972656 -1 0 0 0 0 1 0 1 0 32054.dat 1 0 -39.995105743408203 -144.32711791992187 -69.978424072265625 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 72 -99.991859436035156 -144.32914733886719 -109.97393035888672 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 0 -59.992660522460938 -144.32780456542969 -109.97488403320312 0.99999994039535522 0 0 0 0 1 0 -1 0 32054.dat 1 71 -59.993171691894531 -104.32827758789062 -109.97496795654297 0 1.0000001192092896 -1.5613408322678879E-005 0 1.5697960407123901E-005 1.0000001192092896 1.0000001192092896 0 0 14720.dat 1 0 -59.993152618408203 -104.32827758789062 -119.97518920898437 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 2780.dat 1 72 -59.992820739746094 -124.32825469970703 -129.97554016113281 1 0 0 0 1 0 0 0 1 6536.dat 1 72 -49.992015838623047 -124.32928466796875 -129.97477722167969 -1 0 0 0 1 0 0 0 -1 87083.dat 1 71 0.0081002712249755859 -124.32786560058594 -129.97457885742187 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32034.dat 1 72 50.008056640625 -124.32670593261719 -129.97477722167969 1 0 0 0 1 0 0 0 1 87083.dat 1 72 60.0074462890625 -124.32691192626953 -129.97419738769531 1 0 0 0 1 0 0 0 1 6536.dat 1 0 0.011154641397297382 -144.32772827148437 -129.97465515136719 -0.70710688829421997 0.70710670948028564 0 0 0 -1 -0.70710670948028564 -0.70710688829421997 0 18575.dat 1 71 0.011144506745040417 -124.32772064208984 -129.97467041015625 0 -0.70710688829421997 0.70710670948028564 1 0 0 0 0.70710670948028564 0.70710694789886475 4519.dat 1 19 0.0096766231581568718 -111.32772064208984 -129.97465515136719 0.70710700750350952 -0.7071068286895752 0 0 0 1.0000001192092896 -0.7071068286895752 -0.70710688829421997 0 6589.dat 1 0 60.007499694824219 -104.32691955566406 -119.97518920898437 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 2780.dat 1 71 60.007484436035156 -104.326904296875 -109.97496795654297 0 1.0000001192092896 -1.5613408322678879E-005 0 1.5697960407123901E-005 1.0000001192092896 1.0000001192092896 0 0 14720.dat 1 72 100.00830078125 -144.32644653320312 -109.97545623779297 -1 0 0 0 0 1 0 1 0 11214.dat 1 0 60.007953643798828 -144.32737731933594 -109.97488403320312 -1 0 0 0 0 1 0 1 0 32054.dat 1 0 50.006805419921875 -144.32719421386719 -89.975959777832031 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 50.007949829101563 -144.32696533203125 -129.9749755859375 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 60.006160736083984 -84.326858520507813 -109.97481536865234 0 0.87757188081741333 -0.47944512963294983 0 0.4794451892375946 0.87757188081741333 1 0 0 6558.dat 1 72 0.0084280967712402344 -84.327079772949219 -89.961112976074219 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 1 -59.993350982666016 -84.3282470703125 -109.97481536865234 0 0.87757188081741333 -0.47944512963294983 0 0.4794451892375946 0.87757188081741333 1 0 0 6558.dat 1 72 0.0066876411437988281 -84.3282470703125 -129.97480773925781 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 1 80.006790161132813 -84.329360961914063 -109.97481536865234 0 0.87757188081741333 -0.47944512963294983 0 0.4794451892375946 0.87757188081741333 1 0 0 6558.dat 1 1 -99.993606567382813 -84.330848693847656 -109.98702239990234 0 0.87757188081741333 -0.47944512963294983 0 0.4794451892375946 0.87757188081741333 1 0 0 6558.dat 1 1 -79.993583679199219 -84.330848693847656 -109.98702239990234 0 0.87757188081741333 -0.47944512963294983 0 0.4794451892375946 0.87757188081741333 1 0 0 6558.dat 1 0 0.0082194805145263672 -84.328338623046875 -109.97484588623047 -1 0 0 0 1 0 0 0 -1 32269.dat 1 28 0.0061537814326584339 -84.326866149902344 -89.974815368652344 0 0 1 0 0.99999994039535522 0 -1 0 0 15462.dat 1 4 0.0078012142330408096 -84.319778442382813 -39.971958160400391 1 0 0 0 -1 0 0 0 -1 59443.dat 1 72 0.0078444480895996094 -84.32672119140625 0.026026368141174316 0 0 -1 0 0.99999994039535522 0 1 0 0 87083.dat 1 0 0.0078439712524414063 -84.32672119140625 10.026023864746094 -1 0 0 0 -1 0 0 0 1 32270.dat 1 1 100.00667572021484 -84.3282470703125 -109.97481536865234 0 0.87757188081741333 -0.47944512963294983 0 0.4794451892375946 0.87757188081741333 1 0 0 6558.dat 1 1 60.0057373046875 -64.326774597167969 -129.97477722167969 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 40.0057373046875 -64.326774597167969 -29.974782943725586 0 -1 0 -1 0 0 0 0 -1 32525.dat 1 1 60.006999969482422 -64.327430725097656 70.010734558105469 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 60.005664825439453 -64.326774597167969 30.0252685546875 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 60.085010528564453 -64.623641967773438 -70.002006530761719 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 120.00689697265625 -104.32608032226562 -74.973587036132812 0.99999994039535522 0 -1.2558992239064537E-005 1.2558992239064537E-005 0 1 0 -1 0 41677.dat 1 71 120.00688171386719 -104.325927734375 -49.973434448242188 0 -1.2533307199191768E-005 1 0 1 1.2533307199191768E-005 -1 0 0 4519.dat 1 71 120.00689697265625 -104.32597351074219 -64.973587036132813 1 0 0 0 1 0 0 0 1 32123a.dat 1 72 120.00696563720703 -104.32620239257812 -24.973587036132812 0.99999994039535522 0 -1.2558992239064537E-005 1.2558992239064537E-005 0 1 0 -1 0 41677.dat 1 72 120.00765991210937 -84.325965881347656 -39.973361968994141 0 0 1 0 0.99999994039535522 0 -1 0 0 55013.dat 1 72 90.005889892578125 -84.328842163085938 -54.976177215576172 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32449.dat 1 72 90.005699157714844 -84.32867431640625 -44.976333618164062 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32449.dat 1 71 120.00689697265625 -104.32608032226562 -34.973663330078125 1 0 0 0 1 0 0 0 1 32123a.dat 1 71 60.005687713623047 -84.328681945800781 -49.976261138916016 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 4519.dat 1 72 60.007415771484375 -84.326614379882813 -69.974884033203125 0 0 1 0 0.99999994039535522 0 -1 0 0 6536.dat 1 72 60.007606506347656 -84.326492309570313 -29.975112915039063 0 0 1 0 0.99999994039535522 0 -1 0 0 6536.dat 1 1 60.006046295166016 -64.326789855957031 -29.975151062011719 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 120.00886535644531 -164.32585144042969 40.026336669921875 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 0 79.993309020996094 -184.32058715820312 30.042606353759766 1 0 0 0 1 0 0 0 1 3706.dat 1 0 120.00885009765625 -164.32585144042969 50.026309967041016 -1 0 0 0 -1 0 0 0 1 92907.dat 1 71 24.99327278137207 -184.32058715820312 30.042625427246094 0 0 -1 0 0.99999994039535522 0 1 0 0 32123a.dat 1 71 59.993289947509766 -184.32058715820312 30.042636871337891 0 0 1 -1 0 0 0 -1 0 6590.dat 1 71 100.00837707519531 -124.32608795166016 30.026262283325195 -1 0 0 0 0 1 0 1 0 14720.dat 1 1 80.007949829101563 -84.327163696289063 10.0252685546875 0 0.87757194042205811 -0.47944504022598267 0 0.47944507002830505 0.87757194042205811 1 0 0 6558.dat 1 1 100.00898742675781 -164.32608032226562 10.026222229003906 0 0.87757194042205811 -0.47944504022598267 0 0.47944507002830505 0.87757194042205811 1 0 0 6558.dat 1 72 80.009063720703125 -164.32650756835937 10.025419235229492 1.1539619663381018E-005 0 1.0000001192092896 -1.0000001192092896 0 1.142246946983505E-005 0 -1.0000001192092896 0 32316.dat 1 0 60.009456634521484 -164.32673645019531 30.025533676147461 -1.4466952052316628E-005 1 0 0 0 -1 -1 -1.4485605788649991E-005 0 15100.dat 1 0 49.993259429931641 -164.32057189941406 30.042671203613281 -1 1.0137104254681617E-005 -1.0260971066600177E-005 1.0260740054945927E-005 -2.2624812118010595E-005 -1.0000001192092896 -1.0137337994819973E-005 -1.0000001192092896 2.2893787900102325E-005 2780.dat 1 72 39.993267059326172 -164.32058715820312 90.042472839355469 0 -1 0 -1 0 0 0 0 -1 32140.dat 1 1 50.005088806152344 -164.32760620117187 90.038276672363281 -1 0 0 0 0 1 0 1 0 43093.dat 1 0 60.005153656005859 -164.32774353027344 90.038276672363281 1.4380612810782623E-005 -1 0 1 1.4380612810782623E-005 0 0 0 1 15100.dat 1 71 79.993263244628906 -164.32078552246094 50.042701721191406 -0.7431449294090271 0 -0.66913056373596191 -0.17318442463874817 0.96592587232589722 0.19234083592891693 0.64633029699325562 0.25882008671760559 -0.71782267093658447 3326b.dat 1 71 79.99334716796875 -164.32090759277344 50.042621612548828 0.74314403533935547 0.040851306170225143 0.66788339614868164 0.17318478226661682 0.95238113403320313 -0.25095283985137939 -0.64633125066757202 0.30216133594512939 0.70068150758743286 62520.dat 1 71 79.99334716796875 -164.32058715820312 50.042732238769531 0 0 -1.0000001192092896 -0.96592563390731812 -0.25882002711296082 0 -0.25882020592689514 0.96592563390731812 0 62520.dat 1 4 100.04124450683594 -171.82780456542969 71.059371948242188 -0.66848260164260864 0.017093857750296593 0.74353134632110596 0.24987320601940155 0.94678449630737305 0.20288544893264771 -0.70049583911895752 0.32141393423080444 -0.63718026876449585 32062.dat 1 71 120.09590911865234 -179.3240966796875 92.074111938476562 -0.74314635992050171 0.029371963813900948 -0.66848397254943848 -0.18721525371074677 0.95000910758972168 0.24986685812473297 0.64240485429763794 0.31083804368972778 -0.70049679279327393 62520.dat 1 71 120.09622955322266 -179.32395935058594 92.074371337890625 0.74314612150192261 0.00019178856746293604 0.6691291332244873 0.18721200525760651 0.96000319719314575 -0.20819595456123352 -0.64240604639053345 0.27998903393745422 0.71338677406311035 3326b.dat 1 71 120.09622955322266 -179.32402038574219 92.074287414550781 -0.00019189184240531176 1 0 -0.9600030779838562 -0.00018422098946757615 -0.27998951077461243 -0.27998951077461243 -5.3726475016446784E-005 0.96000319719314575 62520.dat 1 71 39.993415832519531 -164.32014465332031 50.042732238769531 1 0 0 0 0.25881940126419067 0.96592575311660767 0 -0.96592575311660767 0.25881940126419067 4519.dat 1 19 16.993379592895508 -164.32028198242187 50.042892456054688 0 0 -1.0000001192092896 0.25881919264793396 -0.96592581272125244 0 -0.96592593193054199 -0.25881919264793396 0 6589.dat 1 0 40.008956909179688 -164.32525634765625 0.026755034923553467 -1.003228135232348E-005 -1.0000001192092896 2.2746955437469296E-005 0 -2.2627422367804684E-005 -1.0000001192092896 1.0000001192092896 -1.0151818059966899E-005 0 2780.dat 1 0 80.00909423828125 -164.32682800292969 20.025495529174805 0 -1.5939151126076467E-005 1.0000001192092896 -1.6062786016846076E-005 -1 -1.5939145669108257E-005 1.0000001192092896 -1.6062780559877865E-005 0 2780.dat 1 0 90.008262634277344 -124.32663726806641 30.026037216186523 1 0 0 0 -1 0 0 0 -1 2780.dat 1 71 158.98243713378906 -95.330848693847656 -44.973896026611328 -0.22487938404083252 0 0.97438663244247437 0.97438663244247437 0 0.22487936913967133 0 1 0 32017.dat 1 19 158.98249816894531 -95.330703735351563 -49.97381591796875 0 -0.13910020887851715 -0.99027842283248901 0 0.99027842283248901 -0.13910020887851715 1.0000001192092896 0 0 32556.dat 1 0 158.98249816894531 -95.330787658691406 -69.973739624023438 -0.70819288492202759 0.70601904392242432 0 0.70601904392242432 0.70819300413131714 0 0 0 -1 4254.dat 1 4 81.317779541015625 -173.23432922363281 -69.973739624023438 -0.70819300413131714 0.70601892471313477 0 0.70601892471313477 0.70819300413131714 0 0 0 -1 4255.dat 1 19 81.319252014160156 -173.23291015625 -49.97381591796875 0 0.13910047709941864 0.99027830362319946 0 -0.99027824401855469 0.13910047709941864 1 0 0 32556.dat 1 0 158.9822998046875 -95.330978393554688 -29.973587036132813 -0.70819288492202759 0.70601904392242432 0 0.70601904392242432 0.70819300413131714 0 0 0 -1 4254.dat 1 4 81.31658935546875 -173.23786926269531 -29.973587036132813 -0.70819300413131714 0.70601892471313477 0 0.70601892471313477 0.70819300413131714 0 0 0 -1 4255.dat 1 71 158.98240661621094 -95.330772399902344 -54.973747253417969 -0.22488079965114594 0 0.97438633441925049 0.97438633441925049 0 0.2248808741569519 0 1.0000001192092896 0 32017.dat 1 0 197.95779418945313 -86.33575439453125 -49.973400115966797 0 0 1 0 1 0 -1 0 0 2780.dat 1 71 197.96029663085937 -146.33619689941406 -74.973587036132812 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32123a.dat 1 70 197.96029663085937 -146.33619689941406 -57.973617553710938 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 24316.dat 1 71 197.95780944824219 -106.33573913574219 -34.973434448242187 -1 0 0 0 0 -1 0 -1 0 11478.dat 1 70 197.95780944824219 -66.335739135742188 -57.973426818847656 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 24316.dat 1 71 197.95780944824219 -66.335716247558594 -74.973396301269531 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32123a.dat 1 71 197.95780944824219 -106.33573913574219 -64.973739624023437 -1 0 0 0 0 -1 0 -1 0 11478.dat 1 72 139.49374389648438 -79.82781982421875 -9.9738922119140625 -0.22495877742767334 0 -0.97436827421188354 0.97436827421188354 0 -0.22495874762535095 0 -1 0 60483.dat 1 71 139.49365234375 -79.827568054199219 -49.973892211914063 0 -0.22495855391025543 0.97436845302581787 0 0.97436851263046265 0.22495855391025543 -1.0000001192092896 0 0 32073.dat 1 72 139.49411010742187 -79.827285766601563 -89.97381591796875 -0.22495844960212708 0 -0.9743683934211731 0.9743683934211731 0 -0.22495852410793304 0 -1.0000001192092896 0 60483.dat 1 72 139.49374389648438 -79.827590942382813 -24.973817825317383 -0.224961057305336 0 0.97436779737472534 0.97436779737472534 0 0.22496116161346436 0 1.0000001192092896 0 41677.dat 1 72 139.49374389648438 -79.827537536621094 -44.973896026611328 -0.224961057305336 0 0.97436779737472534 0.97436779737472534 0 0.22496116161346436 0 1.0000001192092896 0 41677.dat 1 72 139.49374389648438 -79.826797485351563 -54.973739624023438 -0.224961057305336 0 0.97436779737472534 0.97436779737472534 0 0.22496116161346436 0 1.0000001192092896 0 41677.dat 1 72 139.49374389648438 -79.827476501464844 -74.97381591796875 -0.224961057305336 0 0.97436779737472534 0.97436779737472534 0 0.22496116161346436 0 1.0000001192092896 0 41677.dat 1 71 158.98136901855469 -75.328269958496094 -49.97381591796875 0 -0.22496291995048523 0.97436732053756714 0 0.97436732053756714 0.22496291995048523 -1 0 0 4519.dat 1 72 120.00685882568359 -84.326950073242187 -49.97381591796875 0 0.22496329247951508 -0.97436720132827759 0 -0.97436720132827759 -0.22496329247951508 -0.99999994039535522 0 0 57515.dat 1 0 217.44346618652344 -71.829948425292969 -49.9735107421875 0 -2.2266522137215361E-005 -1 -1 0 0 0 1 -2.2251471818890423E-005 6628.dat 1 0 217.44346618652344 -81.829933166503906 -49.988082885742187 0 0 -1 0 -1 0 -1 0 0 87082.dat 1 0 217.44346618652344 -81.829925537109375 -29.97381591796875 0 1 0 0 0 1 1 0 0 32013.dat 1 1 217.44346618652344 -111.82990264892578 -29.97381591796875 0 0 1 1 0 0 0 1 0 43093.dat 1 1 217.44326782226562 -111.82991027832031 -69.973587036132812 0 0 1 1 0 0 0 1 0 43093.dat 1 0 217.44326782226562 -81.829925537109375 -69.973587036132812 0 1 0 0 0 1 1 0 0 32013.dat 1 0 197.95779418945313 -126.33575439453125 -49.973590850830078 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 178.47024536132812 -90.833259582519531 -59.973854064941406 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 6628.dat 1 0 140.01533508300781 -175.10699462890625 -108.74940490722656 0.92270404100418091 -0.0078546348959207535 0.38542914390563965 -0.34542533755302429 0.42706900835037231 0.8356395959854126 -0.1711684912443161 -0.90418499708175659 0.39134511351585388 32005.dat 1 4 0.0098526477813720703 -164.32357788085937 -149.97123718261719 0 0 -1 -0.2503800094127655 0.9681476354598999 0 0.9681476354598999 0.2503800094127655 0 26287.dat 1 71 80.008628845214844 -164.32254028320312 -149.97296142578125 -1 0 0 0 0.96814757585525513 0.2503800094127655 0 0.2503800094127655 -0.9681476354598999 44294.dat 1 71 40.008785247802734 -164.32666015625 -149.95768737792969 0 0 1.0000001192092896 -0.25038096308708191 -0.9681473970413208 0 0.96814757585525513 -0.25038096308708191 0 6590.dat 1 71 140.01046752929687 -171.8341064453125 -120.93247222900391 0 0 1 0.2503800094127655 0.9681476354598999 0 -0.9681476354598999 0.2503800094127655 0 2736.dat 1 14 140.01046752929687 -169.33074951171875 -130.60772705078125 -1 0 0 0 -0.96814757585525513 -0.25038033723831177 0 -0.25038033723831177 0.96814757585525513 32039.dat 1 71 -79.993537902832031 -164.32734680175781 -149.95938110351562 1 0 0 0 0.9681476354598999 -0.25038003921508789 0 0.25038003921508789 0.9681476354598999 44294.dat 1 71 -39.990081787109375 -164.32363891601562 -149.97114562988281 0 0 -1 0.25038060545921326 -0.96814751625061035 0 -0.96814751625061035 -0.25038060545921326 0 6590.dat 1 71 -139.99174499511719 -171.83816528320312 -120.91329956054687 0 0 1 0.2503800094127655 0.9681476354598999 0 -0.9681476354598999 0.2503800094127655 0 2736.dat 1 14 -139.99174499511719 -169.33465576171875 -130.59538269042969 -1 0 0 0 -0.96814757585525513 -0.25038033723831177 0 -0.25038033723831177 0.96814757585525513 32039.dat 1 0 -178.52981567382812 -91.012916564941406 -70.731773376464844 0.92270433902740479 -0.007854280062019825 0.38542905449867249 0.34542527794837952 -0.42706966400146484 -0.83563929796218872 0.17116843163967133 0.90418469905853271 -0.39134582877159119 32005.dat 1 0 -178.45401000976562 -90.835037231445313 -59.963172912597656 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 6628.dat 1 71 -158.96615600585937 -95.332542419433594 -44.962982177734375 0.2248808741569519 0 -0.97438633441925049 0.97438633441925049 0 0.22488082945346832 0 -1 0 32017.dat 1 72 -119.99071502685547 -104.32794952392578 -74.963134765625 -1 1.2392960343277082E-005 1.2516594324551988E-005 1.251659523404669E-005 0 1 1.239295943378238E-005 1 0 41677.dat 1 71 -119.99066162109375 -104.32766723632812 -49.963291168212891 0 1.2506396160461009E-005 -1 0 0.99999994039535522 1.2506396160461009E-005 1 0 0 4519.dat 1 71 -119.99071502685547 -104.32781982421875 -64.963058471679687 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 72 -119.99071502685547 -104.32781982421875 -24.963136672973633 -1 1.2392960343277082E-005 1.2516594324551988E-005 1.251659523404669E-005 0 1 1.239295943378238E-005 1 0 41677.dat 1 72 -119.99185943603516 -84.325202941894531 -39.964588165283203 0 0 1 0 0.99999994039535522 0 -1 0 0 55013.dat 1 72 -89.991867065429687 -84.331428527832031 -44.974235534667969 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32449.dat 1 72 -89.991676330566406 -84.331596374511719 -54.974079132080078 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32449.dat 1 71 -59.991336822509766 -84.33038330078125 -49.974163055419922 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 4519.dat 1 72 -59.991134643554688 -84.328880310058594 -29.974922180175781 0 0 1 0 0.99999994039535522 0 -1 0 0 6536.dat 1 72 -59.991134643554688 -84.328880310058594 -69.975074768066406 0 0 1 0 0.99999994039535522 0 -1 0 0 6536.dat 1 71 -119.99066925048828 -104.32771301269531 -34.963138580322266 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 72 -139.47755432128906 -79.828681945800781 -89.962837219238281 0.2249586284160614 0 0.9743683934211731 0.9743683934211731 0 -0.22495858371257782 0 1 0 60483.dat 1 71 -139.47735595703125 -79.828399658203125 -49.96282958984375 0 0.22495865821838379 -0.97436827421188354 0 0.97436821460723877 0.22495865821838379 1 0 0 32073.dat 1 72 -139.47734069824219 -79.828559875488281 -44.962982177734375 0.2249612957239151 0 -0.97436779737472534 0.97436779737472534 0 0.22496119141578674 0 -1.0000001192092896 0 41677.dat 1 72 -139.47740173339844 -79.828445434570313 -9.9629077911376953 0.2249586284160614 0 0.9743683934211731 0.9743683934211731 0 -0.22495858371257782 0 1 0 60483.dat 1 72 -139.47734069824219 -79.828483581542969 -54.962833404541016 0.2249612957239151 0 -0.97436779737472534 0.97436779737472534 0 0.22496119141578674 0 -1.0000001192092896 0 41677.dat 1 72 -139.47735595703125 -79.828414916992188 -24.962905883789063 0.2249612957239151 0 -0.97436779737472534 0.97436779737472534 0 0.22496119141578674 0 -1.0000001192092896 0 41677.dat 1 72 -139.4775390625 -79.828544616699219 -74.962905883789062 0.22496096789836884 0 -0.97436785697937012 0.97436785697937012 0 0.22496084868907928 0 -1.0000001192092896 0 41677.dat 1 71 -158.96467590332031 -75.3291015625 -49.962909698486328 0 0.22496303915977478 -0.97436732053756714 0 0.97436726093292236 0.22496303915977478 1 0 0 4519.dat 1 72 -119.98979949951172 -84.327987670898437 -49.962909698486328 0 -0.22496286034584045 0.97436749935150146 0 -0.97436738014221191 -0.22496286034584045 1.0000001192092896 0 0 57515.dat 1 70 -197.9390869140625 -146.33796691894531 -57.963890075683594 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 24316.dat 1 71 -197.94155883789062 -106.33750915527344 -34.963367462158203 0.99999994039535522 0 0 0 0 -1 0 1 0 11478.dat 1 71 -197.94155883789062 -106.33750915527344 -64.963676452636719 0.99999994039535522 0 0 0 0 -1 0 1 0 11478.dat 1 70 -197.94155883789062 -66.337516784667969 -57.963699340820313 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 24316.dat 1 71 -197.94155883789062 -66.337493896484375 -74.963668823242187 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32123a.dat 1 71 -197.93927001953125 -146.33796691894531 -74.963859558105469 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32123a.dat 1 0 -197.94155883789062 -86.337532043457031 -49.963325500488281 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 71 -158.9661865234375 -95.332626342773437 -54.963207244873047 0.22487939894199371 0 -0.97438669204711914 0.97438669204711914 0 0.22487932443618774 0 -1.0000001192092896 0 32017.dat 1 19 -158.96604919433594 -95.332740783691406 -49.963100433349609 0 0.13910016417503357 0.99027842283248901 0 0.99027842283248901 -0.13910016417503357 -1.0000001192092896 0 0 32556.dat 1 0 -158.96604919433594 -95.332740783691406 -69.963134765625 0.70819294452667236 -0.70601892471313477 0 0.70601892471313477 0.70819294452667236 0 0 0 1 4254.dat 1 4 -81.302932739257812 -173.23550415039062 -69.963134765625 0.70819306373596191 -0.70601880550384521 0 0.70601880550384521 0.70819306373596191 0 0 0 1 4255.dat 1 19 -81.303016662597656 -173.23472595214844 -49.963291168212891 0 0.13910016417503357 0.99027842283248901 0 0.99027842283248901 -0.13910016417503357 -1.0000001192092896 0 0 32556.dat 1 0 -158.96604919433594 -95.332550048828125 -29.96336555480957 0.70819294452667236 -0.70601892471313477 0 0.70601892471313477 0.70819294452667236 0 0 0 1 4254.dat 1 4 -81.300674438476562 -173.23481750488281 -29.96336555480957 0.70819306373596191 -0.70601880550384521 0 0.70601880550384521 0.70819306373596191 0 0 0 1 4255.dat 1 0 -197.94155883789062 -126.3375244140625 -49.963516235351563 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 -217.42706298828125 -71.831718444824219 -49.963211059570313 0 2.227835102530662E-005 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 2.234257772215642E-005 6628.dat 1 0 -217.42706298828125 -81.831718444824219 -49.948642730712891 0 0 1 0 -1 0 1 0 0 87082.dat 1 0 -217.42706298828125 -81.831695556640625 -29.963134765625 0 -1 0 0 0 1 -1 0 0 32013.dat 1 1 -217.42706298828125 -111.83168029785156 -29.963134765625 0 0 -1 1 0 0 0 -1 0 43093.dat 1 4 -217.42694091796875 -121.83174133300781 -9.963282585144043 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 41678.dat 1 0 -217.42684936523437 -101.83173370361328 -9.9634408950805664 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 3705.dat 1 0 -217.42706298828125 -116.83173370361328 -49.962989807128906 1 0 0 0 1 0 0 0 1 11478.dat 1 0 -217.4268798828125 -126.83174896240234 -49.963371276855469 1 0 0 0 1 0 0 0 1 11478.dat 1 4 -217.42694091796875 -81.831741333007813 -9.963282585144043 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 41678.dat 1 0 -217.4268798828125 -81.831748962402344 -9.96343994140625 0 0 1 0 0.99999994039535522 0 -1 0 0 60483.dat 1 0 -217.42706298828125 -131.83177185058594 -49.963211059570313 0 2.236976069980301E-005 -1 1 0 0 0 -1 -2.2354708562488668E-005 6628.dat 1 0 -197.43038940429687 -91.862922668457031 -9.9645862579345703 0 -1 0 1 0 0 0 0 0.99999994039535522 6628.dat 1 0 -100.13444519042969 -124.96842193603516 -9.9633827209472656 0 0.22496536374092102 -0.97436678409576416 -1.0509205822017975E-005 0.97436678409576416 0.22496536374092102 1 1.0529506653256249E-005 0 32005.dat 1 0 -99.992073059082031 -114.32992553710937 -9.9600067138671875 -1.4701277905260213E-005 1 0 1 1.4801516954321414E-005 0 0 0 -1 6628.dat 1 0 -217.42706298828125 -81.831680297851562 -69.963287353515625 0 -1 0 0 0 1 -1 0 0 32013.dat 1 1 -217.42706298828125 -111.8316650390625 -69.963287353515625 0 0 -1 1 0 0 0 -1 0 43093.dat 1 1 -59.992515563964844 -64.328292846679687 -29.974960327148438 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 -79.992591857910156 -64.328292846679687 90.025222778320313 0 -1 1.1663751138257794E-005 1 0 -2.4232953364844434E-005 2.4232953364844434E-005 1.1663751138257794E-005 0.99999994039535522 41239.dat 1 1 -59.992515563964844 -64.328292846679687 150.02496337890625 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 -59.913551330566406 -64.625137329101563 69.998146057128906 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 -39.992469787597656 -64.328292846679687 -29.974973678588867 0 -1 0 -1 0 0 0 0 -1 32525.dat 1 1 -59.992481231689453 -64.328880310058594 -69.975112915039063 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 -79.992500305175781 -64.328300476074219 -49.974941253662109 0 -1 0 -1 0 0 0 0 -1 6629.dat 1 0 -89.992485046386719 -64.328628540039063 -149.97496032714844 -1 0 0 0 -1 0 0 0 1 2780.dat 1 72 -99.992546081542969 -64.329193115234375 -149.97535705566406 0 1.0000001192092896 0 0.60002368688583374 0 -0.79998236894607544 -0.79998236894607544 0 -0.60002356767654419 60484.dat 1 0 -89.9925537109375 -96.328147888183594 -173.97627258300781 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 -79.9925537109375 -84.328018188476562 -189.9759521484375 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 -79.992546081542969 -84.328018188476562 -189.9759521484375 0 -1 0 -1 0 0 0 0 -1 18654.dat 1 72 40.004913330078125 -84.328132629394531 -209.97734069824219 0 1 0 -1 0 0 0 0 0.99999994039535522 32140.dat 1 71 0.0073671340942382813 -84.315101623535156 -209.97377014160156 1 0 0 0 1 0 0 0 1 60485.dat 1 72 -39.992626190185547 -84.327690124511719 -209.97540283203125 0 1 0 -1 0 0 0 0 0.99999994039535522 32140.dat 1 0 -79.997299194335938 -84.315040588378906 -209.97726440429687 0.99999994039535522 -0.00017503261915408075 0 0 0 1 -0.00017503261915408075 -1 0 63869.dat 1 0 80.002540588378906 -84.315025329589844 -209.97738647460937 0.99999994039535522 -0.00017503261915408075 0 0 0 1 -0.00017503261915408075 -1 0 63869.dat 1 72 40.004913330078125 -104.32813262939453 -149.97732543945312 -1 0 0 0 0 1 0 1 0 11214.dat 1 72 25.004920959472656 -84.328117370605469 -149.97732543945312 0 -1 0 0 0 -1 1 0 0 41677.dat 1 71 0.0050127506256103516 -84.327461242675781 -149.97807312011719 1 0 0 0 1 0 0 0 1 44294.dat 1 71 15.005008697509766 -84.327461242675781 -149.97804260253906 0 0 -1 0 0.99999994039535522 0 1 0 0 32123a.dat 1 72 -24.992599487304688 -84.327682495117188 -149.97538757324219 0 -1 0 0 0 -1 1 0 0 41677.dat 1 72 -39.992595672607422 -104.32769012451172 -149.97538757324219 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 71 -14.994992256164551 -84.327461242675781 -149.97804260253906 0 0 -1 0 0.99999994039535522 0 1 0 0 32123a.dat 1 0 0.0053891534917056561 -84.315727233886719 -149.96513366699219 0.99999994039535522 -0.00017504452262073755 0 0 0 1 -0.00017504452262073755 -1 0 63869.dat 1 72 60.004966735839844 -164.32745361328125 -149.9774169921875 0 -1 0 0 0 1 -1 0 0 32526.dat 1 72 -59.992713928222656 -164.32801818847656 -149.97561645507812 0 -1 0 0 0 1 -1 0 0 32526.dat 1 71 0.0080406665802001953 -124.32699584960937 -149.9747314453125 1 0 0 0 1 0 0 0 1 44294.dat 1 71 -19.991973876953125 -124.32699584960937 -149.97470092773437 0 0 1 -1 0 0 0 -1 0 6590.dat 1 0 0.005349266342818737 -124.31573486328125 -149.96498107910156 0.99999994039535522 -0.0001750016090227291 0 0 0 1 -0.0001750016090227291 -1 0 63869.dat 1 71 20.008035659790039 -124.32699584960937 -149.97470092773437 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6590.dat 1 1 157.60009765625 -94.315048217773438 -213.17408752441406 0 0.27999690175056458 0.96000099182128906 -1.0000001192092896 0 0 0 -0.96000099182128906 0.27999696135520935 43093.dat 1 4 19.999368667602539 -104.31504058837891 -169.97251892089844 0.60000145435333252 0 0.799998939037323 0 -1 0 0.799998939037323 0 -0.60000145435333252 6629.dat 1 0 20.001726150512695 -104.31575775146484 -169.96751403808594 0 -0.60000109672546387 0.79999929666519165 -1.0000001192092896 0 0 0 -0.79999929666519165 -0.60000103712081909 18651.dat 1 0 176.79873657226562 -84.315032958984375 -207.57252502441406 -0.27992880344390869 0 -0.96002078056335449 0 1 0 0.96002078056335449 0 -0.27992880344390869 32524.dat 1 1 -157.60179138183594 -94.315055847167969 -213.1734619140625 0 -0.28000053763389587 0.95999997854232788 -1.0000001192092896 0 0 0 -0.95999997854232788 -0.28000041842460632 43093.dat 1 4 -20.000150680541992 -104.31505584716797 -169.97364807128906 -0.60000044107437134 0 -0.7999996542930603 0 0.99999994039535522 0 0.7999996542930603 0 -0.60000044107437134 6629.dat 1 0 -20.001848220825195 -104.3150634765625 -169.97343444824219 0 -0.80000364780426025 0.59999531507492065 -1.0000001192092896 0 0 0 -0.59999531507492065 -0.8000035285949707 18651.dat 1 0 -176.8006591796875 -84.315055847167969 -207.56942749023437 -0.27993112802505493 0 -0.96002018451690674 0 -1 0 -0.96002018451690674 0 0.27993136644363403 32524.dat 1 1 -100.00070190429687 -104.31505584716797 -229.97378540039062 0 -0.0020426267292350531 0.99999803304672241 -1.0000001192092896 0 0 0 -0.99999803304672241 -0.0020424909889698029 6558.dat 1 1 -119.20064544677734 -104.31505584716797 -224.37362670898437 0 -0.0020426267292350531 0.99999803304672241 -1.0000001192092896 0 0 0 -0.99999803304672241 -0.0020424909889698029 6558.dat 1 1 99.998970031738281 -104.31503295898437 -229.98088073730469 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 1 138.39924621582031 -104.31503295898437 -218.77406311035156 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 50.004936218261719 -84.327461242675781 -169.97817993164062 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 -49.9925537109375 -84.327682495117188 -169.97607421875 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 -176.8018798828125 -124.31503295898437 -207.5777587890625 -0.27992954850196838 0 -0.96002066135406494 0 -1 0 -0.96002066135406494 0 0.27992984652519226 32524.dat 1 0 -176.80191040039063 -104.31505584716797 -207.57768249511719 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 87082.dat 1 47 -176.8018798828125 -104.31505584716797 -217.57774353027344 0.99999994039535522 0 0 0 0 1 0 -1 0 6141.dat 1 1 -196.0023193359375 -104.31503295898437 -201.97906494140625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 -215.20274353027344 -104.31504058837891 -196.38043212890625 -0.27977889776229858 0 -0.96006453037261963 0 -1 0 -0.96006453037261963 0 0.27977916598320007 32523.dat 1 1 -234.40310668945312 -104.31503295898437 -190.781982421875 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 1 -138.40106201171875 -104.31503295898437 -218.77479553222656 0 -0.0020426267292350531 0.99999803304672241 -1.0000001192092896 0 0 0 -0.99999803304672241 -0.0020424909889698029 6558.dat 1 0 176.80043029785156 -124.31503295898437 -207.57844543457031 -0.27992960810661316 0 -0.96002054214477539 0 1 0 0.96002054214477539 0 -0.27992960810661316 32524.dat 1 1 195.99916076660156 -104.31503295898437 -201.97393798828125 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 215.20045471191406 -104.31503295898437 -196.37837219238281 -0.27977854013442993 0 -0.9600645899772644 0 0.99999994039535522 0 0.9600645899772644 0 -0.27977854013442993 32523.dat 1 1 234.40058898925781 -104.31504058837891 -190.77969360351562 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 1 119.19920349121094 -104.31503295898437 -224.37403869628906 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 47 176.80046081542969 -104.31503295898437 -217.57847595214844 0.99999994039535522 0 0 0 0 1 0 -1 0 6141.dat 1 0 176.80046081542969 -104.31501770019531 -207.5784912109375 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 87082.dat 1 1 59.998912811279297 -104.31503295898437 -229.97381591796875 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 80.002914428710938 -124.31502532958984 -209.977294921875 0.99999994039535522 -0.00017502246191725135 0 0 0 1 -0.00017502246191725135 -1 0 63869.dat 1 71 0.0027537345886230469 -124.31504821777344 -210.00706481933594 1 0 0 0 1 0 0 0 1 60485.dat 1 0 -79.997215270996094 -124.31504821777344 -209.97734069824219 0.99999994039535522 -0.00017502246191725135 0 0 0 1 -0.00017502246191725135 -1 0 63869.dat 1 0 -59.992027282714844 -124.32928466796875 -209.974853515625 0 -1 0 1 0 0 0 0 0.99999994039535522 33299a.dat 1 0 60.005603790283203 -124.32805633544922 -209.97886657714844 0 1 0 -1 0 0 0 0 0.99999994039535522 33299a.dat 1 1 -60.000980377197266 -104.31505584716797 -229.97378540039062 0 -0.0020426267292350531 0.99999803304672241 -1.0000001192092896 0 0 0 -0.99999803304672241 -0.0020424909889698029 6558.dat 1 4 -0.0010788440704345703 -104.31504058837891 -229.97378540039062 0 0 -1 0 -1 0 -1 0 0 32524.dat 1 1 -0.0010327792260795832 -104.31503295898437 -229.97378540039062 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 -0.001099705696105957 -84.315032958984375 -229.97378540039062 0 0 -1 0 -1 0 -1 0 0 32316.dat 1 1 39.998931884765625 -104.31503295898437 -229.97381591796875 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 -0.001099705696105957 -124.31503295898437 -229.97378540039062 0 0 -1 0 -1 0 -1 0 0 32316.dat 1 1 -40.001094818115234 -104.31503295898437 -229.97378540039062 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 1 80.004928588867188 -84.327125549316406 -189.9781494140625 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 80.004920959472656 -84.327125549316406 -189.9781494140625 0 -1 0 -1 0 0 0 0 -1 18654.dat 1 72 100.00494384765625 -64.333511352539063 -149.96983337402344 0 1.0000001192092896 0 0.60002368688583374 0 -0.79998236894607544 -0.79998236894607544 0 -0.60002356767654419 60484.dat 1 0 90.085006713867188 -96.623306274414063 -174.00201416015625 -1 0 0 0 -1 0 0 0 1 2780.dat 1 72 80.085006713867187 -64.623641967773438 -50.002025604248047 0 -1 0 -1 0 0 0 0 -1 6629.dat 1 1 60.0057373046875 -64.326774597167969 -89.974807739257813 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 90.085006713867188 -64.623306274414063 -150.00204467773437 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 -59.992481231689453 -64.328292846679687 -129.97496032714844 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 -59.992481231689453 -64.328292846679687 -89.974998474121094 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 -59.992897033691406 -64.328277587890625 30.025459289550781 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 -69.992515563964844 -64.327995300292969 210.02499389648437 -1 0 0 0 -1 0 0 0 1 2780.dat 1 72 -59.992557525634766 -64.328285217285156 310.02484130859375 0 -1 0 -1 0 0 0 0 -1 32278.dat 1 0 -49.992542266845703 -64.328292846679687 190.02491760253906 1 0 0 0 -1 0 0 0 -1 2780.dat 1 1 -79.983207702636719 -64.625274658203125 349.9996337890625 -1 0 0 0 -1 0 0 0 1 6558.dat 1 71 -119.98273468017578 -83.122909545898438 357.65988159179687 1 1.4929401004337706E-005 4.2763233068399131E-005 3.4073873393936083E-005 0.37407392263412476 -0.92739886045455933 -2.9842118237866089E-005 0.92739886045455933 0.37407392263412476 32073.dat 1 72 -159.98143005371094 -83.123176574707031 357.65908813476562 -2.6544115826254711E-005 -1 -1.0601190297165886E-005 -0.37407374382019043 0 0.92739903926849365 -0.92739903926849365 2.8618254873435944E-005 -0.37407371401786804 60483.dat 1 72 -79.982757568359375 -83.12103271484375 357.65866088867187 -2.6497496946831234E-005 -1.0000001192092896 -1.0620411558193155E-005 -0.37407416105270386 0 0.9273989200592041 -0.9273989200592041 2.8637472496484406E-005 -0.37407407164573669 60483.dat 1 72 -94.990707397460938 -106.65808868408203 342.45443725585938 1.3965327525511384E-005 -1.0000001192092896 -1.3299891179485712E-005 -0.97661060094833374 -1.0599535926303361E-005 -0.21501608192920685 0.21501608192920685 1.5972062101354823E-005 -0.97661048173904419 6632.dat 1 71 -119.99213409423828 -115.25963592529297 303.3909912109375 1 0 2.8273601856199093E-005 0 0.97660559415817261 0.21503840386867523 -2.8280946935410611E-005 -0.21503840386867523 0.97660559415817261 32073.dat 1 72 -79.992088317871094 -115.25972747802734 303.38986206054687 0 0.99999994039535522 -1.3089153981127311E-005 0.97660243511199951 0 -0.21505266427993774 -0.21505266427993774 -1.4343653674586676E-005 -0.97660243511199951 32140.dat 1 71 -119.99045562744141 -106.656982421875 342.45590209960937 1 0 2.889392817451153E-005 0 0.9766080379486084 0.21502730250358582 -2.8901271434733644E-005 -0.21502730250358582 0.9766080379486084 4519.dat 1 71 -119.98439025878906 -106.95524597167969 342.427734375 -1 0 0 0 0.97660791873931885 -0.21502760052680969 0 -0.21502760052680969 -0.97660797834396362 63869.dat 1 72 -144.98966979980469 -106.65701293945312 342.45651245117187 1.3965327525511384E-005 -1.0000001192092896 -1.3299891179485712E-005 -0.97661060094833374 -1.0599535926303361E-005 -0.21501608192920685 0.21501608192920685 1.5972062101354823E-005 -0.97661048173904419 6632.dat 1 72 -134.99058532714844 -106.65666961669922 342.45651245117187 0 -1 2.8296939490246587E-005 0.9766082763671875 0 0.21502628922462463 -0.21502628922462463 2.8338503398117609E-005 0.97660833597183228 41677.dat 1 72 -159.99142456054687 -115.25919342041016 303.392578125 -1.3153332474757917E-005 1.0000001192092896 -1.2793314454029314E-005 0.97660386562347412 1.024173525365768E-005 -0.21504676342010498 -0.21504676342010498 -1.5338606317527592E-005 -0.97660374641418457 32140.dat 1 72 -104.99030303955078 -106.65679931640625 342.4554443359375 0 -1 2.8296939490246587E-005 0.9766082763671875 0 0.21502628922462463 -0.21502628922462463 2.8338503398117609E-005 0.97660833597183228 41677.dat 1 4 -119.99008941650391 -102.35633850097656 361.98855590820312 -1 0 0 0 0.97660839557647705 -0.21502579748630524 0 -0.21502579748630524 -0.97660839557647705 32062.dat 1 71 -119.98146820068359 -102.65531921386719 361.95999145507812 -3.0791186873102561E-005 -1.0000001192092896 0 -0.21502743661403656 0 0.97660815715789795 -0.97660815715789795 3.0608163797296584E-005 -0.21502730250358582 60483.dat 1 0 -139.98388671875 -83.122024536132813 357.66018676757812 -2.6692454412113875E-005 1.0000001192092896 0 -0.21502973139286041 0 -0.9766075611114502 -0.9766075611114502 -2.6570600311970338E-005 0.21502973139286041 15100.dat 1 0 -99.983917236328125 -83.122611999511719 357.65884399414063 -2.6710908059612848E-005 1 0 -0.21502885222434998 0 -0.97660768032073975 -0.97660768032073975 -2.6600004275678657E-005 0.21502886712551117 15100.dat 1 71 -119.99429321289063 -132.46295166015625 225.26296997070313 -3.0019798941793852E-005 0 1.0000001192092896 -0.21504020690917969 0.97660535573959351 0 -0.97660529613494873 -0.21504020690917969 -3.0108956707408652E-005 59443.dat 1 1 -89.994354248046875 -132.46308898925781 225.26286315917969 -1 0 0 0 0.21503554284572601 0.97660642862319946 0 0.97660642862319946 -0.21503520011901855 43093.dat 1 72 -94.993461608886719 -126.01202392578125 254.56059265136719 0 -1 3.0582334147766232E-005 0.97660613059997559 0 0.2150363028049469 -0.2150363028049469 3.0567844078177586E-005 0.97660619020462036 32449.dat 1 1 -149.9935302734375 -132.46102905273437 225.25669860839844 1 0 0 0 -0.2150353342294693 0.97660624980926514 0 -0.97660624980926514 -0.2150353342294693 43093.dat 1 72 -144.99258422851562 -126.00997924804687 254.55538940429688 0 -1 3.0589784728363156E-005 0.97660613059997559 0 0.2150363028049469 -0.2150363028049469 3.057529465877451E-005 0.97660619020462036 32449.dat 1 72 -119.99607086181641 -97.878250122070313 289.32412719726562 -1 0 3.0813527700956911E-005 0 -0.97660636901855469 0.21503497660160065 3.0794621125096455E-005 0.21503497660160065 0.97660624980926514 61904.dat 1 71 -119.991943359375 -119.56081390380859 283.85940551757812 1 0 2.8231192118255422E-005 0 0.97660559415817261 0.21503840386867523 -2.8238535378477536E-005 -0.21503840386867523 0.97660559415817261 4519.dat 1 71 -119.99246215820312 -119.56041717529297 283.85955810546875 -0.00051578076090663671 9.83885329333134E-005 -0.99999988079071045 -0.21499617397785187 -0.97661489248275757 1.4813615962339099E-005 -0.97661477327346802 0.21499615907669067 0.00052496825810521841 6590.dat 1 0 -179.99574279785156 -108.62808227539062 240.49554443359375 -3.6656234442489222E-005 -6.8386521888896823E-005 1 -0.88148146867752075 0.47221863269805908 0 -0.47221860289573669 -0.88148146867752075 -7.7585937106050551E-005 32270.dat 1 0 -129.99502563476562 -108.62863922119141 240.49446105957031 1 1.6634414350846782E-005 2.4585171559010632E-005 0 0.88148128986358643 -0.47221896052360535 -2.9526454454753548E-005 0.47221896052360535 0.88148128986358643 3706.dat 1 19 -102.99318695068359 -108.62079620361328 240.50343322753906 -8.6047271906863898E-005 0.00012228978448547423 -1 0.47221845388412476 -0.88148152828216553 -0.00014844629913568497 -0.8814815878868103 -0.47221848368644714 1.8169337636209093E-005 6589.dat 1 71 -119.994140625 -108.62839508056641 240.49436950683594 0 0 -1.0000001192092896 0.47222709655761719 -0.88147687911987305 0 -0.8814769983291626 -0.47222709655761719 0 6590.dat 1 71 -134.99246215820313 -108.62928771972656 240.49859619140625 6.9906345743220299E-005 4.0416791307507083E-005 -1 -0.47222134470939636 0.88148015737533569 0 0.88148009777069092 0.47222134470939636 8.0717829405330122E-005 32123a.dat 1 72 -79.994491577148437 -132.46295166015625 225.26287841796875 0 1 0 1 0 0 0 0 -1 18654.dat 1 71 -119.99164581298828 -93.574920654296875 308.85748291015625 -0.98759365081787109 0.15703120827674866 3.090159225394018E-005 -0.15335114300251007 -0.96449136734008789 0.21503441035747528 0.033796913921833038 0.21236187219619751 0.97660678625106812 4716.dat 1 71 -119.99200439453125 -95.725944519042969 299.09140014648437 -2.8909278626088053E-005 -0.15703091025352478 0.98759377002716064 -0.21503481268882751 0.96449136734008789 0.15335124731063843 -0.97660642862319946 -0.21236258745193481 -0.033794991672039032 32073.dat 1 0 -119.99336242675781 -104.32806396484375 260.02703857421875 0.15703310072422028 -0.98759341239929199 -3.0127637728583068E-005 -0.96449100971221924 -0.15335303544998169 -0.21503503620624542 0.21236255764961243 0.033796664327383041 -0.97660636901855469 32270.dat 1 72 -89.993385314941406 -104.3280029296875 260.02566528320312 -1 -3.1482908525504172E-005 3.2771127735031769E-005 -3.1356586987385526E-005 -0.043925672769546509 -0.9990348219871521 3.2892017770791426E-005 -0.9990348219871521 0.043925758451223373 32002.dat 1 72 -79.992469787597656 -84.329010009765625 260.02517700195312 0 -4.8523430450586602E-005 1 -4.8647063522366807E-005 -1 -4.8523423174628988E-005 1 -4.8647059884388E-005 0 6536.dat 1 71 -79.993438720703125 -84.327659606933594 250.02658081054687 0 0 1 0 1 0 -1 0 0 4519.dat 1 72 -79.992446899414063 -84.327827453613281 260.025146484375 0 -1.0000001192092896 0 -2.0623736418201588E-005 0 -1.0000001192092896 1.0000001192092896 0 -2.052369927696418E-005 41678.dat 1 72 -79.993423461914063 -84.327163696289063 230.02655029296875 0 0 -1 4.8587124183541164E-005 0.99999994039535522 0 1 -4.8587124183541164E-005 0 6536.dat 1 1 -79.992393493652344 -64.328292846679687 230.02488708496094 1 0 0 0 1 0 0 0 1 6558.dat 1 1 -79.992584228515625 -64.3280029296875 270.02560424804687 1 0 0 0 1 0 0 0 1 6558.dat 1 72 -89.993194580078125 -128.16127014160156 244.79464721679687 -1 0 0 0 0.005997661966830492 -0.99998205900192261 0 -0.99998205900192261 -0.0059976144693791866 32002.dat 1 72 -149.99244689941406 -128.16091918945312 244.79629516601562 1 3.0545474146492779E-005 0 0 -0.0059974268078804016 -0.99998199939727783 -3.0545317713404074E-005 0.99998199939727783 -0.0059974268078804016 32002.dat 1 1 -69.996223449707031 -119.55968475341797 283.85842895507812 1 0 -1.8915119653684087E-005 1.9800212612608448E-005 0.11264796555042267 0.99363493919372559 0 -0.99363493919372559 0.11264796555042267 43093.dat 1 72 -59.993354797363281 -227.5645751953125 384.33197021484375 -1.0889516488532536E-005 -1.0000001192092896 -2.7944588509853929E-005 -0.50605928897857666 -1.8422642824589275E-005 0.86249887943267822 -0.86249887943267822 2.3630473151570186E-005 -0.50605916976928711 32271.dat 1 70 -79.993728637695312 -227.56440734863281 384.33132934570312 -1 0 1.4934095815988258E-005 0 -0.86249607801437378 0.50606381893157959 1.4888250007061288E-005 0.50606381893157959 0.86249637603759766 24316.dat 1 72 -99.989280700683594 -266.08547973632812 395.11068725585938 -3.0140698072500527E-005 -1 0 -0.26946467161178589 0 0.96301031112670898 -0.96301031112670898 2.9660912332474254E-005 -0.26946467161178589 32316.dat 1 71 -119.98814392089844 -304.580322265625 405.98443603515625 1 -0.00019838986918330193 0 -5.533625153475441E-005 -0.27441903948783875 0.96161019802093506 -0.00019051851995754987 -0.96161019802093506 -0.27441903948783875 63869.dat 1 0 -119.98844146728516 -304.5806884765625 405.97821044921875 1 0 0 0 0.9616093635559082 0.27442201972007751 0 -0.27442201972007751 0.9616093635559082 18651.dat 1 1 -139.99177551269531 -290.83413696289062 381.26739501953125 0 -1.0000001192092896 0 -0.96161049604415894 0 -0.27441826462745667 0.27441826462745667 0 -0.96161043643951416 6558.dat 1 71 -119.98859405517578 -285.31890869140625 400.59490966796875 1 -0.00019838892330881208 0 -5.5337080993922427E-005 -0.27441880106925964 0.96161025762557983 -0.00019051728304475546 -0.96161025762557983 -0.27441880106925964 63869.dat 1 0 -119.98851013183594 -285.31729125976562 400.60061645507812 -1 0 0 0 0.96161013841629028 -0.27441936731338501 0 -0.27441936731338501 -0.96161013841629028 18651.dat 1 1 -99.991783142089844 -290.83633422851563 381.25967407226562 0 -1.0000001192092896 0 -0.96161049604415894 0 -0.27441826462745667 0.27441826462745667 0 -0.96161043643951416 6558.dat 1 71 -119.99177551269531 -271.6041259765625 375.77130126953125 0 0 -1.0000001192092896 -0.27441748976707458 -0.96161067485809326 0 -0.96161073446273804 0.27441748976707458 0 32523.dat 1 72 -139.98922729492188 -266.08554077148437 395.11181640625 -3.0140698072500527E-005 -1.0000001192092896 0 -0.26946470141410828 0 0.96301037073135376 -0.96301037073135376 2.9737329896306619E-005 -0.26946461200714111 32316.dat 1 0 -149.98899841308594 -266.08547973632812 395.11209106445312 -1 0 0 0 0.96592098474502563 -0.25883764028549194 0 -0.25883764028549194 -0.96592086553573608 2780.dat 1 72 -159.99006652832031 -208.30531311035156 378.94320678710937 -2.9112356060068123E-005 -1.0000001192092896 0 -0.26939079165458679 0 0.9630311131477356 -0.9630311131477356 2.8757314794347622E-005 -0.26939067244529724 32524.dat 1 0 -149.99014282226562 -150.52342224121094 362.77947998046875 -1 0 0 0 0.96592098474502563 -0.25883764028549194 0 -0.25883764028549194 -0.96592086553573608 2780.dat 1 72 -139.989990234375 -169.78456115722656 368.16519165039062 -3.0140698072500527E-005 -1.0000001192092896 0 -0.26946470141410828 0 0.96301037073135376 -0.96301037073135376 2.9737329896306619E-005 -0.26946461200714111 32316.dat 1 1 -119.99003601074219 -189.04478454589844 373.55374145507812 -1 0 3.5049513826379552E-005 0 -0.98793977499008179 -0.15483878552913666 3.5063090763287619E-005 -0.15483878552913666 0.98793995380401611 6558.dat 1 4 -119.9901123046875 -217.93489074707031 381.6390380859375 0 2.050424154731445E-005 -1 -0.96300840377807617 0.26947137713432312 0 0.26947131752967834 0.96300840377807617 2.0839661374338903E-005 32062.dat 1 71 -119.98976135253906 -246.82510375976562 389.72265625 -1 -1.8789767636917531E-005 2.4624163415865041E-005 -1.865046942839399E-005 -0.26945206522941589 -0.96301376819610596 2.4729835786274634E-005 -0.96301376819610596 0.26945191621780396 32013.dat 1 71 -119.99024963378906 -189.04437255859375 373.55487060546875 1 0 0 0 0.26947259902954102 -0.96300804615020752 0 0.96300804615020752 0.26947259902954102 32034.dat 1 4 -119.99008941650391 -160.15376281738281 365.47061157226562 0 2.050424154731445E-005 -1 -0.96300840377807617 0.26947137713432312 0 0.26947131752967834 0.96300840377807617 2.0839661374338903E-005 32062.dat 1 71 -119.99009704589844 -131.26348876953125 357.386474609375 -1 0 0 0 0.26947355270385742 0.96300768852233887 0 0.96300768852233887 -0.26947367191314697 32013.dat 1 1 -119.98908233642578 -246.8253173828125 389.72207641601562 -1 0 0 0 0.99829041957855225 -0.058448038995265961 0 -0.058448038995265961 -0.99829047918319702 6558.dat 1 72 -74.989295959472656 -131.26361083984375 357.38644409179687 0 -1 -2.6232639356749132E-005 -0.86156582832336426 -1.2833444088755641E-005 0.50764584541320801 -0.50764584541320801 2.2877004084875807E-005 -0.86156582832336426 6632.dat 1 71 -119.99024963378906 -110.95762634277344 322.92556762695312 1 1.7830114302341826E-005 2.6050602173199877E-005 0 0.86156618595123291 -0.50764524936676025 -3.1495692383032292E-005 0.50764524936676025 0.86156618595123291 32073.dat 1 72 -84.989143371582031 -131.26361083984375 357.38693237304687 0 -1.0000001192092896 -2.6233348762616515E-005 -0.86156612634658813 -1.2735376913042273E-005 0.50764560699462891 -0.50764560699462891 2.2877715309732594E-005 -0.86156600713729858 6632.dat 1 71 -104.99078369140625 -110.95695495605469 322.92376708984375 2.6820071070687845E-005 1.7781885617296211E-005 -1.0000001192092896 -0.50764656066894531 0.86156553030014038 0 0.86156553030014038 0.50764656066894531 3.2138559618033469E-005 32123a.dat 1 72 -164.98934936523437 -131.2635498046875 357.389404296875 0 -1 -2.6232639356749132E-005 -0.86156582832336426 -1.2833444088755641E-005 0.50764584541320801 -0.50764584541320801 2.2877004084875807E-005 -0.86156582832336426 6632.dat 1 72 -119.99069213867187 -110.95767211914062 322.92538452148437 2.5128740162472241E-005 0 -1 -0.50763893127441406 0.86156994104385376 0 0.86156988143920898 0.50763893127441406 2.5080094928853214E-005 10928.dat 1 71 -134.99066162109375 -110.95764923095703 322.9259033203125 2.678764212760143E-005 1.7841344742919318E-005 -1 -0.50764650106430054 0.86156553030014038 0 0.86156553030014038 0.50764650106430054 3.2138559618033469E-005 32123a.dat 1 72 -154.98965454101562 -131.26457214355469 357.38900756835937 0 -1 -2.6232639356749132E-005 -0.86156582832336426 -1.2833444088755641E-005 0.50764584541320801 -0.50764584541320801 2.2877004084875807E-005 -0.86156582832336426 6632.dat 1 71 -119.98941802978516 -131.26423645019531 357.38726806640625 1 0 2.6600189812597819E-005 0 0.86156731843948364 -0.50764334201812744 -2.6643647288437933E-005 0.50764334201812744 0.86156731843948364 32073.dat 1 72 -99.990234375 -169.78437805175781 368.16461181640625 -3.0140698072500527E-005 -1.0000001192092896 0 -0.26946470141410828 0 0.96301037073135376 -0.96301037073135376 2.9737329896306619E-005 -0.26946461200714111 32316.dat 1 0 -89.990303039550781 -208.3056640625 378.93988037109375 -1 0 0 0 0.96517950296401978 -0.26158881187438965 0 -0.26158881187438965 -0.965179443359375 2780.dat 1 72 -79.990150451660156 -208.30441284179687 378.9439697265625 -2.9112356060068123E-005 -1.0000001192092896 0 -0.26939079165458679 0 0.9630311131477356 -0.9630311131477356 2.8757314794347622E-005 -0.26939067244529724 32524.dat 1 0 -89.9901123046875 -266.0863037109375 395.10751342773437 -1 0 0 0 0.96517950296401978 -0.26158881187438965 0 -0.26158881187438965 -0.965179443359375 2780.dat 1 0 -89.991065979003906 -150.52421569824219 362.77508544921875 -1 0 0 0 0.96517950296401978 -0.26158881187438965 0 -0.26158881187438965 -0.965179443359375 2780.dat 1 0 -149.99014282226562 -208.30531311035156 378.94293212890625 -1 0 0 0 0.96517950296401978 -0.26158881187438965 0 -0.26158881187438965 -0.965179443359375 2780.dat 1 70 -159.99476623535156 -227.56623840332031 384.3348388671875 1 0 -2.031639996857848E-005 1.9518580302246846E-005 -0.50606244802474976 0.86249685287475586 0 -0.86249685287475586 -0.50606244802474976 24316.dat 1 72 -179.990966796875 -227.56512451171875 384.33447265625 -1.8337474102736451E-005 -1 0 -0.50605243444442749 0 0.86250275373458862 -0.86250275373458862 1.6695556041668169E-005 -0.50605243444442749 32271.dat 1 1 -169.99192810058594 -119.55938720703125 283.86065673828125 -1 2.4938588467193767E-005 2.8056872906745411E-005 2.5068999093491584E-005 -0.11264819651842117 0.99363499879837036 2.7940410291193984E-005 0.99363499879837036 0.1126483678817749 43093.dat 1 1 -169.99098205566406 -141.31524658203125 333.72793579101562 1 -2.6733438062365167E-005 0 1.3356900126382243E-005 0.5076448917388916 0.86156636476516724 -2.3158836484071799E-005 -0.86156636476516724 0.5076448917388916 4274.dat 1 1 -69.990829467773437 -141.31520080566406 333.724853515625 -1 1.2882427654403728E-005 0 1.2966998838237487E-005 0.53209269046783447 0.84668642282485962 0 0.84668642282485962 -0.53209233283996582 4274.dat 1 72 -149.99359130859375 -104.32827758789062 260.02740478515625 1 3.2371790439356118E-005 0 0 -0.019696913659572601 -0.9998059868812561 -3.2371212000725791E-005 0.9998059868812561 -0.019696913659572601 32002.dat 1 72 -159.99240112304687 -84.3311767578125 259.73953247070312 -1.0708866284403484E-005 0 1.0000001192092896 0.014310813508927822 -0.99989759922027588 0 0.99989765882492065 0.014310813508927822 1.0869491234188899E-005 6536.dat 1 72 -159.99354553222656 -132.46090698242187 225.25677490234375 0 1 0 1 0 0 0 0 -1 18654.dat 1 1 -179.98164367675781 -64.574775695800781 350.1773681640625 -1 0 0 0 -1 0 0 0 1 6558.dat 1 0 -49.928535461425781 -64.625434875488281 250.01301574707031 -1 0 0 0 0.99997472763061523 0.0070995832793414593 0 0.0070995832793414593 -0.99997478723526001 2780.dat 1 71 0.0076353549957275391 -64.32757568359375 289.99612426757812 1 0 0 0 -1 0 0 0 -1 64179.dat 1 0 20.007526397705078 -64.327583312988281 220.0106201171875 0 0.19802124798297882 0.98019784688949585 0 -0.9801977276802063 0.19802124798297882 1.0000001192092896 0 0 2780.dat 1 0 -19.992433547973633 -64.327583312988281 220.0106201171875 0 0.19802124798297882 0.98019784688949585 0 -0.9801977276802063 0.19802124798297882 1.0000001192092896 0 0 2780.dat 1 0 -19.992433547973633 -64.327293395996094 359.98184204101562 0 0.19801457226276398 0.98019909858703613 -1.3902421414968558E-005 0.98019909858703613 -0.19801457226276398 -1 -1.3827275324729271E-005 0 2780.dat 1 72 40.058536529541016 -64.6251220703125 370.013671875 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32526.dat 1 1 40.058536529541016 -64.6251220703125 380.01358032226562 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 4274.dat 1 0 -39.941585540771484 -104.62538146972656 360.01364135742187 0 0.19802124798297882 0.98019784688949585 0 -0.9801977276802063 0.19802124798297882 1.0000001192092896 0 0 2780.dat 1 71 0.0046236300840973854 -104.32810974121094 350.01968383789062 1.2586215234478004E-005 0 -1 -1 0 -1.2550294741231482E-005 0 1 0 14720.dat 1 0 20.004671096801758 -94.327857971191406 350.01983642578125 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 2780.dat 1 71 20.004671096801758 -84.327865600585938 340.01983642578125 -1 0 0 0 -1 0 0 0 1 43857.dat 1 0 20.004230499267578 -64.327865600585938 330.019775390625 1.4801516954321414E-005 -1 0 -1 -1.4701277905260213E-005 0 0 0 -1 15100.dat 1 1 40.026760101318359 -64.9229736328125 329.978759765625 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 -39.985256195068359 -124.61509704589844 350.01345825195312 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 72 0.014665722846984863 -124.6151123046875 330.01351928710937 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32316.dat 1 71 0.014586746692657471 -124.6151123046875 310.01351928710937 0 1 0 -1 0 0 0 0 0.99999994039535522 48989.dat 1 71 0.00762939453125 -124.32785034179687 230.02507019042969 1 0 0 0 -1 0 0 0 -1 64179.dat 1 71 0.0075623393058776855 -124.32785034179687 150.03955078125 0 -1 0 -1 0 0 0 0 -1 48989.dat 1 72 -0.0084221363067626953 -123.72892761230469 130.11375427246094 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32524.dat 1 0 30.008066177368164 -124.32649993896484 270.02523803710937 -1 0 0 0 -0.98019909858703613 0.19801455736160278 0 0.19801455736160278 0.98019897937774658 2780.dat 1 72 20.007572174072266 -144.32757568359375 270.02484130859375 0 -1 0 0 0 1 -1 0 0 60483.dat 1 1 30.00749397277832 -144.32757568359375 270.02484130859375 -1 0 0 0 0 -1 0 -1 0 43093.dat 1 0 -29.992389678955078 -124.32757568359375 190.02493286132812 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 0 -40.009300231933594 -123.72892761230469 140.11369323730469 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 71 0.0064177298918366432 -104.33250427246094 150.02127075195312 1.2586215234478004E-005 0 -1 -1 0 -1.2550294741231482E-005 0 1 0 14720.dat 1 0 20.006284713745117 -114.33226776123047 150.02128601074219 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 2780.dat 1 0 -19.993465423583984 -114.33275604248047 150.02127075195312 1.2778454220097046E-005 -1.0000001192092896 0 -1.0000001192092896 -1.2509656698966864E-005 0 0 0 -1 2780.dat 1 0 39.990818023681641 -123.72892761230469 140.11369323730469 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 1 -40.009487152099609 -103.72892761230469 170.11380004882812 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 72 -0.009492039680480957 -103.72892761230469 170.11369323730469 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32316.dat 1 1 39.990444183349609 -103.72892761230469 170.11380004882812 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 0 39.990367889404297 -103.72892761230469 190.11375427246094 0.99999994039535522 1.4797111361986026E-005 0 0 0 1 1.4797111361986026E-005 -1 0 15100.dat 1 0 79.990219116210937 -199.73219299316406 162.11988830566406 0 0 1.0000001192092896 -0.96000248193740845 0.27999183535575867 0 -0.2799917459487915 -0.96000248193740845 0 87082.dat 1 0 79.990348815917969 -206.73210144042969 186.120361328125 0 0 1 -0.96000230312347412 0.27999210357666016 0 -0.27999213337898254 -0.96000230312347412 0 32250.dat 1 1 79.990409851074219 -240.93220520019531 160.52059936523437 0 1 0 -0.27999213337898254 0 0.96000230312347412 0.96000230312347412 0 0.27999210357666016 43093.dat 1 0 79.990348815917969 -203.93211364746094 176.52073669433594 0 0 1 -0.96000230312347412 0.27999222278594971 0 -0.27999219298362732 -0.96000230312347412 0 32250.dat 1 0 160.00776672363281 -189.11921691894531 123.64456939697266 0 0 1 0.2799077033996582 0.96002691984176636 0 -0.96002697944641113 0.2799077033996582 0 63869.dat 1 0 160.00772094726562 -197.51992797851562 152.44465637207031 0 0 1 0.27999189496040344 0.96000242233276367 0 -0.96000242233276367 0.27999189496040344 0 3705.dat 1 0 160.00773620605469 -194.72012329101562 142.84526062011719 0 0 -1.0000001192092896 0.96000266075134277 0.27999138832092285 0 0.27999129891395569 -0.96000266075134277 0 60483.dat 1 0 160.00773620605469 -200.31983947753906 162.04446411132812 0 0 1.0000001192092896 -0.27999186515808105 -0.9600023627281189 0 0.96000242233276367 -0.27999186515808105 0 6536.dat 1 1 79.990409851074219 -202.5322265625 171.72085571289062 0 1 0 -0.27999219298362732 0 0.96000230312347412 0.96000230312347412 0 0.27999222278594971 43093.dat 1 72 90.015823364257813 -175.614990234375 148.47398376464844 1 0 0 0 0.96000289916992188 -0.27999007701873779 0 0.27999007701873779 0.96000289916992188 55013.dat 1 0 119.98888397216797 -174.93304443359375 148.52114868164062 -1 0 0 0 -0.96000277996063232 -0.27999040484428406 0 -0.27999040484428406 0.96000272035598755 6536.dat 1 0 79.990264892578125 -174.93247985839844 148.51983642578125 0 -0.99999994039535522 0 -0.27999550104141235 0 -0.96000128984451294 0.96000128984451294 0 -0.27999556064605713 60483.dat 1 0 99.990226745605469 -174.93234252929687 148.51960754394531 -1 0 0 0 -0.27999120950698853 0.960002601146698 0 0.960002601146698 0.2799912691116333 63869.dat 1 0 139.99009704589844 -174.93119812011719 148.51997375488281 -1 0 0 0 -0.27999064326286316 0.96000266075134277 0 0.96000266075134277 0.27999049425125122 6536.dat 1 4 -0.011116266250610352 -174.93301391601562 148.52142333984375 0 0 -1.0000001192092896 -0.25037947297096252 0.96814799308776855 0 0.968147873878479 0.25037947297096252 0 26287.dat 1 72 -90.009696960449219 -174.9342041015625 148.51972961425781 -1 0 0 0 0.96000128984451294 0.27999535202980042 0 0.27999535202980042 -0.96000134944915771 55013.dat 1 0 -80.009773254394531 -174.93392944335937 148.51954650878906 0 -0.99999994039535522 0 -0.27999550104141235 0 -0.96000128984451294 0.96000128984451294 0 -0.27999556064605713 60483.dat 1 0 -120.00969696044922 -174.9342041015625 148.51976013183594 -1 0 0 0 -0.96000277996063232 -0.27999040484428406 0 -0.27999040484428406 0.96000272035598755 6536.dat 1 0 -100.00977325439453 -174.93228149414062 148.51992797851562 -1 0 0 0 -0.27999120950698853 0.960002601146698 0 0.960002601146698 0.2799912691116333 63869.dat 1 0 -140.00982666015625 -174.93136596679687 148.52006530761719 -1 0 0 0 -0.27999034523963928 0.96000277996063232 0 0.96000277996063232 0.27999031543731689 6536.dat 1 0 -159.99221801757813 -200.31996154785156 162.045166015625 0 0 1.0000001192092896 -0.27999183535575867 -0.9600023627281189 0 0.96000254154205322 -0.27999183535575867 0 6536.dat 1 0 -159.99224853515625 -197.52008056640625 152.44500732421875 0 0 1 0.27999198436737061 0.96000230312347412 0 -0.9600023627281189 0.27999198436737061 0 3705.dat 1 0 -159.99221801757813 -189.11944580078125 123.64519500732422 0 0 1.0000001192092896 0.27990785241127014 0.96002703905105591 0 -0.96002697944641113 0.27990785241127014 0 63869.dat 1 0 -159.99224853515625 -194.72016906738281 142.84512329101562 0 0 1.0000001192092896 -0.960002601146698 0.27999165654182434 0 -0.27999153733253479 -0.960002601146698 0 60483.dat 1 0 -120.00965118408203 -203.93292236328125 176.52055358886719 0 0 -1 0.960002601146698 0.27999138832092285 0 0.27999132871627808 -0.960002601146698 0 11478.dat 1 0 -120.00965118408203 -206.73286437988281 186.12017822265625 0 0 -1 0.96000254154205322 0.2799912691116333 0 0.27999129891395569 -0.96000254154205322 0 11478.dat 1 1 -80.009651184082031 -202.53219604492187 171.72067260742187 0 1 0 -0.27999213337898254 0 0.96000230312347412 0.96000230312347412 0 0.27999210357666016 43093.dat 1 0 -80.009651184082031 -199.732177734375 162.12002563476562 0 0 1.0000001192092896 -0.96000248193740845 0.27999195456504822 0 -0.27999183535575867 -0.96000248193740845 0 87082.dat 1 0 -0.0098705291748046875 -218.93217468261719 156.52032470703125 0 0 -1 -0.27999144792556763 0.96000254154205322 0 0.96000254154205322 0.27999144792556763 0 32278.dat 1 0 -40.009628295898438 -169.33396911621094 129.31948852539062 0 -1.0000001192092896 0 -0.96000123023986816 0 0.27999624609947205 -0.27999624609947205 0 -0.96000111103057861 32523.dat 1 0 59.990142822265625 -238.13255310058594 150.92121887207031 0 1.0000001192092896 0 -0.960002601146698 0 -0.27999135851860046 -0.27999135851860046 0 0.96000266075134277 6536.dat 1 1 59.990142822265625 -228.53146362304687 153.72042846679687 0 1 0 -0.96000230312347412 0 -0.27999210357666016 -0.27999210357666016 0 0.96000230312347412 43093.dat 1 0 39.99029541015625 -169.33247375488281 129.32022094726562 0 -1.0000001192092896 0 -0.96000123023986816 0 0.27999624609947205 -0.27999624609947205 0 -0.96000111103057861 32523.dat 1 72 79.990150451660156 -194.13111877441406 142.92071533203125 1 0 0 0 0.27998948097229004 0.9600030779838562 0 -0.9600030779838562 0.27998948097229004 11214.dat 1 0 99.990150451660156 -194.13192749023437 142.92051696777344 -1 0 0 0 -0.27999064326286316 0.96000266075134277 0 0.96000266075134277 0.27999049425125122 6536.dat 1 0 39.99029541015625 -199.73165893554687 162.12065124511719 0 -1.0000001192092896 0 0.27999615669250488 0 0.96000123023986816 -0.96000123023986816 0 0.27999621629714966 60483.dat 1 0 39.990371704101563 -199.73126220703125 162.12127685546875 1 0 0 0 0.96000123023986816 -0.27999579906463623 0 0.27999579906463623 0.96000123023986816 18651.dat 1 0 59.990184783935547 -199.73286437988281 162.12139892578125 0 1.0000001192092896 0 0.96000134944915771 0 0.2799956202507019 0.2799956202507019 0 -0.96000128984451294 32140.dat 1 0 19.990180969238281 -199.73213195800781 162.12014770507812 0 -1 0 -0.9600023627281189 0 0.27999195456504822 -0.27999195456504822 0 -0.9600023627281189 15100.dat 1 0 59.990375518798828 -103.72943878173828 190.1141357421875 0 1.0000001192092896 0 0.27992185950279236 0 -0.96002286672592163 -0.96002286672592163 0 -0.2799217700958252 32526.dat 1 0 139.9901123046875 -199.73210144042969 162.11981201171875 0 0 -0.99999994039535522 -0.96000266075134277 -0.27999076247215271 0 -0.27999073266983032 0.96000266075134277 0 87082.dat 1 72 -80.009750366210937 -194.13154602050781 142.92044067382812 -1 0 0 0 -0.27998962998390198 0.96000313758850098 0 0.96000313758850098 0.27998992800712585 11214.dat 1 0 -100.00966644287109 -194.13111877441406 142.92039489746094 -1 0 0 0 -0.27999064326286316 0.96000266075134277 0 0.96000266075134277 0.27999049425125122 6536.dat 1 0 -60.009700775146484 -199.73263549804687 162.12005615234375 0 1.0000001192092896 0 0.96000146865844727 0 0.27999532222747803 0.27999532222747803 0 -0.96000140905380249 32140.dat 1 0 -40.009586334228516 -199.73220825195312 162.12039184570312 -1 0 0 0 0.96000152826309204 0.27999439835548401 0 0.27999439835548401 -0.96000164747238159 18651.dat 1 0 -40.009628295898438 -199.73228454589844 162.12040710449219 0 -1 0 0.27999627590179443 0 0.96000111103057861 -0.96000111103057861 0 0.27999621629714966 60483.dat 1 0 -20.009780883789062 -199.7320556640625 162.12017822265625 0 -1.0000001192092896 0 -0.96000230312347412 0 0.27999234199523926 -0.27999234199523926 0 -0.96000224351882935 15100.dat 1 0 -140.0098876953125 -199.73222351074219 162.12014770507812 0 0 -0.99999994039535522 -0.96000266075134277 -0.27999076247215271 0 -0.27999073266983032 0.96000266075134277 0 87082.dat 1 0 -60.009700775146484 -103.73081207275391 190.11372375488281 0 1.0000001192092896 0 0.27992185950279236 0 -0.96002286672592163 -0.96002286672592163 0 -0.2799217700958252 32526.dat 1 1 99.990097045898437 -199.73211669921875 162.11988830566406 0 0 -1.0000001192092896 -0.96000277996063232 -0.27999064326286316 0 -0.27999070286750793 0.96000277996063232 0 6558.dat 1 0 49.990211486816406 -180.53118896484375 167.72001647949219 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -50.009601593017578 -169.33383178710937 129.31918334960937 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 -100.009521484375 -199.73211669921875 162.11988830566406 0 0 -1.0000001192092896 -0.96000277996063232 -0.27999064326286316 0 -0.27999070286750793 0.96000277996063232 0 6558.dat 1 0 -0.0097095966339111328 -188.53274536132812 123.71974945068359 1 0 0 0 1 0 0 0 1 3706.dat 1 0 -120.00978851318359 -199.73213195800781 162.11985778808594 0 0 1 -0.96000242233276367 0.27999195456504822 0 -0.27999186515808105 -0.96000242233276367 0 87082.dat 1 0 -139.99227905273438 -197.51992797851562 152.44473266601562 0 0 1 0.27999088168144226 0.96000266075134277 0 -0.96000266075134277 0.27999088168144226 0 2780.dat 1 0 140.00772094726562 -197.51994323730469 152.44479370117187 0 0 1 0.27999091148376465 0.96000266075134277 0 -0.96000266075134277 0.27999091148376465 0 2780.dat 1 0 -40.009410858154297 -103.72892761230469 190.11387634277344 -1 -1.502365466876654E-005 -1.4900021596986335E-005 -1.4900020687491633E-005 0 1 -1.5023656487755943E-005 1 0 15100.dat 1 0 119.99037170410156 -199.73223876953125 162.11985778808594 0 0 1 -0.96000242233276367 0.27999195456504822 0 -0.27999186515808105 -0.96000242233276367 0 87082.dat 1 0 49.990211486816406 -169.33236694335938 129.32012939453125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -50.009601593017578 -180.53253173828125 167.71963500976562 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 -39.993839263916016 -84.333023071289063 150.02127075195312 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 72 0.0061392784118652344 -84.333023071289063 170.02125549316406 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 32278.dat 1 1 60.005397796630859 -84.327476501464844 150.02394104003906 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 6558.dat 1 72 -0.0088930130004882813 -83.733558654785156 130.11946105957031 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 40490.dat 1 1 79.991127014160156 -83.733558654785156 150.11944580078125 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 1 -59.993541717529297 -84.327468872070313 150.02394104003906 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 1 -80.009101867675781 -83.733558654785156 150.11943054199219 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 1 40.006275177001953 -84.333023071289063 150.02127075195312 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 6558.dat 1 0 0.014895200729370117 -84.61517333984375 110.013427734375 -1 0 0 0 1 0 0 0 -1 32269.dat 1 71 0.014866948127746582 -84.61517333984375 150.01338195800781 0 0 1 0 1 0 -1 0 0 60485.dat 1 4 0.014895200729370117 -84.61517333984375 240.01338195800781 1 0 0 0 -1 0 0 0 -1 59443.dat 1 71 0.014895200729370117 -84.615180969238281 310.08840942382812 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 44294.dat 1 4 0.014895200729370117 -84.615165710449219 380.08834838867187 1 0 0 0 1 0 0 0 1 59443.dat 1 1 0.014896232634782791 -84.615165710449219 400.08840942382812 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 0 0.0045939693227410316 -84.328125 350.01937866210937 0 0 1 -1 -1.4673428267997224E-005 0 1.4692082913825288E-005 -1 0 15100.dat 1 71 0.05852842703461647 -74.625106811523438 312.013671875 0.99999994039535522 0 0 0 0 1 0 -1 0 43857.dat 1 4 -9.9414701461791992 -64.6251220703125 420.013671875 1 0 0 0 -1 0 0 0 -1 32062.dat 1 71 -19.941469192504883 -64.6251220703125 420.01361083984375 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 6590.dat 1 71 0.058530271053314209 -64.6251220703125 400.013671875 1 0 0 0 -1 0 0 0 -1 32039.dat 1 72 0.058530930429697037 -64.625114440917969 357.013671875 0 0 -1 0 0.99999994039535522 0 1 0 0 32209.dat 1 71 0.058527290821075439 -64.625129699707031 385.013671875 1 0 0 0 1 0 0 0 1 32123a.dat 1 72 -0.00972747802734375 -83.733642578125 90.120826721191406 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 1 99.990287780761719 -83.732841491699219 110.12081909179687 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 71 0.014888922683894634 -84.615158081054687 420.08828735351562 0 0 1 0 1 0 -1 0 0 75535.dat 1 4 0.014895200729370117 -84.615165710449219 460.08843994140625 1 0 0 0 1 0 0 0 1 59443.dat 1 1 0.014894168823957443 -84.615165710449219 440.08837890625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 71 0.014910896308720112 -84.615165710449219 510.08853149414063 0 0 -1 0 0.99999994039535522 0 1 0 0 32073.dat 1 19 -0.0066555580124258995 -84.327827453613281 543.025146484375 -1 0 0 0 -1 0 0 0 1 6589.dat 1 72 -0.0066578388214111328 -84.327827453613281 560.02508544921875 0 1 0 -1 0 0 0 0 0.99999994039535522 6573.dat 1 4 0.017946958541870117 -84.626480102539063 660.00030517578125 -1 0 0 0 1 0 0 0 -1 59443.dat 1 1 0.017947990447282791 -84.626480102539063 680.00018310546875 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 71 0.017931262031197548 -84.626480102539063 610.000244140625 0 0 1 0 1 0 -1 0 0 32073.dat 1 19 -0.0068462928757071495 -84.327827453613281 577.02508544921875 -1 0 0 0 1 0 0 0 -1 6589.dat 1 72 0.015556812286376953 -84.62628173828125 630 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 41239.dat 1 71 40.014942169189453 -84.615097045898438 610.58837890625 -0.98078584671020508 0.19508761167526245 0 0.19508761167526245 0.98078596591949463 0 0 0 -1 4019.dat 1 0 40.015560150146484 -84.626266479492188 599.99993896484375 0 0.19434256851673126 0.9809337854385376 0 0.98093372583389282 -0.19434256851673126 -1 0 0 3705.dat 1 72 40.014724731445313 -84.615158081054687 590.0885009765625 -0.98078584671020508 0.19508761167526245 0 0.19508761167526245 0.98078596591949463 0 0 0 -1 10928.dat 1 71 39.991016387939453 -84.32708740234375 570.039794921875 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 44809.dat 1 0 49.990974426269531 -64.32708740234375 570.0399169921875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 71 59.990936279296875 -64.32708740234375 570.03985595703125 0 -1 0 -1 0 0 0 0 -1 32523.dat 1 0 69.991050720214844 -64.32708740234375 590.039794921875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 59.990978240966797 -64.32708740234375 550.03985595703125 1 0 0 0 -1 0 0 0 -1 6558.dat 1 71 39.991016387939453 -84.32708740234375 550.039794921875 0.99999994039535522 0 0 0 0 -1 0 1 0 44809.dat 1 0 39.990631103515625 -84.327613830566406 520.05364990234375 0 0.19434256851673126 0.98093384504318237 0 0.98093384504318237 -0.19434256851673126 -1.0000001192092896 0 0 3705.dat 1 71 40.014900207519531 -84.615165710449219 530.5885009765625 -0.98093342781066895 0.1943439245223999 0 0.1943439245223999 0.9809337854385376 0 0 0 -1 4019.dat 1 72 79.990402221679688 -84.327232360839844 490.03997802734375 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 32140.dat 1 0 59.990512847900391 -84.327232360839844 500.03994750976563 0 0 1 0 1 0 -1 0 0 2780.dat 1 72 -0.00934600830078125 -84.327606201171875 510.05368041992187 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32278.dat 1 1 -99.961082458496094 -84.902999877929688 490.0399169921875 0 0 -1 0 0.99999994039535522 0 1 0 0 6558.dat 1 71 -159.98599243164062 -124.24422454833984 469.97763061523437 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 64179.dat 1 0 -89.961151123046875 -144.90298461914063 470.02581787109375 1 0 0 0 1 0 0 0 1 2780.dat 1 72 -179.96043395996094 -84.902870178222656 470.02572631835937 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 11214.dat 1 72 -179.96043395996094 -84.904624938964844 450.02569580078125 0 0 -1 -0.00017520882829558104 0.99999994039535522 0 1 0.00017520882829558104 0 6536.dat 1 1 -169.98342895507812 -64.625732421875 490.00054931640625 -1 0 0 0 0 1 0 1 0 43093.dat 1 72 -179.9832763671875 -64.623985290527344 490.00054931640625 -1 0 0 0 -1 0 0 0 1 6536.dat 1 1 -179.98321533203125 -64.625732421875 450.00048828125 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 -200.00672912597656 -144.32810974121094 470.025634765625 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 0 -180.00672912597656 -144.32810974121094 470.025634765625 0.99999994039535522 0 0 0 0 1 0 -1 0 6536.dat 1 71 -199.96040344238281 -164.90458679199219 450.02578735351562 0 0 -1 0.00017499930982012302 1 0 1 -0.00017499930982012302 0 63869.dat 1 1 -199.96035766601562 -164.90284729003906 440.0257568359375 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 -189.98333740234375 -144.6240234375 429.99996948242187 1 0 0 0 1 0 0 0 1 2780.dat 1 0 -169.983154296875 -64.625732421875 430.00048828125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -79.974853515625 -124.90287017822266 470.0262451171875 -1 -1.5023657397250645E-005 -1.490002432547044E-005 -1.4900023415975738E-005 0 1 -1.5023659216240048E-005 1 0 15100.dat 1 0 -79.9808349609375 -124.62331390380859 510.00164794921875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 1 -79.974540710449219 -124.90285491943359 480.02633666992187 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 -99.960418701171875 -164.90286254882812 470.02581787109375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 18651.dat 1 72 -79.985343933105469 -164.61508178710937 450.0135498046875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 42003.dat 1 71 -99.960418701171875 -164.90284729003906 500.02584838867187 0 0 -1 0 0.99999994039535522 0 1 0 0 75535.dat 1 0 -99.960426330566406 -164.90286254882812 520.02587890625 0 0.033155426383018494 0.99945026636123657 0 0.99945032596588135 -0.033155426383018494 -1 0 0 2780.dat 1 72 20.009538650512695 -204.69448852539062 690.00018310546875 -1 0 0 0 0 1 0 1 0 11214.dat 1 71 -19.984170913696289 -204.62026977539062 690.0003662109375 -1 0 0 0 0 1 0 1 0 32054.dat 1 0 100.01474761962891 -164.6151123046875 520.01361083984375 0 0.033155426383018494 0.99945026636123657 0 0.99945032596588135 -0.033155426383018494 -1 0 0 2780.dat 1 71 100.0147705078125 -164.6151123046875 500.01358032226562 0 0 -1 0 0.99999994039535522 0 1 0 0 75535.dat 1 0 100.0203857421875 -164.32633972167969 470.02395629882812 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 18651.dat 1 72 80.014739990234375 -164.6151123046875 450.0135498046875 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 42003.dat 1 71 160.02037048339844 -124.32633972167969 470.02392578125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 64179.dat 1 72 179.99116516113281 -84.324287414550781 470.04156494140625 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 11214.dat 1 72 179.99116516113281 -84.326042175292969 450.04153442382812 0 0 -1 -0.00017503398703411222 0.99999994039535522 0 1 0.00017503398703411222 0 6536.dat 1 1 169.98762512207031 -64.322532653808594 490.04025268554687 0.99999994039535522 1.2805560800188687E-005 0 0 0 1 1.2805560800188687E-005 -1 0 43093.dat 1 72 179.98680114746094 -64.324287414550781 490.04043579101562 1 0.00017512147314846516 0 0.00017512147314846516 -1 0 0 0 -1 6536.dat 1 0 169.99220275878906 -64.326042175292969 430.044921875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 189.98416137695312 -144.32402038574219 430.03793334960937 -1 0 0 0 1 0 0 0 -1 2780.dat 1 71 199.98414611816406 -164.32051086425781 450.04144287109375 0 0 -1 0.00017499929526820779 1 0 1 -0.00017499929526820779 0 63869.dat 1 1 199.98416137695312 -164.31877136230469 440.04141235351562 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 1 179.99221801757812 -64.326042175292969 370.04510498046875 -1 0 0 0 -1 0 0 0 1 6558.dat 1 1 180.00607299804687 -64.326507568359375 350.02545166015625 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 80.007171630859375 -82.82293701171875 357.68569946289062 -2.6497496946831234E-005 -1.0000001192092896 -1.0620411558193155E-005 -0.37407416105270386 0 0.9273989200592041 -0.9273989200592041 2.8637472496484406E-005 -0.37407407164573669 60483.dat 1 71 120.00775146484375 -82.822509765625 357.6865234375 1 1.4929417375242338E-005 4.276322215446271E-005 3.4073855204042047E-005 0.37407404184341431 -0.92739886045455933 -2.9842136427760124E-005 0.92739886045455933 0.37407404184341431 32073.dat 1 72 160.00772094726562 -82.822280883789063 357.68435668945312 -2.6625837563187815E-005 -1 -1.0684580047382042E-005 -0.37407398223876953 0 0.92739886045455933 -0.92739886045455933 2.8701640985673293E-005 -0.37407398223876953 60483.dat 1 1 80.00616455078125 -64.326789855957031 350.02536010742187 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 145.00888061523437 -106.65520477294922 342.4539794921875 1.413243717252044E-005 -1 -1.3575508091889787E-005 -0.97661054134368896 -1.0933749763353262E-005 -0.21501576900482178 0.21501576900482178 1.6302208678098395E-005 -0.97661060094833374 6632.dat 1 71 120.00749206542969 -115.25665283203125 303.39068603515625 1 0 2.8403284886735491E-005 0 0.97660553455352783 0.21503867208957672 -2.8410628146957606E-005 -0.21503867208957672 0.97660553455352783 32073.dat 1 72 160.00735473632812 -115.25652313232422 303.38925170898437 0 1.0000001192092896 -1.3132869753462728E-005 0.97660261392593384 0 -0.21505260467529297 -0.21505260467529297 -1.4132832802715711E-005 -0.97660243511199951 32140.dat 1 72 80.007247924804688 -115.25656890869141 303.39154052734375 -1.0587126780592371E-005 1 -1.273991529160412E-005 0.97660374641418457 0 -0.21504674851894379 -0.21504674851894379 -1.4721606930834241E-005 -0.97660374641418457 32140.dat 1 71 120.00905609130859 -106.65401458740234 342.455078125 1 0 2.9023492970736697E-005 0 0.9766080379486084 0.21502730250358582 -2.9030836230958812E-005 -0.21502730250358582 0.9766080379486084 4519.dat 1 72 105.00959014892578 -106.65388488769531 342.45571899414062 0 -1 2.8287555323913693E-005 0.97660809755325317 0 0.21502684056758881 -0.21502684056758881 2.8303184080868959E-005 0.97660809755325317 41677.dat 1 4 120.01007843017578 -102.35354614257812 361.98760986328125 -1 0 0 0 0.97660839557647705 -0.21502602100372314 0 -0.21502602100372314 -0.97660833597183228 32062.dat 1 71 120.01020812988281 -102.35353851318359 361.98779296875 -3.0823102861177176E-005 -1.0000001192092896 0 -0.21502812206745148 0 0.97660791873931885 -0.97660791873931885 3.0598730518249795E-005 -0.21502803266048431 60483.dat 1 72 135.00927734375 -106.65399932861328 342.45468139648437 0 -0.99999994039535522 2.8429107260308228E-005 0.97660809755325317 0 0.21502670645713806 -0.21502670645713806 2.8444736017263494E-005 0.97660809755325317 41677.dat 1 71 120.00533294677734 -106.65433502197266 342.45431518554688 -1 0 0 0 0.97660791873931885 -0.21502794325351715 0 -0.21502794325351715 -0.97660791873931885 63869.dat 1 72 95.009956359863281 -106.65409851074219 342.45513916015625 1.413243717252044E-005 -1 -1.3565064364229329E-005 -0.97661054134368896 -1.0933749763353262E-005 -0.21501578390598297 0.21501578390598297 1.6291764040943235E-005 -0.97661060094833374 6632.dat 1 0 100.00621032714844 -82.82177734375 357.68655395507812 -2.6868710847338662E-005 1 0 -0.21503011882305145 0 -0.97660744190216064 -0.97660744190216064 -2.6647971026250161E-005 0.21503005921840668 15100.dat 1 0 140.00642395019531 -82.821876525878906 357.68539428710937 -2.6743227863335051E-005 1.0000001192092896 0 -0.2150292694568634 0 -0.97660768032073975 -0.97660768032073975 -2.6647992854123004E-005 0.21502932906150818 15100.dat 1 72 145.00732421875 -126.00873565673828 254.55967712402344 0 -1 2.8731434213113971E-005 0.97660636901855469 0 0.2150348424911499 -0.2150348424911499 2.8768215997843072E-005 0.97660642862319946 32449.dat 1 71 120.00770568847656 -119.55776214599609 283.85836791992187 1 0 2.8360815122141503E-005 0 0.97660565376281738 0.21503813564777374 -2.8368160201353021E-005 -0.21503813564777374 0.97660565376281738 4519.dat 1 72 95.007553100585938 -126.00684356689453 254.55439758300781 0 -1 2.8744101655320264E-005 0.97660636901855469 0 0.21503482758998871 -0.21503482758998871 2.8755546736647375E-005 0.97660642862319946 32449.dat 1 1 150.00575256347656 -132.45999145507812 225.26176452636719 -1 0 0 0 0.21503536403179169 0.97660619020462036 0 0.97660619020462036 -0.21503549814224243 43093.dat 1 72 120.00563049316406 -97.875213623046875 289.3233642578125 -1 0 3.0813687772024423E-005 0 -0.97660624980926514 0.21503531932830811 3.079477755818516E-005 0.21503531932830811 0.97660624980926514 61904.dat 1 71 120.00770568847656 -119.55733489990234 283.85867309570312 -0.00048727219109423459 9.3984621344134212E-005 -1 -0.21499715745449066 -0.97661471366882324 1.3001717888982967E-005 -0.97661471366882324 0.21499714255332947 0.00049632583977654576 6590.dat 1 71 120.00588226318359 -132.45973205566406 225.26211547851563 -2.8396101697580889E-005 0 1 -0.21504007279872894 0.97660529613494873 0 -0.97660529613494873 -0.21504007279872894 -2.8425280106603168E-005 59443.dat 1 1 90.006729125976563 -132.45787048339844 225.25576782226562 1 0 0 0 -0.21503545343875885 0.97660624980926514 0 -0.97660624980926514 -0.21503545343875885 43093.dat 1 72 90.006004333496094 -128.15908813476562 244.79476928710937 1 3.0545474146492779E-005 0 0 -0.0059975460171699524 -0.99998199939727783 -3.0545317713404074E-005 0.99998199939727783 -0.0059975460171699524 32002.dat 1 70 160.00262451171875 -227.56242370605469 384.3319091796875 -1 0 1.49340148709598E-005 0 -0.86249595880508423 0.50606393814086914 1.488816906203283E-005 0.50606393814086914 0.86249589920043945 24316.dat 1 72 180.0025634765625 -227.56312561035156 384.32986450195312 -1.3352983842196409E-005 -1.0000001192092896 -2.6204084861092269E-005 -0.50606054067611694 -1.568140578456223E-005 0.86249810457229614 -0.86249810457229614 2.4870632842066698E-005 -0.50606042146682739 32271.dat 1 1 169.99978637695312 -119.55752563476562 283.856689453125 1 -1.038635218719719E-005 -1.7279469830100425E-005 1.8339480448048562E-005 0.11264713853597641 0.99363505840301514 0 -0.99363505840301514 0.11264713853597641 43093.dat 1 72 140.00917053222656 -266.08367919921875 395.10934448242187 -3.0140698072500527E-005 -1.0000001192092896 0 -0.26946470141410828 0 0.96301037073135376 -0.96301037073135376 2.9737329896306619E-005 -0.26946461200714111 32316.dat 1 0 150.00834655761719 -266.08450317382812 395.10617065429687 -1 0 0 0 0.96517950296401978 -0.26158878207206726 0 -0.26158878207206726 -0.965179443359375 2780.dat 1 72 160.00828552246094 -208.30259704589844 378.942626953125 -2.9112356060068123E-005 -1.0000001192092896 0 -0.26939079165458679 0 0.9630311131477356 -0.9630311131477356 2.8757314794347622E-005 -0.26939067244529724 32524.dat 1 0 150.00738525390625 -150.52239990234375 362.77374267578125 -1 0 0 0 0.96517950296401978 -0.26158878207206726 0 -0.26158878207206726 -0.965179443359375 2780.dat 1 72 140.00822448730469 -169.78254699707031 368.16305541992187 -3.0262128348113038E-005 -1 0 -0.26946461200714111 0 0.96301025152206421 -0.96301025152206421 2.9706970963161439E-005 -0.26946467161178589 32316.dat 1 72 165.00874328613281 -131.26271057128906 357.383544921875 -1.0181908692175057E-005 -1 -3.6506720789475366E-005 -0.86157310009002686 0 0.50763362646102905 -0.50763362646102905 3.6637455195887014E-005 -0.86157304048538208 6632.dat 1 71 120.00883483886719 -131.2623291015625 357.38494873046875 1 1.3654392205353361E-005 2.2860233002575114E-005 0 0.86156725883483887 -0.50764346122741699 -2.6627190891304053E-005 0.50764346122741699 0.86156725883483887 32073.dat 1 72 75.008003234863281 -131.26234436035156 357.38629150390625 -1.0661337910278235E-005 -1 -3.6435911169974133E-005 -0.86157310009002686 0 0.50763368606567383 -0.50763368606567383 3.6828121665166691E-005 -0.86157304048538208 6632.dat 1 72 155.0091552734375 -131.26194763183594 357.38388061523437 -1.0279976777383126E-005 -1.0000001192092896 -3.6340763472253457E-005 -0.86157304048538208 0 0.50763380527496338 -0.50763380527496338 3.6602235923055559E-005 -0.86157292127609253 6632.dat 1 71 120.00826263427734 -110.95636749267578 322.9222412109375 1 2.2442865883931518E-005 2.2774805984226987E-005 0 0.86156618595123291 -0.50764524936676025 -3.1015017157187685E-005 0.50764524936676025 0.86156618595123291 32073.dat 1 71 135.00811767578125 -110.95639801025391 322.92178344726562 2.4865285013220273E-005 2.2782711312174797E-005 -1 -0.50765109062194824 0.86156278848648071 0 0.86156278848648071 0.50765109062194824 3.2989039027597755E-005 32123a.dat 1 71 105.00808715820312 -110.95615386962891 322.92257690429687 2.4865285013220273E-005 2.2782711312174797E-005 -1 -0.50765109062194824 0.86156278848648071 0 0.86156278848648071 0.50765109062194824 3.2989039027597755E-005 32123a.dat 1 72 120.00823974609375 -110.95642852783203 322.92230224609375 2.3038797735353E-005 1.3488465810951311E-005 -1 -0.50764501094818115 0.86156642436981201 0 0.86156636476516724 0.50764501094818115 2.6703361072577536E-005 10928.dat 1 72 85.007637023925781 -131.26235961914062 357.38601684570312 -1.0661337910278235E-005 -1 -3.6435911169974133E-005 -0.86157310009002686 0 0.50763368606567383 -0.50763368606567383 3.6828121665166691E-005 -0.86157304048538208 6632.dat 1 72 100.00826263427734 -169.78273010253906 368.163818359375 -3.0262128348113038E-005 -1 0 -0.26946461200714111 0 0.96301025152206421 -0.96301025152206421 2.9706970963161439E-005 -0.26946467161178589 32316.dat 1 0 90.00848388671875 -150.5216064453125 362.77813720703125 -1 0 0 0 0.96592098474502563 -0.25883761048316956 0 -0.25883761048316956 -0.96592086553573608 2780.dat 1 72 80.008369445800781 -208.30349731445312 378.94168090820312 -2.9112356060068123E-005 -1.0000001192092896 0 -0.26939079165458679 0 0.9630311131477356 -0.9630311131477356 2.8757314794347622E-005 -0.26939067244529724 32524.dat 1 1 70.008506774902344 -119.55801391601562 283.8594970703125 -1 2.4938532078522258E-005 2.8056818337063305E-005 2.5068944523809478E-005 -0.11264850944280624 0.99363493919372559 2.7940355721511878E-005 0.99363493919372559 0.11264853924512863 43093.dat 1 72 60.007183074951172 -227.56365966796875 384.333251953125 -1.7515691070002504E-005 -1 0 -0.50605314970016479 0 0.86250227689743042 -0.86250227689743042 1.5770432582939975E-005 -0.50605314970016479 32271.dat 1 70 80.007644653320313 -227.564453125 384.33209228515625 1 0 -2.0316258087405004E-005 1.9518358385539614E-005 -0.50606286525726318 0.86249661445617676 0 -0.86249661445617676 -0.50606286525726318 24316.dat 1 72 100.00940704345703 -266.08367919921875 395.11026000976562 -3.0262128348113038E-005 -1 0 -0.26946461200714111 0 0.96301025152206421 -0.96301025152206421 2.9706970963161439E-005 -0.26946467161178589 32316.dat 1 1 120.00937652587891 -246.82347106933594 389.72055053710937 -1 0 0 0 0.99829041957855225 -0.05844801664352417 0 -0.05844801664352417 -0.99829047918319702 6558.dat 1 4 120.00852966308594 -160.15176391601562 365.4688720703125 0 2.3845639589126222E-005 -1.0000001192092896 -0.96300894021987915 0.26946982741355896 0 0.26946976780891418 0.96300894021987915 2.4027613108046353E-005 32062.dat 1 71 120.00832366943359 -131.26138305664062 357.38485717773437 -1 0 0 0 0.2694733738899231 0.96300780773162842 0 0.96300780773162842 -0.2694733738899231 32013.dat 1 71 120.00846862792969 -189.04220581054687 373.55331420898437 1 0 0 0 0.2694721519947052 -0.96300816535949707 0 0.96300816535949707 0.2694721519947052 32034.dat 1 4 120.00848388671875 -217.932861328125 381.63760375976562 0 2.3845639589126222E-005 -1.0000001192092896 -0.96300894021987915 0.26946982741355896 0 0.26946976780891418 0.96300894021987915 2.4027613108046353E-005 32062.dat 1 71 120.00883483886719 -246.82328796386719 389.7210693359375 -1 -1.9904737200704403E-005 2.6093925043824129E-005 -1.9765438992180862E-005 -0.26945206522941589 -0.96301376819610596 2.6199597414233722E-005 -0.96301376819610596 0.26945191621780396 32013.dat 1 1 120.00840759277344 -189.04296875 373.55221557617187 -1 0 3.5049513826379552E-005 0 -0.98793977499008179 -0.15483880043029785 3.5063090763287619E-005 -0.15483880043029785 0.98793995380401611 6558.dat 1 0 120.01006317138672 -304.57888793945312 405.97686767578125 1 0 0 0 0.96160942316055298 0.27442178130149841 0 -0.27442178130149841 0.96160942316055298 18651.dat 1 71 120.01005554199219 -304.5772705078125 405.98260498046875 1 -0.00019884538778569549 0 -5.4881002142792568E-005 -0.27442178130149841 0.96160942316055298 -0.00019112213340122253 -0.96160942316055298 -0.27442178130149841 63869.dat 1 1 100.00653076171875 -290.83233642578125 381.26608276367188 0 -1.0000001192092896 0 -0.96161049604415894 0 -0.27441826462745667 0.27441826462745667 0 -0.96161043643951416 6558.dat 1 71 120.00999450683594 -285.31729125976562 400.593505859375 1 -0.00019884543144144118 0 -5.4880481911823153E-005 -0.2744193971157074 0.96161013841629028 -0.0001911223225761205 -0.96161013841629028 -0.2744193971157074 63869.dat 1 0 120.01007843017578 -285.3154296875 400.59930419921875 -1 0 0 0 0.96161037683486938 -0.27441933751106262 0 -0.27441933751106262 -0.96161013841629028 18651.dat 1 1 140.00651550292969 -290.83453369140625 381.25833129882813 0 -1.0000001192092896 0 -0.96161049604415894 0 -0.27441826462745667 0.27441826462745667 0 -0.96161043643951416 6558.dat 1 71 120.00651550292969 -271.60235595703125 375.76986694335937 0 0 -1.0000001192092896 -0.27441748976707458 -0.96161067485809326 0 -0.96161073446273804 0.27441748976707458 0 32523.dat 1 0 90.009437561035156 -266.08367919921875 395.11056518554687 -1 0 0 0 0.96592098474502563 -0.25883761048316956 0 -0.25883761048316956 -0.96592086553573608 2780.dat 1 1 70.007453918457031 -141.31341552734375 333.72659301757812 1 -2.6733438062365167E-005 0 1.3356901035876945E-005 0.5076448917388916 0.86156636476516724 -2.3158836484071799E-005 -0.86156636476516724 0.5076448917388916 4274.dat 1 0 90.00848388671875 -208.30349731445312 378.94140625 -1 0 0 0 0.96517950296401978 -0.26158878207206726 0 -0.26158878207206726 -0.965179443359375 2780.dat 1 0 150.00834655761719 -208.3038330078125 378.9383544921875 -1 0 0 0 0.96517950296401978 -0.26158878207206726 0 -0.26158878207206726 -0.965179443359375 2780.dat 1 1 170.00761413574219 -141.31336975097656 333.7235107421875 -1 1.2882427654403728E-005 0 1.2966998838237487E-005 0.53209269046783447 0.84668642282485962 0 0.84668642282485962 -0.53209233283996582 4274.dat 1 72 80.006584167480469 -132.4578857421875 225.25576782226562 0 1 0 1 0 0 0 0 -1 18654.dat 1 72 150.0052490234375 -128.159423828125 244.79331970214844 -1 0 0 0 0.005997661966830492 -0.99998205900192261 0 -0.99998205900192261 -0.0059976144693791866 32002.dat 1 72 160.00559997558594 -132.45994567871094 225.26182556152344 0 1 0 1 0 0 0 0 -1 18654.dat 1 71 105.00533294677734 -108.62975311279297 240.49720764160156 7.1372560341842473E-005 3.8234709791140631E-005 -1 -0.47221919894218445 0.88148117065429688 0 0.88148117065429688 0.47221919894218445 8.0966950918082148E-005 32123a.dat 1 0 130.00550842285156 -108.62918090820312 240.49237060546875 1 1.4387968803930562E-005 2.6681507733883336E-005 0 0.88148117065429688 -0.47221916913986206 -3.0313522074720822E-005 0.47221916913986206 0.88148117065429688 3706.dat 1 0 180.00485229492187 -108.62886810302734 240.49043273925781 -3.4186039556516334E-005 -6.8678244133479893E-005 1.0000001192092896 -0.88148027658462524 0.47222107648849487 0 -0.47222098708152771 -0.88148027658462524 -7.6630240073427558E-005 32270.dat 1 71 120.00436401367187 -108.62765502929687 240.4930419921875 0 -1.3366514394874685E-005 -1.0000001192092896 0.47225093841552734 -0.88146418333053589 1.6439184037153609E-005 -0.88146424293518066 -0.47225093841552734 0 6590.dat 1 19 137.0050048828125 -108.61990356445312 240.502197265625 -7.6678690675180405E-005 0.00012891032383777201 -1 0.47221741080284119 -0.88148212432861328 -0.00014985166490077972 -0.88148218393325806 -0.47221741080284119 0 6589.dat 1 72 90.005050659179688 -104.32734680175781 260.02474975585938 1 3.2371794077334926E-005 0 0 -0.019696913659572601 -0.9998059868812561 -3.2371215638704598E-005 0.9998059868812561 -0.019696913659572601 32002.dat 1 72 80.006233215332031 -84.329399108886719 259.73916625976562 -1.0708866284403484E-005 0 1 0.014310812577605247 -0.99989759922027588 0 0.99989759922027588 0.014310812577605247 1.0700910024752375E-005 6536.dat 1 71 120.00639343261719 -93.575050354003906 308.85537719726562 -0.98759371042251587 0.15703088045120239 2.9679949875571765E-005 -0.15335099399089813 -0.96449095010757446 0.21503661572933197 0.033796012401580811 0.21236425638198853 0.97660624980926514 4716.dat 1 71 120.00611877441406 -95.725700378417969 299.089111328125 -2.8825528715969995E-005 -0.15703022480010986 0.98759382963180542 -0.21503464877605438 0.96449154615402222 0.1533505916595459 -0.97660648822784424 -0.21236246824264526 -0.033794738352298737 32073.dat 1 0 120.00495147705078 -104.32656097412109 260.02487182617187 0.15703053772449493 -0.98759400844573975 -2.9623537557199597E-005 -0.96449160575866699 -0.1533503383398056 -0.21503481268882751 0.21236249804496765 0.0337955541908741 -0.97660642862319946 32270.dat 1 72 150.00505065917969 -104.32658386230469 260.02398681640625 -1 -3.3861444535432383E-005 3.587746323319152E-005 -3.3734078897396103E-005 -0.061305657029151917 -0.99811917543411255 3.5997247323393822E-005 -0.99811917543411255 0.061305899173021317 32002.dat 1 1 179.99226379394531 -64.326042175292969 450.04510498046875 -1 0 0 0 -1 0 0 0 1 6558.dat 1 1 179.99220275878906 -64.326034545898437 550.0450439453125 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 179.98944091796875 -84.327217102050781 530.0400390625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 72 179.99116516113281 -84.326042175292969 550.04144287109375 0 0 -1 -0.00017512141494080424 0.99999994039535522 0 1 0.00017512141494080424 0 6536.dat 1 72 159.98873901367187 -64.32672119140625 510.04046630859375 0.99999994039535522 0 0 0 0 -1 0 1 0 11214.dat 1 72 179.9886474609375 -64.324966430664062 510.04046630859375 1 0.00017512147314846516 0 0.00017512147314846516 -1 0 0 0 -1 6536.dat 1 0 150.00605773925781 -96.324958801269531 614.02471923828125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 160.00599670410156 -112.32511138916016 626.02459716796875 0 -1.0000001192092896 0 -0.59998881816864014 0 0.80000847578048706 -0.80000847578048706 0 -0.59998875856399536 32316.dat 1 0 99.9903564453125 -64.327415466308594 490.0384521484375 -1 0 0 0 0 1 0 1 0 32054.dat 1 4 130.00596618652344 -64.325424194335938 490.02471923828125 -1 0 0 0 1 0 0 0 -1 32062.dat 1 1 150.00602722167969 -112.32723999023437 626.02496337890625 -1 0 0 0 0.60000103712081909 0.79999947547912598 0 0.79999947547912598 -0.60000073909759521 43093.dat 1 72 140.00611877441406 -64.327468872070312 490.02484130859375 0 1 0 -1 0 0 0 0 0.99999994039535522 6629.dat 1 0 150.00605773925781 -144.32546997070312 650.0240478515625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 140.00605773925781 -144.32550048828125 650.02423095703125 0 0 1 0 0.99999994039535522 0 -1 0 0 42003.dat 1 1 140.00608825683594 -164.32550048828125 660.024169921875 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 1 120.00613403320312 -124.32549285888672 650.0240478515625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 120.01612091064453 -104.62641906738281 640.00006103515625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 71 120.01612091064453 -124.62641143798828 649.99993896484375 0 0 1 0 -1 0 1 0 0 32184.dat 1 19 120.01612091064453 -144.62643432617187 659.99993896484375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 6562.dat 1 19 120.01709747314453 -144.63275146484375 759.98675537109375 0 -0.9743695855140686 -0.22495317459106445 0 -0.22495315968990326 0.9743695855140686 -1 0 0 6562.dat 1 0 158.99075317382812 -135.63858032226562 744.985107421875 -0.22495409846305847 0 -0.9743693470954895 0.9743693470954895 0 -0.22495414316654205 0 -1 0 11478.dat 1 28 197.96658325195312 -126.63471984863281 709.98687744140625 0 0.22495792806148529 -0.97436857223510742 0 -0.97436851263046265 -0.22495792806148529 -1.0000001192092896 0 0 15462.dat 1 0 197.96696472167969 -126.63459777832031 754.98687744140625 -0.22495795786380768 0 -0.97436857223510742 0.97436857223510742 0 -0.22495807707309723 0 -1.0000001192092896 0 41677.dat 1 28 178.47941589355469 -131.13372802734375 709.98687744140625 0 0.22495840489864349 -0.9743683934211731 0 -0.9743683934211731 -0.22495840489864349 -1 0 0 15462.dat 1 0 197.96664428710937 -126.63470458984375 689.98687744140625 0.22495868802070618 0 0.97436845302581787 -0.97436845302581787 0 0.22495856881141663 0 -1.0000001192092896 0 60483.dat 1 0 197.96661376953125 -126.63478851318359 729.98681640625 0.22495868802070618 0 0.97436845302581787 -0.97436845302581787 0 0.22495856881141663 0 -1.0000001192092896 0 60483.dat 1 0 197.96681213378906 -126.63463592529297 709.98675537109375 -0.22495584189891815 0 -0.97436904907226563 0.97436904907226563 0 -0.22495590150356293 0 -1.0000001192092896 0 60483.dat 1 28 139.50425720214844 -140.13214111328125 709.98687744140625 0 0.22495780885219574 -0.9743686318397522 0 -0.97436851263046265 -0.22495780885219574 -1.0000001192092896 0 0 15462.dat 1 0 139.50431823730469 -140.133544921875 754.98687744140625 -0.22495776414871216 0 -0.9743686318397522 0.9743686318397522 0 -0.22495792806148529 0 -1.0000001192092896 0 41677.dat 1 0 158.99128723144531 -135.63998413085937 669.98504638671875 0.22487424314022064 0 0.97438782453536987 -0.97438782453536987 0 0.22487421333789825 0 -1 0 32316.dat 1 71 178.478271484375 -111.13066864013672 689.98651123046875 -1 0 0 0 0 -1 0 -1 0 32316.dat 1 19 178.478271484375 -71.130653381347656 709.98651123046875 0 0.13910017907619476 0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 -1.0000001192092896 0 0 32556.dat 1 72 178.478271484375 -71.130577087402344 709.986572265625 0.22487424314022064 0 0.97438782453536987 -0.97438782453536987 0 0.22487421333789825 0 -1 0 32316.dat 1 72 139.50408935546875 -80.12274169921875 749.9884033203125 -0.22495889663696289 0 -0.97436833381652832 0.97436833381652832 0 -0.22495895624160767 0 -1.0000001192092896 0 60483.dat 1 71 139.50218200683594 -80.124923706054688 709.98651123046875 0 -0.22495883703231812 0.97436827421188354 0 0.97436827421188354 0.22495883703231812 -1 0 0 32073.dat 1 72 139.50405883789062 -80.122879028320312 669.98846435546875 -0.22495889663696289 0 -0.97436833381652832 0.97436833381652832 0 -0.22495895624160767 0 -1.0000001192092896 0 60483.dat 1 72 139.50259399414062 -80.126548767089844 689.98663330078125 0.22495883703231812 0 0.97436833381652832 -0.97436833381652832 0 0.22495879232883453 0 -1 0 60483.dat 1 72 139.50270080566406 -80.126533508300781 729.98663330078125 0.22495883703231812 0 0.97436833381652832 -0.97436833381652832 0 0.22495879232883453 0 -1 0 60483.dat 1 1 158.99050903320312 -75.628128051757813 709.986572265625 0 0.87757194042205811 -0.47944509983062744 0 -0.47944504022598267 -0.87757194042205811 -1.0000001192092896 0 0 6558.dat 1 4 237.45376586914062 -112.13556671142578 669.98687744140625 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 41678.dat 1 0 237.45384216308594 -102.13557434082031 669.9869384765625 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 3705.dat 1 4 237.45384216308594 -82.135566711425781 669.9869384765625 0 -1 0 1 0 0 0 0 0.99999994039535522 6536.dat 1 4 237.45384216308594 -112.13556671142578 669.9869384765625 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 6590.dat 1 4 237.45384216308594 -67.135581970214844 669.9869384765625 0 0 -1 0 0.99999994039535522 0 1 0 0 41677.dat 1 4 237.45384216308594 -137.13557434082031 669.9869384765625 0 0 -1 0 0.99999994039535522 0 1 0 0 41677.dat 1 0 217.45376586914062 -82.135581970214844 754.9866943359375 0.99999994039535522 0 0 0 0 -1 0 1 0 6632.dat 1 28 217.45376586914062 -82.135597229003906 709.9866943359375 0 0 1 0 0.99999994039535522 0 -1 0 0 15462.dat 1 0 217.45376586914062 -82.135597229003906 744.98681640625 0.99999994039535522 0 0 0 0 -1 0 1 0 6632.dat 1 71 217.45376586914062 -62.135677337646484 709.98675537109375 0 0 -1 0 0.99999994039535522 0 1 0 0 4519.dat 1 0 217.45376586914062 -62.135578155517578 689.9866943359375 -1 0 0 0 0 -1 0 -1 0 33299a.dat 1 71 217.45376586914062 -82.135604858398437 724.98675537109375 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 71 217.45376586914062 -82.135604858398437 694.98663330078125 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 0 217.45376586914062 -62.135589599609375 729.9866943359375 0.99999994039535522 0 0 0 0 -1 0 1 0 33299a.dat 1 28 217.45376586914062 -122.13558959960937 709.9866943359375 0 0 1 0 0.99999994039535522 0 -1 0 0 15462.dat 1 71 217.45376586914062 -102.13558959960937 709.9866943359375 0 0 -1 0 1 0 1 0 0 11950.dat 1 72 247.203857421875 -102.13603973388672 709.98663330078125 0 2.2660628019366413E-005 -1 0 0.99999994039535522 2.2660628019366413E-005 1 0 0 92909.dat 1 71 217.45542907714844 -102.13029479980469 709.99853515625 -0.22494953870773315 0 -0.97437041997909546 0.97437041997909546 0 -0.22494956851005554 0 -1 0 32494.dat 1 71 169.95480346679687 -113.09664154052734 709.99853515625 -0.97437036037445068 -0.22494971752166748 0 -0.22494971752166748 0.97437036037445068 0 0 0 -1 4519.dat 1 71 120.01787567138672 -124.62582397460937 709.99853515625 -0.22494968771934509 0 0.97437041997909546 0.97437041997909546 0 0.22494970262050629 0 1 0 32494.dat 1 72 120.01802825927734 -124.62577819824219 709.998291015625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 92906.dat 1 4 70.018096923828125 -124.62577819824219 709.99853515625 0 0 -1 0 0.99999994039535522 0 1 0 0 59443.dat 1 71 40.017986297607422 -124.62577819824219 709.998291015625 -1 0 0 0 1 0 0 0 -1 4519.dat 1 19 17.016458511352539 -124.62620544433594 710.0010986328125 0 -1.3719112757826224E-005 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 -1.3656633200298529E-005 6589.dat 1 0 100.01808166503906 -124.626220703125 709.99853515625 1.4738240679434966E-005 -1 0 1 1.4738240679434966E-005 0 0 0 1 15100.dat 1 0 60.017604827880859 -104.62565612792969 650.00030517578125 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 71 60.018383026123047 -104.62623596191406 709.99853515625 0 0 -1 0 0.99999994039535522 0 1 0 0 32073.dat 1 71 60.018367767333984 -104.62622833251953 689.9984130859375 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 6536.dat 1 71 60.018367767333984 -104.62622833251953 729.99853515625 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 6536.dat 1 72 60.018402099609375 -124.62518310546875 749.99847412109375 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 42003.dat 1 71 80.018333435058594 -104.62623596191406 709.99853515625 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 42003.dat 1 71 60.01763916015625 -104.62564086914062 650.00030517578125 0 1.0000001192092896 -1.4382368135557044E-005 0 -1.4260476746130735E-005 -1.0000001192092896 -1.0000001192092896 0 0 14720.dat 1 1 80.016273498535156 -144.62615966796875 649.99981689453125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 71 100.01608276367187 -124.62628173828125 649.99969482421875 0.99999994039535522 0 1.2498033356678206E-005 1.2498033356678206E-005 0 -1 0 1 0 14720.dat 1 0 100.01663208007812 -164.62628173828125 659.999755859375 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 1 79.990402221679688 -84.327232360839844 630.02557373046875 0 0 -1 0 0.99999994039535522 0 1 0 0 6558.dat 1 72 79.990402221679688 -104.32723999023437 510.02554321289063 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 60483.dat 1 71 79.990394592285156 -104.32723999023437 530.02557373046875 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 79.990394592285156 -104.32723999023437 610.0255126953125 0 0 1 0 1 0 -1 0 0 18651.dat 1 71 79.990402221679688 -104.32722473144531 570.0255126953125 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 32034.dat 1 72 79.990402221679688 -104.32723999023437 610.02557373046875 -1 0 0 0 0 1 0 1 0 60483.dat 1 72 79.990402221679688 -104.32723999023437 530.025634765625 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 0 99.990478515625 -104.32760620117187 500.05368041992187 0 0 1 0 1 0 -1 0 0 2780.dat 1 1 80.005851745605469 -124.32427215576172 480.041015625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 79.990402221679688 -124.32723236083984 510.0255126953125 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 0 80.005599975585938 -124.32428741455078 470.04104614257812 0.99999994039535522 1.4797114999964833E-005 0 0 0 1 1.4797114999964833E-005 -1 0 15100.dat 1 1 115.99036407470703 -104.3272705078125 570.025634765625 0.99999994039535522 0 0 0 0 1 0 -1 0 43093.dat 1 72 120.99046325683594 -84.327278137207031 570.025634765625 0 1 0 0 0 -1 -1 0 0 41677.dat 1 72 79.990409851074219 -84.327278137207031 570.025634765625 0 1 0 -1 0 0 0 0 0.99999994039535522 6553.dat 1 72 110.99044036865234 -124.32726287841797 570.025634765625 0 1 0 0 0 1 1 0 0 6632.dat 1 71 115.99044799804687 -124.32727813720703 570.025634765625 -1 0 0 0 1 0 0 0 -1 2736.dat 1 4 99.990325927734375 -124.32726287841797 570.025634765625 0 0 1 -1 0 0 0 -1 0 6641.dat 1 71 79.990409851074219 -104.32722473144531 570.025634765625 0 1 0 -1 0 0 0 0 0.99999994039535522 4519.dat 1 0 127.99043273925781 -124.32727813720703 410.02560424804687 0 -1 0 1 0 0 0 0 0.99999994039535522 32293.dat 1 1 100.01718902587891 -84.625213623046875 629.9857177734375 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 1 59.990440368652344 -144.32762145996094 670.0391845703125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 59.990440368652344 -144.32723999023437 630.02569580078125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 59.991012573242188 -64.32708740234375 630.03997802734375 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 60.017986297607422 -84.625648498535156 650.00030517578125 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 0 60.017414093017578 -124.62565612792969 650.00030517578125 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 72 0.017201900482177734 -124.62522888183594 629.98577880859375 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 0 100.01718139648437 -124.62522888183594 619.98565673828125 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 -59.982669830322266 -124.62331390380859 650.00164794921875 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 0 -19.981550216674805 -124.62518310546875 640.01300048828125 0 -0.033155404031276703 -0.99945026636123657 0 0.99945032596588135 -0.033155404031276703 1 0 0 2780.dat 1 0 20.014595031738281 -124.61511993408203 640.013427734375 0 0.032980550080537796 -0.99945604801177979 0 0.99945604801177979 0.032980550080537796 1 0 0 2780.dat 1 0 0.014311827719211578 -124.6151123046875 489.93829345703125 0.98078560829162598 -0.19508866965770721 0 0.19508866965770721 0.98078560829162598 0 0 0 1 32270.dat 1 0 0.016676435247063637 -124.62522888183594 540.0146484375 0 -0.19434258341789246 0.98093384504318237 0 0.98093384504318237 0.19434258341789246 -1.0000001192092896 0 0 3737.dat 1 71 0.014459313824772835 -124.61511993408203 469.43841552734375 0.98093342781066895 -0.19434405863285065 0 0.19434405863285065 0.98093342781066895 0 0 0 1 4019.dat 1 71 0.014680624008178711 -124.61509704589844 410.01339721679687 0 0 -1 0 0.99999994039535522 0 1 0 0 64179.dat 1 71 0.01459270715713501 -104.61508941650391 450.01336669921875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 48989.dat 1 0 -69.98541259765625 -124.61511993408203 410.01339721679687 1 0 0 0 1 0 0 0 1 3705.dat 1 71 -19.985443115234375 -124.6151123046875 410.01339721679687 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32034.dat 1 0 50.014732360839844 -124.61511993408203 410.01339721679687 1 0 0 0 1 0 0 0 1 3706.dat 1 72 105.01473999023437 -124.61511993408203 390.0133056640625 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 14 40.043613433837891 -124.61514282226562 410.01339721679687 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32072.dat 1 71 110.01470184326172 -124.61511993408203 390.0133056640625 -1 0 0 0 1 0 0 0 -1 2736.dat 1 72 -104.98534393310547 -144.61514282226562 410.01339721679687 0 0.99999994039535522 0 0 0 0.99999994039535522 0.99999994039535522 0 0 41677.dat 1 71 -109.98530578613281 -144.61514282226562 410.01339721679687 0.99999994039535522 0 0 0 0 -1 0 1 0 2736.dat 1 72 95.014694213867188 -124.61511993408203 390.0133056640625 0 -1 0 1 0 0 0 0 0.99999994039535522 41677.dat 1 72 -94.985298156738281 -144.61514282226562 410.01339721679687 0 0.99999994039535522 0 0 0 0.99999994039535522 0.99999994039535522 0 0 41677.dat 1 72 -79.985382080078125 -104.61512756347656 410.01339721679687 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 32523.dat 1 71 -69.985374450683594 -84.615127563476563 410.01339721679687 -1 0 0 0 1 0 0 0 -1 3673.dat 1 72 -59.992355346679688 -84.327888488769531 350.02529907226563 0 -1 0 -1 0 0 0 0 -1 32524.dat 1 0 -49.992275238037109 -84.327613830566406 290.0252685546875 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 72 -39.992279052734375 -84.32733154296875 270.0252685546875 0 -1 0 -1 0 0 0 0 -1 32316.dat 1 0 -29.992277145385742 -84.327056884765625 250.02525329589844 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 72 -19.99247932434082 -59.328414916992188 290.02496337890625 0 0 1 0 0.99999994039535522 0 -1 0 0 6632.dat 1 4 20.007526397705078 -74.328414916992188 290.02499389648437 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 32062.dat 1 72 20.007526397705078 -84.328422546386719 270.0250244140625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 42003.dat 1 72 -19.992456436157227 -69.328407287597656 290.02496337890625 0 0 1 0 0.99999994039535522 0 -1 0 0 6632.dat 1 72 -19.992403030395508 -84.327323913574219 270.02520751953125 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 42003.dat 1 4 -19.992403030395508 -74.327323913574219 290.02517700195313 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 32062.dat 1 0 30.007530212402344 -84.328147888183594 270.0250244140625 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 72 40.007644653320312 -84.327598571777344 270.02505493164063 0 -1 0 -1 0 0 0 0 -1 32316.dat 1 14 -9.9923877716064453 -184.32783508300781 230.02507019042969 0 1 0 0 0 1 1 0 0 32006.dat 1 4 0.0075712800025939941 -184.32783508300781 230.02507019042969 -1 0 0 0 1 0 0 0 -1 32062.dat 1 14 10.007682800292969 -184.32781982421875 230.02507019042969 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 32006.dat 1 71 0.0076472759246826172 -124.32785034179687 230.02505493164062 1 0 0 0 1 0 0 0 1 32073.dat 1 72 -24.992469787597656 -114.32783508300781 230.02507019042969 0 1 0 0 0 -1 -1 0 0 32449.dat 1 19 -29.992389678955078 -84.32733154296875 230.0252685546875 0.99999994039535522 0 0 0 0 1 0 -1 0 6562.dat 1 72 -14.992430686950684 -114.32783508300781 230.02507019042969 0 1 0 0 0 -1 -1 0 0 32449.dat 1 71 0.0075697898864746094 -144.32785034179687 230.02507019042969 1 0 0 0 1 0 0 0 1 4519.dat 1 19 30.007684707641602 -84.327857971191406 230.02507019042969 -1 0 0 0 0 1 0 1 0 6562.dat 1 72 25.007530212402344 -114.32785797119141 230.02507019042969 0 1 0 0 0 -1 -1 0 0 32449.dat 1 72 15.007683753967285 -114.32785797119141 230.02507019042969 0 1 0 0 0 -1 -1 0 0 32449.dat 1 0 -29.992467880249023 -104.32784271240234 230.02507019042969 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 -39.992435455322266 -104.32784271240234 230.02507019042969 0 1 0 1 0 0 0 0 -1 18654.dat 1 0 30.007535934448242 -104.32785797119141 230.02507019042969 1 0 0 0 1 0 0 0 1 2780.dat 1 72 40.007503509521484 -104.32785797119141 230.02507019042969 0 -1 0 1 0 0 0 0 0.99999994039535522 18654.dat 1 0 30.007648468017578 -84.327873229980469 250.02508544921875 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 0 50.007534027099609 -84.327598571777344 310.0250244140625 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 72 60.007720947265625 -84.327873229980469 350.02511596679687 0 -1 0 -1 0 0 0 0 -1 32524.dat 1 0 50.007652282714844 -84.327323913574219 290.02508544921875 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 14 40.043621063232422 -84.614700317382813 410.0133056640625 0 0 1 0.70658957958221436 -0.70762360095977783 0 0.70762366056442261 0.70658957958221436 0 32072.dat 1 72 50.0076904296875 -84.328147888183594 410.0252685546875 0.99999994039535522 0 0 0 -0.70762330293655396 -0.70658987760543823 0 0.70658987760543823 -0.70762330293655396 87083.dat 1 72 20.043621063232422 -104.61514282226562 410.01339721679687 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 32523.dat 1 72 80.007606506347656 -104.32784271240234 410.02520751953125 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 32523.dat 1 0 -29.992395401000977 -84.32733154296875 270.02517700195313 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 0 -49.992465972900391 -84.327613830566406 310.02520751953125 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 71 20.014589309692383 -144.61509704589844 370.013427734375 0 -1 0 -1 0 0 0 0 -1 87082.dat 1 0 20.014514923095703 -164.61509704589844 370.013427734375 1 1.4743282008566894E-005 0 1.4743282008566894E-005 -1 0 0 0 -1 15100.dat 1 72 40.007644653320312 -164.32792663574219 390.02554321289062 0 -1 -1.6248901374638081E-005 -1 0 1.6372534446418285E-005 -1.6372536265407689E-005 1.6248899555648677E-005 -1 32316.dat 1 1 40.007652282714844 -164.32858276367187 430.02557373046875 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -19.985017776489258 -204.62344360351562 430.0009765625 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 32316.dat 1 71 0.014871358871459961 -204.62400817871094 430.00088500976563 0 0 -1 0 -1 0 -1 0 0 48989.dat 1 0 20.014877319335938 -204.62400817871094 430.00088500976563 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 32316.dat 1 0 40.014873504638672 -204.62405395507812 430.00091552734375 0.99999994039535522 0 0 0 0 -1 0 1 0 18651.dat 1 0 40.007625579833984 -324.32913208007812 350.02557373046875 0 -1.0000001192092896 0 0.7999996542930603 0 0.60000061988830566 -0.60000061988830566 0 0.79999971389770508 6629.dat 1 0 60.000957489013672 -204.41342163085937 450.06991577148437 0.99999994039535522 0 0 0 0 -1 0 1 0 42003.dat 1 0 40.007625579833984 -324.3291015625 350.02557373046875 -1 0 0 0 0.7999991774559021 -0.60000109672546387 0 -0.60000109672546387 -0.7999991774559021 18651.dat 1 0 -39.985103607177734 -324.62680053710937 350.00167846679687 0 -1.0000001192092896 0 0.79999953508377075 0 0.60000073909759521 -0.60000073909759521 0 0.79999959468841553 6629.dat 1 0 -39.985107421875 -324.62686157226562 350.00167846679687 1 0 0 0 -0.60000085830688477 0.79999935626983643 0 -0.79999935626983643 -0.60000085830688477 18651.dat 1 0 0.014895200729370117 -324.62689208984375 350.00167846679687 0 0 1.0000001192092896 -0.79999947547912598 -0.60000073909759521 0 0.60000085830688477 -0.79999947547912598 0 32034.dat 1 0 -39.985012054443359 -204.62420654296875 430.00091552734375 -1 0 0 0 0 -1.0000001192092896 0 -1.0000001192092896 0 18651.dat 1 0 -59.999050140380859 -204.41378784179687 450.06991577148437 0.99999994039535522 0 0 0 0 -1 0 1 0 42003.dat 1 0 -29.985029220581055 -244.62344360351562 430.0009765625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 0.014883597381412983 -224.62400817871094 440.00091552734375 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 71 -19.984991073608398 -144.6229248046875 370.00103759765625 0 -1 0 -1 0 0 0 0 -1 87082.dat 1 0 -19.985113143920898 -164.62290954589844 370.00103759765625 -1 0 0 0 -1 0 0 0 1 15100.dat 1 0 -49.985408782958984 -124.61511993408203 430.01345825195312 1 0 0 0 1 0 0 0 1 2780.dat 1 71 -39.985446929931641 -124.61513519287109 390.01336669921875 0 0 1 0 0.99999994039535522 0 -1 0 0 32184.dat 1 71 -39.985458374023438 -144.61512756347656 410.0133056640625 0 0 1 0 1 0 -1 0 0 4519.dat 1 71 -39.985446929931641 -124.61513519287109 430.01351928710937 0 0 1 0 0.99999994039535522 0 -1 0 0 32184.dat 1 72 -39.943103790283203 -104.62541198730469 422.01351928710937 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 87083.dat 1 71 -29.985177993774414 -144.61512756347656 410.01382446289062 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 43857.dat 1 14 -19.985179901123047 -144.61512756347656 425.01345825195312 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 4 -19.985185623168945 -144.61512756347656 410.01348876953125 0 0 1 0 1 0 -1 0 0 32062.dat 1 14 -19.985179901123047 -144.61514282226562 395.0135498046875 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 0 -49.985408782958984 -124.61511993408203 390.01348876953125 1 0 0 0 1 0 0 0 1 2780.dat 1 72 40.057010650634766 -64.62542724609375 450.01339721679687 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32526.dat 1 1 -19.984989166259766 -64.615158081054687 470.08847045898437 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 72 -79.985031127929688 -84.615158081054687 490.0885009765625 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32140.dat 1 0 -59.985153198242188 -84.615158081054687 500.08840942382812 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 -19.984983444213867 -84.615165710449219 500.08840942382812 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 2780.dat 1 71 -39.9852294921875 -84.615341186523438 530.5885009765625 -0.98093348741531372 0.19434385001659393 0 0.19434385001659393 0.9809335470199585 0 0 0 -1 4019.dat 1 0 -40.009365081787109 -84.327606201171875 520.05364990234375 0 0.19434256851673126 0.98093384504318237 0 0.98093384504318237 -0.19434256851673126 -1.0000001192092896 0 0 3705.dat 1 71 -39.928607940673828 -84.625434875488281 550.0133056640625 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 44809.dat 1 1 -59.928573608398438 -64.62542724609375 550.01336669921875 -1 0 0 0 1 0 0 0 -1 6558.dat 1 71 -59.928657531738281 -64.62542724609375 570.0133056640625 0 -1 0 -1 0 0 0 0 -1 32523.dat 1 0 -69.92864990234375 -64.62542724609375 590.0133056640625 1 0 0 0 -1 0 0 0 -1 2780.dat 1 0 -49.928569793701172 -64.62542724609375 570.01324462890625 1 0 0 0 -1 0 0 0 -1 2780.dat 1 71 -39.928607940673828 -84.625434875488281 570.0133056640625 -1 0 0 0 0 -1 0 -1 0 44809.dat 1 72 -39.985263824462891 -84.615135192871094 590.08831787109375 -0.98078584671020508 0.19508759677410126 0 0.19508759677410126 0.98078596591949463 0 0 0 -1 10928.dat 1 0 -39.984466552734375 -84.626274108886719 599.99993896484375 0 0.19434256851673126 0.9809337854385376 0 0.98093372583389282 -0.19434256851673126 -1 0 0 3705.dat 1 71 -39.985260009765625 -84.615028381347656 610.58837890625 -0.98078584671020508 0.19508759677410126 0 0.19508759677410126 0.98078596591949463 0 0 0 -1 4019.dat 1 71 -19.985410690307617 -84.6151123046875 470.013427734375 0 1 0 0 0 -1 -1 0 0 44809.dat 1 1 40.057010650634766 -64.62542724609375 440.01339721679687 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 4274.dat 1 1 19.990365982055664 -64.327239990234375 470.0400390625 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 71 20.014741897583008 -84.6151123046875 470.013427734375 0 1 0 0 0 -1 -1 0 0 44809.dat 1 71 -29.985177993774414 -104.61514282226562 410.013427734375 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 43857.dat 1 14 -19.985179901123047 -104.61514282226562 425.01345825195312 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 4 -19.985185623168945 -104.61514282226562 410.01348876953125 0 0 1 0 1 0 -1 0 0 32062.dat 1 14 -19.985179901123047 -104.61514282226562 395.0135498046875 -1 0 0 0 1 0 0 0 -1 32123a.dat 1 1 40.014667510986328 -124.61509704589844 350.01345825195312 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 71 -59.985340118408203 -144.61509704589844 450.01336669921875 0 1 0 -1 0 0 0 0 0.99999994039535522 87082.dat 1 71 35.011367797851563 -184.6484375 449.99981689453125 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 6632.dat 1 71 0.010991096496582031 -184.65509033203125 449.99981689453125 -1 -0.00016966515977401286 0 -0.00016966515977401286 1 0 0 0 -1 32073.dat 1 71 0.011238717474043369 -184.65541076660156 449.99984741210937 1 0 0 0 1 0 0 0 1 63869.dat 1 71 -19.986007690429688 -184.66098022460937 449.99942016601562 1 0.00017512515478301793 0 0.00017512515478301793 -1 0 0 0 -1 6536.dat 1 71 20.011337280273438 -184.6513671875 449.99981689453125 1 0.0001751214440446347 0 0.0001751214440446347 -1 0 0 0 -1 6536.dat 1 71 -34.989059448242188 -184.65982055664062 449.99981689453125 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 6632.dat 1 72 -60.021339416503906 -144.32713317871094 450.0244140625 0.99999994039535522 0 0 0 0 -1 0 1 0 11214.dat 1 72 59.990406036376953 -144.32743835449219 450.039306640625 -1 0 0 0 0 -1 0 -1 0 11214.dat 1 71 -45.021312713623047 -144.32725524902344 450.0244140625 0 0 -1 0 0.99999994039535522 0 1 0 0 32123a.dat 1 71 44.990749359130859 -144.3270263671875 450.039306640625 0 0 -1 0 0.99999994039535522 0 1 0 0 32123a.dat 1 1 -19.982318878173828 -204.66098022460937 470.0003662109375 0 0 -1 0 0.99999994039535522 0 1 0 0 6558.dat 1 14 -36.213623046875 -191.73233032226562 499.99008178710937 0.62620806694030762 0.77965599298477173 0 -0.77965599298477173 0.62620806694030762 0 0 0 1 2851.dat 1 71 -52.391 -205.035 500.012 -0.626 0.78 0 0.78 0.626 0 0 0 -1 2850.dat 1 0 -45.030574798583984 -173.47471618652344 520.0003662109375 0 -0.033155407756567001 -0.99945026636123657 0 0.99945032596588135 -0.033155407756567001 1 0 0 2780.dat 1 14 -26.426549911499023 -184.38711547851562 540.01275634765625 0.62620770931243896 0.77965623140335083 0 -0.77965623140335083 0.62620770931243896 0 0 0 1 2851.dat 1 71 -52.388 -205.037 539.989 0.626 0.78 0 -0.78 0.626 0 0 0 1 2850.dat 1 0 -19.982503890991211 -204.66098022460937 560.00048828125 0 -0.033155407756567001 -0.99945026636123657 0 0.99945032596588135 -0.033155407756567001 1 0 0 2780.dat 1 71 -52.387 -205.036 579.989 0.626 0.78 0 -0.78 0.626 0 0 0 1 2850.dat 1 14 -36.241355895996094 -191.47140502929687 580.00146484375 0.62620818614959717 0.77965587377548218 0 -0.77965587377548218 0.62620818614959717 0 0 0 1 2851.dat 1 71 0.018709897994995117 -174.64923095703125 580.001708984375 -0.42103633284568787 0.90704375505447388 0 0.90704375505447388 0.42103630304336548 0 0 0 -1 2852.dat 1 71 -0.0085586700588464737 -164.38862609863281 500.01287841796875 0 -1 0 1 0 0 0 0 0.99999994039535522 2853.dat 1 4 0.0078317327424883842 -164.65519714355469 469.99978637695312 0 0 1 0 1 0 -1 0 0 32062.dat 1 19 0.018709897994995117 -164.64889526367187 520.0013427734375 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 2854.dat 1 4 0.018716175109148026 -154.64889526367187 540.00140380859375 0 0 -1 0 0.99999994039535522 0 1 0 0 32062.dat 1 19 0.018709897994995117 -164.64901733398437 560.00152587890625 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 2854.dat 1 4 0.018716175109148026 -174.64921569824219 580.00152587890625 0 0 -1 0 0.99999994039535522 0 1 0 0 32062.dat 1 71 -0.0085651874542236328 -164.38862609863281 469.51300048828125 1 0 0 0 1 0 0 0 1 4019.dat 1 19 0.018709897994995117 -164.64921569824219 600.00146484375 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 2854.dat 1 4 -0.0089403791353106499 -154.38983154296875 620.01312255859375 0 0 -1 0 0.99999994039535522 0 1 0 0 32062.dat 1 71 0.016618330031633377 -154.62742614746094 650.00103759765625 0 -1 0 1 0 0 0 0 0.99999994039535522 2853.dat 1 71 0.018709897994995117 -174.64923095703125 580.0015869140625 0.42103579640388489 -0.90704405307769775 0 0.90704405307769775 0.42103579640388489 0 0 0 1 2852.dat 1 14 36.278579711914063 -191.47352600097656 580.00146484375 -0.62612056732177734 -0.77972632646560669 0 -0.77972632646560669 0.62612068653106689 0 0 0 -1 2851.dat 1 71 52.42 -205.022 579.989 0.626 -0.78 0 0.78 0.626 0 0 0 1 2850.dat 1 0 45.058452606201172 -173.44126892089844 600.00030517578125 0 -0.032980520278215408 0.99945604801177979 0 0.99945604801177979 0.032980520278215408 -1 0 0 2780.dat 1 14 26.408723831176758 -184.38716125488281 620.0130615234375 -0.62612110376358032 -0.77972579002380371 0 -0.77972579002380371 0.62612110376358032 0 0 0 -1 2851.dat 1 71 52.415 -205.07 620.011 -0.626 -0.78 0 -0.78 0.626 0 0 0 -1 2850.dat 1 72 20.009527206420898 -204.69448852539062 650.00018310546875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 71 20.009542465209961 -204.69448852539062 690.00018310546875 -1 0 0 0 -1 0 0 0 1 32013.dat 1 71 -34.980800628662109 -184.61892700195312 650.00115966796875 0 0.99999994039535522 0 0 0 0.99999994039535522 0.99999994039535522 0 0 41677.dat 1 71 0.015580654144287109 -184.61799621582031 650.00115966796875 -1 0 0 0 1 0 0 0 -1 32073.dat 1 71 20.01695442199707 -184.63026428222656 650.00115966796875 -1 0 0 0 -1 0 0 0 1 6536.dat 1 71 35.020195007324219 -184.61892700195312 650.00115966796875 0 0.99999994039535522 0 0 0 0.99999994039535522 0.99999994039535522 0 0 41677.dat 1 71 -19.980709075927734 -184.62026977539062 650.00115966796875 -1 0 0 0 -1 0 0 0 1 6536.dat 1 71 0.019869374111294746 -184.62739562988281 650.0009765625 1 0 0 0 1 0 0 0 1 63869.dat 1 0 -19.979452133178711 -164.63395690917969 660.000732421875 0 -0.033155404031276703 -0.99945026636123657 0 0.99945032596588135 -0.033155404031276703 1 0 0 2780.dat 1 0 20.016693115234375 -164.62388610839844 660.0010986328125 0 0.032980550080537796 -0.99945604801177979 0 0.99945604801177979 0.032980550080537796 1 0 0 2780.dat 1 72 -19.984165191650391 -204.62026977539062 650.0001220703125 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 71 -19.984157562255859 -204.62026977539062 690.0001220703125 -1 0 0 0 -1 0 0 0 1 32013.dat 1 71 -52.392 -205.055 620.011 -0.626 0.78 0 0.78 0.626 0 0 0 -1 2850.dat 1 14 -27.291675567626953 -183.94235229492187 620.0362548828125 0.62620681524276733 0.77965700626373291 0 -0.77965700626373291 0.62620681524276733 0 0 0 1 2851.dat 1 1 -45.030963897705078 -173.45433044433594 640.00042724609375 0 0.72355848550796509 -0.69026309251785278 0 0.69026315212249756 0.72355848550796509 1 0 0 43093.dat 1 0 -45.030967712402344 -173.454345703125 600.00030517578125 0 -0.032980520278215408 0.99945604801177979 0 0.99945604801177979 0.032980520278215408 -1 0 0 2780.dat 1 71 -0.0089466571807861328 -154.38983154296875 620.01312255859375 -0.75037914514541626 0.66100764274597168 0 0.66100764274597168 0.75037902593612671 0 0 0 -1 2852.dat 1 0 -19.982706069946289 -204.64057922363281 600.00030517578125 0 -0.032980557531118393 0.99945604801177979 0 0.99945604801177979 0.032980557531118393 -1 0 0 2780.dat 1 0 20.014202117919922 -204.650634765625 600.00030517578125 0 0.033155389130115509 0.99945026636123657 0 0.99945032596588135 -0.033155389130115509 -1 0 0 2780.dat 1 71 -0.0089466571807861328 -154.38983154296875 620.01300048828125 0.75037866830825806 -0.66100823879241943 0 0.66100823879241943 0.75037866830825806 0 0 0 1 2852.dat 1 1 45.058460235595703 -173.44126892089844 640.000244140625 0 0.72355848550796509 -0.69026309251785278 0 0.69026315212249756 0.72355848550796509 1 0 0 43093.dat 1 0 20.014595031738281 -204.65087890625 560.00048828125 0 0.032980538904666901 -0.99945604801177979 0 0.99945604801177979 0.032980538904666901 1 0 0 2780.dat 1 71 52.42 -205.024 539.99 0.626 -0.78 0 0.78 0.626 0 0 0 1 2850.dat 1 14 27.27375602722168 -184.83125305175781 539.989501953125 -0.62612080574035645 -0.77972608804702759 0 -0.77972608804702759 0.626120924949646 0 0 0 -1 2851.dat 1 71 -0.0087559223175048828 -154.3895263671875 540.01287841796875 0.75037866830825806 -0.66100823879241943 0 0.66100823879241943 0.75037866830825806 0 0 0 1 2852.dat 1 0 20.014595031738281 -204.65092468261719 520.000732421875 0 0.032980538904666901 -0.99945604801177979 0 0.99945604801177979 0.032980538904666901 1 0 0 2780.dat 1 14 36.305244445800781 -191.73158264160156 499.990234375 -0.62612062692642212 -0.77972620725631714 0 -0.77972620725631714 0.62612044811248779 0 0 0 -1 2851.dat 1 71 52.416 -205.049 500.012 -0.626 -0.78 0 -0.78 0.626 0 0 0 -1 2850.dat 1 0 45.059608459472656 -173.46186828613281 520.000732421875 0 0.032980538904666901 -0.99945604801177979 0 0.99945604801177979 0.032980538904666901 1 0 0 2780.dat 1 1 20.014970779418945 -204.65135192871094 470.000732421875 0 0 -1 0 0.99999994039535522 0 1 0 0 6558.dat 1 71 32.538742065429688 -189.05815124511719 470.00079345703125 0.77966415882110596 0 -0.62619823217391968 -0.62619823217391968 0 -0.77966403961181641 0 1.0000001192092896 0 32523.dat 1 72 45.062698364257813 -173.46487426757812 470.00079345703125 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 71 0.046175718307495117 -174.90837097167969 499.990234375 0.42103567719459534 -0.90704405307769775 0 0.90704405307769775 0.42103567719459534 0 0 0 1 2852.dat 1 0 45.059608459472656 -173.46183776855469 560.00048828125 0 0.032980538904666901 -0.99945604801177979 0 0.99945604801177979 0.032980538904666901 1 0 0 2780.dat 1 71 0.046175718307495117 -174.90837097167969 499.99032592773437 -0.42103633284568787 0.90704381465911865 0 0.90704381465911865 0.42103651165962219 0 0 0 -1 2852.dat 1 71 -0.0087559223175048828 -154.3895263671875 540.01300048828125 -0.75037914514541626 0.66100764274597168 0 0.66100764274597168 0.75037902593612671 0 0 0 -1 2852.dat 1 0 -45.030574798583984 -173.47470092773437 560.00048828125 0 -0.033155407756567001 -0.99945026636123657 0 0.99945032596588135 -0.033155407756567001 1 0 0 2780.dat 1 0 -19.982503890991211 -204.66098022460937 520.0003662109375 0 -0.033155407756567001 -0.99945026636123657 0 0.99945032596588135 -0.033155407756567001 1 0 0 2780.dat 1 72 -45.030246734619141 -173.47438049316406 470.00027465820312 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 71 -32.506282806396484 -189.06765747070312 470.00030517578125 -0.77966392040252686 0 0.62619823217391968 -0.62619823217391968 0 -0.77966398000717163 0 -1.0000001192092896 0 32523.dat 1 71 60.014743804931641 -144.61509704589844 450.01336669921875 0 -1 0 -1 0 0 0 0 -1 87082.dat 1 4 40.014667510986328 -124.61511993408203 570.0885009765625 -1 0 0 0 1 0 0 0 -1 26287.dat 1 0 40.0146484375 -124.61511993408203 500.08843994140625 0 0 1 0 1 0 -1 0 0 3706.dat 1 71 40.014656066894531 -124.61511993408203 610.08843994140625 0 0 1 0 1 0 -1 0 0 4519.dat 1 71 40.014663696289063 -124.61511993408203 490.08840942382812 0 1 0 1 0 0 0 0 -1 6590.dat 1 71 40.014667510986328 -124.61511993408203 469.58831787109375 -1 0 0 0 -1 0 0 0 1 4019.dat 1 4 40.014667510986328 -124.61511993408203 610.08837890625 -1 0 0 0 1 0 0 0 -1 18946.dat 1 4 40.014667510986328 -124.61511993408203 530.0133056640625 -1 0 0 0 1 0 0 0 -1 18946.dat 1 0 -39.985256195068359 -124.61509704589844 490.08840942382812 -1 0 0 0 -1 0 0 0 1 32269.dat 1 0 -39.985275268554688 -124.61509704589844 500.08843994140625 0 0 1 0 1 0 -1 0 0 3706.dat 1 4 -39.985256195068359 -124.61509704589844 570.0885009765625 -1 0 0 0 1 0 0 0 -1 26287.dat 1 71 -39.985260009765625 -124.61509704589844 470.08853149414062 0 1 0 1 0 0 0 0 -1 6590.dat 1 71 -39.985267639160156 -124.61509704589844 610.08843994140625 0 0 1 0 1 0 -1 0 0 4519.dat 1 4 -39.985256195068359 -124.61511993408203 530.0133056640625 -1 0 0 0 1 0 0 0 -1 18946.dat 1 4 -39.985256195068359 -124.61511993408203 610.08837890625 -1 0 0 0 1 0 0 0 -1 18946.dat 1 0 -99.961090087890625 -124.90298461914062 620.01104736328125 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 50.018440246582031 -124.62518310546875 749.99847412109375 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 40.018482208251953 -114.62519073486328 689.9986572265625 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 50.018440246582031 -144.62518310546875 749.99847412109375 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 40.018482208251953 -114.62519073486328 729.9984130859375 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 72 0.016343593597412109 -124.62546539306641 710.00091552734375 5.0327347707934678E-005 1.3718065019929782E-005 -1.0000001192092896 0.99999988079071045 0.00069187971530482173 5.0200767873320729E-005 0.000691744324285537 -0.99999988079071045 -1.3547285561799072E-005 62821.dat 1 19 0.017182406038045883 -107.62547302246094 710.01129150390625 0.70712977647781372 0.70708394050598145 0 0 0 -1.0000001192092896 -0.70708394050598145 0.70712977647781372 0 6589.dat 1 72 197.96601867675781 -66.633155822753906 729.9866943359375 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 71 197.96603393554687 -66.633155822753906 709.98675537109375 0 0 -1 0 0.99999994039535522 0 1 0 0 4519.dat 1 72 197.96601867675781 -66.633148193359375 689.98675537109375 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 19 197.96601867675781 -86.633148193359375 709.986572265625 0 0.13910016417503357 0.99027842283248901 0 0.99027842283248901 -0.13910016417503357 -1.0000001192092896 0 0 32556.dat 1 71 178.47944641113281 -111.12902069091797 729.98687744140625 -1 0 0 0 0 -1 0 -1 0 32316.dat 1 0 178.47825622558594 -91.135551452636719 739.98992919921875 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 6628.dat 1 0 178.55426025390625 -91.313560485839844 750.75836181640625 -0.92270386219024658 0.0078539904206991196 -0.3854295015335083 0.34542587399482727 -0.4270692765712738 -0.83563911914825439 -0.17116817831993103 -0.90418475866317749 0.39134538173675537 32005.dat 1 19 178.47943115234375 -151.12901306152344 709.98681640625 0 0.13910017907619476 0.99027842283248901 0 0.99027842283248901 -0.13910017907619476 -1.0000001192092896 0 0 32556.dat 1 0 130.00616455078125 -64.3255615234375 590.02398681640625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 71 120.00605773925781 -84.329071044921875 610.0205078125 0 0 1 0.00017502224363852292 0.99999994039535522 0 -1 0.00017502224363852292 0 63869.dat 1 1 120.01554870605469 -84.626289367675781 619.99981689453125 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 1 99.990371704101563 -64.327606201171875 610.03912353515625 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 150.00605773925781 -80.324790954589844 602.0250244140625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 150.00605773925781 -64.32562255859375 530.0255126953125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 149.99232482910156 -64.326042175292969 570.04510498046875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 139.98944091796875 -84.327217102050781 530.0400390625 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32524.dat 1 0 79.98944091796875 -84.327217102050781 520.0400390625 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 139.98948669433594 -84.327232360839844 520.0400390625 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 119.98960113525391 -84.327217102050781 520.0400390625 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 89.990364074707031 -144.32754516601562 470.0391845703125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 99.990478515625 -84.327606201171875 490.0538330078125 0 0 -1 0 0.99999994039535522 0 1 0 0 6558.dat 1 0 19.990371704101563 -84.327232360839844 500.03994750976563 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 2780.dat 1 0 -120.00948333740234 -84.327629089355469 520.05364990234375 0 0 1 0 1 0 -1 0 0 2780.dat 1 72 -139.98675537109375 -84.627494812011719 529.99932861328125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32524.dat 1 72 -179.98675537109375 -84.627494812011719 529.99932861328125 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 11214.dat 1 72 -179.98675537109375 -84.629249572753906 549.9993896484375 0 0 -1 -0.00017520882829558104 0.99999994039535522 0 1 0.00017520882829558104 0 6536.dat 1 1 -179.98576354980469 -64.629249572753906 550.00286865234375 -1 0 0 0 -1 0 0 0 1 6558.dat 1 0 -80.009368896484375 -84.327606201171875 520.05364990234375 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 -140.00936889648437 -84.327606201171875 520.05364990234375 0 0 1 0 1 0 -1 0 0 2780.dat 1 1 -99.984352111816406 -84.6241455078125 630.0009765625 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 0 -59.982097625732422 -84.623306274414063 650.00164794921875 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 1 -119.98308563232422 -84.628089904785156 619.99615478515625 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 71 -119.98303985595703 -84.629844665527344 609.99627685546875 0 0 1 0.00017502224363852292 0.99999994039535522 0 -1 0.00017502224363852292 0 63869.dat 1 1 -99.961158752441406 -64.902992248535156 610.02557373046875 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -129.98324584960937 -64.625755310058594 590.0003662109375 1 0 0 0 -1 0 0 0 -1 2780.dat 1 71 0.017940681427717209 -84.626480102539063 700.00030517578125 0 0 1 0 1 0 -1 0 0 75535.dat 1 1 0.017945926636457443 -84.626480102539063 720.0003662109375 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 4 0.017946958541870117 -84.626480102539063 740.000244140625 1 0 0 0 1 0 0 0 1 59443.dat 1 72 0.016992807388305664 -84.626228332519531 780 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 87083.dat 1 0 0.039499998092651367 -84.913787841796875 790.0635986328125 1 0 0 0 1 0 0 0 1 32269.dat 1 72 0.015419721603393555 -84.62921142578125 810.001953125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 32524.dat 1 1 60.015506744384766 -84.626319885253906 790.0006103515625 0 0.87757194042205811 -0.47944509983062744 0 -0.47944504022598267 -0.87757194042205811 -1.0000001192092896 0 0 6558.dat 1 72 0.017082691192626953 -84.626228332519531 769.99993896484375 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 41239.dat 1 0 80.017112731933594 -84.626228332519531 780 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 100.01720428466797 -84.626235961914063 780 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 -99.982818603515625 -84.626228332519531 780 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 -79.982933044433594 -84.626228332519531 780 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 1 -59.984577178955078 -84.62921142578125 790.00177001953125 0 0.87757194042205811 -0.47944509983062744 0 -0.47944504022598267 -0.87757194042205811 -1.0000001192092896 0 0 6558.dat 1 71 -59.984230041503906 -104.62864685058594 790.00177001953125 0 -1.0000001192092896 1.4433986507356167E-005 0 -1.4363714399223682E-005 -1.0000001192092896 1.0000001192092896 0 0 14720.dat 1 72 -99.983657836914063 -144.62821960449219 790.00189208984375 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 0 -59.983695983886719 -144.62821960449219 790.00189208984375 0.99999994039535522 0 0 0 0 1 0 -1 0 32054.dat 1 1 -59.984970092773438 -144.62449645996094 810.0015869140625 0.99999994039535522 0 0 0 0 -1 0 1 0 6558.dat 1 0 -49.984813690185547 -64.628791809082031 790.00177001953125 1 0 0 0 1 0 0 0 1 2780.dat 1 1 -59.984195709228516 -104.628662109375 800.0018310546875 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 72 -59.984195709228516 -104.628662109375 810.00177001953125 0 0 -1 0 -1 0 -1 0 0 6536.dat 1 1 -79.984817504882813 -64.6287841796875 810.00177001953125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 -100.0064697265625 -64.332771301269531 810.03369140625 0 -1 0 0.60002350807189941 0 -0.79998236894607544 0.79998236894607544 0 0.60002344846725464 60484.dat 1 1 -80.006462097167969 -84.326385498046875 850.04205322265625 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 -80.006462097167969 -84.326385498046875 850.04205322265625 0 1 0 -1 0 0 0 0 0.99999994039535522 18654.dat 1 0 -90.086540222167969 -96.62255859375 834.06591796875 1 -1.6636016880511306E-005 0 -1.6636016880511306E-005 -1 0 0 0 -1 2780.dat 1 0 -49.983692169189453 -144.6287841796875 770.00177001953125 1 0 0 0 1 0 0 0 1 2780.dat 1 71 60.015850067138672 -104.62631988525391 790.0006103515625 0 -1.0000001192092896 1.4433986507356167E-005 0 -1.4363714399223682E-005 -1.0000001192092896 1.0000001192092896 0 0 14720.dat 1 72 100.01631164550781 -144.62644958496094 790.000732421875 -1 0 0 0 0 1 0 1 0 11214.dat 1 0 60.016345977783203 -144.62620544433594 790.000732421875 -1 0 0 0 0 1 0 1 0 32054.dat 1 1 79.99102783203125 -64.327079772949219 810.03997802734375 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 79.991020202636719 -64.32708740234375 710.03997802734375 0 1 0 -1 0 0 0 0 0.99999994039535522 6629.dat 1 1 59.991012573242188 -64.32708740234375 770.0400390625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 89.991012573242187 -96.327415466308594 834.0401611328125 1 -1.6636016880511306E-005 0 -1.6636016880511306E-005 -1 0 0 0 -1 2780.dat 1 72 99.991012573242188 -64.328453063964844 810.03924560546875 0 -1 0 0.60002350807189941 0 -0.79998236894607544 0.79998236894607544 0 0.60002344846725464 60484.dat 1 1 79.991012573242188 -84.327278137207031 850.03985595703125 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 79.990997314453125 -84.327278137207031 850.03985595703125 0 1 0 -1 0 0 0 0 0.99999994039535522 18654.dat 1 1 60.022491455078125 -144.6302490234375 810.03448486328125 1 0 0 0 -0.47944512963294983 -0.87757188081741333 0 0.87757188081741333 -0.47944512963294983 6558.dat 1 0 50.016307830810547 -144.62615966796875 770.0008544921875 1 0 0 0 1 0 0 0 1 2780.dat 1 72 60.015697479248047 -104.62631988525391 810.0006103515625 0 0 -1 0 -1 0 -1 0 0 6536.dat 1 1 60.015697479248047 -104.62631988525391 800.00067138671875 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 50.015281677246094 -64.626190185546875 790.0006103515625 1 0 0 0 1 0 0 0 1 2780.dat 1 72 -0.0066575817763805389 -84.327827453613281 610.025146484375 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 18654.dat 1 19 -0.0066573936492204666 -101.82783508300781 560.0250244140625 -0.19508950412273407 0.9807855486869812 0 0 0 1.0000001192092896 0.9807855486869812 0.19508965313434601 0 6589.dat 1 1 139.99026489257812 -83.733345031738281 150.1209716796875 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 1 -140.01119995117187 -83.726547241210937 150.11944580078125 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 0 -29.992389678955078 -124.32757568359375 270.0250244140625 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 72 -19.992387771606445 -144.32730102539062 270.0250244140625 0 -1 0 0 0 1 -1 0 0 60483.dat 1 1 -29.991813659667969 -144.32835388183594 270.0250244140625 0.99999994039535522 0 0 0 0 -1 0 1 0 43093.dat 1 0 59.992229461669922 -123.72889709472656 140.08602905273437 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 0 30.008066177368164 -124.32649993896484 190.02510070800781 -1 0 0 0 -0.98019909858703613 0.19801458716392517 0 0.19801458716392517 0.98019897937774658 2780.dat 1 0 -60.0084228515625 -123.72892761230469 140.11349487304688 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 0 -19.995288848876953 -94.328361511230469 350.01983642578125 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 2780.dat 1 71 -19.995479583740234 -84.328369140625 340.01983642578125 -1 0 0 0 -1 0 0 0 1 43857.dat 1 0 -19.977994918823242 -64.327430725097656 329.9818115234375 1.4970105439715553E-005 -1 0 -1 -1.4869863662170246E-005 0 0 0 -1 15100.dat 1 1 -39.977897644042969 -64.327583312988281 329.9818115234375 -1 0 0 0 -1 0 0 0 1 6558.dat 1 0 -39.941585540771484 -84.625396728515625 360.01364135742187 0 0.19802124798297882 0.98019784688949585 0 -0.9801977276802063 0.19802124798297882 1.0000001192092896 0 0 2780.dat 1 0 20.058464050292969 -64.624832153320312 360.01364135742187 0 -0.19801442325115204 -0.98019909858703613 -1.3807999494019896E-005 0.98019909858703613 -0.19801442325115204 1 1.3742902410740498E-005 0 2780.dat 1 0 50.007568359375 -64.32757568359375 249.99546813964844 -1 0 0 0 0.99997472763061523 0.0070995832793414593 0 0.0070995832793414593 -0.99997478723526001 2780.dat 1 1 -79.9925537109375 -64.328292846679687 370.02487182617187 -1 0 0 0 -1 0 0 0 1 6558.dat 1 72 -79.992431640625 -64.328292846679687 370.02487182617187 0 1 0 1 0 0 0 0 -1 18654.dat 1 1 -79.992584228515625 -64.328292846679687 170.02484130859375 1 0 0 0 1 0 0 0 1 6558.dat 1 1 -59.928565979003906 -64.625434875488281 430.0135498046875 -1 0 0 0 -1 0 0 0 1 6558.dat 1 71 -39.928539276123047 -64.625442504882813 410.01339721679687 0 -1 0 -1 0 0 0 0 -1 32523.dat 1 71 -19.928556442260742 -64.625457763671875 390.01339721679687 0 0 -1 0 1 0 1 0 0 6590.dat 1 1 -29.928546905517578 -64.625442504882813 390.013427734375 0.99999994039535522 0 0 0 0 1 0 -1 0 43093.dat 1 1 -59.928565979003906 -64.625434875488281 410.01339721679687 -1 0 0 0 -1 0 0 0 1 6558.dat 1 0 -69.928619384765625 -64.625434875488281 390.0133056640625 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 -69.928619384765625 -64.625434875488281 450.0135498046875 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 -89.992591857910156 -64.328285217285156 90.025123596191406 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 -100.00962829589844 -63.732582092285156 130.12045288085937 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 -120.00968170166016 -63.732917785644531 110.12036895751953 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -130.00970458984375 -79.732894897460938 78.120407104492188 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 -120.00963592529297 -63.732234954833984 150.12046813964844 0 1 0 -1 0 1.6836289432831109E-005 1.6836289432831109E-005 0 0.99999994039535522 32316.dat 1 1 -130.00971984863281 -111.73316192626953 54.120964050292969 -1 0 0 0 -0.60000038146972656 0.79999977350234985 0 0.79999977350234985 0.60000061988830566 43093.dat 1 72 -140.00971984863281 -63.732212066650391 190.12098693847656 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6629.dat 1 72 -120.00971984863281 -63.732128143310547 190.12091064453125 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 11214.dat 1 72 -119.99361419677734 -112.32689666748047 54.037910461425781 0 1.0000001192092896 0 -0.59998816251754761 0 0.80000901222229004 0.80000901222229004 0 0.59998828172683716 32316.dat 1 0 -130.00970458984375 -63.732917785644531 150.12052917480469 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -130.00970458984375 -95.73291015625 66.120323181152344 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 -150.00559997558594 -63.731800079345703 130.12043762207031 -1 0 0 0 0 -1 0 -1 0 43093.dat 1 72 -160.00552368164062 -63.733554840087891 130.12043762207031 -1 0 0 0 -1 0 0 0 1 6536.dat 1 0 -49.992626190185547 -144.32843017578125 -129.9749755859375 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 -49.993770599365234 -144.32833862304688 -89.976150512695312 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 -60.009681701660156 -143.73237609863281 70.119834899902344 1 0 0 0 -1 0 0 0 -1 6558.dat 1 72 -80.009613037109375 -143.73237609863281 70.119941711425781 0 1 0 -1 0 0 0 0 0.99999994039535522 60484.dat 1 1 -60.009681701660156 -143.73237609863281 110.11979675292969 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 -90.009597778320312 -143.73265075683594 90.119537353515625 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 1 -79.992088317871094 -164.33332824707031 -109.97672271728516 0 0.87757194042205811 -0.47944504022598267 0 0.47944507002830505 0.87757194042205811 1 0 0 6558.dat 1 72 0.0080447494983673096 -164.33139038085937 -89.975807189941406 2.4347207727259956E-005 1.1786941286118235E-005 1.0000001192092896 -1.0000001192092896 0 2.4278699129354209E-005 0 -1.0000001192092896 1.1855452612508088E-005 41239.dat 1 1 80.007949829101563 -164.32945251464844 -109.97481536865234 0 0.87757188081741333 -0.47944507002830505 0 0.47944507002830505 0.87757188081741333 1 0 0 6558.dat 1 72 0.0078976154327392578 -164.33332824707031 -129.97671508789062 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 40490.dat 1 0 100.00802612304687 -164.32862854003906 -99.974578857421875 0 -1.5939151126076467E-005 1.0000001192092896 -1.6062786016846076E-005 -1 -1.5939145669108257E-005 1.0000001192092896 -1.6062780559877865E-005 0 2780.dat 1 0 -99.991989135742188 -164.32862854003906 -99.974578857421875 0 -1.5939151126076467E-005 1.0000001192092896 -1.6062786016846076E-005 -1 -1.5939145669108257E-005 1.0000001192092896 -1.6062780559877865E-005 0 2780.dat 1 0 -59.990554809570313 -164.32931518554687 30.025056838989258 -1.4466952052316628E-005 1 0 0 0 -1 -1 -1.4485605788649991E-005 0 15100.dat 1 0 -49.990505218505859 -164.32929992675781 30.025375366210938 -1 1.0137104254681617E-005 -1.0260971066600177E-005 1.0260740054945927E-005 -2.2624812118010595E-005 -1.0000001192092896 -1.0137337994819973E-005 -1.0000001192092896 2.2893787900102325E-005 2780.dat 1 72 -39.990501403808594 -164.32931518554687 90.025588989257813 0 -1 0 -1 0 0 0 0 -1 32140.dat 1 1 -49.990493774414063 -164.32931518554687 90.025588989257813 0.99999994039535522 0 0 0 0 1 0 -1 0 43093.dat 1 0 -59.990554809570313 -164.32945251464844 90.025588989257813 -1.4532691238855477E-005 1 0 1 1.4632928468927275E-005 0 0 0 -1 15100.dat 1 0 0.0078317327424883842 -104.32080078125 40.042549133300781 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 72 79.990257263183594 -143.732421875 70.120002746582031 0 1 0 -1 0 0 0 0 0.99999994039535522 60484.dat 1 1 59.990249633789063 -143.732421875 110.11998748779297 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 59.990249633789063 -143.732421875 70.119834899902344 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 89.990364074707031 -143.73269653320312 90.119522094726563 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 0 -149.99224853515625 -144.32035827636719 110.04252624511719 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 0 -159.99226379394531 -144.32086181640625 110.04254913330078 0 1.0000001192092896 0 0.60000109672546387 0 -0.79999929666519165 -0.79999929666519165 0 -0.60000103712081909 15100.dat 1 0 150.00149536132812 -144.41456604003906 110.07357788085937 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 0 160.00148010253906 -144.41481018066406 110.07361602783203 0 1.0000001192092896 0 0.60000109672546387 0 -0.79999929666519165 -0.79999929666519165 0 -0.60000103712081909 15100.dat 1 0 -120.01115417480469 -163.73304748535156 110.12022399902344 1.4484624443866778E-005 -1 0 0 0 -1 1 1.4445846318267286E-005 0 15100.dat 1 0 119.99098205566406 -83.733375549316406 140.12155151367188 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 99.990287780761719 -123.73309326171875 100.12135314941406 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 2780.dat 1 1 100.00848388671875 -64.326438903808594 130.02641296386719 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 109.99024963378906 -143.73350524902344 110.12157440185547 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 0 120.00148010253906 -144.41481018066406 110.07361602783203 0 1.0000001192092896 0 0.60000109672546387 0 -0.79999929666519165 -0.79999929666519165 0 -0.60000103712081909 15100.dat 1 0 70.042549133300781 -64.625137329101563 210.0135498046875 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 60.005588531494141 -84.327476501464844 10.052940368652344 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 72 -59.992588043212891 -104.32945251464844 50.024814605712891 0 0 -1 0 -1 0 -1 0 0 6536.dat 1 1 -59.992588043212891 -104.32945251464844 40.024810791015625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 1 -39.991863250732422 -144.32835388183594 150.02534484863281 1 0 0 0 -1 0 0 0 -1 6558.dat 1 1 -59.993534088134766 -84.327468872070313 10.05274772644043 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 6558.dat 1 1 -99.992172241210938 -84.329345703125 10.024887084960937 0 0.87757194042205811 -0.47944504022598267 0 0.47944507002830505 0.87757194042205811 1 0 0 6558.dat 1 0 -89.991477966308594 -124.3294677734375 30.024892807006836 1 0 0 0 -1 0 0 0 -1 2780.dat 1 0 -109.98102569580078 -145.00141906738281 109.99452972412109 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 0 -119.99227142333984 -144.32086181640625 110.04254913330078 0 1.0000001192092896 0 0.60000109672546387 0 -0.79999929666519165 -0.79999929666519165 0 -0.60000103712081909 15100.dat 1 0 -109.99246978759766 -144.32876586914062 130.02410888671875 -1 0 0 0 -0.98019909858703613 0.19801457226276398 0 0.19801457226276398 0.98019897937774658 2780.dat 1 0 -180.01133728027344 -83.726547241210937 130.11941528320312 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 0 -149.9832763671875 -64.625732421875 570.00048828125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -149.98313903808594 -64.625755310058594 530.00048828125 1 0 0 0 -1 0 0 0 -1 2780.dat 1 0 -149.9832763671875 -144.62626647949219 649.99981689453125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 -139.98320007324219 -144.62628173828125 649.99981689453125 0 0 1 0 0.99999994039535522 0 -1 0 0 42003.dat 1 1 -139.98316955566406 -164.62628173828125 659.99993896484375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 1 -119.98490905761719 -124.62427520751953 650.0009765625 1 0 0 0 1 0 0 0 1 6558.dat 1 0 -149.9832763671875 -96.625747680664063 614.00048828125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -89.96112060546875 -64.902999877929687 530.0255126953125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 -59.983314514160156 -64.622039794921875 629.99932861328125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -89.96112060546875 -64.902999877929687 570.025634765625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -49.983470916748047 -64.622032165527344 689.99920654296875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 19 -197.93183898925781 -86.632041931152344 710.0123291015625 0 -0.13910013437271118 -0.99027842283248901 0 0.99027842283248901 -0.13910013437271118 1.0000001192092896 0 0 32556.dat 1 72 -197.93183898925781 -66.632057189941406 730.01226806640625 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 71 -197.93182373046875 -66.632057189941406 710.0123291015625 0 0 -1 0 0.99999994039535522 0 1 0 0 4519.dat 1 72 -197.93183898925781 -66.632041931152344 690.0123291015625 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 0 -158.95689392089844 -95.628425598144531 690.001220703125 0.70819294452667236 -0.70601892471313477 0 0.70601892471313477 0.70819294452667236 0 0 0 1 4254.dat 1 4 -81.293449401855469 -173.53071594238281 690.001220703125 0.70819306373596191 -0.70601880550384521 0 0.70601880550384521 0.70819306373596191 0 0 0 1 4255.dat 1 1 -79.98388671875 -164.62368774414062 770.0020751953125 0 -0.87758046388626099 0.47942948341369629 0 -0.4794294536113739 -0.87758046388626099 1 0 0 6558.dat 1 0 100.01718139648437 -104.62522888183594 619.98565673828125 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 -99.961090087890625 -104.90299224853516 620.01104736328125 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 -49.983207702636719 -144.62440490722656 750.0003662109375 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 0.016997285187244415 -124.62497711181641 750.00042724609375 -0.70710670948028564 0.7071068286895752 0 0.7071068286895752 0.70710664987564087 0 0 0 -1 18575.dat 1 72 0.01704103872179985 -124.62497711181641 797.00042724609375 0 -0.70710659027099609 -0.7071070671081543 0 0.70710712671279907 -0.70710659027099609 1.0000001192092896 0 0 32209.dat 1 0 0.016933251172304153 -124.62495422363281 790.00030517578125 0.70710712671279907 -0.70710641145706177 0 0.70710641145706177 0.70710712671279907 0 0 0 1 32270.dat 1 0 -9.9826498031616211 -84.629203796386719 860.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 71 -9.9826488494873047 -84.629203796386719 880.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 75535.dat 1 36 -176.77592468261719 -124.6287841796875 877.60589599609375 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 6141.dat 1 0 -176.77592468261719 -124.62880706787109 867.60589599609375 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 87082.dat 1 0 -176.77593994140625 -144.6287841796875 867.60589599609375 0.279929518699646 0 0.96002054214477539 0 1 0 -0.96002054214477539 0 0.279929518699646 32524.dat 1 1 -234.3760986328125 -124.62880706787109 850.80706787109375 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 0 -215.17591857910156 -124.62879180908203 856.40582275390625 0.27977845072746277 0 0.9600645899772644 0 1 0 -0.9600645899772644 0 0.27977845072746277 32523.dat 1 0 -49.983043670654297 -104.62887573242187 830.0010986328125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 60.00262451171875 -160.41339111328125 858.0701904296875 1 -3.1885228963801637E-005 1.0706724424380809E-005 -1.0563743671809789E-005 -0.59994953870773315 -0.80003786087036133 3.1932882848195732E-005 0.80003786087036133 -0.59994953870773315 44809.dat 1 0 80.002525329589844 -176.41438293457031 846.07183837890625 0 -1 0 0.80003780126571655 0 -0.59994959831237793 0.59994959831237793 0 0.80003786087036133 15100.dat 1 0 30.017349243164063 -84.629196166992188 860.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 71 30.017349243164063 -84.629196166992188 880.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 75535.dat 1 0 -29.982646942138672 -84.629203796386719 860.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 71 -29.982646942138672 -84.629203796386719 880.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 75535.dat 1 1 60.025482177734375 -124.62881469726562 890.001220703125 0 0.0020423589739948511 -0.99999791383743286 -1 0 0 0 0.99999791383743286 0.0020423256792128086 6558.dat 1 4 0.0255584716796875 -124.62879180908203 890.00128173828125 0 0 1 0 -1 0 1 0 0 32524.dat 1 1 0.025564789772033691 -124.62879180908203 890.00128173828125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 0 0.025579333305358887 -104.62879180908203 890.00128173828125 0 0 1 0 -1 0 1 0 0 32316.dat 1 1 -39.974445343017578 -124.62879180908203 890.001220703125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 0 0.025549530982971191 -144.62879943847656 890.00128173828125 0 0 1 0 -1 0 1 0 0 32316.dat 1 1 40.025550842285156 -124.62879180908203 890.001220703125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 1 -59.974445343017578 -124.62879180908203 890.00128173828125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6558.dat 1 0 50.017059326171875 -104.62886047363281 830.0010986328125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 10.017354965209961 -84.629196166992188 860.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 71 10.017352104187012 -84.629196166992188 880.00079345703125 0 0 -1 0 0.99999994039535522 0 1 0 0 75535.dat 1 0 -59.977878570556641 -160.62908935546875 858.03509521484375 -1 1.8022208678303286E-005 0 1.7944012142834254E-005 0.59996753931045532 -0.80002421140670776 0 -0.80002421140670776 -0.59996765851974487 44809.dat 1 0 -79.978057861328125 -176.62962341308594 846.03521728515625 0 -1 0 0.80003780126571655 0 -0.59994965791702271 0.59994965791702271 0 0.80003786087036133 15100.dat 1 1 -59.982933044433594 -144.62887573242187 670.001220703125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -69.985107421875 -144.6240234375 430.00106811523437 1 0 0 0 1 0 0 0 1 2780.dat 1 0 -89.96112060546875 -144.90298461914063 610.02557373046875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -89.96112060546875 -144.90298461914063 570.02545166015625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -89.96112060546875 -144.90298461914063 490.0255126953125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -89.96112060546875 -144.90298461914063 530.0255126953125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 30.007648468017578 -144.32785034179687 190.02493286132812 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 0 -29.991817474365234 -144.32807922363281 330.02508544921875 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 0 -29.991817474365234 -144.32833862304688 190.02513122558594 1 0 0 0 -0.98019909858703613 0.1980145126581192 0 -0.1980145126581192 -0.98019909858703613 2780.dat 1 0 69.990447998046875 -144.32762145996094 430.03921508789062 1 0 0 0 1 0 0 0 1 2780.dat 1 0 89.990364074707031 -144.32762145996094 530.0391845703125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 89.990364074707031 -144.32762145996094 490.03924560546875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 89.989791870117187 -144.32815551757812 610.03857421875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 89.990364074707031 -64.327606201171875 570.0391845703125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 90.004287719726563 -64.327186584472656 530.019775390625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 -110.97551727294922 -124.90299987792969 570.02545166015625 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 6632.dat 1 72 -79.975486755371094 -84.90301513671875 570.02545166015625 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6553.dat 1 71 -115.97552490234375 -124.90299987792969 570.02545166015625 1 0 0 0 1 0 0 0 1 2736.dat 1 4 -99.975593566894531 -124.90298461914062 570.02545166015625 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 6641.dat 1 71 -79.975494384765625 -104.90300750732422 570.02545166015625 0 1 0 -1 0 0 0 0 0.99999994039535522 4519.dat 1 72 -120.97554016113281 -84.90301513671875 570.02545166015625 0 -1 0 0 0 -1 1 0 0 41677.dat 1 1 -115.97563171386719 -104.90300750732422 570.02545166015625 -1 0 0 0 0 1 0 1 0 43093.dat 1 0 -127.97552490234375 -124.90298461914062 410.02560424804687 0 1 0 -1 0 0 0 0 0.99999994039535522 32293.dat 1 0 60.016513824462891 -164.62628173828125 649.99969482421875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 0 -59.983230590820313 -164.62628173828125 649.99969482421875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 1 139.50445556640625 -160.12701416015625 709.98699951171875 0 0.87757194042205811 -0.47944509983062744 0 -0.47944504022598267 -0.87757194042205811 -1.0000001192092896 0 0 6558.dat 1 0 158.991455078125 -95.630172729492187 729.98699951171875 -0.70819282531738281 0.70601910352706909 0 0.70601910352706909 0.70819300413131714 0 0 0 -1 4254.dat 1 4 81.327911376953125 -173.53280639648437 729.98699951171875 -0.70819294452667236 0.70601898431777954 0 0.70601898431777954 0.70819300413131714 0 0 0 -1 4255.dat 1 0 49.990974426269531 -64.32708740234375 690.0400390625 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 70.006118774414063 -64.326789855957031 450.0247802734375 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 80.00616455078125 -64.326789855957031 270.02542114257812 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 80.006072998046875 -84.327354431152344 260.02536010742187 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 41678.dat 1 71 80.005081176757812 -84.327003479003906 250.02619934082031 0 0 1 0 1 0 -1 0 0 4519.dat 1 72 80.005088806152344 -84.326515197753906 230.02616882324219 0 0 -1 4.8581830924376845E-005 0.99999994039535522 0 1 -4.8581830924376845E-005 0 6536.dat 1 1 80.00616455078125 -64.327079772949219 230.02545166015625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 180.0250244140625 -64.329360961914062 170.02484130859375 -1 0 0 0 -1 0 0 0 1 6558.dat 1 0 130.00616455078125 -80.325630187988281 78.025421142578125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 130.00616455078125 -64.325653076171875 150.02536010742187 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 119.80789947509766 -124.12560272216797 10.040452003479004 -1.4701277905260213E-005 1 0 1 1.4801516954321414E-005 0 0 0 -1 15100.dat 1 0 40.007888793945313 -114.32850646972656 -29.974000930786133 1.4801516954321414E-005 1.0000001192092896 0 1.0000001192092896 -1.4532691238855477E-005 0 0 0 -1 2780.dat 1 71 40.007801055908203 -104.32849884033203 -29.974006652832031 0 0 -1 0 0.99999994039535522 0 1 0 0 44809.dat 1 1 50.007759094238281 -104.32851409912109 -9.9739303588867187 0.99999994039535522 0 0 0 0 1 0 -1 0 4274.dat 1 0 58.007835388183594 -104.32851409912109 -9.9739313125610352 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 98138.dat 1 0 60.007869720458984 -104.32851409912109 -49.974006652832031 0 0 1 0 1 0 -1 0 0 18651.dat 1 71 80.009559631347656 -104.32737731933594 -49.972553253173828 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 42003.dat 1 71 60.007499694824219 -104.32929992675781 -69.9736328125 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 6536.dat 1 0 100.00911712646484 -124.32738494873047 -49.972751617431641 1.4738240679434966E-005 -1 0 1 1.4738240679434966E-005 0 0 0 1 15100.dat 1 72 120.00925445556641 -124.32723236083984 -49.972770690917969 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 92906.dat 1 4 70.009323120117188 -124.32723236083984 -49.972770690917969 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 59443.dat 1 71 40.009212493896484 -124.32723236083984 -49.972782135009766 -1 0 0 0 -1 0 0 0 1 4519.dat 1 19 17.007684707641602 -124.32679748535156 -49.975322723388672 0 -1.3574882359534968E-005 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 1.3736049368162639E-005 6589.dat 1 72 0.0075697898864746094 -124.32755279541016 -49.975204467773438 5.0462305807741359E-005 1.352397430309793E-005 -1.0000001192092896 -0.99999988079071045 -0.00069158378755673766 -5.0371145334793255E-005 -0.00069168495247140527 0.99999988079071045 1.3589638911071233E-005 62821.dat 1 19 0.0080271326005458832 -141.32756042480469 -49.985149383544922 0.70712971687316895 0.707084059715271 0 0 0 1.0000001192092896 0.707084059715271 -0.70712965726852417 0 6589.dat 1 4 -69.992515563964844 -124.32832336425781 -49.974655151367188 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 59443.dat 1 71 -39.992588043212891 -124.32832336425781 -49.974666595458984 -1 0 0 0 -1 0 0 0 1 4519.dat 1 72 -119.99259185791016 -124.32832336425781 -49.974655151367188 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 92906.dat 1 19 -16.992586135864258 -124.32832336425781 -49.974559783935547 0 -1.3506075447367039E-005 1 -1 0 0 0 -1 -1.3446262528304942E-005 6589.dat 1 0 -99.992683410644531 -124.32848358154297 -49.974651336669922 -1.4701277905260213E-005 1 0 1 1.4801516954321414E-005 0 0 0 -1 15100.dat 1 0 -59.993942260742187 -104.32748413085937 -49.975914001464844 0 0 1 0 1 0 -1 0 0 18651.dat 1 71 -79.993125915527344 -104.3284912109375 -49.974662780761719 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 42003.dat 1 71 -59.991828918457031 -104.32919311523437 -69.974693298339844 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 6536.dat 1 0 -39.992206573486328 -114.32859039306641 -69.97454833984375 -1.4825663129158784E-005 -1 0 1 -1.4825663129158784E-005 0 0 0 0.99999994039535522 2780.dat 1 71 -39.993839263916016 -104.32748413085937 -29.975914001464844 0 0 1 0 -1 0 1 0 0 44809.dat 1 1 -49.993991851806641 -104.32746124267578 -9.9758377075195313 -1 0 0 0 0 -1 0 -1 0 4274.dat 1 0 -57.993881225585938 -104.32746124267578 -9.9758386611938477 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 98138.dat 1 0 -39.992206573486328 -114.32859039306641 -29.974777221679688 -1.4825663129158784E-005 -1 0 1 -1.4825663129158784E-005 0 0 0 0.99999994039535522 2780.dat 1 71 -169.92942810058594 -112.79991912841797 -49.974666595458984 0.97437053918838501 0.22494900226593018 0 -0.22494900226593018 0.97437053918838501 0 0 0 1 4519.dat 1 71 -119.99272155761719 -124.32880401611328 -49.974655151367188 0.22494974732398987 0 -0.97437047958374023 0.97437047958374023 0 0.22494964301586151 0 -1.0000001192092896 0 32494.dat 1 71 -217.42973327636719 -101.8331298828125 -49.974655151367188 0.22494930028915405 0 0.97437041997909546 0.97437041997909546 0 -0.22494934499263763 0 1 0 32494.dat 1 72 -247.45066833496094 -101.83380889892578 -49.974655151367188 0 -2.266062620037701E-005 1 0 0.99999994039535522 2.266062620037701E-005 -1 0 0 92909.dat 1 71 169.94523620605469 -112.79837036132812 -49.972740173339844 -0.97437036037445068 -0.22494973242282867 0 -0.22494973242282867 0.97437036037445068 0 0 0 -1 4519.dat 1 71 120.00891876220703 -124.32723999023437 -49.972747802734375 -0.22495000064373016 0 0.97437030076980591 0.97437030076980591 0 0.22494994103908539 0 0.99999994039535522 0 32494.dat 1 71 217.44622802734375 -101.83200836181641 -49.972747802734375 -0.22494962811470032 0 -0.97437036037445068 0.97437036037445068 0 -0.22494961321353912 0 -1 0 32494.dat 1 72 247.46707153320312 -101.83268737792969 -49.972652435302734 0 2.2660628019366413E-005 -1 0 0.99999994039535522 2.2660628019366413E-005 1 0 0 92909.dat 1 0 40.007888793945313 -114.32850646972656 -69.973770141601562 1.4801516954321414E-005 1.0000001192092896 0 1.0000001192092896 -1.4532691238855477E-005 0 0 0 -1 2780.dat 1 1 -39.995128631591797 -144.32711791992187 -209.9783935546875 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 119.97742462158203 -184.33506774902344 30.042102813720703 -1.0333777026971802E-005 1.0000001192092896 0 -0.80000746250152588 -1.0314009159628768E-005 -0.59999024868011475 -0.59999024868011475 0 0.80000764131546021 60484.dat 1 28 99.977165222167969 -224.33383178710937 50.042736053466797 1 0 0 0 -0.80000966787338257 0.59998708963394165 0 -0.59998708963394165 -0.80000966787338257 15462.dat 1 0 39.977169036865234 -224.33383178710937 50.042881011962891 0 0 1.0000001192092896 -0.59998732805252075 -0.80000948905944824 0 0.80000954866409302 -0.59998732805252075 0 32034.dat 1 71 -0.022840499877929688 -224.33383178710937 50.042881011962891 1 0 0 0 0.80000936985015869 -0.59998750686645508 0 0.59998750686645508 0.80000936985015869 4519.dat 1 28 -100.00756072998047 -224.317138671875 50.04443359375 -1 0 0 0 -0.5999872088432312 0.80000954866409302 0 0.80000954866409302 0.59998714923858643 15462.dat 1 0 -40.007652282714844 -224.317138671875 50.044315338134766 0 0 1 -0.59998732805252075 -0.80000954866409302 0 0.80000954866409302 -0.59998732805252075 0 32034.dat 1 4 100.00154876708984 -208.40010070800781 62.069900512695312 1 0 0 0 0.80000936985015869 -0.59998750686645508 0 0.59998750686645508 0.80000936985015869 32184.dat 1 71 120.00124359130859 -192.40013122558594 74.069862365722656 1 0 0 0 0.80000954866409302 -0.59998726844787598 0 0.59998726844787598 0.80000954866409302 4519.dat 1 4 140.00144958496094 -192.39935302734375 74.070365905761719 1 0 0 0 -0.80000936985015869 0.59998750686645508 0 -0.59998750686645508 -0.80000936985015869 6536.dat 1 4 -100.00709533691406 -208.31747436523437 62.044437408447266 1 0 0 0 0.80000948905944824 -0.59998738765716553 0 0.59998738765716553 0.80000948905944824 32184.dat 1 71 -120.00703430175781 -192.31681823730469 74.044593811035156 1 0 0 0 0.80000960826873779 -0.59998714923858643 0 0.59998714923858643 0.80000960826873779 4519.dat 1 4 -140.00715637207031 -192.31742858886719 74.043685913085938 1 0 0 0 -0.80000966787338257 0.59998708963394165 0 -0.59998708963394165 -0.80000966787338257 6536.dat 1 0 -120.00706481933594 -184.31826782226562 30.043325424194336 -1.0333777026971802E-005 1.0000001192092896 0 -0.80000746250152588 -1.0333777026971802E-005 -0.59999024868011475 -0.59999024868011475 0 0.80000764131546021 60484.dat 1 1 99.977287292480469 -205.8167724609375 -68.52020263671875 1 -0.00019173578766640276 -3.3095690014306456E-005 -0.00019173578766640276 -1 0 -3.3095704566221684E-005 0 -1 6558.dat 1 1 99.977287292480469 -208.90338134765625 -48.759738922119141 1 -0.00019173581677023321 -3.3095686376327649E-005 -0.00019173581677023321 -1 0 -3.3095700928242877E-005 0 -1 6558.dat 1 0 79.981513977050781 -196.83467102050781 3.7482705116271973 0 0 1.0000001192092896 0.15392407774925232 0.9880828857421875 0 -0.98808276653289795 0.15392407774925232 0 2780.dat 1 0 89.977279663085937 -202.73539733886719 -88.28155517578125 -1 0.0001249949709745124 0 0.00012499449076130986 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 4 59.976482391357422 -201.51405334472656 33.356166839599609 0 0 -1 0.15392306447029114 -0.98808282613754272 0 -0.9880828857421875 -0.15392306447029114 0 6536.dat 1 28 59.981491088867188 -198.37370300292969 13.628996849060059 0 0 -1 0.15392675995826721 -0.98808223009109497 0 -0.98808228969573975 -0.15392675995826721 0 6587.dat 1 4 59.981491088867188 -198.37387084960937 13.628964424133301 0 0 1.0000001192092896 -0.98808306455612183 0.15392223000526428 0 -0.15392217040061951 -0.98808306455612183 0 32140.dat 1 0 139.97723388671875 -198.40716552734375 13.60447883605957 1 0 0 0 0.98804318904876709 -0.15417735278606415 0 0.15417735278606415 0.98804318904876709 10197.dat 1 0 139.98149108886719 -196.06510925292969 -1.1921366453170776 0 0 -1 -0.98808372020721436 -0.15391765534877777 0 -0.15391767024993896 0.98808372020721436 0 6632.dat 1 1 99.981498718261719 -196.83473205566406 3.74835205078125 0 -1 0 0.15392015874385834 0 0.98808330297470093 -0.98808330297470093 0 0.1539202481508255 43093.dat 1 0 139.98149108886719 -194.52587890625 -11.07289981842041 0 0 -1.0000001192092896 -0.98808383941650391 -0.15391735732555389 0 -0.15391752123832703 0.98808383941650391 0 6632.dat 1 4 139.97723388671875 -221.25129699707031 30.281850814819336 0 0 1 0.98804336786270142 -0.15417639911174774 0 0.15417639911174774 0.98804336786270142 0 42003.dat 1 0 119.97721099853516 -221.25129699707031 30.281703948974609 1 0 0 0 0.15391843020915985 0.98808354139328003 0 -0.98808354139328003 0.15391843020915985 15100.dat 1 4 79.977622985839844 -215.05706787109375 -9.2111330032348633 0.00018134244601242244 1 0 0.98808276653289795 -0.00017899661906994879 0.15392395853996277 0.15392395853996277 -2.8013337214360945E-005 -0.98808270692825317 64391.dat 1 4 119.77725219726562 -215.07949829101562 -9.2396211624145508 -0.00020583208242896944 -1 0 -0.98802196979522705 0.00020367313118185848 0.15431362390518188 -0.15431362390518188 3.0667957616969943E-005 -0.98802191019058228 11947.dat 1 72 119.77731323242187 -218.15397644042969 10.522652626037598 0 -1.0000001192092896 0 0.15392081439495087 0 0.98808330297470093 -0.98808330297470093 0 0.15392090380191803 11214.dat 1 0 119.98151397705078 -196.834716796875 3.7482326030731201 0 0 1.0000001192092896 0.15392085909843445 0.9880833625793457 0 -0.98808324337005615 0.15392085909843445 0 2780.dat 1 4 99.977287292480469 -202.7364501953125 -88.281661987304688 -0.00017798588669393212 -1.0000001192092896 0 -0.98806452751159668 0.00017630890943109989 0.15404139459133148 -0.15404139459133148 2.6160549168707803E-005 -0.98806440830230713 41239.dat 1 0 34.977455139160156 -190.42027282714844 -167.32791137695312 0 -1.0000001192092896 0 -0.98804265260696411 0 0.15418154001235962 -0.15418154001235962 0 -0.98804253339767456 6632.dat 1 71 80.067008972167969 -190.37870788574219 -167.32215881347656 1 0 0 0 0.98804306983947754 -0.15417811274528503 0 0.15417811274528503 0.98804306983947754 44294.dat 1 4 54.976348876953125 -187.3328857421875 -187.08792114257812 0 -1 0 0.98804277181625366 0 -0.15417997539043427 0.15417997539043427 0 0.98804283142089844 41677.dat 1 4 65.066940307617188 -187.29460144042969 -187.08302307128906 0 -1 0 0.98804283142089844 0 -0.15417985618114471 0.15417985618114471 0 0.98804283142089844 41677.dat 1 72 69.977798461914062 -184.25381469726562 -206.84971618652344 1 0 0 0 0.98804312944412231 -0.15417774021625519 0 0.15417774021625519 0.98804312944412231 87083.dat 1 4 79.977294921875 -164.45822143554687 -203.76034545898437 -1 0 0 0 -0.98804301023483276 -0.15417847037315369 0 -0.15417847037315369 0.98804336786270142 32184.dat 1 71 99.977455139160156 -144.69744873046875 -200.6766357421875 1 0 0 0 0.98804306983947754 -0.15417811274528503 0 0.15417811274528503 0.98804306983947754 4519.dat 1 0 120.20254516601562 -144.69717407226562 -200.67681884765625 0 0 1 0.98804372549057007 -0.15417380630970001 0 0.15417380630970001 0.98804372549057007 0 11946.dat 1 0 44.976703643798828 -190.41787719726562 -167.326171875 0 -1.0000001192092896 0 -0.98804271221160889 0 0.15418116748332977 -0.15418116748332977 0 -0.98804259300231934 6632.dat 1 0 -0.0080078840255737305 -190.37742614746094 -167.32218933105469 0 0 -1 0.15417784452438354 -0.98804312944412231 0 -0.98804312944412231 -0.15417784452438354 0 32034.dat 1 72 89.976333618164062 -187.33305358886719 -187.0880126953125 1 0 0 0 0.98804306983947754 -0.15417811274528503 0 0.15417811274528503 0.98804306983947754 87083.dat 1 4 140.29193115234375 -190.3775634765625 -167.32212829589844 0 0 1.0000001192092896 0.98804384469985962 -0.15417400002479553 0 0.15417413413524628 0.98804384469985962 0 11946.dat 1 71 -80.008193969726563 -190.37734985351562 -167.3221435546875 1 0 0 0 0.98804318904876709 -0.15417735278606415 0 0.15417735278606415 0.98804318904876709 44294.dat 1 4 -55.023223876953125 -187.34178161621094 -187.0885009765625 0 -1 0 0.98804277181625366 0 -0.15417987108230591 0.15417987108230591 0 0.98804283142089844 41677.dat 1 72 -90.023231506347656 -187.34178161621094 -187.08847045898437 -1 0 0 0 0.98804289102554321 0.15418063104152679 0 0.15418063104152679 -0.98804265260696411 87083.dat 1 4 -65.023162841796875 -187.34173583984375 -187.08851623535156 0 -1 0 0.98804283142089844 0 -0.15417976677417755 0.15417976677417755 0 0.98804283142089844 41677.dat 1 0 -45.023136138916016 -190.42474365234375 -167.32769775390625 0 -1.0000001192092896 0 -0.98804271221160889 0 0.15418076515197754 -0.15418076515197754 0 -0.98804265260696411 6632.dat 1 72 -70.00732421875 -184.19662475585937 -206.84182739257812 -1 0 0 0 0.98804289102554321 0.15417987108230591 0 0.15417987108230591 -0.98804277181625366 87083.dat 1 4 -80.022666931152344 -164.49636840820312 -203.76608276367187 -1 0 0 0 -0.98804306983947754 -0.15417830646038055 0 -0.15417830646038055 0.98804336786270142 32184.dat 1 71 -100.02272033691406 -144.73530578613281 -200.68215942382812 1 0 0 0 0.98804318904876709 -0.15417735278606415 0 0.15417735278606415 0.98804318904876709 4519.dat 1 0 -120.02249908447266 -144.73553466796875 -200.68235778808594 0 0 -1.0000001192092896 -0.98804306983947754 -0.15417866408824921 0 -0.15417879819869995 0.98804306983947754 0 11947.dat 1 0 -35.023906707763672 -190.42189025878906 -167.32572937011719 0 -1.0000001192092896 0 -0.98804295063018799 0 0.15417999029159546 -0.15417999029159546 0 -0.98804277181625366 6632.dat 1 4 -140.02372741699219 -190.42268371582031 -167.32731628417969 0 0 -1.0000001192092896 -0.98804295063018799 -0.15417906641960144 0 -0.1541791558265686 0.98804295063018799 0 11947.dat 1 4 119.97666168212891 -193.48431396484375 -147.56396484375 -0.00020036904606968164 -1.0000001192092896 0 -0.98809909820556641 0.00019807096396107227 0.15381917357444763 -0.15381917357444763 3.1200281227938831E-005 -0.98809903860092163 32316.dat 1 4 80.067153930664063 -190.36054992675781 -167.31951904296875 -9.1989997599739581E-005 -1 0 -0.98790860176086426 9.0936860942747444E-005 0.15503750741481781 -0.15503750741481781 1.4116125385044143E-005 -0.98790860176086426 32523.dat 1 4 -100.00693511962891 -202.6845703125 -88.274559020996094 -0.00017832151206675917 -1 0 -0.98806440830230713 0.00017647675122134387 0.15404137969017029 -0.15404137969017029 2.6169564080191776E-005 -0.98806440830230713 41239.dat 1 4 -80.023033142089844 -190.44210815429687 -167.33035278320312 -9.1822177637368441E-005 -1.0000001192092896 0 -0.98790866136550903 9.0936860942747444E-005 0.15503790974617004 -0.15503790974617004 1.4497690244752448E-005 -0.98790854215621948 32523.dat 1 4 -120.02310943603516 -193.49334716796875 -147.56442260742187 -0.00020064508134964854 -1.0000001192092896 0 -0.98809915781021118 0.00019863412308041006 0.1538194864988327 -0.1538194864988327 3.0885632440913469E-005 -0.98809897899627686 32316.dat 1 0 -110.02309417724609 -199.64515686035156 -108.04034423828125 -1 0.0001249949709745124 0 0.00012499449076130986 0.9999852180480957 -0.0054209716618061066 0 -0.0054209716618061066 -0.99998527765274048 2780.dat 1 1 -100.02324676513672 -193.49046325683594 -147.56394958496094 1 0 0 0 1 0 0 0 1 6558.dat 1 4 -80.007049560546875 -218.08531188964844 10.532142639160156 -1 0 0 0 0 -1 0 -1 0 32054.dat 1 4 79.9775390625 -218.18278503417969 10.518266677856445 0.99999994039535522 0 0 0 0 1 0 -1 0 32054.dat 1 4 79.977546691894531 -221.28092956542969 30.276859283447266 -8.9976027084048837E-005 -1.0000001192092896 0 -0.98790860176086426 8.9090899564325809E-005 0.15503793954849243 -0.15503793954849243 1.3713484804611653E-005 -0.98790848255157471 32523.dat 1 1 79.9775390625 -221.2777099609375 30.277362823486328 1 -0.00017481097893323749 9.0677407570183277E-005 -0.00019442809571046382 -0.80324810743331909 0.59564459323883057 -3.1288753234548494E-005 -0.59564459323883057 -0.80324810743331909 6558.dat 1 0 -80.023391723632812 -166.03315734863281 -193.88288879394531 0 0 1 0.1541782021522522 0.98804306983947754 0 -0.98804306983947754 0.1541782021522522 0 2780.dat 1 0 -0.02339482307434082 -167.57493591308594 -184.00250244140625 0 0 -1 -0.98804295063018799 -0.15417896211147308 0 -0.15417905151844025 0.98804295063018799 0 40490.dat 1 1 59.97662353515625 -169.11663818359375 -174.1220703125 0 1 0 -0.1541752815246582 0 0.98804348707199097 0.98804348707199097 0 0.1541752964258194 4274.dat 1 0 99.977401733398437 -169.84889221191406 -169.17839050292969 0 0 -1 -0.98817884922027588 -0.15330557525157928 0 -0.15330563485622406 0.98817884922027588 0 32065.dat 1 1 159.97738647460938 -167.54061889648437 -183.99971008300781 0 1.0000001192092896 0 0.15417560935020447 0 -0.98804360628128052 -0.98804360628128052 0 -0.15417547523975372 4274.dat 1 0 159.97732543945312 -168.32023620605469 -179.06094360351562 0 0 1 0.98804354667663574 -0.1541752815246582 0 0.1541752815246582 0.98804354667663574 0 32017.dat 1 71 199.97735595703125 -167.54891967773437 -184.00128173828125 -1 0 0 0 0.15417516231536865 -0.98804348707199097 0 -0.98804348707199097 -0.15417525172233582 6141.dat 1 57 199.97735595703125 -166.31552124023437 -191.90567016601562 -1 0 0 0 0.15417516231536865 -0.98804348707199097 0 -0.98804348707199097 -0.15417525172233582 6141.dat 1 1 119.9776611328125 -166.09881591796875 -193.89118957519531 0 1 0 0.15418022871017456 0 -0.98804277181625366 -0.98804277181625366 0 -0.15418021380901337 4274.dat 1 0 139.97734069824219 -165.22775268554687 -198.82052612304687 0 0 -1 -0.98804366588592529 -0.15417435765266418 0 -0.15417437255382538 0.98804366588592529 0 6632.dat 1 71 119.97733306884766 -164.45565795898437 -203.76103210449219 -1 0 0 0 0.15417534112930298 -0.98804366588592529 0 -0.98804366588592529 -0.15417510271072388 6141.dat 1 0 99.977340698242188 -165.99855041503906 -193.88034057617187 0 0 1 0.1541757732629776 0.98804354667663574 0 -0.98804348707199097 0.1541757732629776 0 32062.dat 1 0 99.977333068847656 -165.99858093261719 -193.87968444824219 0 -1 0 -0.15417428314685822 0 -0.98804372549057007 0.98804372549057007 0 -0.15417425334453583 41678.dat 1 0 139.97734069824219 -166.76942443847656 -188.93997192382812 0 0 1.0000001192092896 0.98804360628128052 -0.15417547523975372 0 0.15417560935020447 0.98804360628128052 0 11478.dat 1 71 159.97738647460938 -165.99867248535156 -193.88015747070312 -1 0 0 0 0.1541755199432373 -0.98804354667663574 0 -0.98804354667663574 -0.15417541563510895 6141.dat 1 43 159.97738647460938 -164.76533508300781 -201.78451538085937 -1 0 0 0 0.1541755199432373 -0.98804354667663574 0 -0.98804354667663574 -0.15417541563510895 6141.dat 1 43 119.97733306884766 -163.22343444824219 -211.66534423828125 -1 0 0 0 0.15417534112930298 -0.98804366588592529 0 -0.98804366588592529 -0.15417510271072388 6141.dat 1 1 139.97740173339844 -169.08236694335937 -174.1192626953125 0 1 0 -0.15330547094345093 0 0.9881787896156311 0.9881787896156311 0 0.15330548584461212 4274.dat 1 1 39.977409362792969 -169.08236694335937 -174.1192626953125 0 1 0 -0.15330547094345093 0 0.9881787896156311 0.9881787896156311 0 0.15330548584461212 4274.dat 1 1 -60.022209167480469 -169.20314025878906 -174.14006042480469 0 1 0 -0.15330547094345093 0 0.9881787896156311 0.9881787896156311 0 0.15330548584461212 4274.dat 1 0 -100.02227020263672 -169.96966552734375 -169.19918823242187 0 0 -1 -0.98817884922027588 -0.15330557525157928 0 -0.15330563485622406 0.98817884922027588 0 32065.dat 1 1 -160.02226257324219 -167.65261840820313 -184.01914978027344 0 -1.0000001192092896 0 0.15417900681495667 0 0.98804301023483276 -0.98804301023483276 0 0.15417905151844025 4274.dat 1 71 -200.02259826660156 -167.553955078125 -183.99943542480469 1 0 0 0 0.154176265001297 0.98804336786270142 0 -0.98804336786270142 0.154176265001297 6141.dat 1 0 -160.02259826660156 -168.32485961914063 -179.05917358398437 0 0 1 0.98804336786270142 -0.15417629480361938 0 0.1541762501001358 0.98804336786270142 0 32017.dat 1 57 -200.02259826660156 -166.320556640625 -191.90403747558594 1 0 0 0 0.154176265001297 0.98804336786270142 0 -0.98804336786270142 0.154176265001297 6141.dat 1 1 -140.02223205566406 -169.20314025878906 -174.14006042480469 0 1 0 -0.15330547094345093 0 0.9881787896156311 0.9881787896156311 0 0.15330548584461212 4274.dat 1 0 -100.02261352539062 -165.26626586914063 -198.82618713378906 0 0 -1.0000001192092896 -0.98804372549057007 -0.15417426824569702 0 -0.1541743278503418 0.98804372549057007 0 6632.dat 1 71 -120.0225830078125 -164.49482727050781 -203.76655578613281 1 0 0 0 0.15417426824569702 0.98804366588592529 0 -0.98804366588592529 0.15417426824569702 6141.dat 1 43 -120.0225830078125 -163.26115417480469 -211.6708984375 1 0 0 0 0.15417426824569702 0.98804366588592529 0 -0.98804366588592529 0.15417426824569702 6141.dat 1 0 -100.02261352539062 -166.03750610351562 -193.88601684570312 0 0 1 0.15417580306529999 0.98804342746734619 0 -0.98804342746734619 0.15417580306529999 0 32062.dat 1 0 -140.02252197265625 -166.78195190429687 -188.93931579589844 0 0 1.0000001192092896 0.98804360628128052 -0.15417547523975372 0 0.15417560935020447 0.98804360628128052 0 11478.dat 1 0 -100.02261352539062 -166.03775024414062 -193.88542175292969 0 -1 0 -0.15417428314685822 0 -0.98804372549057007 0.98804372549057007 0 -0.15417425334453583 41678.dat 1 43 -160.02259826660156 -164.77713012695312 -201.78410339355469 1 0 0 0 0.15417544543743134 0.98804348707199097 0 -0.98804348707199097 0.15417544543743134 6141.dat 1 71 -160.02259826660156 -166.01113891601562 -193.8797607421875 1 0 0 0 0.15417544543743134 0.98804348707199097 0 -0.98804348707199097 0.15417544543743134 6141.dat 1 1 -120.02253723144531 -166.01223754882813 -193.87966918945312 0 -1 0 0.15417422354221344 0 0.98804372549057007 -0.98804372549057007 0 0.15417428314685822 4274.dat 1 1 -40.02337646484375 -169.11665344238281 -174.1220703125 0 1 0 -0.1541752815246582 0 0.98804348707199097 0.98804348707199097 0 0.1541752964258194 4274.dat 1 0 79.977317810058594 -165.99891662597656 -193.88040161132812 0 0 1 0.15417823195457458 0.98804306983947754 0 -0.98804306983947754 0.15417823195457458 0 2780.dat 1 4 -60.022579193115234 -164.28414916992187 -208.40766906738281 0 1.0000001192092896 0 -0.078133709728717804 0 -0.99694299697875977 -0.99694299697875977 0 0.078133799135684967 32523.dat 1 1 0.0019083811203017831 -134.31575012207031 -169.96588134765625 0 -1 0 -1 0 0 0 0 -1 43093.dat 1 0 0.001917034387588501 -144.31573486328125 -189.96589660644531 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 42003.dat 1 1 39.977329254150391 -144.34031677246094 -209.96975708007812 -1 0 0 0 1 0 0 0 -1 6558.dat 1 72 19.977388381958008 -164.27919006347656 -208.40670776367188 0 1.0000001192092896 0 -0.078133709728717804 0 -0.99694299697875977 -0.99694299697875977 0 0.078133799135684967 32523.dat 1 1 -0.022679567337036133 -184.21810913085937 -206.84419250488281 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 -0.0072468924336135387 -188.83549499511719 -177.20266723632812 0 -1 0 0.1541760265827179 0 0.98804342746734619 -0.98804342746734619 0 0.15417605638504028 43093.dat 1 0 -0.022696677595376968 -184.21800231933594 -206.84419250488281 -1 0 0 0 0.98804384469985962 0.15417544543743134 0 0.15417544543743134 -0.98804348707199097 32013.dat 1 0 109.97731781005859 -199.65571594238281 -108.04311370849609 -1 0.0001249949709745124 0 0.00012499449076130986 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 72 -20.022668838500977 -164.27923583984375 -208.4068603515625 0 1.0000001192092896 0 -0.078133709728717804 0 -0.99694299697875977 -0.99694299697875977 0 0.078133799135684967 32523.dat 1 28 -40.022659301757813 -164.27919006347656 -208.40701293945312 1 0 0 0 -1 0 0 0 -1 6587.dat 1 72 -0.022657960653305054 -164.27919006347656 -208.40701293945312 0 1 0 1 0 0 0 0 -1 18654.dat 1 28 39.977394104003906 -164.27919006347656 -208.40670776367188 -1 0 0 0 -1 0 0 0 1 6587.dat 1 4 59.977352142333984 -164.27919006347656 -208.40704345703125 0 1.0000001192092896 0 -0.078133709728717804 0 -0.99694299697875977 -0.99694299697875977 0 0.078133799135684967 32523.dat 1 0 -0.022839754819869995 -224.33383178710937 50.042869567871094 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 1 -100.007080078125 -205.76980590820312 -68.514106750488281 1 0 0 0 -1 0 0 0 -1 6558.dat 1 4 -60.008094787597656 -201.39286804199219 33.369781494140625 0 0 -1.0000001192092896 0.1539231538772583 -0.98808282613754272 0 -0.98808294534683228 -0.1539231538772583 0 6536.dat 1 28 -60.003292083740234 -198.32919311523437 13.635006904602051 0 0 -1 0.15392637252807617 -0.98808228969573975 0 -0.98808234930038452 -0.15392637252807617 0 6587.dat 1 4 -60.003517150878906 -198.32945251464844 13.635013580322266 0 0 -1.0000001192092896 -0.98808354139328003 -0.15391911566257477 0 -0.15391924977302551 0.98808354139328003 0 32140.dat 1 0 -100.0035400390625 -194.48146057128906 -11.066864013671875 0 0 -1.0000001192092896 -0.98808419704437256 -0.15391486883163452 0 -0.1539149284362793 0.98808419704437256 0 6632.dat 1 1 -100.00352478027344 -196.79017639160156 3.7542662620544434 0 -1 0 0.15391527116298676 0 0.98808407783508301 -0.98808407783508301 0 0.15391531586647034 43093.dat 1 4 -140.00747680664062 -221.23358154296875 30.283618927001953 0 0 1.0000001192092896 0.98804336786270142 -0.15417681634426117 0 0.15417695045471191 0.98804336786270142 0 42003.dat 1 0 -140.00357055664062 -198.33209228515625 13.634857177734375 1 0 0 0 0.98804306983947754 -0.15417811274528503 0 0.15417811274528503 0.98804306983947754 10197.dat 1 0 -100.0035400390625 -196.02061462402344 -1.186011791229248 0 0 -1.0000001192092896 -0.98808419704437256 -0.15391486883163452 0 -0.1539149284362793 0.98808419704437256 0 6632.dat 1 0 -120.00749206542969 -221.23358154296875 30.283317565917969 -1 0 0 0 -0.15391941368579865 0.98808348178863525 0 0.98808348178863525 0.15391962230205536 15100.dat 1 4 -80.007102966308594 -215.00497436523437 -9.2044353485107422 -0.00017694593407213688 -1 0 -0.98807960748672485 0.0001750012015691027 0.15394377708435059 -0.15394377708435059 2.6218456696369685E-005 -0.98807960748672485 64683.dat 1 4 -119.80705261230469 -214.92936706542969 -9.445317268371582 0.00024676148314028978 1 0 0.98818427324295044 -0.00024349961313419044 0.15327067673206329 0.15327067673206329 -3.9292517612921074E-005 -0.98818427324295044 11946.dat 1 72 -119.80706787109375 -218.04869079589844 10.537425994873047 0 -1.0000001192092896 0 0.15392062067985535 0 0.9880833625793457 -0.9880833625793457 0 0.15392078459262848 11214.dat 1 0 -120.00352478027344 -196.790283203125 3.7543931007385254 0 0 0.99999994039535522 0.15391775965690613 0.9880836009979248 0 -0.9880836009979248 0.15391775965690613 0 2780.dat 1 1 -80.007057189941406 -221.16036987304687 30.29249382019043 -1 1.0223356184724253E-005 3.1228788429871202E-005 1.038937898556469E-005 -0.80324792861938477 0.59564489126205444 3.1173949537333101E-005 0.59564489126205444 0.80324798822402954 6558.dat 1 0 -80.003509521484375 -196.79017639160156 3.7544217109680176 0 0 1.0000001192092896 0.15392407774925232 0.9880828857421875 0 -0.98808276653289795 0.15392407774925232 0 2780.dat 1 4 -80.007232666015625 -221.21878051757812 30.285442352294922 -8.9976027084048837E-005 -1.0000001192092896 0 -0.98790860176086426 8.9090899564325809E-005 0.15503792464733124 -0.15503792464733124 1.3702995602216106E-005 -0.98790854215621948 32523.dat 1 1 -100.007080078125 -208.85061645507812 -48.752830505371094 1 0 0 0 -1 0 0 0 -1 6558.dat 1 0 -90.007049560546875 -202.68377685546875 -88.274734497070313 -1 0.00012499498552642763 0 0.00012499450531322509 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 1 99.977294921875 -193.49928283691406 -147.56636047363281 1 0 0 0 1 0 0 0 1 6558.dat 1 0 -209.984375 -64.632156372070312 430.00308227539062 1 0 0 0 1 0 0 0 1 2780.dat 1 1 -240.00634765625 -128.49058532714844 538.04974365234375 0 1.0000001192092896 0 0.59998214244842529 0 0.80001348257064819 0.80001348257064819 0 -0.59998202323913574 6558.dat 1 4 -240.01451110839844 -124.24036407470703 510.00299072265625 1 0 0 0 0.5999990701675415 -0.80000072717666626 0 0.80000072717666626 0.5999990701675415 32526.dat 1 0 -220.0145263671875 -176.24247741699219 574.00286865234375 0 0 1 -0.80000132322311401 -0.59999823570251465 0 0.59999823570251465 -0.80000132322311401 0 32140.dat 1 1 -220.0145263671875 -182.24235534667969 566.00286865234375 0 -1.0000001192092896 0 0.59999871253967285 0 -0.80000114440917969 0.80000114440917969 0 0.5999988317489624 43093.dat 1 0 -200.0145263671875 -182.240478515625 566.00286865234375 0 0 -1.0000001192092896 0.60000044107437134 0.79999983310699463 0 0.79999977350234985 -0.60000044107437134 0 2780.dat 1 0 -240.01451110839844 -166.24061584472656 554.0029296875 0 0 -1 0.59999918937683105 0.80000060796737671 0 0.80000060796737671 -0.59999918937683105 0 2780.dat 1 1 -160.01457214355469 -246.23660278320312 614.0030517578125 0 0.79999905824661255 0.60000127553939819 0.59999990463256836 -0.48000064492225647 0.6399996280670166 0.80000013113021851 0.36000126600265503 -0.47999885678291321 43093.dat 1 4 -160.01313781738281 -240.23640441894531 622.00299072265625 0.59999954700469971 0 -0.80000072717666626 0.63999903202056885 -0.60000193119049072 0.47999909520149231 -0.48000249266624451 -0.79999864101409912 -0.36000001430511475 6629.dat 1 1 -240.00491333007812 -138.49052429199219 558.0498046875 0 1.0000001192092896 0 -0.59999972581863403 0 -0.80000030994415283 -0.80000030994415283 0 0.59999972581863403 43093.dat 1 0 -240.01451110839844 -182.24049377441406 566.00286865234375 0 0 -1 0.59999918937683105 0.80000060796737671 0 0.80000060796737671 -0.59999918937683105 0 2780.dat 1 0 -224.01223754882813 -207.84101867675781 585.201904296875 0 0 -1 0.59998470544815063 0.80001151561737061 0 0.80001151561737061 -0.59998470544815063 0 2780.dat 1 4 -224.01220703125 -213.84100341796875 577.20184326171875 -0.60007500648498535 0 0.79994380474090576 -0.63995462656021118 -0.60000067949295044 -0.48005977272987366 0.47996684908866882 -0.79999953508377075 0.36004564166069031 32523.dat 1 0 -240.01260375976562 -216.24124145507812 554.0023193359375 0 0 1.0000001192092896 0.59999918937683105 -0.80000066757202148 0 0.80000072717666626 0.59999918937683105 0 15100.dat 1 4 -240.01451110839844 -184.12120056152344 530.16162109375 -1 0 0 0 0.59998250007629395 0.80001336336135864 0 0.80001336336135864 -0.59998226165771484 11947.dat 1 72 -240.01261901855469 -200.24264526367187 542.00238037109375 0 1 0 0.80000180006027222 0 -0.59999763965606689 -0.59999763965606689 0 -0.80000174045562744 11214.dat 1 4 -240.01260375976562 -212.241455078125 526.00238037109375 -1 0 0 0 0.59999889135360718 0.80000072717666626 0 0.80000072717666626 -0.59999901056289673 42003.dat 1 1 -230.00531005859375 -224.33175659179687 510.024658203125 -1 0 0 0 0.80000120401382446 -0.59999889135360718 0 -0.59999889135360718 -0.80000084638595581 43093.dat 1 0 -60.008609771728516 -324.6441650390625 370.04302978515625 0 -0.99998581409454346 0.0053306720219552517 -0.99998581409454346 -2.1444711819640361E-005 -0.0053305095061659813 0.0053305481560528278 -0.0053306333720684052 -0.99997156858444214 40490.dat 1 0 -199.97529602050781 -164.71354675292969 510.03042602539062 -1 0 0 0 0 1 0 1 0 40490.dat 1 1 -199.97529602050781 -244.71356201171875 490.0303955078125 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 0 -200.0211181640625 -224.33378601074219 490.04287719726562 -1 0 0 0 -1 0 0 0 1 6536.dat 1 1 -210.0211181640625 -224.33381652832031 490.040771484375 0.99999994039535522 0 0 0 0 1 0 -1 0 43093.dat 1 0 -176.01603698730469 -276.33001708984375 470.04180908203125 -0.79990506172180176 0 0.60012656450271606 -0.60012656450271606 0 -0.79990506172180176 0 -1 0 32316.dat 1 0 -188.00840759277344 -260.32437133789062 460.0416259765625 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 1 -200.00843811035156 -244.32440185546875 440.04159545898437 0 -0.60000115633010864 -0.7999991774559021 0 0.79999923706054688 -0.60000115633010864 1 0 0 43093.dat 1 0 -200.00843811035156 -244.32440185546875 450.04156494140625 0.79999935626983643 0 0.60000085830688477 0.60000085830688477 0 -0.7999994158744812 0 1 0 6629.dat 1 1 -80.008270263671875 -324.32431030273437 440.04183959960937 0 0 1 0 -1 0 1 0 0 43093.dat 1 0 -80.00860595703125 -324.32431030273437 430.04183959960937 0.99999994039535522 1.4928249584045261E-005 0 0 0 1 1.4928249584045261E-005 -1 0 15100.dat 1 0 -50.008575439453125 -324.21771240234375 450.04196166992187 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -40.007919311523438 -324.3243408203125 450.04156494140625 -1.4729137546964921E-005 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 1.4788762200623751E-005 0 15100.dat 1 0 -0.0083208084106445313 -324.32431030273437 470.04159545898437 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32278.dat 1 0 -80.008804321289062 -324.32431030273437 490.0416259765625 1.4923482012818567E-005 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 -1.485223947383929E-005 0 15100.dat 1 0 19.991205215454102 -324.32431030273437 490.04153442382813 1.4923482012818567E-005 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 -1.485223947383929E-005 0 15100.dat 1 0 119.98413848876953 -324.31869506835937 460.04153442382812 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 1 199.98416137695312 -244.31877136230469 440.04141235351562 0 -0.79999935626983643 -0.60000085830688477 0 0.60000085830688477 -0.79999935626983643 1 0 0 43093.dat 1 0 199.98439025878906 -244.31877136230469 450.04144287109375 -0.79999929666519165 0 -0.60000097751617432 0.60000097751617432 0 -0.7999994158744812 0 -1.0000001192092896 0 6629.dat 1 1 79.983757019042969 -324.31887817382812 440.04144287109375 0 0 1 0 -1 0 1 0 0 43093.dat 1 0 79.984245300292969 -324.31863403320312 430.04144287109375 -1 -1.5154791071836371E-005 -1.5031158000056166E-005 -1.5031157090561464E-005 0 1 -1.5154792890825775E-005 1 0 15100.dat 1 0 59.984241485595703 -324.63848876953125 370.04217529296875 0 -0.99998581409454346 0.0053306720219552517 -0.99998581409454346 -2.1444711819640361E-005 -0.0053305095061659813 0.0053305481560528278 -0.0053306333720684052 -0.99997156858444214 40490.dat 1 0 49.992324829101563 -325.17990112304688 330.0435791015625 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 0 39.992324829101563 -325.17739868164062 310.04400634765625 0 -1 0 -1 0 0 0 0 -1 32523.dat 1 0 49.992321014404297 -325.17990112304688 310.04360961914062 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209730587899685 0 -0.0054209730587899685 -0.99998527765274048 2780.dat 1 0 154.07969665527344 -305.61993408203125 248.45741271972656 -0.92387950420379639 0 0.38268357515335083 0.1639581173658371 0.90356796979904175 0.39583209156990051 -0.34578093886375427 0.42844521999359131 -0.83478760719299316 59443.dat 1 4 146.42610168457031 -313.53656005859375 265.15313720703125 0.38268381357192993 0 0.92387938499450684 0.39582985639572144 0.90356862545013428 -0.16395886242389679 -0.83478850126266479 0.42844343185424805 0.34578084945678711 32062.dat 1 0 134.94560241699219 -325.4117431640625 290.19705200195312 0 0 1.0000001192092896 0.90356910228729248 -0.42844244837760925 0 0.42844250798225403 0.90356910228729248 0 32015.dat 1 0 -4.0077495574951172 -325.17697143554687 290.04345703125 1 0 0 0 0.90356916189193726 -0.42844226956367493 0 0.42844226956367493 0.90356916189193726 3708.dat 1 0 79.992202758789062 -325.177001953125 290.04351806640625 0 0 -1 -0.42844194173812866 0.90356934070587158 0 0.90356934070587158 0.42844194173812866 0 6590.dat 1 0 -20.007778167724609 -325.17684936523437 290.04348754882812 0 -1.0000001192092896 0 -0.90356481075286865 0 0.4284517765045166 -0.4284517765045166 0 -0.9035646915435791 60483.dat 1 0 19.992313385009766 -325.17697143554687 290.04397583007812 0 -1 0 -0.90356475114822388 0 0.42845156788825989 -0.42845156788825989 0 -0.90356475114822388 60483.dat 1 0 -134.92561340332031 -325.420654296875 290.182861328125 0 -0.92387938499450684 0.38268408179283142 0.90356826782226563 -0.1639583557844162 -0.39583107829093933 0.42844441533088684 0.3457813560962677 0.83478796482086182 32015.dat 1 4 -146.40621948242187 -313.54568481445312 265.13906860351562 -0.38268274068832397 0 0.92387986183166504 0.39583063125610352 0.90356874465942383 0.16395723819732666 -0.83478868007659912 0.4284435510635376 -0.34578043222427368 32062.dat 1 0 -80.007881164550781 -325.17691040039062 290.04348754882812 0 0 -1.0000001192092896 -0.42844194173812866 0.90356951951980591 0 0.90356945991516113 0.42844194173812866 0 6590.dat 1 0 174.36209106445312 -284.640869140625 204.21347045898437 -0.38268396258354187 0 -0.92387932538986206 -0.3958289623260498 0.90356910228729248 0.16395850479602814 0.83478885889053345 0.42844247817993164 -0.34578117728233337 32209.dat 1 0 200.00190734863281 -232.413818359375 94.067176818847656 -1 0 0 0 0.90356886386871338 0.42844298481941223 0 0.42844298481941223 -0.9035688042640686 32013.dat 1 4 200.001708984375 -245.2669677734375 121.17485046386719 0 0 1.0000001192092896 0.42844280600547791 0.90356910228729248 0 -0.90356904268264771 0.42844280600547791 0 32062.dat 1 0 200.00169372558594 -258.1202392578125 148.28173828125 0 1 0 -0.90356910228729248 0 -0.42844250798225403 -0.42844250798225403 0 0.90356910228729248 32016.dat 1 0 -154.05972290039062 -305.62945556640625 248.44329833984375 -0.92387974262237549 0 -0.38268294930458069 -0.16395549476146698 0.90357202291488647 0.39582374691963196 0.34578147530555725 0.4284365177154541 -0.83479183912277222 59443.dat 1 0 -174.34193420410156 -284.6500244140625 204.19912719726562 0.38268342614173889 0 -0.92387956380844116 -0.3958294689655304 0.90356898307800293 -0.16395784914493561 0.83478891849517822 0.42844271659851074 0.34578090906143188 32209.dat 1 0 -199.98153686523437 -258.12945556640625 148.26849365234375 -5.9189300372963771E-005 -0.92388683557510376 -0.3826659619808197 -0.9035833477973938 -0.1638893187046051 0.39582505822181702 -0.42841240763664246 0.34579405188560486 -0.83479893207550049 32016.dat 1 4 -199.98171997070313 -245.27655029296875 121.16079711914062 0 0 1.0000001192092896 0.42844280600547791 0.90356910228729248 0 -0.90356904268264771 0.42844280600547791 0 32062.dat 1 0 -199.98171997070313 -232.4228515625 94.053863525390625 -1 0 0 0 0.90356886386871338 0.42844262719154358 0 0.42844262719154358 -0.90356898307800293 32013.dat 1 1 -0.0077903270721435547 -316.60791015625 271.97216796875 1 0 0 0 1 0 0 0 1 6558.dat 1 0 -0.0077907801605761051 -316.60806274414062 271.97216796875 0 1 0 0.99939090013504028 0 -0.034898880869150162 -0.034898880869150162 0 -0.99939084053039551 15100.dat 1 71 -0.0082406224682927132 -296.6202392578125 271.274169921875 -0.17365135252475739 0 -0.98480737209320068 -0.034369867295026779 -0.99939078092575073 0.0060599995777010918 -0.9842073917388916 0.034900020807981491 0.1735459566116333 32523.dat 1 1 -239.99786376953125 -128.40557861328125 122.06946563720703 0 0 -1.0000001192092896 -0.59998267889022827 0.80001318454742432 0 0.80001306533813477 0.59998267889022827 0 6558.dat 1 72 -207.998779296875 -191.60313415527344 99.669975280761719 0 -0.59999763965606689 -0.80000180006027222 0.59998816251754761 -0.64000511169433594 0.48000800609588623 -0.80000889301300049 -0.47999617457389832 0.35998538136482239 11214.dat 1 4 -207.99844360351562 -179.60336303710937 83.669219970703125 -0.59999686479568481 0 0.8000023365020752 -0.64001208543777466 0.59998178482055664 -0.48000681400299072 -0.47998777031898499 -0.80001378059387207 -0.35998576879501343 32140.dat 1 4 -239.99858093261719 -124.40254974365234 150.07005310058594 1 0 0 0 -0.59999817609786987 -0.80000138282775879 0 0.80000138282775879 -0.59999817609786987 32348.dat 1 0 -191.99876403808594 -201.20327758789063 92.470573425292969 0 -0.59998095035552979 0.8000144362449646 -0.59998106956481934 -0.64002221822738647 -0.47999411821365356 0.80001437664031982 -0.4799942672252655 -0.35997593402862549 18651.dat 1 0 -191.998779296875 -213.20259094238281 108.47026062011719 0.59999918937683105 0 -0.80000072717666626 0.64001357555389404 0.59997951984405518 0.48000773787498474 0.47998315095901489 -0.80001550912857056 0.35998827219009399 60483.dat 1 0 -239.99859619140625 -168.40298461914062 142.07084655761719 0 -1 0 -0.59997999668121338 0 -0.80001503229141235 0.80001503229141235 0 -0.5999799370765686 32013.dat 1 0 -239.99858093261719 -136.40231323242187 166.07002258300781 1 0 0 0 0.80001389980316162 -0.59998142719268799 0 0.59998142719268799 0.80001389980316162 10197.dat 1 0 -239.99838256835937 -84.706581115722656 130.0946044921875 1 0 0 0 -0.60000026226043701 -0.79999977350234985 0 0.79999977350234985 -0.60000026226043701 11946.dat 1 1 -239.99838256835937 -76.52655029296875 136.22959899902344 0 0 1 -0.79999983310699463 0.60000032186508179 0 -0.60000032186508179 -0.79999983310699463 0 43093.dat 1 1 -239.99838256835937 -144.40583801269531 110.06976318359375 0 0 -1.0000001192092896 -0.59998267889022827 0.80001318454742432 0 0.80001306533813477 0.59998267889022827 0 6558.dat 1 0 -199.99226379394531 -138.32048034667969 102.04283905029297 0 3.5552511690184474E-005 -1 -0.59998214244842529 0.80001348257064819 2.8675493012997322E-005 0.80001342296600342 0.59998214244842529 2.106956162606366E-005 2780.dat 1 0 -159.99226379394531 -132.32084655761719 94.042572021484375 0 0 -1.0000001192092896 -0.79999947547912598 -0.60000073909759521 0 -0.60000085830688477 0.79999947547912598 0 32316.dat 1 4 -179.99229431152344 -144.32106018066406 110.04244232177734 0 0 -1.0000001192092896 -0.80001199245452881 -0.59998410940170288 0 -0.59998422861099243 0.80001199245452881 0 32140.dat 1 1 -179.99226379394531 -138.32084655761719 102.04256439208984 0 1 0 -0.60000056028366089 0 0.79999959468841553 0.79999959468841553 0 0.60000056028366089 43093.dat 1 0 -239.99833679199219 -166.40333557128906 106.07005310058594 0 0.00093165086582303047 -0.99999964237213135 -0.59998464584350586 0.80001121759414673 0.00074554455932229757 0.80001157522201538 0.59998440742492676 0.0005587079213000834 2780.dat 1 0 220.02037048339844 -84.326347351074219 450.02389526367187 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 4 220.02041625976562 -84.326339721679688 450.02392578125 0.99999994039535522 0 0 0 0 1 0 -1 0 44809.dat 1 0 240.02041625976562 -94.326332092285156 450.02392578125 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 4 240.00015258789062 -104.41415405273437 450.06900024414062 1 0 0 0 -1 0 0 0 -1 32524.dat 1 1 240.00018310546875 -104.41415405273437 430.06903076171875 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 0 210.00613403320312 -64.326507568359375 210.02545166015625 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 -240.00634765625 -84.609207153320313 529.890625 -1 0 0 0 -0.59998220205307007 -0.80001342296600342 0 -0.80001342296600342 0.59998250007629395 11947.dat 1 1 -240.00634765625 -76.609375 523.890869140625 0 0 1.0000001192092896 -0.80001348257064819 -0.59998208284378052 0 0.59998220205307007 -0.80001348257064819 0 43093.dat 1 0 -208.01443481445312 -217.4407958984375 592.4029541015625 0 0 -1.0000001192092896 0.59999996423721313 0.80000019073486328 0 0.80000013113021851 -0.59999996423721313 0 2780.dat 1 0 -240.01455688476562 -130.2406005859375 502.0028076171875 0 0 1 0.60000121593475342 -0.79999905824661255 0 0.79999905824661255 0.60000121593475342 0 2780.dat 1 0 -240.00634765625 -68.609100341796875 517.89105224609375 0.99996042251586914 0 0.0089036654680967331 -0.005342031829059124 0.80001324415206909 0.59995865821838379 -0.007123058196157217 -0.59998244047164917 0.79998147487640381 18654.dat 1 0 -220.00672912597656 -84.329124450683594 450.02566528320312 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 4 -220.00669860839844 -84.329132080078125 450.02566528320312 -1 0 0 0 0 1 0 1 0 44809.dat 1 0 -240.00668334960937 -94.329124450683594 450.02560424804687 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 4 -240.00668334960937 -104.32913208007812 450.02560424804687 1 0 0 0 -1 0 0 0 -1 32524.dat 1 1 -240.02011108398437 -84.327980041503906 490.025146484375 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 6558.dat 1 0 -240.005615234375 -64.327964782714844 490.025146484375 1 0 0 0 -1 0 0 0 -1 87082.dat 1 0 -260.00570678710937 -84.329170227050781 415.0255126953125 0.99999994039535522 0 0 0 0 1 0 -1 0 41677.dat 1 71 -260.00570678710937 -84.329177856445313 410.02554321289062 0 0 -1 0 0.99999994039535522 0 1 0 0 4519.dat 1 0 -260.00570678710937 -84.329185485839844 390.02560424804687 -1 0 0 0 1 0 0 0 -1 11947.dat 1 71 -260.00570678710937 -64.329170227050781 410.02554321289062 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 -260.00570678710937 -84.329177856445313 430.25054931640625 1 0 0 0 1 0 0 0 1 11946.dat 1 0 -260.00567626953125 -64.329170227050781 380.0255126953125 1 0 0 0 1 0 0 0 1 59443.dat 1 0 -260.00555419921875 -64.327964782714844 440.025146484375 1 0 0 0 1 0 0 0 1 59443.dat 1 1 -260.01458740234375 -64.240982055664063 520.0018310546875 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 0 -260.01458740234375 -64.240982055664063 490.00186157226562 1 0 0 0 1 0 0 0 1 32034.dat 1 4 -260.00555419921875 -64.327964782714844 460.02511596679687 0 0 1 0 1 0 -1 0 0 32062.dat 1 4 -260.00570678710937 -64.329170227050781 360.02548217773437 0 0 1 0 1 0 -1 0 0 32062.dat 1 0 -260.00570678710937 -84.329170227050781 405.02557373046875 0.99999994039535522 0 0 0 0 1 0 -1 0 41677.dat 1 0 -260.00570678710937 -64.32916259765625 330.02542114257812 1 0 0 0 1 0 0 0 1 32034.dat 1 4 -260.00570678710937 -64.329170227050781 300.02545166015625 0 0 1 0 1 0 -1 0 0 32062.dat 1 0 -260.005859375 -64.330375671386719 170.02584838867187 -1 0 0 0 1 0 0 0 -1 32034.dat 1 1 -260.005859375 -64.330375671386719 140.02586364746094 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 4 -260.005859375 -64.330375671386719 200.02581787109375 0 0 1 0 1 0 -1 0 0 32062.dat 1 0 -260.005859375 -64.330375671386719 220.02580261230469 1 0 0 0 1 0 0 0 1 59443.dat 1 71 -260.00570678710937 -64.329170227050781 250.02548217773437 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 -260.00570678710937 -64.329170227050781 280.02545166015625 1 0 0 0 1 0 0 0 1 59443.dat 1 0 -239.99235534667969 -64.329185485839844 330.02499389648437 1 0 0 0 -1 0 0 0 -1 87082.dat 1 1 -240.00688171386719 -84.329185485839844 330.02499389648437 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 4 -240.00692749023437 -84.329177856445313 330.02490234375 1 0 0 0 -1 0 0 0 -1 32525.dat 1 0 -240.00688171386719 -94.32916259765625 270.02493286132812 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 4 -240.00688171386719 -104.32917022705078 250.02493286132812 1 0 0 0 -1 0 0 0 -1 32525.dat 1 0 -240.00688171386719 -94.32916259765625 210.02499389648437 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 4 -160.02041625976562 -84.330375671386719 210.0240478515625 0 0 -1 0 -1 0 -1 0 0 32526.dat 1 0 -179.99247741699219 -74.329330444335938 210.02507019042969 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 1 -240.00688171386719 -84.329170227050781 170.02494812011719 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 6558.dat 1 0 -240.00584411621094 -64.330375671386719 170.02584838867187 1 0 0 0 -1 0 0 0 -1 87082.dat 1 0 -240.00692749023437 -94.329170227050781 230.02493286132812 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 1 -240.00672912597656 -104.32914733886719 430.02572631835937 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 4 -180.00672912597656 -124.32916259765625 450.02569580078125 0 0 -1 0 -1 0 -1 0 0 32140.dat 1 1 -180.00672912597656 -134.32914733886719 450.02569580078125 0 0 1 1 0 0 0 1 0 43093.dat 1 0 -199.96037292480469 -204.90286254882812 430.02572631835937 0.99999994039535522 0 0 0 0 -1 0 1 0 32316.dat 1 0 -199.96040344238281 -224.90286254882812 450.02584838867187 0 -1 0 0 0 1 -1 0 0 15100.dat 1 4 -240.00527954101562 -208.33370971679687 438.02310180664062 1 2.7204474463360384E-005 0 -2.1763935365015641E-005 0.80001306533813477 0.5999826192855835 1.6322212104569189E-005 -0.5999826192855835 0.80001306533813477 42003.dat 1 0 -210.00582885742187 -224.33430480957031 450.02261352539062 -1 0 0 0 0.80001300573348999 -0.59998267889022827 0 -0.59998267889022827 -0.80001294612884521 3705.dat 1 0 -160.00582885742187 -224.33621215820312 450.02304077148437 1 0 0 0 0.79999899864196777 0.60000133514404297 0 -0.60000133514404297 0.79999899864196777 32054.dat 1 0 -140.00540161132812 -204.33125305175781 450.0235595703125 0 0 -1.0000001192092896 -1.0000001192092896 0 0 0 1.0000001192092896 0 44809.dat 1 0 -119.99900054931641 -204.41331481933594 470.06982421875 0 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 0 0 42003.dat 1 1 -139.99897766113281 -204.41331481933594 460.06985473632812 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 1 -99.999031066894531 -224.41339111328125 470.06988525390625 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 -79.999458312988281 -244.41340637207031 470.06988525390625 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 60484.dat 1 0 -79.9990234375 -234.41340637207031 470.06988525390625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 0.00098943710327148438 -224.41342163085937 470.06988525390625 0 0 1 0 -1 0 1 0 0 32525.dat 1 1 100.00096893310547 -224.41339111328125 470.06988525390625 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 1 140.00096130371094 -204.41331481933594 460.07098388671875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 120.00096893310547 -204.41331481933594 470.071044921875 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 42003.dat 1 0 120.00098419189453 -204.41336059570312 470.0697021484375 0 0 -0.99999994039535522 -0.99999994039535522 0 0 0 0.99999994039535522 0 32054.dat 1 1 120.02033996582031 -174.32635498046875 470.02386474609375 0 0 -0.99999994039535522 -0.99999994039535522 0 0 0 0.99999994039535522 0 43093.dat 1 1 120.00098419189453 -224.41334533691406 570.06976318359375 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 200.09092712402344 -224.31781005859375 530.04193115234375 -1 0 0 0 -1 0 0 0 1 6558.dat 1 1 159.99359130859375 -204.32644653320312 530.04852294921875 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 1 120.00093078613281 -224.413330078125 770.06988525390625 1 0 0 0 1 0 0 0 1 6558.dat 1 0 200.00094604492187 -184.25338745117187 840.19012451171875 0 1 0 0.79999935626983643 0 0.60000085830688477 0.60000085830688477 0 -0.79999935626983643 2780.dat 1 1 159.99429321289062 -204.32644653320312 570.0487060546875 -1 0 0 0 1 0 0 0 -1 6558.dat 1 1 -160.01451110839844 -204.24044799804687 570.00286865234375 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 120.00083923339844 -263.94155883789062 732.00994873046875 1 0 0 0 0.96999990940093994 0.24310527741909027 0 -0.24310527741909027 0.96999990940093994 32013.dat 1 0 119.99461364746094 -280.86056518554688 664.06536865234375 0 0 1.0000001192092896 -0.24310387670993805 0.97000038623809814 0 -0.97000032663345337 -0.24310387670993805 0 3706.dat 1 0 119.99464416503906 -295.4464111328125 605.86529541015625 1 0 0 0 0.9700005054473877 0.24310289323329926 0 -0.24310289323329926 0.9700005054473877 59443.dat 1 0 119.99464416503906 -309.30374145507812 550.5753173828125 0 0 1.0000001192092896 -0.24310198426246643 0.97000086307525635 0 -0.97000080347061157 -0.24310198426246643 0 32209.dat 1 0 119.99464416503906 -324.61810302734375 489.46517944335937 0.99999994039535522 0 0 0 -0.97000008821487427 -0.24310450255870819 0 0.24310450255870819 -0.97000008821487427 32013.dat 1 1 -120.00856018066406 -224.22976684570312 569.96710205078125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -120.00522613525391 -263.84567260742187 731.963134765625 1 0 0 0 0.96999990940093994 0.24310527741909027 0 -0.24310527741909027 0.96999990940093994 32013.dat 1 0 -120.0052490234375 -280.86294555664062 664.06365966796875 0 0 1.0000001192092896 -0.24310389161109924 0.97000038623809814 0 -0.97000032663345337 -0.24310389161109924 0 3706.dat 1 0 -120.00532531738281 -295.44918823242187 605.86370849609375 1 0 0 0 0.9700005054473877 0.24310289323329926 0 -0.24310289323329926 0.9700005054473877 59443.dat 1 0 -120.00532531738281 -309.30621337890625 550.5733642578125 0 0 1.0000001192092896 -0.24310199916362762 0.97000086307525635 0 -0.97000080347061157 -0.24310199916362762 0 32209.dat 1 0 -120.00522613525391 -324.62164306640625 489.46353149414062 1 0 0 0 -0.97000002861022949 -0.2431047260761261 0 0.2431047260761261 -0.97000002861022949 32013.dat 1 1 -230.00567626953125 -176.33212280273437 414.02545166015625 1 -3.7143294321140274E-005 -2.1438063413370401E-005 0 -0.60000103712081909 0.79999923706054688 -4.2577466956572607E-005 -0.79999923706054688 -0.60000103712081909 43093.dat 1 4 -220.00566101074219 -224.33213806152344 550.024658203125 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 6629.dat 1 28 -180.00572204589844 -224.3316650390625 550.023681640625 1 0 0 0 1 0 0 0 1 15462.dat 1 72 -100.00516510009766 -204.33149719238281 520.02459716796875 0 0 1 0 0.99999994039535522 0 -1 0 0 87083.dat 1 0 -140.00523376464844 -204.33132934570312 505.0225830078125 -1 0 0 0 0 1 0 1 0 2905.dat 1 4 -180.00526428222656 -204.3314208984375 500.02261352539062 0 0 1 0 1 0 -1 0 0 32062.dat 1 0 -140.00518798828125 -204.33145141601562 515.0225830078125 -1 0 0 0 0 1 0 1 0 2905.dat 1 4 -179.9991455078125 -204.41346740722656 490.06982421875 0 0 -1 -1 0 0 0 1 0 32140.dat 1 0 -100.005126953125 -204.32785034179687 530.0272216796875 0 -0.00017527730960864574 1 -0.00017515367653686553 -0.99999994039535522 -0.00017527738236822188 1 -0.00017515374929644167 0 63869.dat 1 0 -140.00544738769531 -204.33154296875 555.02288818359375 0 -1.449746559956111E-005 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 1.4587863006454427E-005 11478.dat 1 0 -180.01435852050781 -224.24063110351562 550.00274658203125 0 0 -1 1 0 0 0 -1 0 42003.dat 1 72 -180.01432800292969 -204.24055480957031 570.0028076171875 1 0 0 0 1 0 0 0 1 10197.dat 1 0 -140.00531005859375 -204.33154296875 545.02288818359375 0 -1.449746559956111E-005 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 1.4587863006454427E-005 11478.dat 1 72 -199.99942016601562 -204.41351318359375 510.06979370117187 0 1 0 0 0 1 1 0 0 11214.dat 1 0 -200.00631713867187 -204.33210754394531 530.02459716796875 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 6536.dat 1 0 -100.00546264648437 -224.33157348632812 490.0235595703125 -1 0 0 0 1 0 0 0 -1 6536.dat 1 70 -120.00550842285156 -224.33175659179687 490.0234375 -1 0 0 0 0 1 0 1 0 24316.dat 1 0 -120.00550079345703 -224.33148193359375 470.02349853515625 -1 0 0 0 0 -1 0 -1 0 42003.dat 1 0 -140.00546264648437 -224.33174133300781 630.0235595703125 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32278.dat 1 71 -0.0087261199951171875 -324.32437133789062 490.04141235351562 1 0 0 0 0.80000293254852295 0.59999608993530273 0 -0.59999608993530273 0.80000293254852295 32073.dat 1 0 49.991180419921875 -324.32431030273437 490.04168701171875 0 0 1.0000001192092896 -0.59999656677246094 0.8000028133392334 0 -0.80000269412994385 -0.59999656677246094 0 59443.dat 1 0 -50.008686065673828 -324.32431030273437 490.04135131835937 0 0 1 -0.59999698400497437 0.8000023365020752 0 -0.80000227689743042 -0.59999698400497437 0 59443.dat 1 28 99.991081237792969 -324.323486328125 490.04168701171875 1 0 0 0 0.8000023365020752 0.59999692440032959 0 -0.59999692440032959 0.8000023365020752 15462.dat 1 0 100.00095367431641 -324.41293334960937 490.06982421875 0 -1 0 0.7999998927116394 0 0.60000020265579224 -0.60000020265579224 0 0.7999998927116394 6629.dat 1 1 110.0009765625 -204.412841796875 570.06976318359375 -1 0 0 0 0 -1 0 -1 0 43093.dat 1 28 -100.0086669921875 -324.32418823242187 490.041259765625 -1 0 0 0 0.59999656677246094 0.80000287294387817 0 0.80000287294387817 -0.59999626874923706 15462.dat 1 1 -110.0052490234375 -204.33154296875 570.02337646484375 0.99999994039535522 0 0 0 0 -1 0 1 0 43093.dat 1 0 -100.00848388671875 -324.22979736328125 489.96697998046875 0 -1 0 0.8000028133392334 0 0.59999632835388184 -0.59999632835388184 0 0.80000275373458862 6629.dat 1 0 -120.00508117675781 -224.33158874511719 510.023681640625 0 -1 0 1 0 0 0 0 0.99999994039535522 32140.dat 1 1 -110.00514984130859 -224.32438659667969 510.02374267578125 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 43093.dat 1 0 -140.0146484375 -204.2406005859375 570.0030517578125 -1.4729137546964921E-005 1.0000001192092896 0 0 0 -1.0000001192092896 -1.0000001192092896 -1.4788762200623751E-005 0 15100.dat 1 0 -159.99813842773437 -224.41864013671875 530.0440673828125 -1 0 0 0 1 0 0 0 -1 6536.dat 1 72 -140.00546264648437 -224.33157348632812 530.023681640625 -1 0 0 0 1 0 0 0 -1 11214.dat 1 0 179.99436950683594 -224.32656860351562 550.0487060546875 0 0 -1 1 0 0 0 -1 0 42003.dat 1 72 179.99436950683594 -204.32658386230469 570.0487060546875 1 0 0 0 1 0 0 0 1 10197.dat 1 0 139.99455261230469 -204.32670593261719 555.04888916015625 0 -1.449746559956111E-005 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 1.4587863006454427E-005 11478.dat 1 0 139.99468994140625 -204.32670593261719 545.04888916015625 0 -1.449746559956111E-005 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 1.4587863006454427E-005 11478.dat 1 72 100.00107574462891 -204.41355895996094 520.07086181640625 0 0 1 0 0.99999994039535522 0 -1 0 0 87083.dat 1 0 140.00105285644531 -204.41365051269531 505.07101440429688 0.99999994039535522 0 0 0 0 1 0 -1 0 2905.dat 1 4 180.00103759765625 -204.41372680664062 500.07095336914062 0 0 1 0 1 0 -1 0 0 32062.dat 1 4 180.00103759765625 -204.41372680664062 490.07095336914062 0 0 1 -1 0 0 0 -1 0 32140.dat 1 0 100.00107574462891 -204.41729736328125 530.07318115234375 0 -0.00017514567298348993 1 -0.00017502203991170973 -0.99999994039535522 -0.00017514574574306607 1 -0.00017502211267128587 0 63869.dat 1 0 140.00105285644531 -204.41365051269531 515.07098388671875 0.99999994039535522 0 0 0 0 1 0 -1 0 2905.dat 1 4 220.09083557128906 -224.31788635253906 550.0419921875 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 6629.dat 1 1 230.09080505371094 -176.31794738769531 414.04205322265625 -1 0 0 0 0.7999994158744812 -0.60000103712081909 0 -0.60000103712081909 -0.79999923706054688 43093.dat 1 28 180.00082397460937 -224.41375732421875 550.070068359375 -1 0 0 0 1 0 0 0 -1 15462.dat 1 72 200.00100708007812 -204.41355895996094 510.07095336914062 0 1 0 0 0 1 1 0 0 11214.dat 1 0 199.9998779296875 -204.41355895996094 530.071044921875 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 6536.dat 1 70 120.00104522705078 -224.41377258300781 490.06991577148437 0.99999994039535522 0 0 0 0 1 0 -1 0 24316.dat 1 0 120.00112915039062 -224.41354370117187 470.06988525390625 -1 0 0 0 0 -1 0 -1 0 42003.dat 1 0 100.00110626220703 -224.41346740722656 490.06985473632812 -1 0 0 0 1 0 0 0 -1 6536.dat 1 0 140.00103759765625 -224.413818359375 630.0697021484375 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 32278.dat 1 0 120.00113677978516 -224.41387939453125 510.0697021484375 0 -1 0 1 0 0 0 0 0.99999994039535522 32140.dat 1 1 110.00114440917969 -224.41387939453125 510.06976318359375 0.99999994039535522 0 0 0 0 -1 0 1 0 43093.dat 1 0 139.99435424804687 -204.32646179199219 570.04888916015625 1.4613766325055622E-005 -1 0 0 0 1 -1 -1.4594143976864871E-005 0 15100.dat 1 0 160.00106811523437 -224.41371154785156 530.070068359375 -1 0 0 0 1 0 0 0 -1 6536.dat 1 72 140.00105285644531 -224.41371154785156 530.070068359375 1 0 0 0 1 0 0 0 1 11214.dat 1 0 60.000724792480469 -176.41336059570312 846.06951904296875 0 -1.0000001192092896 0 -0.79999929666519165 0 0.60000109672546387 -0.60000109672546387 0 -0.79999923706054688 60483.dat 1 71 100.00093078613281 -176.41351318359375 846.06951904296875 1 0 0 0 0.79999935626983643 -0.60000085830688477 0 0.60000085830688477 0.79999935626983643 32073.dat 1 4 100.00071716308594 -224.41371154785156 710.06951904296875 0 -1 0 1 0 0 0 0 0.99999994039535522 6629.dat 1 0 140.00094604492187 -176.41354370117187 846.0697021484375 0 0 1 -0.60000061988830566 -0.79999953508377075 0 0.79999953508377075 -0.60000061988830566 0 11947.dat 1 72 120.00069427490234 -224.41397094726562 710.06964111328125 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 11214.dat 1 0 120.00094604492187 -176.41357421875 846.06951904296875 0 -1 0 0.60000097751617432 0 0.79999929666519165 -0.79999929666519165 0 0.60000097751617432 60483.dat 1 0 150.00106811523437 -192.25456237792969 834.189697265625 0 0 1.0000001192092896 -0.80000013113021851 0.60000014305114746 0 -0.60000002384185791 -0.80000013113021851 0 59443.dat 1 4 170.00106811523437 -192.2545166015625 834.189697265625 -1 0 0 0 0.80000007152557373 0.59999972581863403 0 0.59999972581863403 -0.80000019073486328 32062.dat 1 0 200.00105285644531 -192.25477600097656 834.189697265625 0 0 1.0000001192092896 -0.80000030994415283 0.59999972581863403 0 -0.59999972581863403 -0.80000030994415283 0 32013.dat 1 72 120.00107574462891 -192.25448608398437 834.189697265625 1 0 0 0 -0.59999990463256836 -0.80000007152557373 0 0.80000007152557373 -0.59999990463256836 11214.dat 1 0 -60.005420684814453 -176.33177185058594 846.0240478515625 0 -1 0 -0.79999876022338867 0 0.6000017523765564 -0.6000017523765564 0 -0.7999987006187439 60483.dat 1 71 -100.00542449951172 -176.33192443847656 846.02386474609375 1 0 0 0 0.79999876022338867 -0.60000169277191162 0 0.60000169277191162 0.79999876022338867 32073.dat 1 0 -140.23042297363281 -176.3319091796875 846.023681640625 0 0 -1 0.60000157356262207 -0.79999887943267822 0 -0.79999887943267822 -0.60000157356262207 0 11946.dat 1 0 -120.00543212890625 -176.33183288574219 846.02386474609375 0 -1 0 0.60000133514404297 0 0.79999899864196777 -0.79999899864196777 0 0.60000127553939819 60483.dat 1 4 -100.00540924072266 -224.33180236816406 710.02423095703125 0 -1 0 1 0 0 0 0 0.99999994039535522 6629.dat 1 72 -120.00543975830078 -224.33197021484375 710.02374267578125 0.99999994039535522 0 0 0 0 1 0 -1 0 11214.dat 1 72 -120.00550079345703 -192.33158874511719 834.024169921875 -1 0 0 0 -0.59999990463256836 0.80000013113021851 0 0.80000013113021851 0.60000020265579224 11214.dat 1 0 -150.00579833984375 -192.17144775390625 834.1434326171875 0 0 1.0000001192092896 -0.80000030994415283 0.59999972581863403 0 -0.59999972581863403 -0.80000030994415283 0 59443.dat 1 4 -170.00581359863281 -192.17182922363281 834.1434326171875 -1 0 0 0 0.79999983310699463 0.60000002384185791 0 0.60000002384185791 -0.79999995231628418 32062.dat 1 0 -200.00547790527344 -192.17146301269531 834.1434326171875 0 0 -1.0000001192092896 0.79999834299087524 0.60000234842300415 0 0.60000228881835938 -0.79999834299087524 0 32013.dat 1 1 -200.0052490234375 -224.33197021484375 530.024658203125 -1 0 0 0 -1 0 0 0 1 6558.dat 1 1 -160.00541687011719 -204.33134460449219 530.0225830078125 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 0 210.00144958496094 -116.41211700439453 106.07386779785156 -1 0.00012499494187068194 0 0.00012499446165747941 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 0 -200.00529479980469 -184.17120361328125 840.1435546875 0 1.0000001192092896 0 0.79999929666519165 0 0.60000109672546387 0.60000109672546387 0 -0.7999991774559021 2780.dat 1 0 110.0009765625 -224.41372680664062 550.06964111328125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 140.00099182128906 -204.4130859375 450.06875610351562 -1 0 0 0 0 1 0 1 0 44809.dat 1 1 120.00098419189453 -224.41337585449219 450.06982421875 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 80.001365661621094 -244.41340637207031 470.06982421875 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 60484.dat 1 0 80.0009765625 -234.41339111328125 470.06988525390625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 160.00099182128906 -224.412841796875 450.06875610351562 -1 -1.513273218733957E-005 0 -1.5054537470859941E-005 0.59998291730880737 0.80001312494277954 0 0.80001312494277954 -0.59998255968093872 32054.dat 1 0 210.00099182128906 -224.41250610351562 450.0687255859375 -1 0 0 0 0.80001300573348999 -0.59998267889022827 0 -0.59998267889022827 -0.80001300573348999 3705.dat 1 4 240.00137329101562 -208.41615295410156 438.06710815429687 1 2.7181360565009527E-005 0 -2.1740821466664784E-005 0.80001312494277954 0.59998250007629395 1.6314505046466365E-005 -0.59998250007629395 0.80001312494277954 42003.dat 1 1 240.0015869140625 -192.41616821289062 426.06741333007812 0 0 1.0000001192092896 -0.5999826192855835 0.80001318454742432 0 -0.80001312494277954 -0.5999826192855835 0 6558.dat 1 1 160.00212097167969 -234.4129638671875 470.0689697265625 0 -0.8000025749206543 0.59999662637710571 0.60000163316726685 -0.47999802231788635 -0.63999998569488525 0.79999881982803345 0.35999703407287598 0.48000425100326538 43093.dat 1 4 160.00074768066406 -228.41276550292969 478.06890869140625 -0.59999972581863403 0 0.80000025033950806 0.64000111818313599 0.59999978542327881 0.47999906539916992 -0.4799988865852356 0.80000030994415283 -0.3600008487701416 6629.dat 1 72 240.0013427734375 -144.4127197265625 390.06948852539062 0 1.0000001192092896 0 0.5999983549118042 0 0.80000132322311401 0.80000132322311401 0 -0.59999829530715942 11214.dat 1 4 240.0015869140625 -172.4151611328125 386.06784057617187 -1 0 0 0 0.59998267889022827 0.80001330375671387 0 0.80001330375671387 -0.59998238086700439 32524.dat 1 4 240.00167846679687 -128.41474914550781 378.06671142578125 1 2.7075755497207865E-005 0 2.0948908058926463E-005 -0.80001640319824219 -0.59997814893722534 -1.7194433894474059E-005 0.59997814893722534 -0.80001640319824219 42003.dat 1 1 230.00115966796875 -112.41355133056641 366.06671142578125 0.99999994039535522 0 0 0 -0.59999853372573853 0.80000108480453491 0 -0.80000108480453491 -0.59999853372573853 43093.dat 1 0 240.0015869140625 -134.41461181640625 370.06842041015625 0 -3.2517229556106031E-005 1.0000001192092896 -0.59999799728393555 0.80000180006027222 2.6136542146559805E-005 -0.80000168085098267 -0.59999799728393555 -1.922583942359779E-005 2780.dat 1 0 240.00096130371094 -176.41282653808594 414.06927490234375 0 -1.0000001192092896 0 -0.59999847412109375 0 0.80000126361846924 -0.80000126361846924 0 -0.5999983549118042 87082.dat 1 0 160.00096130371094 -224.41311645507812 450.06875610351562 0 -1.0000001192092896 0 -0.60000157356262207 0 0.79999887943267822 -0.79999887943267822 0 -0.60000151395797729 44809.dat 1 1 240.00091552734375 -160.41275024414062 402.06927490234375 0 0 1.0000001192092896 -0.59999948740005493 0.80000066757202148 0 -0.80000054836273193 -0.59999948740005493 0 6558.dat 1 4 220.00096130371094 -160.41273498535156 402.0693359375 0 1 0 -0.80000066757202148 0 0.59999912977218628 0.59999912977218628 0 0.80000072717666626 42003.dat 1 72 200.00093078613281 -144.41262817382812 390.06878662109375 -1 0 0 0 0.80000078678131104 -0.5999988317489624 0 -0.5999988317489624 -0.80000084638595581 10197.dat 1 0 240.00103759765625 -214.41658020019531 430.06719970703125 0 -3.2497460779268295E-005 1.0000001192092896 -0.59999799728393555 0.80000168085098267 2.6156309104408138E-005 -0.80000162124633789 -0.59999799728393555 -1.9206070646760054E-005 2780.dat 1 0 200.09091186523437 -224.31912231445312 450.04147338867188 0 -1 0 0 0 1 -1 0 0 15100.dat 1 0 199.98419189453125 -204.31878662109375 430.04135131835937 0.99999994039535522 0 0 0 0 -1 0 1 0 32316.dat 1 1 180.00018310546875 -134.41419982910156 450.06900024414062 0 0 1 1 0 0 0 1 0 43093.dat 1 4 180.00016784667969 -124.41416931152344 450.06900024414062 0 0 1 0 0.99999994039535522 0 -1 0 0 32140.dat 1 0 0.00094143551541492343 -214.41337585449219 470.06988525390625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 0.0019625413697212934 -204.413818359375 470.06988525390625 0 1.4604163879994303E-005 -1 1.4727798770763911E-005 -1 -1.4604165698983707E-005 -1 -1.4727799680258613E-005 0 15100.dat 1 0 0.0019620177336037159 -264.41336059570312 450.06985473632812 -1 0 0 0 0 1 0 1 0 32524.dat 1 0 -59.999031066894531 -214.41340637207031 470.06988525390625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 60.000961303710938 -214.41340637207031 470.06988525390625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 30.014873504638672 -244.6240234375 430.00088500976563 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -110.00531005859375 -224.32421875 550.023681640625 1 0 0 0 -1 0 0 0 -1 2780.dat 1 0 -160.0145263671875 -204.24058532714844 570.0029296875 0 -1 0 0.60000014305114746 0 -0.7999998927116394 0.7999998927116394 0 0.60000002384185791 15100.dat 1 0 -209.99250793457031 -64.328857421875 210.02488708496094 1 0 0 0 1 0 0 0 1 2780.dat 1 0 -209.99250793457031 -64.328857421875 290.02493286132812 1 0 0 0 1 0 0 0 1 2780.dat 1 0 -199.98674011230469 -84.627494812011719 529.99932861328125 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 0 199.98945617675781 -84.327217102050781 530.04010009765625 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 0 200.00090026855469 -164.41326904296875 510.07113647460937 -1 0 0 0 0 1 0 1 0 40490.dat 1 0 200.0008544921875 -164.41259765625 510.0711669921875 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 0 120.00090026855469 -164.41328430175781 490.07110595703125 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32526.dat 1 0 200.0008544921875 -124.41258239746094 510.0711669921875 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 1 140.00099182128906 -164.41331481933594 490.07110595703125 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 0 180.00091552734375 -164.41328430175781 480.07110595703125 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 1 200.00094604492187 -244.41328430175781 490.07110595703125 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 0 199.98670959472656 -224.32064819335937 490.04049682617187 1 0 0 0 -1 0 0 0 -1 6536.dat 1 1 209.9866943359375 -224.32064819335937 490.04049682617187 -1 0 0 0 0 1 0 1 0 43093.dat 1 0 175.98167419433594 -276.31689453125 470.04150390625 0.79990541934967041 0 -0.60012632608413696 -0.60012632608413696 0 -0.79990530014038086 0 1.0000001192092896 0 32316.dat 1 0 151.97663879394531 -308.31307983398437 460.04153442382812 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 187.984375 -260.31875610351562 460.04147338867187 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 160.00148010253906 -132.41459655761719 94.073806762695313 0 0 -1 -0.80001336336135864 -0.59998214244842529 0 -0.59998220205307007 0.80001336336135864 0 32316.dat 1 4 180.00148010253906 -144.41453552246094 110.07402801513672 0 0 1 -0.80001324415206909 0.59998255968093872 0 -0.59998244047164917 -0.80001324415206909 0 32140.dat 1 1 180.00149536132812 -138.41441345214844 102.07394409179687 0 1.0000001192092896 0 -0.59998196363449097 0 0.80001360177993774 0.80001360177993774 0 0.59998208284378052 43093.dat 1 0 200.00148010253906 -138.41468811035156 102.07389831542969 0 3.5555367503548041E-005 -1 -0.59998202323913574 0.80001348257064819 2.8613327231141739E-005 0.80001348257064819 0.59998202323913574 2.1138395823072642E-005 2780.dat 1 0 240.00149536132812 -166.41461181640625 106.07450866699219 0 0.00093165086582303047 -0.99999964237213135 -0.59998464584350586 0.80001121759414673 0.00074554455932229757 0.80001157522201538 0.59998440742492676 0.0005587079213000834 2780.dat 1 4 208.0015869140625 -179.60365295410156 83.670379638671875 0.59999817609786987 0 -0.80000144243240356 -0.64000248908996582 -0.59999775886535645 -0.47999951243400574 -0.4799991250038147 0.80000168085098267 -0.35999748110771179 32140.dat 1 72 208.00149536132812 -191.61468505859375 99.675102233886719 0 -0.79999995231628418 -0.60000008344650269 0.59998482465744019 -0.48000374436378479 0.6400114893913269 -0.80001139640808105 -0.35999521613121033 0.47998461127281189 11214.dat 1 4 240.00154113769531 -124.41377258300781 150.07357788085937 -1 0 0 0 0.5999830961227417 -0.80001282691955566 0 -0.80001282691955566 -0.59998297691345215 32348.dat 1 0 192.00042724609375 -201.22633361816406 92.480125427246094 0 -0.79999613761901855 0.60000544786453247 -0.59995687007904053 -0.48002433776855469 -0.64002233743667603 0.80003255605697632 -0.35997641086578369 -0.47996363043785095 18651.dat 1 0 192.00033569335937 -213.22581481933594 108.48049926757813 0.60000157356262207 0 0.79999887943267822 -0.64000910520553589 0.59998321533203125 0.48000901937484741 -0.4799860417842865 -0.80001264810562134 0.35999059677124023 60483.dat 1 0 240.00151062011719 -168.41372680664062 142.07470703125 0 -1.0000001192092896 0 -0.59997987747192383 0 -0.80001527070999146 0.80001527070999146 0 -0.59997975826263428 32013.dat 1 0 240.00155639648437 -136.41311645507812 166.0738525390625 1 0 0 0 0.80001366138458252 -0.59998178482055664 0 0.59998178482055664 0.80001366138458252 10197.dat 1 1 240.00215148925781 -144.4114990234375 110.06929016113281 0 0 -1 -0.59998255968093872 0.80001318454742432 0 0.80001312494277954 0.59998255968093872 0 6558.dat 1 1 240.00215148925781 -76.530921936035156 136.227783203125 0 0 1 -0.80001318454742432 0.59998244047164917 0 -0.59998238086700439 -0.80001318454742432 0 43093.dat 1 0 240.00215148925781 -84.53106689453125 130.22798156738281 0.99999994039535522 0 0 0 -0.59998232126235962 -0.80001324415206909 0 0.80001324415206909 -0.59998232126235962 11947.dat 1 1 240.0015869140625 -128.41445922851562 122.07366180419922 0 0 -1 -0.59998255968093872 0.80001318454742432 0 0.80001312494277954 0.59998255968093872 0 6558.dat 1 0 240.00215148925781 -68.530799865722656 142.22763061523438 0.99996042251586914 0 0.0089037464931607246 0.005342080257833004 0.80001318454742432 -0.59995877742767334 -0.0071231224574148655 0.59998255968093872 0.79998141527175903 18654.dat 1 0 224.00216674804687 -176.01397705078125 98.869743347167969 0 0.00093165086582303047 -0.99999964237213135 -0.59998464584350586 0.80001121759414673 0.00074554455932229757 0.80001157522201538 0.59998440742492676 0.0005587079213000834 2780.dat 1 1 188.00228881835937 -217.6146240234375 67.670578002929688 0 -0.79999947547912598 -0.60000073909759521 0.59998255968093872 -0.48000845313072205 0.64000999927520752 -0.80001312494277954 -0.35998991131782532 0.4799858033657074 43093.dat 1 4 188.00213623046875 -211.61477661132812 59.670429229736328 -0.60000449419021606 0 0.79999667406082153 0.64000731706619263 -0.59998351335525513 0.48001086711883545 0.47998464107513428 0.80001240968704224 0.35999327898025513 32140.dat 1 4 204.00279235839844 -214.0150146484375 82.870185852050781 0.59997224807739258 0 -0.80002117156982422 -0.64002746343612671 -0.59998273849487305 -0.47998511791229248 -0.47999867796897888 0.80001306533813477 -0.35997307300567627 32316.dat 1 0 236.00369262695312 -188.81570434570312 89.26885986328125 0 3.5514782211976126E-005 -1 -0.59998577833175659 0.80001074075698853 2.859459891624283E-005 0.80001068115234375 0.59998577833175659 2.1110601664986461E-005 2780.dat 1 0 172.00155639648437 -227.20341491699219 60.470569610595703 0 3.5514782211976126E-005 -1 -0.59998577833175659 0.80001074075698853 2.859459891624283E-005 0.80001068115234375 0.59998577833175659 2.1110601664986461E-005 2780.dat 1 0 204.00225830078125 -208.01451110839844 74.870338439941406 0 3.5514782211976126E-005 -1 -0.59998577833175659 0.80001074075698853 2.859459891624283E-005 0.80001068115234375 0.59998577833175659 2.1110601664986461E-005 2780.dat 1 1 160.00157165527344 -220.40325927734375 78.070648193359375 0 0 1.0000001192092896 -0.59998703002929688 -0.80000972747802734 0 0.80000984668731689 -0.59998703002929688 0 6558.dat 1 0 100.00157165527344 -220.40325927734375 78.070724487304688 0 0 -1 -0.80000972747802734 -0.59998708963394165 0 -0.59998703002929688 0.80000972747802734 0 32524.dat 1 0 140.00160217285156 -214.40341186523437 70.070701599121094 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 40.001583099365234 -214.40348815917969 70.070610046386719 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 0.0015318393707275391 -208.40359497070312 62.070549011230469 0 0 -1.0000001192092896 -0.80000990629196167 -0.59998691082000732 0 -0.59998703002929688 0.80000990629196167 0 40490.dat 1 0 -79.998451232910156 -214.40348815917969 70.070610046386719 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 -99.998435974121094 -220.40336608886719 78.070724487304688 0 0 -1 -0.80000972747802734 -0.59998708963394165 0 -0.59998703002929688 0.80000972747802734 0 32524.dat 1 1 -159.99845886230469 -220.40333557128906 78.070648193359375 0 0 1.0000001192092896 -0.59998703002929688 -0.80000972747802734 0 0.80000984668731689 -0.59998703002929688 0 6558.dat 1 1 -189.99844360351562 -232.40365600585938 94.071197509765625 1 0 0 0 0.59998548030853271 0.80001091957092285 0 -0.80001091957092285 0.59998548030853271 43093.dat 1 0 -159.99845886230469 -232.40365600585938 94.071922302246094 0 0 1 0.59998208284378052 0.80001348257064819 0 -0.80001348257064819 0.59998208284378052 0 32034.dat 1 1 -129.99842834472656 -232.40313720703125 94.071212768554687 -1 0 0 0 -0.59999579191207886 0.80000323057174683 0 0.80000323057174683 0.59999614953994751 43093.dat 1 0 -119.99842071533203 -232.40310668945312 94.070907592773438 0 1.0000001192092896 0 0.59998732805252075 0 -0.80000966787338257 -0.80000966787338257 0 -0.5999872088432312 15100.dat 1 0 -39.998447418212891 -214.4034423828125 70.070610046386719 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 -99.998420715332031 -214.40345764160156 70.070610046386719 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 -140.00688171386719 -214.31887817382812 70.043716430664063 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 80.001594543457031 -214.40336608886719 70.070610046386719 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 100.0015869140625 -214.40336608886719 70.070610046386719 0 0.00093169114552438259 -0.99999964237213135 -0.59998726844787598 0.80000942945480347 0.00074562267400324345 0.80000966787338257 0.59998703002929688 0.00055875914404168725 2780.dat 1 0 120.0015869140625 -232.40301513671875 94.070907592773438 0 1.0000001192092896 0 0.59998732805252075 0 -0.80000966787338257 -0.80000966787338257 0 -0.5999872088432312 15100.dat 1 0 160.0015869140625 -232.40382385253906 94.070167541503906 0 0 1.0000001192092896 0.59999781847000122 0.80000174045562744 0 -0.80000168085098267 0.59999781847000122 0 32034.dat 1 1 190.00160217285156 -232.40385437011719 94.070571899414063 -1 0 0 0 -0.59999793767929077 0.80000150203704834 0 0.80000150203704834 0.59999781847000122 43093.dat 1 1 130.00160217285156 -232.40296936035156 94.070884704589844 1 0 0 0 0.59998559951782227 0.8000108003616333 0 -0.8000108003616333 0.59998559951782227 43093.dat 1 0 -0.0083324117586016655 -324.32431030273437 460.0416259765625 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 1 -120.00539398193359 -224.33123779296875 450.0235595703125 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 6558.dat 1 0 -120.00537109375 -204.33125305175781 470.02349853515625 0 0 -0.99999994039535522 -0.99999994039535522 0 0 0 0.99999994039535522 0 32054.dat 1 1 -119.98600769042969 -174.24424743652344 469.97763061523437 0 0 -0.99999994039535522 -0.99999994039535522 0 0 0 0.99999994039535522 0 43093.dat 1 0 -160.00537109375 -224.33108520507812 450.0235595703125 0 -1.0000001192092896 1.7797950931708328E-005 -0.59999805688858032 1.8433742297929712E-005 0.80000156164169312 -0.80000156164169312 0 -0.59999793767929077 44809.dat 1 4 -240.00477600097656 -172.33357238769531 386.02392578125 -1 0 0 0 0.59998267889022827 0.80001288652420044 0 0.80001288652420044 -0.59998279809951782 32524.dat 1 72 -240.00546264648437 -144.33116149902344 390.0252685546875 0 1.0000001192092896 0 0.59999924898147583 0 0.80000072717666626 0.80000072717666626 0 -0.59999912977218628 11214.dat 1 4 -160.00619506835937 -228.33132934570312 478.02529907226563 0.59999978542327881 0 -0.80000060796737671 0.63999736309051514 -0.60000342130661011 0.47999945282936096 -0.48000454902648926 -0.79999756813049316 -0.35999977588653564 6629.dat 1 1 -160.00543212890625 -234.33116149902344 470.02529907226562 0 -0.60000234842300415 0.79999840259552002 0.60000032186508179 -0.63999706506729126 -0.48000362515449524 0.7999998927116394 0.48000112175941467 0.35999917984008789 43093.dat 1 1 -230.005859375 -112.32904052734375 366.02581787109375 -1 0 1.935250656970311E-005 0 -0.80001288652420044 0.59998291730880737 1.929721656779293E-005 0.59998291730880737 0.80001318454742432 43093.dat 1 4 -240.00511169433594 -128.32943725585937 378.02536010742187 1 2.7279740606900305E-005 0 2.1886407921556383E-005 -0.80001252889633179 -0.59998327493667603 -1.6284355297102593E-005 0.59998327493667603 -0.80001252889633179 42003.dat 1 1 -240.00473022460937 -192.33441162109375 426.02334594726562 0 0 1.0000001192092896 -0.59998267889022827 0.80001318454742432 0 -0.80001306533813477 -0.59998267889022827 0 6558.dat 1 0 -240.00469970703125 -134.33317565917969 370.02459716796875 0 -3.2574040233157575E-005 1 -0.5999826192855835 0.80001312494277954 2.6198375053354539E-005 -0.80001306533813477 -0.5999826192855835 -1.929205609485507E-005 2780.dat 1 1 -240.00599670410156 -160.33033752441406 402.02493286132812 0 0 1.0000001192092896 -0.59998279809951782 0.80001306533813477 0 -0.80001300573348999 -0.59998279809951782 0 6558.dat 1 4 -220.0059814453125 -160.32896423339844 402.02493286132812 0 -1.0000001192092896 0 -0.80001312494277954 0 -0.59998273849487305 0.59998273849487305 0 -0.80001300573348999 42003.dat 1 72 -200.0059814453125 -144.33029174804687 390.02566528320312 -1 0 0 0 0.80001318454742432 -0.59998238086700439 0 -0.59998238086700439 -0.80001318454742432 10197.dat 1 0 -240.0052490234375 -214.33479309082031 430.023193359375 0 -3.2517229556106031E-005 1.0000001192092896 -0.59999799728393555 0.80000180006027222 2.6136542146559805E-005 -0.80000168085098267 -0.59999799728393555 -1.922583942359779E-005 2780.dat 1 0 -240.00469970703125 -176.33407592773437 414.02374267578125 0 -1.0000001192092896 0 -0.59998297691345215 0 0.80001288652420044 -0.80001288652420044 0 -0.59998291730880737 87082.dat 1 0 -240.00668334960937 -94.329124450683594 390.02560424804687 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 -260.00588989257812 -64.330368041992188 130.02584838867187 0.0089036561548709869 0 -0.99996042251586914 0.99996042251586914 0 0.0089035863056778908 0 -1 0 18654.dat 1 0 -260.01455688476562 -64.240974426269531 530.00189208984375 -0.0089036673307418823 0 0.99996036291122437 0.99996036291122437 0 0.0089037111029028893 0 1 0 18654.dat 1 0 -260.00567626953125 -64.329154968261719 250.0255126953125 -0.0089036673307418823 0 0.99996036291122437 0.99996036291122437 0 0.0089037111029028893 0 1 0 18654.dat 1 4 -240.02008056640625 -84.327987670898437 480.025146484375 1 0 0 0 -1 0 0 0 -1 43857.dat 1 0 -240.02008056640625 -94.327980041503906 470.025146484375 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 1 -139.98600769042969 -164.24423217773437 489.97760009765625 0 0 1 0 0.99999994039535522 0 -1 0 0 6558.dat 1 0 -119.98602294921875 -164.24423217773437 489.97760009765625 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 32526.dat 1 0 -199.97549438476562 -164.71286010742187 510.03036499023437 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 0 -199.97549438476562 -124.71284484863281 510.03036499023437 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 32054.dat 1 0 -179.98600769042969 -164.24423217773437 479.97760009765625 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 240.00105285644531 -64.414169311523438 330.06878662109375 1 0 0 0 -1 0 0 0 -1 87082.dat 1 71 260.0010986328125 -64.414169311523438 410.06884765625 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 260.0010986328125 -64.414169311523438 380.06881713867187 1 0 0 0 1 0 0 0 1 59443.dat 1 4 260.0010986328125 -64.414169311523438 360.06881713867187 0 0 1 0 1 0 -1 0 0 32062.dat 1 0 260.0010986328125 -64.414169311523438 330.06878662109375 1 0 0 0 1 0 0 0 1 32034.dat 1 4 260.0010986328125 -64.414169311523438 300.06878662109375 0 0 1 0 1 0 -1 0 0 32062.dat 1 71 260.0010986328125 -64.414169311523438 250.06883239746094 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 260.0010986328125 -64.414169311523438 280.06881713867187 1 0 0 0 1 0 0 0 1 59443.dat 1 0 260.0010986328125 -64.414169311523438 440.06881713867187 1 0 0 0 1 0 0 0 1 59443.dat 1 0 260.00106811523438 -64.414169311523438 220.06895446777344 1 0 0 0 1 0 0 0 1 59443.dat 1 4 260.00094604492188 -64.415374755859375 200.06916809082031 0 0 1 0 1 0 -1 0 0 32062.dat 1 0 260.0009765625 -64.415374755859375 170.06919860839844 -1 0 0 0 1 0 0 0 -1 32034.dat 1 1 260.0009765625 -64.415374755859375 140.0692138671875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 260.0010986328125 -84.414169311523438 405.06887817382812 -1 0 0 0 0 1 0 1 0 41677.dat 1 71 260.0010986328125 -84.414169311523438 410.06884765625 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 260.0010986328125 -84.414169311523438 415.06881713867187 -1 0 0 0 0 1 0 1 0 41677.dat 1 4 259.99221801757812 -64.325981140136719 460.04513549804687 0 0 1 0 1 0 -1 0 0 32062.dat 1 0 259.99221801757812 -64.32598876953125 490.045166015625 1 0 0 0 1 0 0 0 1 32034.dat 1 1 259.99221801757812 -64.32598876953125 520.045166015625 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 0 260.0010986328125 -84.414169311523438 389.84378051757812 -1 0 0 0 1 0 0 0 -1 11946.dat 1 0 260.0010986328125 -84.4141845703125 430.06878662109375 1 0 0 0 1 0 0 0 1 11947.dat 1 0 259.99224853515625 -64.325981140136719 530.045166015625 -0.0089036673307418823 0 0.99996036291122437 0.99996036291122437 0 0.0089037111029028893 0 1 0 18654.dat 1 0 260.0009765625 -64.415367126464844 130.06919860839844 0.0089036561548709869 0 -0.99996042251586914 0.99996042251586914 0 0.0089035863056778908 0 -1 0 18654.dat 1 0 240.00094604492187 -64.415374755859375 170.06916809082031 1 0 0 0 -1 0 0 0 -1 87082.dat 1 1 239.9864501953125 -84.415367126464844 170.06916809082031 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 0 239.99217224121094 -64.32598876953125 490.045166015625 1 0 0 0 -1 0 0 0 -1 87082.dat 1 1 239.97767639160156 -84.32598876953125 490.045166015625 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 4 240.00015258789062 -84.414146423339844 480.06903076171875 1 0 0 0 -1 0 0 0 -1 43857.dat 1 0 240.00015258789062 -94.414154052734375 470.06903076171875 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 260.0010986328125 -64.41412353515625 250.06884765625 -0.99996036291122437 1.6763055100454949E-005 -0.0089066792279481888 -0.0089066792279481888 0 0.99996042251586914 1.676155261520762E-005 1.0000001192092896 0 18654.dat 1 1 239.99235534667969 -128.32591247558594 538.043701171875 0 0 1 -0.60000133514404297 0.79999911785125732 0 -0.79999905824661255 -0.60000133514404297 0 6558.dat 1 0 239.99418640136719 -84.628105163574219 530.02386474609375 -1 0 0 0 -0.60000115633010864 -0.79999905824661255 0 -0.79999905824661255 0.60000103712081909 11946.dat 1 1 239.99418640136719 -76.447647094726563 523.88885498046875 0 0 1.0000001192092896 -0.79999929666519165 -0.60000103712081909 0 0.60000109672546387 -0.79999929666519165 0 43093.dat 1 0 239.99421691894531 -68.447769165039063 517.88885498046875 0.99996042251586914 0 0.0089036086574196815 -0.0053421654738485813 0.79999905824661255 0.59997761249542236 -0.0071228863671422005 -0.60000139474868774 0.79996734857559204 18654.dat 1 1 159.99436950683594 -246.32707214355469 614.04925537109375 0 0.60000002384185791 0.80000007152557373 0.59999990463256836 -0.6400001049041748 0.48000001907348633 0.80000013113021851 0.47999989986419678 -0.35999995470046997 43093.dat 1 4 159.99545288085937 -240.32673645019531 622.04901123046875 -0.60000032186508179 0 0.79999983310699463 0.63999897241592407 0.60000133514404297 0.4800000786781311 -0.48000109195709229 0.79999923706054688 -0.36000046133995056 6629.dat 1 1 239.99423217773437 -138.32687377929687 558.04888916015625 0 1.0000001192092896 0 -0.59999972581863403 0 -0.80000030994415283 -0.80000030994415283 0 0.59999972581863403 43093.dat 1 0 207.9964599609375 -217.52861022949219 592.44744873046875 0 0 -1 0.60000061988830566 0.79999959468841553 0 0.79999953508377075 -0.60000061988830566 0 2780.dat 1 4 223.99533081054687 -213.92742919921875 577.24658203125 -0.60007524490356445 0 0.79994356632232666 0.63995450735092163 0.60000079870223999 0.48006001114845276 -0.4799666702747345 0.79999959468841553 -0.36004552245140076 32523.dat 1 0 223.9942626953125 -207.92626953125 585.24560546875 0 0 -1.0000001192092896 0.60000044107437134 0.79999983310699463 0 0.79999977350234985 -0.60000044107437134 0 2780.dat 1 0 239.99423217773437 -216.32626342773437 554.045654296875 0 0 1.0000001192092896 0.59999918937683105 -0.80000066757202148 0 0.80000072717666626 0.59999918937683105 0 15100.dat 1 4 239.99235534667969 -184.02561950683594 530.07110595703125 -1 0 0 0 0.59999954700469971 0.80000066757202148 0 0.80000066757202148 -0.59999918937683105 11946.dat 1 72 239.99423217773437 -200.32551574707031 542.04595947265625 0 1 0 0.80000078678131104 0 -0.59999889135360718 -0.59999889135360718 0 -0.80000078678131104 11214.dat 1 4 239.99423217773437 -212.33003234863281 526.0458984375 -1 0 0 0 0.59999889135360718 0.80000078678131104 0 0.80000078678131104 -0.59999895095825195 42003.dat 1 1 229.99424743652344 -224.32618713378906 510.0458984375 1 0 0 0 0.59999871253967285 -0.80000096559524536 0 0.80000096559524536 0.59999871253967285 43093.dat 1 0 239.99235534667969 -130.32559204101562 502.04611206054687 0 0 -1 0.59999918937683105 0.80000060796737671 0 0.80000060796737671 -0.59999918937683105 0 2780.dat 1 4 239.99423217773437 -124.32649230957031 510.04891967773437 -1 0 0 0 -0.59999912977218628 -0.80000066757202148 0 -0.80000066757202148 0.59999930858612061 32526.dat 1 0 219.99427795410156 -176.32901000976562 574.04888916015625 0 0 -1.0000001192092896 -0.80000001192092896 0.60000026226043701 0 0.60000020265579224 0.80000001192092896 0 32140.dat 1 1 219.9942626953125 -182.32925415039062 566.04888916015625 0 -1.0000001192092896 0 0.59999871253967285 0 -0.80000102519989014 0.80000102519989014 0 0.59999877214431763 43093.dat 1 0 199.9942626953125 -182.32661437988281 566.04888916015625 0 0 -1.0000001192092896 0.60000044107437134 0.79999983310699463 0 0.79999977350234985 -0.60000044107437134 0 2780.dat 1 0 159.99427795410156 -204.32658386230469 570.048828125 0 -1 0 0.60000008344650269 0 -0.79999995231628418 0.79999995231628418 0 0.60000002384185791 15100.dat 1 0 239.99235534667969 -182.32551574707031 566.04620361328125 0 0 -1 0.59999918937683105 0.80000060796737671 0 0.80000060796737671 -0.59999918937683105 0 2780.dat 1 0 239.99423217773437 -166.32661437988281 554.04888916015625 0 0 -1 0.59999918937683105 0.80000060796737671 0 0.80000060796737671 -0.59999918937683105 0 2780.dat 1 0 139.99430847167969 -252.33125305175781 606.049072265625 0 1 0 0.80000078678131104 0 -0.59999901056289673 -0.59999901056289673 0 -0.80000072717666626 42003.dat 1 1 119.99430847167969 -244.32745361328125 600.049072265625 0 0 1 -0.8000030517578125 -0.59999591112136841 0 0.59999597072601318 -0.8000030517578125 0 43093.dat 1 0 109.99430084228516 -224.32701110839844 610.0491943359375 1 0 0 0 0.8000028133392334 0.59999620914459229 0 -0.59999620914459229 0.8000028133392334 41678.dat 1 0 119.99430847167969 -224.32627868652344 610.04925537109375 -1 0 0 0 0.8000028133392334 -0.59999644756317139 0 -0.59999644756317139 -0.80000269412994385 18651.dat 1 0 99.994316101074219 -244.32691955566406 600.04913330078125 0 0 -1 0.80000066757202148 -0.5999990701675415 0 -0.59999912977218628 -0.80000066757202148 0 2780.dat 1 0 -0.014555454254150391 -252.24029541015625 606.00311279296875 0 0 1 -0.59999871253967285 0.80000096559524536 0 -0.80000096559524536 -0.59999871253967285 0 32525.dat 1 0 -100.01451873779297 -244.24028015136719 600.003173828125 0 0 -1 0.80000066757202148 -0.5999990701675415 0 -0.59999912977218628 -0.80000066757202148 0 2780.dat 1 0 -110.01453399658203 -224.24302673339844 610.003173828125 1 0 0 0 0.80000287294387817 0.59999620914459229 0 -0.59999620914459229 0.80000287294387817 41678.dat 1 0 -120.0145263671875 -224.24040222167969 610.00311279296875 1 0 0 0 0.59999573230743408 -0.80000323057174683 0 0.80000323057174683 0.59999573230743408 18651.dat 1 0 -140.01457214355469 -252.24089050292969 606.0030517578125 0 -1.0000001192092896 0 -0.80000054836273193 0 -0.59999948740005493 0.59999948740005493 0 -0.80000042915344238 42003.dat 1 1 -120.0145263671875 -244.24099731445312 600.00311279296875 0 0 1.0000001192092896 -0.80000013113021851 -0.59999990463256836 0 0.59999996423721313 -0.80000013113021851 0 43093.dat 1 0 209.99224853515625 -64.326042175292969 470.04510498046875 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 239.99998474121094 -94.414176940917969 270.0682373046875 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 239.99996948242187 -94.4141845703125 230.06825256347656 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 240.00015258789062 -94.414138793945313 390.06890869140625 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 -239.99838256835937 -68.526565551757812 142.22962951660156 0.99996036291122437 0 0.0089036878198385239 0.0053422050550580025 0.79999977350234985 -0.59997659921646118 -0.0071229566819965839 0.60000038146972656 0.79996806383132935 18654.dat 1 0 -223.99835205078125 -176.00335693359375 98.870552062988281 0 3.2614530937280506E-005 -1 -0.59998279809951782 0.80001294612884521 2.6275984055246226E-005 0.80001288652420044 0.59998279809951782 1.9370221707504243E-005 2780.dat 1 1 -187.99940490722656 -217.60330200195312 67.670059204101563 0 0.80000382661819458 -0.59999507665634155 0.60000514984130859 -0.47999328374862671 -0.64000028371810913 -0.79999631643295288 -0.36000058054924011 -0.48000586032867432 43093.dat 1 4 -187.99861145019531 -211.60333251953125 59.67022705078125 0.59999829530715942 0 -0.80000138282775879 0.6400025486946106 0.59999752044677734 0.47999978065490723 0.47999885678291321 -0.80000191926956177 0.35999739170074463 32140.dat 1 4 -203.99832153320312 -214.00433349609375 82.87042236328125 -0.59999978542327881 0 -0.80000030994415283 -0.64000082015991211 -0.5999988317489624 0.48000064492225647 -0.47999942302703857 0.80000102519989014 0.3599993884563446 32316.dat 1 0 -235.998291015625 -188.80307006835937 89.270713806152344 0 3.2545813155593351E-005 -1.0000001192092896 -0.59999799728393555 0.80000174045562744 2.622606189106591E-005 0.80000168085098267 0.59999799728393555 1.9327335394336842E-005 2780.dat 1 0 -203.99827575683594 -208.00309753417969 74.870857238769531 0 3.2614530937280506E-005 -1 -0.59998279809951782 0.80001294612884521 2.6275984055246226E-005 0.80001288652420044 0.59998279809951782 1.9370221707504243E-005 2780.dat 1 0 -171.99845886230469 -227.20365905761719 60.470817565917969 0 3.2614530937280506E-005 -1 -0.59998279809951782 0.80001294612884521 2.6275984055246226E-005 0.80001288652420044 0.59998279809951782 1.9370221707504243E-005 2780.dat 1 0 -0.0077806413173675537 -325.17694091796875 290.04348754882812 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 0 -40.007808685302734 -325.1773681640625 310.04351806640625 0 -1 0 -1 0 0 0 0 -1 32523.dat 1 0 -50.00860595703125 -324.96649169921875 310.04348754882812 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 0 -50.008613586425781 -324.85989379882812 330.04318237304687 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 0 49.992092132568359 -324.32431030273437 450.04110717773437 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 39.992076873779297 -324.32431030273437 450.04129028320312 -1.4466952052316628E-005 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 1.4588845260732342E-005 0 15100.dat 1 0 49.984256744384766 -324.52938842773437 390.04217529296875 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 0 39.9842529296875 -324.52935791015625 410.04217529296875 0 -1 0 -1 0 0 0 0 -1 32523.dat 1 0 49.984256744384766 -324.42276000976563 410.0419921875 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 0 99.991752624511719 -324.32437133789062 460.04153442382812 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 -100.00843811035156 -324.32431030273437 460.04180908203125 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 139.9912109375 -324.32431030273437 490.0416259765625 1.4923482012818567E-005 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 -1.485223947383929E-005 0 15100.dat 1 0 -140.0087890625 -324.32431030273437 490.04159545898437 1.4923482012818567E-005 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 -1.485223947383929E-005 0 15100.dat 1 0 -120.00831604003906 -324.32431030273437 460.0416259765625 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 -20.008790969848633 -324.32431030273437 490.0416259765625 1.4923482012818567E-005 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 -1.485223947383929E-005 0 15100.dat 1 0 79.990959167480469 -324.32431030273437 490.0416259765625 1.4923482012818567E-005 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 -1.485223947383929E-005 0 15100.dat 1 0 -50.008613586425781 -324.54006958007812 390.04238891601562 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209725931286812 0 -0.0054209725931286812 -0.99998527765274048 2780.dat 1 0 -40.00860595703125 -324.54257202148437 410.0419921875 0 -1 0 -1 0 0 0 0 -1 32523.dat 1 0 -50.008613586425781 -324.43344116210937 410.04208374023437 -1 0.00012499492731876671 0 0.00012499444710556418 0.9999852180480957 -0.0054209721274673939 0 -0.0054209721274673939 -0.99998527765274048 2780.dat 1 0 -152.00834655761719 -308.3243408203125 460.0416259765625 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 -0.008764117956161499 -324.32437133789062 490.04150390625 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 0 -169.99324035644531 -219.51992797851562 156.44505310058594 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -179.99324035644531 -229.51486206054687 156.76295471191406 0 -1 0 -0.031791709363460541 0 0.99949449300765991 -0.99949449300765991 0 -0.03179178386926651 43857.dat 1 1 -199.99322509765625 -239.50982666015625 157.08087158203125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -199.98173522949219 -240.05818176269531 156.83757019042969 0 -0.99999994039535522 0 -0.90356838703155518 0 0.42844372987747192 -0.42844372987747192 0 -0.90356844663619995 15100.dat 1 0 -219.98171997070312 -240.05918884277344 156.83743286132812 0 1 0 -0.99619424343109131 0 -0.087161198258399963 -0.087161198258399963 0 0.99619418382644653 44809.dat 1 0 -219.99858093261719 -144.62191772460937 145.27420043945312 0 -1 0 -0.99619466066360474 0 0.087156310677528381 -0.087156310677528381 0 -0.99619466066360474 41678.dat 1 0 -219.98173522949219 -166.58953857421875 143.18934631347656 0 1 0 0.99619489908218384 0 0.087153904139995575 0.087153904139995575 0 -0.99619483947753906 3705.dat 1 0 -219.98171997070312 -218.39205932617187 138.65646362304687 0 0 1 -0.99619430303573608 0.087160445749759674 0 -0.087160401046276093 -0.99619430303573608 0 32054.dat 1 71 -219.98173522949219 -144.67327880859375 145.10653686523437 0 -1.0000001192092896 0 0.087155066430568695 0 0.99619483947753906 -0.99619483947753906 0 0.087155133485794067 6590.dat 1 0 -219.98171997070312 -218.39205932617187 138.65670776367188 1 0 0 0 -0.99619477987289429 0.087154924869537354 0 -0.087154924869537354 -0.99619477987289429 15100.dat 1 0 -199.98167419433594 -225.44961547851562 218.34483337402344 0 1.0000001192092896 0 0.99610108137130737 0 0.088220328092575073 0.088220328092575073 0 -0.99610096216201782 32526.dat 1 0 -219.981689453125 -178.54803466796875 142.18551635742187 1 0 0 0 -0.99619477987289429 0.087154924869537354 0 -0.087154924869537354 -0.99619477987289429 15100.dat 1 0 -209.98165893554687 -220.15647888183594 158.57876586914062 -1 0 0 0 -0.99999994039535522 0.00029972282936796546 0 0.00029972282936796546 1 2780.dat 1 0 -219.98190307617187 -232.53030395507812 298.03073120117187 0 -1.0000001192092896 0 -0.99608761072158813 0 0.088372938334941864 -0.088372938334941864 0 -0.99608743190765381 32278.dat 1 0 -229.98139953613281 -234.25953674316406 317.91064453125 -1 0 0 0 -0.99612104892730713 -0.087993331253528595 0 -0.087993331253528595 0.99612116813659668 2780.dat 1 4 -239.98146057128906 -236.91790771484375 347.79379272460937 0 0 -1 -0.088294066488742828 0.99609440565109253 0 0.9960944652557373 0.088294066488742828 0 32062.dat 1 0 -239.98133850097656 -234.25851440429687 317.9119873046875 0.99999994039535522 0 0 0 -0.99609404802322388 0.088298723101615906 0 -0.088298723101615906 -0.99609404802322388 32034.dat 1 0 -239.94230651855469 -239.56668090820312 377.67547607421875 -0.0039126886986196041 -0.99999237060546875 0 0.99608749151229858 -0.0038973693735897541 -0.088286735117435455 0.088286057114601135 -0.00034590173163451254 0.99609518051147461 32013.dat 1 4 -239.98136901855469 -231.61061096191406 288.0272216796875 0 0 -1 -0.088294073939323425 0.99609440565109253 0 0.9960944652557373 0.088294073939323425 0 32062.dat 1 0 -239.98143005371094 -228.95600891113281 258.145263671875 0 1.0000001192092896 0 0.99609464406967163 0 0.08829275518655777 0.08829275518655777 0 -0.99609458446502686 32034.dat 1 4 -239.98167419433594 -226.33375549316406 228.3040771484375 0 0 -1 -0.088294051587581635 0.99609440565109253 0 0.9960944652557373 0.088294051587581635 0 32062.dat 1 0 -239.98167419433594 -223.68473815917969 198.4215087890625 0.99999994039535522 0 0 0 -0.99609404802322388 0.088298723101615906 0 -0.088298723101615906 -0.99609404802322388 32034.dat 1 4 -239.98159790039062 -221.03581237792969 168.53868103027344 0 0 -1 -0.088294737040996552 0.99609440565109253 0 0.99609440565109253 0.088294737040996552 0 32062.dat 1 0 -239.98165893554687 -218.38729858398437 138.65592956542969 -0.0039238720200955868 -0.99999243021011353 0 -0.99608749151229858 0.0039088437333703041 0.088287249207496643 -0.088286571204662323 0.00034582923399284482 -0.99609506130218506 32013.dat 1 0 -239.98146057128906 -218.99554443359375 259.02822875976562 0 -1 0 0.99609488248825073 0 -0.088289402425289154 0.088289402425289154 0 0.99609488248825073 2780.dat 1 4 -239.98149108886719 -209.03463745117187 259.91116333007812 1 0 0 0 -0.99609494209289551 0.088288508355617523 0 -0.088288508355617523 -0.99609494209289551 41239.dat 1 0 -239.98143005371094 -207.90245056152344 360.40371704101562 0 1.0000001192092896 0 0.99609452486038208 0 0.088293746113777161 0.088293746113777161 0 -0.9960944652557373 2780.dat 1 4 -239.98150634765625 -190.19451904296875 271.61993408203125 0 1 0 -0.99609518051147461 0 -0.088285498321056366 -0.088285498321056366 0 0.99609512090682983 6590.dat 1 0 -239.98155212402344 -190.19450378417969 271.61990356445312 0 0 1 0.088287793099880219 0.99609488248825073 0 -0.99609500169754028 0.088287793099880219 0 3705.dat 1 4 -239.98150634765625 -192.84245300292969 301.50302124023437 -1 0 0 0 -0.99609488248825073 -0.088289014995098114 0 -0.088289014995098114 0.99609518051147461 11947.dat 1 4 -239.98150634765625 -187.52604675292969 241.51309204101562 1 0 0 0 -0.99609535932540894 0.088283762335777283 0 -0.088283762335777283 -0.99609535932540894 11946.dat 1 4 -239.98155212402344 -190.19444274902344 271.61990356445312 0 -1 0 -0.088285245001316071 0 -0.99609524011611938 0.99609524011611938 0 -0.088285177946090698 41678.dat 1 0 -229.98153686523437 -171.1553955078125 283.3465576171875 -1 0 0 0 -0.99612104892730713 -0.087993353605270386 0 -0.087993353605270386 0.99612116813659668 2780.dat 1 0 -219.98152160644531 -197.47021484375 390.15264892578125 0 0 -1 -0.97096389532089233 -0.23922599852085114 0 -0.23922599852085114 0.97096389532089233 0 4254.dat 1 4 -219.98152160644531 -171.1553955078125 283.34634399414062 0 0 -1 -0.97096401453018188 -0.23922570049762726 0 -0.23922567069530487 0.97096401453018188 0 4255.dat 1 72 -209.98153686523437 -197.47021484375 390.15267944335937 0.99999994039535522 0 0 0 0 -1 0 1 0 32002.dat 1 0 -204.98153686523437 -203.13775634765625 409.33285522460937 0 -1.0000001192092896 0 -0.95900875329971313 0 0.28337669372558594 -0.28337669372558594 0 -0.95900869369506836 32249.dat 1 72 -237.98188781738281 -241.36752319335937 397.64208984375 1 0 0 0 0.95900839567184448 -0.28337767720222473 0 0.28337767720222473 0.95900839567184448 87083.dat 1 4 -269.98178100585937 -241.36824035644531 397.64163208007812 0 1 0 0.9590071439743042 0 0.28338181972503662 0.28338181972503662 0 -0.9590071439743042 41669.dat 1 4 -254.98191833496094 -241.36750793457031 397.64208984375 0 -1 0 0.95900887250900269 0 -0.28337603807449341 0.28337603807449341 0 0.95900881290435791 41677.dat 1 0 -239.98188781738281 -241.36750793457031 397.64096069335937 1.7446514902985655E-005 1.0000001192092896 0 0.99996054172515869 -1.7281974578509107E-005 0.0088933957740664482 0.0088933957740664482 0 -0.99996048212051392 18654.dat 1 0 -239.98150634765625 -193.77639770507812 201.02830505371094 0 1 0 0.99609524011611938 0 0.088285692036151886 0.088285692036151886 0 -0.99609518051147461 2780.dat 1 0 -239.98146057128906 -192.01065063476562 181.10633850097656 0 -1 0 0.99609535932540894 0 -0.088284127414226532 0.088284127414226532 0 0.99609535932540894 2780.dat 1 0 -239.98146057128906 -206.13667297363281 340.48165893554687 0 -1 0 0.99609488248825073 0 -0.088289394974708557 0.088289394974708557 0 0.99609488248825073 2780.dat 1 0 -239.98149108886719 -208.40106201171875 139.49685668945312 0 -1 0 0.99609488248825073 0 -0.088289402425289154 0.088289402425289154 0 0.99609488248825073 2780.dat 1 0 -239.98146057128906 -229.60581970214844 378.55828857421875 0 -1 0 0.99609488248825073 0 -0.088289394974708557 0.088289394974708557 0 0.99609488248825073 2780.dat 1 1 -219.981689453125 -223.68519592285156 198.42279052734375 1 0 0 0 1 0 0 0 1 6558.dat 1 0 -209.98188781738281 -225.46052551269531 218.34403991699219 -1 0 0 0 -0.99999994039535522 0.00029972271295264363 0 0.00029972271295264363 1 2780.dat 1 0 -229.98147583007812 -244.86424255371094 437.441162109375 -1 0 0 0 -0.99612104892730713 -0.087993331253528595 0 -0.087993331253528595 0.99612116813659668 2780.dat 1 0 -239.98146057128906 -244.86424255371094 437.44119262695312 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 72 -219.99858093261719 -136.40306091308594 166.06999206542969 1 0 0 0 -0.79999923706054688 0.60000103712081909 0 -0.60000103712081909 -0.79999923706054688 11214.dat 1 0 -199.99858093261719 -136.40315246582031 166.06997680664062 0 -1.0000001192092896 0 -0.79999935626983643 0 0.60000115633010864 -0.60000115633010864 0 -0.7999991774559021 32140.dat 1 1 -219.9923095703125 -138.32122802734375 102.04232788085937 0 0 -1.0000001192092896 0.59998375177383423 -0.80001223087310791 0 -0.80001235008239746 -0.59998375177383423 0 43093.dat 1 0 -219.9923095703125 -116.32115936279297 106.04183959960937 0 0 -1 -0.59998387098312378 0.80001223087310791 0 0.80001217126846313 0.59998387098312378 0 42003.dat 1 0 -209.9923095703125 -100.32341766357422 118.04112243652344 -1 0.00012499494187068194 0 0.00012499446165747941 0.9999852180480957 -0.0054209716618061066 0 -0.0054209716618061066 -0.99998527765274048 2780.dat 1 0 -209.9923095703125 -116.32366180419922 106.04144287109375 -1 0.00012499494187068194 0 0.00012499446165747941 0.9999852180480957 -0.0054209725931286812 0 -0.0054209725931286812 -0.99998527765274048 2780.dat 1 0 -219.86820983886719 -261.7161865234375 175.01876831054687 -0.0037840385921299458 -0.99618899822235107 -0.087140314280986786 0.086823947727680206 -0.08713909238576889 0.9924054741859436 -0.99621659517288208 -0.0038104918785393238 0.086822867393493652 15100.dat 1 0 -239.79196166992187 -263.45907592773437 174.94270324707031 0.99618798494338989 0.087153986096382141 -0.0037993853911757469 0.087154112756252289 -0.99240410327911377 0.086823403835296631 0.003796478733420372 -0.086823530495166779 -0.99621647596359253 15100.dat 1 0 -240.77720642089844 -253.53663635253906 175.7347412109375 0.087156333029270172 0 0.99619472026824951 -0.99240392446517944 0.087155438959598541 0.086824655532836914 -0.086823754012584686 -0.99619477987289429 0.0075963200069963932 2780.dat 1 4 -260.0560302734375 -245.88394165039063 184.08714294433594 -0.38122710585594177 -0.087155893445014954 0.92036396265029907 0.047294806689023972 0.99240410327911377 0.1135680302977562 -0.92327094078063965 0.086823649704456329 -0.37420922517776489 32523.dat 1 0 -277.59170532226562 -258.079345703125 190.703125 0.087156333029270172 0 0.99619472026824951 -0.99240392446517944 0.087155438959598541 0.086824655532836914 -0.086823754012584686 -0.99619477987289429 0.0075963200069963932 2780.dat 1 4 -267.51681518554688 -266.86767578125 186.09271240234375 -0.38123133778572083 0.087157122790813446 -0.92036205530166626 0.047294586896896362 -0.99240374565124512 -0.11356969177722931 -0.92326909303665161 -0.086824469268321991 0.37421333789825439 43857.dat 1 0 -259.18475341796875 -255.80796813964844 183.21884155273437 0.087156333029270172 0 0.99619472026824951 -0.99240392446517944 0.087155438959598541 0.086824655532836914 -0.086823754012584686 -0.99619477987289429 0.0075963200069963932 2780.dat 1 0 200.00166320800781 -240.04901123046875 156.85044860839844 0 -0.99999994039535522 0 -0.90356838703155518 0 0.42844372987747192 -0.42844372987747192 0 -0.90356844663619995 15100.dat 1 1 200.00672912597656 -239.50982666015625 157.08033752441406 1 0 0 0 1 0 0 0 1 6558.dat 1 0 180.0067138671875 -229.51486206054687 156.76242065429687 0 -1 0 -0.031791709363460541 0 0.99949449300765991 -0.99949449300765991 0 -0.03179178386926651 43857.dat 1 0 170.00672912597656 -219.51992797851562 156.44451904296875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 72 220.00152587890625 -136.41328430175781 166.07418823242187 -1 0 0 0 -0.60000103712081909 0.79999929666519165 0 0.79999929666519165 0.60000121593475342 11214.dat 1 0 200.00093078613281 -136.41429138183594 166.06784057617187 0 -1.0000001192092896 0 -0.79999935626983643 0 0.60000109672546387 -0.60000109672546387 0 -0.7999991774559021 32140.dat 1 0 220.00250244140625 -166.5484619140625 143.36125183105469 0 1 0 0.99619477987289429 0 0.087154574692249298 0.087154574692249298 0 -0.99619477987289429 3705.dat 1 71 220.00248718261719 -144.63214111328125 145.27850341796875 0 -1 0 0.087155111134052277 0 0.99619477987289429 -0.99619477987289429 0 0.087155133485794067 6590.dat 1 0 220.00253295898437 -218.35060119628906 138.82931518554687 0 0 1 -0.99619430303573608 0.087160445749759674 0 -0.087160445749759674 -0.99619430303573608 0 32054.dat 1 0 220.00248718261719 -144.63214111328125 145.27865600585937 0 -1 0 -0.99619460105895996 0 0.087157696485519409 -0.087157696485519409 0 -0.99619454145431519 41678.dat 1 0 220.00244140625 -218.35398864746094 138.86929321289062 -1 1.4590887985832524E-005 0 1.4598163943446707E-005 0.99653679132461548 0.083156131207942963 0 0.083156131207942963 -0.99653655290603638 15100.dat 1 0 200.00259399414062 -225.38948059082031 218.51396179199219 0 1.0000001192092896 0 0.99610108137130737 0 0.088220313191413879 0.088220313191413879 0 -0.99610096216201782 32526.dat 1 0 210.00248718261719 -220.09335327148437 158.74813842773437 -1 0 0 0 -0.99999994039535522 0.00029968988383188844 0 0.00029968988383188844 1 2780.dat 1 0 220.00250244140625 -232.46548461914062 298.20037841796875 0 -1.0000001192092896 0 -0.99608761072158813 0 0.08837292343378067 -0.08837292343378067 0 -0.99608743190765381 32278.dat 1 0 230.00251770019531 -234.23292541503906 318.12216186523437 -1 0 0 0 -0.99612104892730713 -0.087993353605270386 0 -0.087993353605270386 0.99612116813659668 2780.dat 1 0 240.00413513183594 -234.23390197753906 318.12353515625 1 0 0 0 -0.99609410762786865 0.088298007845878601 0 -0.088298007845878601 -0.99609410762786865 32034.dat 1 4 240.00382995605469 -231.58409118652344 288.23916625976562 0 0 -1 -0.088287986814975739 0.99609500169754028 0 0.99609500169754028 0.088287986814975739 0 32062.dat 1 0 240.0035400390625 -228.92985534667969 258.35662841796875 0 1.0000001192092896 0 0.99609488248825073 0 0.088290996849536896 0.088290996849536896 0 -0.99609470367431641 32034.dat 1 4 240.00338745117187 -226.28102111816406 228.47354125976562 0 0 -1 -0.088293701410293579 0.99609452486038208 0 0.99609452486038208 0.088293701410293579 0 32062.dat 1 0 240.00299072265625 -223.65861511230469 198.63375854492187 1 0 0 0 -0.99609410762786865 0.088298007845878601 0 -0.088298007845878601 -0.99609410762786865 32034.dat 1 4 240.0025634765625 -221.00985717773437 168.75076293945313 0 0 -1 -0.088288255035877228 0.99609488248825073 0 0.99609494209289551 0.088288255035877228 0 32062.dat 1 0 240.00234985351562 -218.36094665527344 138.86787414550781 -0.0039314921014010906 -0.99999231100082397 0 -0.99608737230300903 0.0039162053726613522 0.088287375867366791 -0.088286690413951874 0.00034762654104270041 -0.99609506130218506 32013.dat 1 4 240.00418090820312 -236.89151000976562 348.00579833984375 0 0 -1 -0.088288314640522003 0.99609500169754028 0 0.99609500169754028 0.088288314640522003 0 32062.dat 1 0 240.00418090820312 -239.54013061523438 377.887451171875 -0.0039129676297307014 -0.99999237060546875 0 0.99608755111694336 -0.0038976098876446486 -0.088286250829696655 0.088285572826862335 -0.00034634053008630872 0.99609518051147461 32013.dat 1 0 240.00257873535156 -208.37443542480469 139.70822143554688 0 -1 0 0.99609488248825073 0 -0.088289342820644379 0.088289342820644379 0 0.99609488248825073 2780.dat 1 4 240.00257873535156 -209.00799560546875 260.12252807617187 1 0 0 0 -0.99609494209289551 0.088288508355617523 0 -0.088288508355617523 -0.99609494209289551 41239.dat 1 0 240.00251770019531 -207.87705993652344 360.61505126953125 0 1.0000001192092896 0 0.99609452486038208 0 0.088293775916099548 0.088293775916099548 0 -0.9960944652557373 2780.dat 1 4 240.0025634765625 -187.5196533203125 241.94886779785156 1 0 0 0 -0.99609494209289551 0.088288508355617523 0 -0.088288508355617523 -0.99609494209289551 11947.dat 1 0 240.00251770019531 -190.16813659667969 271.8316650390625 0 0 1 0.088287912309169769 0.99609488248825073 0 -0.99609500169754028 0.088287912309169769 0 3705.dat 1 4 240.00260925292969 -192.83746337890625 301.93878173828125 -1 0 0 0 -0.9960944652557373 -0.088293798267841339 0 -0.088293798267841339 0.99609470367431641 11946.dat 1 4 240.00253295898437 -190.16815185546875 271.8316650390625 0 1 0 -0.99609518051147461 0 -0.088285498321056366 -0.088285498321056366 0 0.99609512090682983 6590.dat 1 4 240.00248718261719 -190.16806030273437 271.8316650390625 0 -1.0000001192092896 0 -0.08828367292881012 0 -0.99609547853469849 0.99609547853469849 0 -0.088283546268939972 41678.dat 1 0 240.00251770019531 -193.75076293945312 201.23968505859375 0 1.0000001192092896 0 0.99609506130218506 0 0.088288344442844391 0.088288344442844391 0 -0.99609494209289551 2780.dat 1 0 240.0025634765625 -191.98403930664062 181.31794738769531 0 1.0000001192092896 0 0.99609452486038208 0 0.088293775916099548 0.088293775916099548 0 -0.9960944652557373 2780.dat 1 0 240.00253295898437 -206.11119079589844 340.6932373046875 0 1.0000001192092896 0 0.99609452486038208 0 0.088293775916099548 0.088293775916099548 0 -0.9960944652557373 2780.dat 1 0 230.00250244140625 -171.12898254394531 283.55828857421875 -1 0 0 0 -0.99612104892730713 -0.087993353605270386 0 -0.087993353605270386 0.99612116813659668 2780.dat 1 0 220.00250244140625 -197.44380187988281 390.36434936523437 0 0 -1 -0.97096389532089233 -0.23922599852085114 0 -0.23922599852085114 0.97096389532089233 0 4254.dat 1 4 220.00250244140625 -171.12898254394531 283.55828857421875 0 0 -1 -0.97096401453018188 -0.23922565579414368 0 -0.23922564089298248 0.97096401453018188 0 4255.dat 1 72 210.00248718261719 -197.44380187988281 390.36434936523437 -1 0 0 0 0 -1 0 -1 0 32002.dat 1 0 205.00251770019531 -202.94247436523437 409.1441650390625 0 -1 0 -0.95900863409042358 0 0.28337696194648743 -0.28337696194648743 0 -0.95900863409042358 32249.dat 1 72 238.00248718261719 -241.30278015136719 397.80899047851562 -1 0 0 0 0.95900845527648926 0.28337696194648743 0 0.28337696194648743 -0.95900857448577881 87083.dat 1 4 255.00251770019531 -241.30278015136719 397.80935668945312 0 -1.0000001192092896 0 0.95900893211364746 0 -0.2833760678768158 0.2833760678768158 0 0.95900893211364746 41677.dat 1 4 270.00250244140625 -241.30279541015625 397.80868530273437 0 -1.0000001192092896 0 -0.95900774002075195 0 0.28338032960891724 -0.28338032960891724 0 -0.9590076208114624 41669.dat 1 0 240.00251770019531 -241.30274963378906 397.80908203125 1.7446514902985655E-005 1.0000001192092896 0 0.99996054172515869 -1.7281974578509107E-005 0.0088933957740664482 0.0088933957740664482 0 -0.99996048212051392 18654.dat 1 0 240.00251770019531 -229.57919311523437 378.76980590820312 0 -1 0 0.99609488248825073 0 -0.088289335370063782 0.088289335370063782 0 0.99609488248825073 2780.dat 1 0 240.00253295898437 -218.96891784667969 259.23968505859375 0 -1 0 0.99609488248825073 0 -0.088289342820644379 0.088289342820644379 0 0.99609488248825073 2780.dat 1 1 220.00274658203125 -223.62031555175781 198.5924072265625 1 0 0 0 1 0 0 0 1 6558.dat 1 0 210.00254821777344 -225.39567565917969 218.51362609863281 -1 0 0 0 -0.99999994039535522 0.00029968976741656661 0 0.00029968976741656661 1 2780.dat 1 0 230.00247192382812 -244.83761596679687 437.65264892578125 -1 0 0 0 -0.99612104892730713 -0.087993361055850983 0 -0.087993361055850983 0.99612116813659668 2780.dat 1 0 240.00248718261719 -244.83761596679687 437.65267944335937 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 0 220.00239562988281 -178.50621032714844 142.3553466796875 -1 1.4590888895327225E-005 0 1.4598164852941409E-005 0.99653679132461548 0.083156131207942963 0 0.083156131207942963 -0.99653655290603638 15100.dat 1 0 220.00253295898437 -240.01777648925781 157.00994873046875 0 -1 0 0.087161712348461151 0 0.99619418382644653 -0.99619418382644653 0 0.087161697447299957 44809.dat 1 0 220.00265502929687 -261.67626953125 175.11503601074219 0.003783911932259798 0.99618905782699585 -0.087139204144477844 0.086823657155036926 -0.087137937545776367 -0.99240559339523315 -0.99621665477752686 -0.0038106613792479038 -0.086822390556335449 15100.dat 1 0 239.92636108398437 -263.419189453125 175.03898620605469 -0.99618756771087646 -0.087154403328895569 -0.0037977711763232946 0.087154388427734375 -0.99240404367446899 -0.086823336780071259 0.0037981118075549603 -0.086823321878910065 0.99621647596359253 15100.dat 1 0 240.79794311523437 -253.49514770507812 175.90725708007812 -0.087155409157276154 0 0.99619483947753906 -0.99240398406982422 0.087155863642692566 -0.086823835968971252 -0.086824126541614532 -0.99619477987289429 -0.0075960573740303516 2780.dat 1 4 260.0767822265625 -245.84245300292969 184.25965881347656 -0.38122785091400146 -0.087159216403961182 0.92036324739456177 -0.04729238897562027 -0.99240368604660034 -0.11357069760560989 0.92327064275741577 -0.086822487413883209 0.37420982122421265 32523.dat 1 0 259.2052001953125 -255.7664794921875 183.39143371582031 -0.087155371904373169 0 0.99619477987289429 -0.99240386486053467 0.087156705558300018 -0.08682376891374588 -0.086824983358383179 -0.99619466066360474 -0.0075961700640618801 2780.dat 1 4 267.53726196289062 -266.82623291015625 186.2652587890625 -0.38122722506523132 0.087155669927597046 -0.92036396265029907 -0.047295428812503815 0.99240392446517944 0.11356804519891739 0.9232708215713501 0.086824238300323486 -0.37420931458473206 43857.dat 1 0 277.61245727539062 -258.037841796875 190.87559509277344 -0.087155409157276154 0 0.99619483947753906 -0.99240398406982422 0.087155863642692566 -0.086823835968971252 -0.086824126541614532 -0.99619477987289429 -0.0075960573740303516 2780.dat 1 0 210.00144958496094 -100.411865234375 118.07354736328125 -1 0.00012499494187068194 0 0.00012499446165747941 0.9999852180480957 -0.0054209716618061066 0 -0.0054209716618061066 -0.99998527765274048 2780.dat 1 0 220.00146484375 -116.41460418701172 106.07344055175781 0 0 -1 -0.59998375177383423 0.80001211166381836 0 0.80001211166381836 0.59998375177383423 0 42003.dat 1 1 220.00146484375 -138.41468811035156 102.0745849609375 0 0 -1.0000001192092896 0.59998387098312378 -0.80001217126846313 0 -0.80001223087310791 -0.59998387098312378 0 43093.dat 1 1 -120.00529479980469 -224.33125305175781 770.0235595703125 1 0 0 0 1 0 0 0 1 6558.dat 1 0 100.00093841552734 -160.413330078125 858.0697021484375 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 0 110.00095367431641 -160.413330078125 858.0697021484375 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -120.00569152832031 -192.17123413085937 834.1434326171875 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 0 120.00106811523437 -192.25440979003906 834.1898193359375 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 0 -110.00539398193359 -160.33148193359375 858.02374267578125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 -100.00540161132812 -160.33146667480469 858.02374267578125 1.7446514902985655E-005 1.0000001192092896 0 0.99996054172515869 -1.7281974578509107E-005 0.0088933957740664482 0.0088933957740664482 0 -0.99996048212051392 18654.dat 1 0 -79.985244750976562 -144.62120056152344 810.0010986328125 0 1 0 0 0 -1 -1 0 0 32526.dat 1 1 -100.00555419921875 -224.33120727539062 790.023681640625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 -120.00556182861328 -224.34573364257812 790.023681640625 0 1 0 -1 0 0 0 0 0.99999994039535522 87082.dat 1 0 -100.00547027587891 -204.32984924316406 790.02001953125 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 44809.dat 1 0 -100.00544738769531 -204.32981872558594 770.0198974609375 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 0 -100.00543212890625 -204.32981872558594 770.0198974609375 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32523.dat 1 1 -120.00537872314453 -204.32981872558594 760.021240234375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 0 -120.00539398193359 -204.32806396484375 750.01995849609375 0 -0.00017574465891811997 -0.99999994039535522 -0.00017562102584633976 -0.99999994039535522 0.00017574460071045905 -0.99999994039535522 0.00017562096763867885 0 63869.dat 1 0 -130.00535583496094 -224.33154296875 730.02349853515625 -1 0 0 0 -1 0 0 0 1 2780.dat 1 1 -100.00542449951172 -224.3314208984375 750.02423095703125 -1 0 0 0 1 0 0 0 -1 6558.dat 1 57 -160.00489807128906 -244.33148193359375 848.02362060546875 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 71 -160.0048828125 -244.33145141601562 840.02362060546875 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 4 -160.0048828125 -244.33148193359375 830.0235595703125 0 1 0 1 0 0 0 0 -1 87086.dat 1 47 -160.00486755371094 -224.33148193359375 848.02349853515625 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 71 -160.0048828125 -224.33148193359375 840.02362060546875 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 36 -200.00486755371094 -224.33148193359375 848.02362060546875 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 6141.dat 1 71 -200.00486755371094 -224.33145141601562 840.02362060546875 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 36 -180.00489807128906 -224.33148193359375 848.02349853515625 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 6141.dat 1 71 -180.00486755371094 -224.33148193359375 840.02362060546875 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 4 -130.00540161132812 -244.3310546875 770.02374267578125 0 0 1 0 -1 0 1 0 0 6590.dat 1 1 -150.0048828125 -244.33152770996094 770.03289794921875 0.99999994039535522 0 0 0 0 1 0 -1 0 43093.dat 1 4 -130.00540161132812 -244.3311767578125 770.023681640625 1 0 0 0 -1 0 0 0 -1 41678.dat 1 4 -110.0052490234375 -244.33132934570312 770.02398681640625 -1 0 0 0 1 0 0 0 -1 32062.dat 1 0 -100.0052490234375 -244.33132934570312 770.02398681640625 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 32039.dat 1 72 -80.0052490234375 -244.33132934570312 740.0240478515625 0 0 1 0 0.99999994039535522 0 -1 0 0 87083.dat 1 0 -80.005416870117188 -224.33145141601562 750.02423095703125 0 0 1 0 -1 0 1 0 0 32184.dat 1 1 -80.005416870117188 -204.33146667480469 760.02423095703125 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 0 -140.00538635253906 -234.3310546875 790.023681640625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 -160.00515747070312 -204.33108520507812 710.02374267578125 1 0 0 0 -1 0 0 0 -1 32525.dat 1 1 -160.00515747070312 -214.33108520507812 730.0238037109375 0 0 -0.99999994039535522 -0.99999994039535522 0 0 0 0.99999994039535522 0 43093.dat 1 4 -160.00535583496094 -224.33103942871094 730.02374267578125 1 0 0 0 1 0 0 0 1 32140.dat 1 0 -160.00537109375 -214.3310546875 790.02362060546875 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 2780.dat 1 1 -160.00325012207031 -204.33015441894531 670.02374267578125 0 1 0 -1 0 0 0 0 0.99999994039535522 6558.dat 1 0 -140.00563049316406 -184.33152770996094 650.0238037109375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 42003.dat 1 0 -120.00560760498047 -184.33152770996094 660.0238037109375 0 0 -1 0 0.99999994039535522 0 1 0 0 3705.dat 1 0 -140.00563049316406 -184.33152770996094 670.0238037109375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 42003.dat 1 0 -120.00539398193359 -204.33154296875 690.02349853515625 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 42003.dat 1 0 -120.00537872314453 -204.33154296875 630.0235595703125 0 0 -1.0000001192092896 0 -1 0 -1.0000001192092896 0 0 42003.dat 1 0 -140.00563049316406 -194.33152770996094 670.0238037109375 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 -140.00563049316406 -204.33151245117187 670.0238037109375 0 0 -1 0 0.99999994039535522 0 1 0 0 44809.dat 1 0 -120.00564575195312 -204.33151245117187 660.02386474609375 0 0 -1 0 0.99999994039535522 0 1 0 0 2780.dat 1 0 -140.00563049316406 -204.33146667480469 650.02374267578125 0 0 -1 0 -1 0 -1 0 0 44809.dat 1 0 -130.00538635253906 -204.33154296875 630.0235595703125 1 0 0 0 1 0 0 0 1 2780.dat 1 0 -140.00563049316406 -194.33152770996094 650.02374267578125 0 -1 0 1 0 0 0 0 0.99999994039535522 2780.dat 1 0 -130.005615234375 -204.33151245117187 690.0238037109375 1 0 0 0 1 0 0 0 1 2780.dat 1 0 -130.00538635253906 -224.33154296875 630.0235595703125 1 0 0 0 1 0 0 0 1 2780.dat 1 1 -160.00325012207031 -204.33013916015625 650.023681640625 0 1 0 -1 0 0 0 0 0.99999994039535522 6558.dat 1 4 -160.00325012207031 -224.13015747070312 710.02374267578125 -1 0 0 0 1 0 0 0 -1 11947.dat 1 0 -130.00543212890625 -224.33154296875 690.02349853515625 1 0 0 0 1 0 0 0 1 2780.dat 1 0 -160.00515747070312 -194.33106994628906 630.02392578125 0 0.99998927116394043 -0.0046372180804610252 -1 0 -1.2758653610944748E-005 -1.2758653610944748E-005 0.0046372180804610252 0.99998921155929565 2780.dat 1 0 -170.40188598632812 -184.33110046386719 612.93890380859375 0.8542664647102356 0 -0.51983529329299927 0 -1 0 -0.51983529329299927 0 -0.85426652431488037 32523.dat 1 0 -180.79859924316406 -194.31520080566406 595.85009765625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 -180.798583984375 -204.315185546875 595.85009765625 0.0089035807177424431 0 -0.99996036291122437 0 1 0 0.99996036291122437 0 0.0089035807177424431 18654.dat 1 0 -160.00602722167969 -214.33134460449219 750.02374267578125 1.6655993022141047E-005 1.0000001192092896 0 1.0000001192092896 -1.6387139112339355E-005 0 0 0 -1 2780.dat 1 0 159.99557495117187 -214.41592407226562 790.0703125 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 2780.dat 1 0 159.99557495117187 -204.41593933105469 710.0703125 1 0 0 0 -1 0 0 0 -1 32525.dat 1 4 159.99562072753906 -224.41593933105469 730.0701904296875 -1 0 0 0 -1 0 0 0 1 32140.dat 1 1 159.99710083007812 -214.41519165039062 730.07012939453125 0 0 -0.99999994039535522 -0.99999994039535522 0 0 0 0.99999994039535522 0 43093.dat 1 0 140.00090026855469 -234.42781066894531 790.07000732421875 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 1 80.000953674316406 -204.41696166992187 760.06207275390625 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 0 79.999847412109375 -224.41348266601562 750.06988525390625 0 0 1 0 -1 0 1 0 0 32184.dat 1 72 79.994735717773438 -244.33132934570312 740.0240478515625 0 0 1 0 0.99999994039535522 0 -1 0 0 87083.dat 1 0 99.995460510253906 -244.41607666015625 770.0975341796875 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 32039.dat 1 4 109.99546051025391 -244.41607666015625 770.0975341796875 1 0 0 0 1 0 0 0 1 32062.dat 1 4 130.00093078613281 -244.42779541015625 770.07000732421875 -1 0 0 0 1 0 0 0 -1 41678.dat 1 1 149.99508666992187 -244.41621398925781 770.08868408203125 -1 0 0 0 0 1 0 1 0 43093.dat 1 4 129.99560546875 -244.41578674316406 770.09783935546875 0 0 -1 0 -1 0 -1 0 0 6590.dat 1 0 159.99560546875 -194.41592407226562 630.07025146484375 0 0.99998927116394043 -0.0046372171491384506 -1 0 -1.2758653610944748E-005 -1.2758653610944748E-005 0.0046372171491384506 0.99998921155929565 2780.dat 1 0 170.39230346679687 -184.41593933105469 612.9849853515625 0.85426628589630127 0 -0.51983565092086792 0 1 0 0.51983565092086792 0 0.85426628589630127 32523.dat 1 0 180.78901672363281 -194.4000244140625 595.89605712890625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 2780.dat 1 0 180.78901672363281 -204.39999389648437 595.89605712890625 0.0089035807177424431 0 -0.99996036291122437 0 1 0 0.99996036291122437 0 0.0089035807177424431 18654.dat 1 1 159.99560546875 -204.41596984863281 650.070068359375 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 0 119.99541473388672 -204.41593933105469 690.07037353515625 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 42003.dat 1 0 119.99562835693359 -184.41592407226562 660.07012939453125 0 0 1 0 1 0 -1 0 0 3705.dat 1 0 139.99560546875 -184.41592407226562 650.07012939453125 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 42003.dat 1 0 119.99541473388672 -204.41593933105469 630.0704345703125 0 0 1.0000001192092896 0 -1 0 1.0000001192092896 0 0 42003.dat 1 0 139.99560546875 -184.41592407226562 670.07012939453125 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 42003.dat 1 0 129.99542236328125 -204.41593933105469 690.07049560546875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 139.99571228027344 -204.41586303710937 670.0701904296875 0 0 1 0 -1 0 1 0 0 44809.dat 1 0 119.99562835693359 -204.41592407226562 660.070068359375 0 0 1 0 1 0 -1 0 0 2780.dat 1 0 139.99571228027344 -204.41592407226562 650.07012939453125 0 0 1 0 0.99999994039535522 0 -1 0 0 44809.dat 1 0 139.99571228027344 -194.41592407226562 650.07012939453125 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 2780.dat 1 0 129.99569702148437 -204.41592407226562 630.0701904296875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 139.99571228027344 -194.41592407226562 670.0701904296875 0 1.0000001192092896 0 1.0000001192092896 0 0 0 0 -1 2780.dat 1 0 129.99542236328125 -224.41593933105469 690.07049560546875 -1 0 0 0 1 0 0 0 -1 2780.dat 1 1 159.99560546875 -204.41592407226562 670.070068359375 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 6558.dat 1 4 159.99565124511719 -224.21591186523437 709.8450927734375 -1 0 0 0 1 0 0 0 -1 11946.dat 1 0 129.99542236328125 -224.41593933105469 630.0704345703125 -1 0 0 0 1 0 0 0 -1 2780.dat 1 0 159.99627685546875 -214.41545104980469 750.0701904296875 1.6655993022141047E-005 1.0000001192092896 0 1.0000001192092896 -1.6387139112339355E-005 0 0 0 -1 2780.dat 1 1 100.00088500976562 -224.41348266601562 750.06988525390625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 120.00093078613281 -204.41683959960937 750.06640625 0 -0.00017574465891811997 -0.99999994039535522 -0.00017562102584633976 -0.99999994039535522 0.00017574460071045905 -0.99999994039535522 0.00017562096763867885 0 63869.dat 1 1 120.00093078613281 -204.41860961914063 760.06634521484375 0 -1.0000001192092896 0 0 0 1.0000001192092896 -1.0000001192092896 0 0 43093.dat 1 0 100.00090789794922 -204.41696166992187 770.06207275390625 0 0 1.0000001192092896 -1.0000001192092896 0 0 0 -1.0000001192092896 0 32523.dat 1 0 100.0009765625 -204.40106201171875 770.05865478515625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 32054.dat 1 0 100.00096893310547 -204.41195678710937 790.06646728515625 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 44809.dat 1 0 120.00093078613281 -224.42782592773437 790.0699462890625 0 1 0 -1 0 0 0 0 0.99999994039535522 87082.dat 1 1 100.00093078613281 -224.413330078125 790.0699462890625 -1 0 0 0 1 0 0 0 -1 6558.dat 1 0 80.022232055664063 -144.62693786621094 810.03387451171875 0 1 0 0 0 -1 -1 0 0 32526.dat 1 4 100.00076293945312 -224.41337585449219 810.0694580078125 -1 0 0 0 0 1 0 1 0 32054.dat 1 71 140.00079345703125 -224.41337585449219 810.0694580078125 1 0 0 0 1 0 0 0 1 4519.dat 1 4 180.00079345703125 -224.41337585449219 810.0694580078125 0 -1.0538426977291238E-005 1 -1.0414792086521629E-005 -1 -1.0538427886785939E-005 1 -1.0414792996016331E-005 0 32013.dat 1 1 180.00080871582031 -224.41348266601562 820.06939697265625 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 4274.dat 1 4 140.00077819824219 -224.41392517089844 810.06927490234375 5.4976619139779359E-005 1 1.808509296097327E-005 0.80002468824386597 -5.4768494010204449E-005 0.59996718168258667 0.59996718168258667 -1.8494107280275784E-005 -0.80002462863922119 44809.dat 1 4 124.00438690185547 -210.81730651855469 845.26702880859375 5.5692904425086454E-005 -0.80005365610122681 0.59992861747741699 0.59996938705444336 0.47998338937759399 0.64004123210906982 -0.80002301931381226 0.35990312695503235 0.48003438115119934 42003.dat 1 1 140.00566101074219 -214.4154052734375 830.06866455078125 -5.4487216402776539E-005 -0.59996753931045532 0.80002439022064209 -0.59996765851974487 -0.64001923799514771 -0.48001477122306824 0.80002433061599731 -0.48001492023468018 -0.35992616415023804 43093.dat 1 0 101.99917602539062 -207.61518859863281 847.67120361328125 -0.60000103712081909 0.69970935583114624 -0.38782188296318054 -0.64000880718231201 -0.71069186925888062 -0.29207175970077515 -0.47998717427253723 0.072965994477272034 0.87423622608184814 2780.dat 1 4 79.995452880859375 -204.41534423828125 850.06817626953125 0 0.60000097751617432 -0.79999935626983643 -0.59998798370361328 0.6400076150894165 0.48000496625900269 0.80000901222229004 0.47998878359794617 0.359995037317276 32316.dat 1 0 85.999954223632813 -198.01618957519531 854.864501953125 -0.60000097751617432 0.69970935583114624 -0.38782194256782532 -0.64000880718231201 -0.71069186925888062 -0.29207172989845276 -0.47998720407485962 0.0729660764336586 0.87423622608184814 2780.dat 1 1 60.002368927001953 -166.41191101074219 866.0692138671875 -5.5667293054284528E-005 -0.59996682405471802 0.80002498626708984 -0.59996694326400757 -0.64001971483230591 -0.48001512885093689 0.80002492666244507 -0.48001524806022644 -0.35992440581321716 43093.dat 1 4 76.001869201660156 -182.01190185546875 866.8697509765625 0 0.79999947547912598 0.60000085830688477 -0.59998393058776855 -0.48000827431678772 0.64000892639160156 0.80001217126846313 -0.35999023914337158 0.47998735308647156 42003.dat 1 0 69.998847961425781 -188.41654968261719 862.06243896484375 -0.60000097751617432 0.69970935583114624 -0.38782194256782532 -0.64000880718231201 -0.71069186925888062 -0.29207175970077515 -0.47998720407485962 0.072966039180755615 0.87423622608184814 2780.dat 1 0 118.00367736816406 -217.2161865234375 840.4676513671875 -0.60000097751617432 0.69970935583114624 -0.38782194256782532 -0.64000880718231201 -0.71069186925888062 -0.29207172989845276 -0.47998720407485962 0.0729660764336586 0.87423622608184814 2780.dat 1 0 130.00094604492187 -224.41365051269531 730.06988525390625 -1 0 0 0 -1 0 0 0 1 2780.dat 1 0 89.994735717773438 -224.33135986328125 730.0240478515625 -1 0 0 0 -1 0 0 0 1 2780.dat 1 71 159.99508666992187 -244.41621398925781 840.07940673828125 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 4 159.99508666992187 -244.41621398925781 830.079345703125 0 -1 0 -1 0 0 0 0 -1 87080.dat 1 57 159.99508666992187 -244.41622924804687 848.07940673828125 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 36 199.99508666992187 -224.41621398925781 848.07928466796875 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 71 199.99507141113281 -224.41621398925781 840.07940673828125 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 71 159.99508666992187 -224.41621398925781 840.07940673828125 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 47 159.99508666992187 -224.41622924804687 848.07940673828125 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 6141.dat 1 36 179.99505615234375 -224.41621398925781 848.07928466796875 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 6141.dat 1 71 179.99508666992187 -224.41621398925781 840.07940673828125 0.99999994039535522 0 0 0 0 -1 0 1 0 6141.dat 1 0 -90.00531005859375 -224.33131408691406 730.02398681640625 -1 0 0 0 -1 0 0 0 1 2780.dat 1 4 -100.00527191162109 -224.33120727539062 810.023681640625 1 0 0 0 -1 0 0 0 -1 32054.dat 1 71 -140.00531005859375 -224.33123779296875 810.023681640625 1 0 0 0 1 0 0 0 1 4519.dat 1 4 -180.00531005859375 -224.33123779296875 810.023681640625 0 0 -1 1.0553912943578325E-005 0.99999994039535522 0 1 -1.0553912943578325E-005 0 32013.dat 1 4 -139.97892761230469 -224.63201904296875 810.03778076171875 5.4976619139779359E-005 1 1.808509296097327E-005 0.80002468824386597 -5.4768494010204449E-005 0.59996718168258667 0.59996718168258667 -1.8494107280275784E-005 -0.80002462863922119 44809.dat 1 4 -123.97939300537109 -211.03054809570312 845.23822021484375 0 0.7999991774559021 0.60000109672546387 0.59998303651809692 0.48000988364219666 -0.64000856876373291 -0.80001276731491089 0.35998862981796265 -0.47998729348182678 42003.dat 1 1 -139.97845458984375 -214.63047790527344 830.0377197265625 -2.4451510398648679E-005 -0.80000394582748413 0.59999477863311768 -0.59994733333587646 -0.48000776767730713 -0.64004361629486084 0.80003952980041504 -0.35998091101646423 -0.47994846105575562 43093.dat 1 0 -101.98117828369141 -207.82925415039062 847.641845703125 -0.60000091791152954 0.69970923662185669 -0.38782212138175964 0.64000868797302246 0.71069234609603882 0.29207184910774231 0.47998741269111633 -0.0729660764336586 -0.87423568964004517 2780.dat 1 4 -79.978981018066406 -204.63015747070312 850.03826904296875 0 0.59998798370361328 -0.80000907182693481 0.59998810291290283 -0.64001530408859253 -0.4799945056438446 -0.80000901222229004 -0.47999462485313416 -0.35998725891113281 32316.dat 1 0 -69.975631713867188 -188.63131713867187 862.0322265625 -0.60000091791152954 0.69970923662185669 -0.38782212138175964 0.64000868797302246 0.71069234609603882 0.29207184910774231 0.47998741269111633 -0.0729660764336586 -0.87423568964004517 2780.dat 1 1 -59.977519989013672 -166.62965393066406 866.0357666015625 -3.1197556381812319E-005 -0.80000019073486328 0.59999996423721313 -0.5999482274055481 -0.48000818490982056 -0.64004248380661011 0.80003893375396729 -0.35998889803886414 -0.47994354367256165 43093.dat 1 4 -75.980934143066406 -182.22917175292969 866.83819580078125 5.7323672081110999E-005 -0.80005389451980591 0.59992820024490356 -0.59996604919433594 -0.47998535633087158 -0.64004284143447876 0.80002546310424805 -0.3598998486995697 -0.48003265261650085 42003.dat 1 0 -85.976715087890625 -198.23095703125 854.83428955078125 -0.60000091791152954 0.69970923662185669 -0.38782212138175964 0.64000868797302246 0.71069234609603882 0.29207184910774231 0.47998741269111633 -0.0729660764336586 -0.87423568964004517 2780.dat 1 0 -117.97891998291016 -217.43023681640625 840.43817138671875 -0.60000097751617432 0.69970911741256714 -0.38782203197479248 0.64000850915908813 0.71069192886352539 0.29207193851470947 0.47998741269111633 -0.072965964674949646 -0.87423568964004517 2780.dat 1 1 -180.00534057617187 -224.33108520507812 820.02362060546875 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 4274.dat 1 0 -119.99852752685547 -234.33448791503906 710.2880859375 0 -0.99999988079071045 0.00067156454315409064 0.026422848924994469 -0.00067124294582754374 -0.99965071678161621 0.99965095520019531 1.7448439393774606E-005 0.026422938331961632 43857.dat 1 4 -139.99179077148437 -245.99244689941406 730.48248291015625 -1 0 0 0 -0.083409182727336884 0.99651539325714111 0 0.99651539325714111 0.083409197628498077 42003.dat 1 1 -129.99183654785156 -244.32427978515625 710.55218505859375 -1 0 0 0 0.083415515720844269 -0.99651485681533813 0 -0.99651485681533813 -0.083415478467941284 43093.dat 1 0 -139.99211120605469 -255.9598388671875 729.6744384765625 0 1.0000001192092896 0 0.99662333726882935 0 0.082110017538070679 0.082110017538070679 0 -0.99662327766418457 2780.dat 1 0 120.00765991210937 -234.41653442382812 710.33441162109375 0 -0.99999988079071045 0.00067156454315409064 0.026422848924994469 -0.00067124294582754374 -0.99965071678161621 0.99965095520019531 1.7448439393774606E-005 0.026422938331961632 43857.dat 1 0 -0.0052332878112792969 -244.33132934570312 710.0240478515625 0 0 1.0000001192092896 1.0000001192092896 0 0 0 1.0000001192092896 0 32525.dat 1 1 -40.004226684570313 -244.33128356933594 720.02398681640625 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 -40.001060485839844 -244.32940673828125 730.017822265625 0 0 -1 0 -1 0 -1 0 0 6536.dat 1 0 -40.005443572998047 -236.99049377441406 815.65625 0 -0.99999994039535522 0 0.64304983615875244 0 0.76582431793212891 -0.76582431793212891 0 0.64304983615875244 60483.dat 1 0 -0.0053584575653076172 -236.99078369140625 815.65618896484375 1 0 0 0 0.76582092046737671 -0.64305388927459717 0 0.64305388927459717 0.76582092046737671 3707.dat 1 0 39.994586944580078 -236.99069213867187 815.65625 0 -1.0000001192092896 0 0.64305019378662109 0 0.76582419872283936 -0.76582419872283936 0 0.64305031299591064 60483.dat 1 0 -59.985630035400391 -264.55758666992187 729.98681640625 0 -1 0 0.9984891414642334 0 -0.05495043471455574 0.05495043471455574 0 0.9984891414642334 32348.dat 1 71 -0.0053584575653076172 -221.67344665527344 828.517333984375 1 0 0 0 0.76582026481628418 -0.64305466413497925 0 0.64305466413497925 0.76582026481628418 44294.dat 1 0 59.994514465332031 -264.32781982421875 730.02532958984375 0 -0.99999994039535522 0 0.99848908185958862 0 -0.054950449615716934 0.054950449615716934 0 0.99848902225494385 32348.dat 1 0 49.997959136962891 -264.32937622070313 730.01971435546875 1 0 0 0 0.99893879890441895 -0.046057313680648804 0 0.046057313680648804 0.99893879890441895 3705.dat 1 0 99.997734069824219 -264.3260498046875 730.019775390625 1 0 0 0 0.046057451516389847 0.99893879890441895 0 -0.99893879890441895 0.046057451516389847 32054.dat 1 0 -50.005279541015625 -264.331298828125 730.025146484375 1 0 0 0 0.9984891414642334 -0.054949380457401276 0 0.054949380457401276 0.9984891414642334 3705.dat 1 0 -100.00555419921875 -264.32803344726562 730.0255126953125 -1 0 0 0 -0.054950069636106491 0.99848920106887817 0 0.99848920106887817 0.054950308054685593 32054.dat 1 0 -0.0052869319915771484 -264.331298828125 730.02520751953125 1.2995528777537402E-005 0 1.0000001192092896 -0.034720379859209061 -0.99939703941345215 0 0.9993971586227417 -0.034720379859209061 -1.2792511370207649E-005 32034.dat 1 72 19.994630813598633 -221.6744384765625 828.517333984375 0 -1.0000001192092896 0 0.64305394887924194 0 0.76582098007202148 -0.76582098007202148 0 0.64305394887924194 32523.dat 1 72 -20.005331039428711 -221.6748046875 828.51715087890625 0 -1.0000001192092896 0 0.64305412769317627 0 0.76582080125808716 -0.76582080125808716 0 0.64305418729782104 32523.dat 1 72 -0.0054441392421722412 -221.67532348632812 828.51678466796875 0 1.0000001192092896 0 0.99979513883590698 0 0.02024485170841217 0.02024485170841217 0 -0.99979507923126221 18654.dat 1 0 -0.0053010880947113037 -236.99070739746094 815.6558837890625 1.7506119547761045E-005 1.0000001192092896 0 0.99996048212051392 -1.7222369933733717E-005 0.008906833827495575 0.008906833827495575 0 -0.99996036291122437 18654.dat 1 1 -0.0053703784942626953 -206.35855102539062 841.37628173828125 -1 0 0 0 0.99979496002197266 0.020246714353561401 0 0.020246714353561401 -0.99979501962661743 6558.dat 1 0 -0.0053964555263519287 -206.35855102539062 841.37628173828125 0 1.0000001192092896 0 0.99979513883590698 0 0.02024485170841217 0.02024485170841217 0 -0.99979507923126221 18654.dat 1 72 -39.985347747802734 -267.85519409179687 789.89556884765625 1 0 0 0 0.020246628671884537 0.99979501962661743 0 -0.99979501962661743 0.020246628671884537 11214.dat 1 0 0.014659762382507324 -267.855224609375 789.89599609375 1.0849691534531303E-005 0 -1 -0.054959911853075027 0.9984886646270752 0 0.99848860502243042 0.054959911853075027 1.0861882401513867E-005 32034.dat 1 72 40.014675140380859 -267.85519409179687 789.89532470703125 -1 0 0 0 -0.020246686413884163 0.99979507923126221 0 0.99979507923126221 0.020246773958206177 11214.dat 1 0 39.994754791259766 -287.59524536132812 788.8350830078125 0 0 -1.0000001192092896 -0.054962605237960815 0.99848854541778564 0 0.99848848581314087 0.054962605237960815 0 42003.dat 1 72 39.994480133056641 -308.65814208984375 807.703857421875 0 -1 0 0.054941698908805847 0 0.99848955869674683 -0.99848955869674683 0 0.054941676557064056 11214.dat 1 0 -39.985378265380859 -287.8250732421875 788.79693603515625 0 0 -1.0000001192092896 -0.054962590336799622 0.99848854541778564 0 0.99848848581314087 0.054962590336799622 0 42003.dat 1 72 -39.985366821289063 -308.89382934570312 807.66650390625 0 -1 0 0.054956942796707153 0 0.99848872423171997 -0.99848872423171997 0 0.054956916719675064 11214.dat 1 0 -140.00602722167969 -309.20706176757812 817.69073486328125 0 0 0.99999994039535522 0.054941784590482712 0.99848949909210205 0 -0.99848955869674683 0.054941784590482712 0 2780.dat 1 4 -139.98606872558594 -309.97412109375 827.63690185546875 0 0 -0.99999994039535522 -0.054965488612651825 0.99848818778991699 0 0.99848824739456177 0.054965488612651825 0 32013.dat 1 0 -90.005813598632812 -309.75613403320312 827.6746826171875 1 0 0 0 0.99848848581314087 -0.054961293935775757 0 0.054961293935775757 0.99848848581314087 3705.dat 1 4 -100.00580596923828 -309.7562255859375 827.67572021484375 0 0 -1.0000001192092896 0.054982941597700119 -0.99848729372024536 0 -0.99848741292953491 -0.054982941597700119 0 6590.dat 1 4 -40.005855560302734 -309.75616455078125 827.67474365234375 1.0850612852664199E-005 0 -1 -0.05495993047952652 0.99848854541778564 0 0.99848854541778564 0.05495993047952652 1.0862087037821766E-005 32034.dat 1 4 -80.005844116210937 -309.7562255859375 827.67572021484375 -1 0 0 0 0.99848824739456177 0.054965533316135406 0 0.054965533316135406 -0.99848824739456177 6536.dat 1 71 -0.0058352947235107422 -309.756103515625 827.67437744140625 -1 0 0 0 0.99848753213882446 0.054979711771011353 0 0.054979711771011353 -0.99848747253417969 4519.dat 1 4 -0.0055693089962005615 -309.75619506835937 827.67486572265625 0 0 -1.0000001192092896 0.054982941597700119 -0.99848729372024536 0 -0.99848741292953491 -0.054982941597700119 0 6590.dat 1 4 79.994384765625 -309.75686645507812 827.6729736328125 -1 0 0 0 0.99848824739456177 0.054965555667877197 0 0.054965555667877197 -0.99848824739456177 6536.dat 1 0 89.993751525878906 -309.75643920898437 827.6724853515625 1 0 0 0 0.99848842620849609 -0.054962377995252609 0 0.054962377995252609 0.99848842620849609 3705.dat 1 4 99.994338989257813 -309.75686645507812 827.67315673828125 0 0 -1.0000001192092896 0.054982937872409821 -0.99848729372024536 0 -0.99848741292953491 -0.054982937872409821 0 6590.dat 1 4 139.99375915527344 -309.7564697265625 827.67218017578125 0 0 1.0000001192092896 0.054962530732154846 0.99848854541778564 0 -0.99848848581314087 0.054962530732154846 0 32013.dat 1 4 39.994400024414063 -309.75656127929687 827.672607421875 1.0852764717128593E-005 0 -1 -0.054959982633590698 0.99848854541778564 0 0.99848854541778564 0.054959982633590698 1.0862701856240164E-005 32034.dat 1 4 -0.0059210709296166897 -308.65780639648438 807.704345703125 0 1.1233763871132396E-005 -1 -0.99848854541778564 -0.054960474371910095 0 -0.0549604631960392 0.99848854541778564 1.1233078112127259E-005 32278.dat 1 1 -100.00586700439453 -307.55850219726562 787.735595703125 -1.1018770237569697E-005 0 1 0.054962102323770523 0.99848848581314087 0 -0.99848848581314087 0.054962102323770523 -1.1018258192052599E-005 6558.dat 1 4 -80.005897521972656 -307.55877685546875 787.7354736328125 0 1.1168608580192085E-005 -1.0000001192092896 -0.99848842620849609 -0.054963797330856323 0 -0.054963894188404083 0.99848842620849609 1.1270135473750997E-005 32523.dat 1 1 19.993877410888672 -307.55853271484375 787.73443603515625 -1.1018974873877596E-005 0 1 0.054962094873189926 0.99848848581314087 0 -0.99848848581314087 0.054962094873189926 -1.1018462828360498E-005 6558.dat 1 4 -0.0061183013021945953 -307.55856323242187 787.73468017578125 0 1.1168608580192085E-005 -1.0000001192092896 -0.99848842620849609 -0.054963797330856323 0 -0.054963894188404083 0.99848842620849609 1.1270135473750997E-005 32523.dat 1 1 -20.006132125854492 -307.55850219726562 787.73486328125 -1.1018974873877596E-005 0 1 0.054962098598480225 0.99848848581314087 0 -0.99848848581314087 0.054962098598480225 -1.1018258192052599E-005 6558.dat 1 1 59.993888854980469 -307.5584716796875 787.7337646484375 -1.1018770237569697E-005 0 1 0.054962102323770523 0.99848848581314087 0 -0.99848848581314087 0.054962102323770523 -1.1018258192052599E-005 6558.dat 1 4 79.993904113769531 -307.55850219726562 787.7337646484375 0 1.1168608580192085E-005 -1.0000001192092896 -0.99848842620849609 -0.054963797330856323 0 -0.054963894188404083 0.99848842620849609 1.1270135473750997E-005 32523.dat 1 1 99.993896484375 -307.55850219726562 787.7333984375 -1.1018974873877596E-005 0 1 0.054962098598480225 0.99848848581314087 0 -0.99848848581314087 0.054962098598480225 -1.1018258192052599E-005 6558.dat 1 0 139.9940185546875 -309.20693969726562 817.68768310546875 0 0 0.99999994039535522 0.054941784590482712 0.99848949909210205 0 -0.99848955869674683 0.054941784590482712 0 2780.dat 1 1 -60.005855560302734 -307.55865478515625 787.7352294921875 -1.1037033800675999E-005 0 1 0.054957110434770584 0.99848860502243042 0 -0.9984886646270752 0.054957110434770584 -1.1036112482543103E-005 6558.dat 1 4 -0.0063502243719995022 -306.45932006835937 767.7646484375 0 1.1233763871132396E-005 -1 -0.99848854541778564 -0.054960474371910095 0 -0.0549604631960392 0.99848854541778564 1.1233078112127259E-005 32278.dat 1 0 -40.006214141845703 -305.9100341796875 757.78021240234375 0 0 1 0.054941792041063309 0.99848949909210205 0 -0.99848955869674683 0.054941792041063309 0 2780.dat 1 71 197.5938720703125 -290.78390502929687 788.661376953125 0 -0.27999597787857056 0.96000117063522339 0.054942350834608078 0.95855110883712769 0.279572993516922 -0.99848949909210205 0.05274447426199913 0.015384480357170105 4519.dat 1 4 91.993804931640625 -271.61288452148437 789.712158203125 0.6000029444694519 0 0.79999786615371704 0.79878908395767212 -0.054952062666416168 -0.59909629821777344 0.043961863964796066 0.99848902225494385 -0.032970987260341644 32348.dat 1 71 91.994338989257813 -271.61260986328125 789.7154541015625 0 0.60000187158584595 0.79999864101409912 0.054947208613157272 0.7987900972366333 -0.59909534454345703 -0.99848926067352295 0.04395730048418045 -0.032968930900096893 4519.dat 1 0 91.99432373046875 -270.513916015625 769.7462158203125 -0.79999810457229614 0 -0.60000264644622803 0.59909605979919434 0.054950341582298279 -0.79878950119018555 0.032970167696475983 -0.99848926067352295 -0.043960008770227432 60483.dat 1 0 91.993934631347656 -272.71163940429688 809.6820068359375 -0.79999756813049316 0 -0.60000324249267578 0.59909677505493164 0.054950661957263947 -0.79878884553909302 0.032969925552606583 -0.9984891414642334 -0.043960753828287125 60483.dat 1 4 197.59391784667969 -289.41018676757812 763.69940185546875 0.27999392151832581 0 -0.96000182628631592 -0.95855212211608887 -0.054936151951551437 -0.27957099676132202 -0.052738547325134277 0.99848991632461548 -0.015382779762148857 6632.dat 1 4 197.59394836425781 -289.95953369140625 773.68408203125 0.27999392151832581 0 -0.96000182628631592 -0.95855212211608887 -0.054936151951551437 -0.27957099676132202 -0.052738547325134277 0.99848991632461548 -0.015382779762148857 6632.dat 1 4 197.59388732910156 -292.1572265625 813.61968994140625 0.2799936830997467 0 -0.96000194549560547 -0.95855224132537842 -0.054935865104198456 -0.27957072854042053 -0.052738271653652191 0.99848997592926025 -0.015382779762148857 6632.dat 1 4 197.59379577636719 -291.60781860351562 803.638916015625 0.27999380230903625 0 -0.96000200510025024 -0.95855230093002319 -0.054935865104198456 -0.27957078814506531 -0.052738312631845474 0.99849003553390503 -0.015382779762148857 6632.dat 1 71 159.19410705566406 -301.96612548828125 788.04638671875 0 -0.27999183535575867 0.96000242233276367 0.054924570024013519 0.9585532546043396 0.27956900000572205 -0.99849051237106323 0.052726715803146362 0.015381801873445511 32073.dat 1 4 159.19346618652344 -304.1630859375 827.98138427734375 -0.2799927294254303 0 -0.96000218391418457 0.95855313539505005 0.054923105984926224 -0.279570072889328 0.052725743502378464 -0.99849063158035278 -0.015379683114588261 41669.dat 1 4 159.19389343261719 -299.76901245117187 748.1063232421875 0.27998954057693481 0 -0.96000319719314575 -0.95855391025543213 -0.054927483201026917 -0.27956664562225342 -0.052730049937963486 0.99849045276641846 -0.015381074510514736 41669.dat 1 0 79.99462890625 -286.49603271484375 768.86279296875 0 1 0 0.054970856755971909 0 -0.99848800897598267 -0.99848800897598267 0 -0.054970819503068924 32054.dat 1 72 79.995010375976563 -288.68792724609375 808.803466796875 0 1.0000001192092896 0 0.054962389171123505 0 -0.99848848581314087 -0.99848848581314087 0 -0.054962307214736938 11214.dat 1 0 -80.004791259765625 -286.50222778320312 768.8619384765625 0 1.0000001192092896 0 0.054970700293779373 0 -0.99848812818527222 -0.99848812818527222 0 -0.054970577359199524 32054.dat 1 72 -80.0057373046875 -288.69515991210937 808.803466796875 0 1.0000001192092896 0 0.054962340742349625 0 -0.99848854541778564 -0.99848854541778564 0 -0.05496220663189888 11214.dat 1 1 178.39376831054687 -296.37570190429687 788.3494873046875 0 0 -1 -0.054946828633546829 0.99848926067352295 0 0.99848926067352295 0.054946828633546829 0 6558.dat 1 1 139.99407958984375 -306.459716796875 767.7640380859375 -1.1018974873877596E-005 0 1 0.054962098598480225 0.99848848581314087 0 -0.99848848581314087 0.054962098598480225 -1.1018258192052599E-005 6558.dat 1 0 39.99456787109375 -305.91555786132813 757.77899169921875 0 0 0.99999994039535522 0.054941784590482712 0.99848949909210205 0 -0.99848955869674683 0.054941784590482712 0 2780.dat 1 4 -40.006141662597656 -305.36276245117187 747.79595947265625 1.0848257261386607E-005 0 -1 -0.054959449917078018 0.99848854541778564 0 0.99848854541778564 0.054959449917078018 1.0838011803571135E-005 32034.dat 1 0 -89.986122131347656 -305.5797119140625 747.7576904296875 1 0 0 0 0.99848830699920654 -0.054964542388916016 0 0.054964542388916016 0.99848830699920654 3705.dat 1 4 -80.006179809570313 -285.3905029296875 748.89556884765625 -1 0 0 0 -0.99848824739456177 -0.054965328425168991 0 -0.054965328425168991 0.99848824739456177 32184.dat 1 4 -139.98611450195312 -305.58010864257812 747.7576904296875 0 0 -1 -0.054964948445558548 0.99848830699920654 0 0.99848830699920654 0.054964948445558548 0 32013.dat 1 4 -100.00608825683594 -305.36270141601563 747.79638671875 1.192931358673377E-005 0 -1.0000001192092896 0.054982040077447891 -0.99848735332489014 0 -0.99848747253417969 -0.054982040077447891 -1.1828026799776126E-005 6590.dat 1 71 -0.0053197145462036133 -305.36862182617187 747.7943115234375 1 0 1.0810617823153734E-005 0 0.9984891414642334 -0.054949380457401276 -1.0811091669893358E-005 0.054949380457401276 0.9984891414642334 4519.dat 1 4 99.994674682617188 -305.36865234375 747.79364013671875 1.1760820598283317E-005 0 -1 0.054980956017971039 -0.99848741292953491 0 -0.99848741292953491 -0.054980956017971039 -1.1828026799776126E-005 6590.dat 1 0 89.994705200195313 -305.36810302734375 747.79296875 1 0 0 0 0.99848830699920654 -0.054964542388916016 0 0.054964542388916016 0.99848830699920654 3705.dat 1 4 39.994686126708984 -305.36865234375 747.7939453125 1.0730366739153396E-005 0 -1 -0.054959505796432495 0.9984886646270752 0 0.99848860502243042 0.054959505796432495 1.0720326827140525E-005 32034.dat 1 4 139.99371337890625 -305.36285400390625 747.7945556640625 0 0 1.0000001192092896 0.0549650639295578 0.99848842620849609 0 -0.99848836660385132 0.0549650639295578 0 32013.dat 1 4 79.994674682617188 -285.3966064453125 748.89312744140625 -1 0 0 0 -0.99848824739456177 -0.054965339601039886 0 -0.054965339601039886 0.99848824739456177 32184.dat 1 4 -0.0053785741329193115 -305.36862182617187 747.79449462890625 0 0 -1.0000001192092896 0.054952289909124374 -0.99848896265029907 0 -0.99848908185958862 -0.054952289909124374 0 6590.dat 1 1 -69.985610961914062 -265.65655517578125 749.95672607421875 -1 0 0 0 -0.054963346570730209 0.99848842620849609 0 0.99848842620849609 0.054963469505310059 43093.dat 1 1 69.994529724121094 -265.42672729492187 749.9949951171875 1 0 0 0 0.054965037852525711 0.99848830699920654 0 -0.99848830699920654 0.054965037852525711 43093.dat 1 1 -139.98579406738281 -306.6771240234375 767.72723388671875 -1.1018974873877596E-005 0 1 0.054962098598480225 0.99848848581314087 0 -0.99848848581314087 0.054962098598480225 -1.1018258192052599E-005 6558.dat 1 4 -197.58750915527344 -289.6279296875 763.65869140625 -0.27999618649482727 0 0.96000117063522339 -0.95855116844177246 0.054941337555646896 -0.27957335114479065 -0.052743677049875259 -0.9984896183013916 -0.015383251942694187 6632.dat 1 71 -159.18724060058594 -302.18511962890625 788.00494384765625 0 0.27999243140220642 -0.96000224351882935 -0.054938320070505142 0.95855236053466797 0.27956956624984741 0.99848973751068115 0.052740789949893951 0.015382733196020126 32073.dat 1 4 -197.58732604980469 -291.82559204101562 803.59771728515625 -0.27999550104141235 0 0.96000140905380249 -0.95855140686035156 0.054941296577453613 -0.27957272529602051 -0.052743609994649887 -0.99848973751068115 -0.015383027493953705 6632.dat 1 4 -197.58723449707031 -292.37490844726562 813.5826416015625 -0.27999567985534668 0 0.96000128984451294 -0.95855128765106201 0.054941296577453613 -0.27957281470298767 -0.052743725478649139 -0.9984896183013916 -0.015383027493953705 6632.dat 1 4 -197.58734130859375 -290.17721557617187 773.64361572265625 -0.2799961268901825 0 0.96000111103057861 -0.95855116844177246 0.054941087961196899 -0.27957326173782349 -0.052743509411811829 -0.9984896183013916 -0.015383133664727211 6632.dat 1 71 -197.5863037109375 -291.00128173828125 788.62066650390625 0 0.27999722957611084 0.96000087261199951 0.05494256317615509 0.95855087041854858 -0.27957427501678467 -0.9984896183013916 0.05274488776922226 -0.01538380328565836 4519.dat 1 71 -91.987297058105469 -271.83120727539062 789.67578125 0 0.79999846220016479 0.60000205039978027 0.05494718998670578 0.59909570217132568 -0.7987898588180542 -0.99848926067352295 0.032967600971460342 -0.043958257883787155 4519.dat 1 0 -92.007484436035156 -270.52093505859375 769.743896484375 0.7999994158744812 1.1468586308183149E-005 0.60000073909759521 0.59909427165985107 -0.05496201291680336 -0.79878979921340942 0.032968081533908844 0.99848842620849609 -0.043976452201604843 60483.dat 1 4 -91.986274719238281 -271.83062744140625 789.67535400390625 -0.60000115633010864 0 -0.7999991774559021 0.79879045486450195 0.054950147867202759 -0.5990946888923645 0.043959930539131165 -0.99848920106887817 -0.032970152795314789 32348.dat 1 0 -92.007057189941406 -272.719482421875 809.6839599609375 0.7999994158744812 1.168986000266159E-005 0.60000103712081909 0.59909462928771973 -0.054961834102869034 -0.79878968000411987 0.032967880368232727 0.99848854541778564 -0.04397641122341156 60483.dat 1 4 -159.18734741210937 -304.3828125 827.944580078125 -0.27999252080917358 0 0.96000212430953979 -0.95855206251144409 0.054942488670349121 -0.27956956624984741 -0.05274498462677002 -0.99848943948745728 -0.015383394435048103 41669.dat 1 4 -159.1875 -299.98764038085937 748.06591796875 0.27999135851860046 0 0.96000266075134277 0.95855247974395752 -0.054944887757301331 -0.27956822514533997 0.052747245877981186 0.99848949909210205 -0.015384428203105927 41669.dat 1 1 -178.38626098632812 -296.59320068359375 788.31268310546875 0 0 -1.0000001192092896 -0.054945137351751328 0.99848949909210205 0 0.99848943948745728 0.054945137351751328 0 6558.dat 1 0 -100.00858306884766 -264.33306884765625 730.03057861328125 0 -1 0 1 0 0 0 0 0.99999994039535522 15100.dat 1 0 -80.005302429199219 -244.33132934570312 730.02398681640625 -1 0 0 0 0 -1 0 -1 0 44809.dat 1 0 240.0909423828125 -224.31852722167969 470.04180908203125 -1 1.459088616684312E-005 0 1.4598162124457303E-005 0.99653679132461548 0.083156131207942963 0 0.083156131207942963 -0.99653655290603638 15100.dat 1 0 240.0908203125 -234.28347778320312 469.20486450195313 0 0.99999988079071045 -0.00052272854372859001 -0.99651420116424561 -4.364505730336532E-005 -0.083423495292663574 -0.083423502743244171 0.00052090641111135483 0.99651402235031128 2780.dat 1 4 179.45863342285156 -257.497314453125 626.6365966796875 -0.35666638612747192 0 -0.93423193693161011 -0.077934511005878448 0.99651479721069336 0.029749399051070213 0.93097555637359619 0.08341950923204422 -0.35542353987693787 32062.dat 1 0 172.3251953125 -259.05679321289062 645.25604248046875 -0.93423241376876831 0 0.35666486620903015 0.029741976410150528 0.9965166449546814 0.07791147381067276 -0.35542261600494385 0.083395346999168396 -0.93097794055938721 59443.dat 1 4 165.19190979003906 -260.61541748046875 663.8758544921875 -0.35666495561599731 0 -0.93423241376876831 -0.077934399247169495 0.99651467800140381 0.029749182984232903 0.93097603321075439 0.083419330418109894 -0.35542210936546326 32062.dat 1 0 158.05857849121094 -262.1739501953125 682.49530029296875 -0.93423247337341309 0 0.35666462779045105 0.029741881415247917 0.99651658535003662 0.077911451458930969 -0.35542237758636475 0.083395287394523621 -0.93097805976867676 59443.dat 1 4 150.92434692382812 -263.73171997070312 701.1148681640625 -0.35666647553443909 0 -0.93423181772232056 -0.077929407358169556 0.99651491641998291 0.029748419299721718 0.93097585439682007 0.08341439813375473 -0.3554236888885498 32062.dat 1 0 140.22456359863281 -266.06936645507812 729.043701171875 3.2072479370981455E-005 0.93423283100128174 -0.35666376352310181 -0.99651634693145752 -0.029715171083807945 -0.07792450487613678 -0.083397969603538513 0.35542374849319458 0.93097734451293945 32013.dat 1 0 190.15777587890625 -255.15924072265625 598.70684814453125 0 -0.93423205614089966 -0.35666587948799133 0.99651491641998291 0.02974800206720829 -0.077930554747581482 0.083415292203426361 -0.35542312264442444 0.93097609281539917 32034.dat 1 0 240.09103393554687 -244.24870300292969 468.37066650390625 -1.4925498362572398E-005 -0.93422722816467285 0.35667821764945984 -0.99651235342025757 0.029776778072118759 0.077951215207576752 -0.083444900810718536 -0.35543310642242432 -0.93096953630447388 32013.dat 1 4 229.39109802246094 -246.58685302734375 496.29983520507812 0.35666659474372864 0 0.93423175811767578 0.07793041318655014 0.99651491641998291 -0.029747653752565384 -0.93097573518753052 0.083415061235427856 0.35542386770248413 32062.dat 1 0 222.25770568847656 -248.14627075195312 514.91839599609375 0.93423253297805786 0 -0.35666459798812866 -0.029748212546110153 0.99651479721069336 -0.077931731939315796 0.35542184114456177 0.083416491746902466 0.93097639083862305 59443.dat 1 4 215.12434387207031 -249.70402526855469 533.5389404296875 0.35666686296463013 0 0.93423175811767578 0.077926896512508392 0.99651527404785156 -0.029747271910309792 -0.93097603321075439 0.083411641418933868 0.3554241955280304 32062.dat 1 0 207.99116516113281 -251.2626953125 552.15814208984375 0.93423187732696533 0 -0.35666632652282715 -0.029748346656560898 0.99651479721069336 -0.077931672334671021 0.35542353987693787 0.083416484296321869 0.93097573518753052 59443.dat 1 4 200.8577880859375 -252.82127380371094 570.7777099609375 0.35666653513908386 0 0.93423187732696533 0.077926881611347198 0.99651533365249634 -0.029747135937213898 -0.93097615242004395 0.083411574363708496 0.35542386770248413 32062.dat 1 0 -240.00537109375 -224.33140563964844 470.02447509765625 1 0 0 0 -0.99662297964096069 0.082113601267337799 0 -0.082113601267337799 -0.99662297964096069 15100.dat 1 0 -240.00523376464844 -234.296630859375 469.19122314453125 0 0.93441200256347656 -0.35619428753852844 0.99657279253005981 0.029465027153491974 0.077296100556850433 0.08272165060043335 -0.35497349500656128 -0.93120944499969482 2780.dat 1 0 140.20478820800781 -256.1044921875 729.87591552734375 0 -1 0 -0.99651521444320679 0 0.083411797881126404 -0.083411797881126404 0 -0.99651515483856201 2780.dat 1 1 130.01438903808594 -244.41983032226562 710.59893798828125 0.99999994039535522 0 0 0 -0.083412937819957733 -0.99651509523391724 0 0.99651509523391724 -0.083412937819957733 43093.dat 1 4 140.20480346679687 -246.13934326171875 730.7099609375 -1 0 0 0 -0.083409182727336884 0.99651539325714111 0 0.99651539325714111 0.083409197628498077 42003.dat 1 0 -172.23971557617187 -258.94583129882812 645.2596435546875 -0.93423134088516235 0 -0.35666757822036743 -0.029516741633415222 0.99657076597213745 0.077303074300289154 0.35544413328170776 0.082746624946594238 -0.93102765083312988 59443.dat 1 4 -165.10636901855469 -260.49154663085937 663.8800048828125 0.35666742920875549 0 -0.9342314600944519 -0.077284425497055054 0.99657231569290161 -0.029509792104363441 0.93102931976318359 0.082726716995239258 0.35544455051422119 32062.dat 1 0 -157.97293090820312 -262.03689575195312 682.50091552734375 -0.9342314600944519 0 -0.35666736960411072 -0.029516557231545448 0.99657076597213745 0.077303133904933929 0.35544392466545105 0.082746610045433044 -0.93102771043777466 59443.dat 1 0 -140.13858032226562 -265.90069580078125 729.05242919921875 4.104873733012937E-005 0.93423134088516235 0.35666775703430176 -0.99657237529754639 0.029543913900852203 -0.077270641922950745 -0.082725986838340759 -0.35544204711914063 0.93103039264678955 32013.dat 1 4 -150.83952331542969 -263.58255004882812 701.12127685546875 0.35666739940643311 0 -0.9342314600944519 -0.077280953526496887 0.99657267332077026 -0.029509324580430984 0.93102961778640747 0.082723312079906464 0.35544455051422119 32062.dat 1 4 -179.37283325195312 -257.400146484375 626.63897705078125 0.35666754841804504 0 -0.9342314600944519 -0.077284380793571472 0.99657243490219116 -0.029509760439395905 0.93102931976318359 0.082726664841175079 0.35544466972351074 32062.dat 1 0 -190.07182312011719 -255.08175659179687 598.70782470703125 0 -0.93423157930374146 0.35666713118553162 0.99657261371612549 -0.02950860932469368 -0.0772814080119133 0.082723468542098999 0.35544434189796448 0.93102961778640747 32034.dat 1 4 -200.7718505859375 -252.76336669921875 570.77685546875 -0.35666775703430176 0 0.93423134088516235 0.077275082468986511 0.99657338857650757 0.029506618157029152 -0.93102997541427612 0.082716859877109528 -0.35544514656066895 32062.dat 1 4 -229.30548095703125 -246.58119201660156 496.29458618164062 -0.35666477680206299 0 0.93423241376876831 0.077280305325984955 0.99657273292541504 0.029507461935281754 -0.93103063106536865 0.08272203803062439 -0.35544207692146301 32062.dat 1 0 -240.00532531738281 -244.26228332519531 468.36361694335937 0 -0.93422079086303711 -0.3566957414150238 -0.99657481908798218 -0.029494600370526314 0.077259466052055359 -0.082698039710521698 0.35547423362731934 -0.93102043867111206 32013.dat 1 0 -222.17204284667969 -248.12643432617187 514.91522216796875 0.93423205614089966 0 0.35666581988334656 0.029508698731660843 0.99657243490219116 -0.077282503247261047 -0.35544303059577942 0.082724533975124359 0.9310300350189209 59443.dat 1 4 -215.03865051269531 -249.67205810546875 533.53564453125 -0.35666751861572266 0 0.9342314600944519 0.077275097370147705 0.99657338857650757 0.02950655110180378 -0.93103009462356567 0.082716844975948334 -0.35544490814208984 32062.dat 1 0 -207.90522766113281 -251.21769714355469 552.15631103515625 0.93423134088516235 0 0.35666775703430176 0.029508829116821289 0.99657249450683594 -0.077282324433326721 -0.35544493794441223 0.082724414765834808 0.93102931976318359 59443.dat 1 0 99.994743347167969 -264.33132934570312 730.0240478515625 0 1 0 1 0 0 0 0 -1 15100.dat 1 0 79.994743347167969 -244.33132934570312 730.0240478515625 0 0 -1.0000001192092896 1.0000001192092896 0 0 0 -1.0000001192092896 0 44809.dat 1 1 39.993698120117188 -244.33132934570312 720.02410888671875 0 -1.0000001192092896 0 0 0 -1.0000001192092896 1.0000001192092896 0 0 43093.dat 1 0 39.993701934814453 -244.33132934570312 730.02410888671875 0 0 -1 0 -1 0 -1 0 0 6536.dat 1 0 275.4183349609375 -101.83232879638672 -49.972652435302734 0 0 -1 0 0.99999994039535522 0 1 0 0 2902.dat 1 0 239.15505981445312 -102.13564300537109 709.98663330078125 0 0 -1 0 0.99999994039535522 0 1 0 0 2902.dat 1 15 0.0074560223147273064 -72.203361511230469 162.01039123535156 -1 0 0 0 0 1.0000001192092896 0 1.0000001192092896 0 85543.dat 1 0 239.41903686523437 -101.83230590820312 -49.972461700439453 0 0 -1 0 0.99999994039535522 0 1 0 0 2902.dat 1 0 -203.40219116210937 -101.83338928222656 -49.97503662109375 0 0 1 0 0.99999994039535522 0 -1 0 0 2902.dat 1 0 119.98865509033203 -213.17185974121094 208.20069885253906 -1 0 0 0 0.2799929678440094 -0.96000200510025024 0 -0.96000200510025024 -0.27999308705329895 2741.dat 1 72 40.014667510986328 -122.38368988037109 570.0885009765625 -1 0 0 0 1 0 0 0 -1 18947.dat 1 0 237.19635009765625 -102.08225250244141 -49.972747802734375 0 0 -1 0 0.99999994039535522 0 1 0 0 50951.dat 1 71 119.98884582519531 -189.9329833984375 128.52052307128906 1 0 0 0 0.96000021696090698 -0.2799992561340332 0 0.2799992561340332 0.96000021696090698 32123a.dat 1 15 8.0147809982299805 -124.61505889892578 396.13836669921875 0 -1.0000001192092896 0 -1.0000001192092896 0 0 0 0 -1 85543.dat 1 0 275.15512084960937 -102.13567352294922 709.98663330078125 0 0 -1 0 0.99999994039535522 0 1 0 0 2902.dat 1 0 -275.40213012695312 -101.83343505859375 -49.974655151367188 0 0 1 0 0.99999994039535522 0 -1 0 0 2902.dat 1 0 261.41851806640625 -101.83228302001953 -49.972652435302734 0 0 -1 0 0.99999994039535522 0 1 0 0 58088.dat 1 0 261.15533447265625 -102.1356201171875 709.98663330078125 0 0 -1 0 0.99999994039535522 0 1 0 0 58088.dat 1 0 -261.12118530273437 -102.13474273681641 710.01226806640625 0 0 1 0 0.99999994039535522 0 -1 0 0 58088.dat 1 0 -239.40225219726562 -101.83341217041016 -49.97503662109375 0 0 1 0 0.99999994039535522 0 -1 0 0 2902.dat 1 15 0.058531597256660461 -72.500213623046875 418.01382446289062 0.99999994039535522 0 0 0 0 1 0 -1 0 85543.dat 1 0 -203.12123107910156 -102.13472747802734 710.01226806640625 0 0 1 0 0.99999994039535522 0 -1 0 0 2902.dat 1 0 -237.17974853515625 -102.0833740234375 -49.974655151367188 0 0 1 0 0.99999994039535522 0 -1 0 0 50951.dat 1 1 -59.976100921630859 -203.86981201171875 770.04998779296875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 6558.dat 1 71 0.023823976516723633 -243.86982727050781 770.05010986328125 -1 0 0 0 1 0 0 0 -1 4519.dat 1 71 -4.9761009216308594 -243.86982727050781 770.05010986328125 0 0 1 0 0.99999994039535522 0 -1 0 0 32123a.dat 1 0 -24.976177215576172 -223.86982727050781 770.05010986328125 0 1 0 0 0 -1 -1 0 0 41677.dat 1 71 -14.976139068603516 -243.86982727050781 770.05010986328125 0 0 1 0 0.99999994039535522 0 -1 0 0 32123a.dat 1 71 15.023880004882812 -243.86982727050781 770.05010986328125 0 0 1 0 0.99999994039535522 0 -1 0 0 32123a.dat 1 71 5.0238418579101563 -243.86982727050781 770.05010986328125 0 0 1 0 0.99999994039535522 0 -1 0 0 32123a.dat 1 0 25.023862838745117 -223.86982727050781 770.05010986328125 0 -1 0 0 0 -1 1 0 0 41677.dat 1 0 -59.976203918457031 -203.869873046875 770.050048828125 1 0 0 0 1 0 0 0 1 42003.dat 1 71 0.023859739303588867 -223.86982727050781 770.0499267578125 -1 0 0 0 1 0 0 0 -1 44294.dat 1 0 60.023777008056641 -203.86979675292969 770.04998779296875 1 0 0 0 1 0 0 0 1 42003.dat 1 0 -59.9761962890625 -183.86984252929687 790.05010986328125 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 71 -59.976207733154297 -183.86984252929687 770.05010986328125 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 -59.9761962890625 -183.86982727050781 750.050048828125 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 0 60.023784637451172 -183.86982727050781 750.050048828125 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 71 60.023773193359375 -183.86984252929687 770.0501708984375 0 0 1 0 1 0 -1 0 0 4519.dat 1 0 60.023784637451172 -183.86984252929687 790.05010986328125 0.99999994039535522 0 0 0 0 -1 0 1 0 60483.dat 1 1 60.023784637451172 -203.86981201171875 770.04998779296875 0 1.0000001192092896 0 0 0 1.0000001192092896 1.0000001192092896 0 0 6558.dat 1 0 -39.976215362548828 -223.86982727050781 770.03546142578125 0 -0.99999994039535522 0 0 0 0.99999994039535522 -0.99999994039535522 0 0 87082.dat 1 0 0.023883581161499023 -183.86982727050781 810.064208984375 0 0 -1 0 0.99999994039535522 0 1 0 0 24119.dat 1 0 0.023800134658813477 -183.86982727050781 730.06451416015625 0 0 1 0 0.99999994039535522 0 -1 0 0 24119.dat 1 0 40.0238037109375 -223.86982727050781 770.06451416015625 0 1 0 0 0 1 1 0 0 87082.dat Quote
Didumos69 Posted May 18, 2017 Author Posted May 18, 2017 3 hours ago, LvdH said: This car has been growing on me. I've been looking into the parts list and I'm not missing much. Thanks for the instructions! Since red is so common, I will try yellow . Seems possible except for 10x 1x2 thin liftarm, but I think I can work around those. Would be cool, but also(11946) and(11947) are not available in yellow. You could also make it mainly black and work with yellow accents. 1 hour ago, davebarrett said: Bricks and Pieces order is in. @Didumos69 Why did you go with black 3L pins instead of blue? This seems to be a frequent occurrence with MOCs, and I'm a bit worried that with the more common blue pins it'll look quite different. I know the availability of black 3L pins is decreasing. This is why I only used black ones in the body (113) and blue ones for the chassis (141). This is what it would look like with all blue 3L pins (forgive me about the motorcycle tires). Especially in the bumpers black pins look much better: Quote
JJ2 Posted May 18, 2017 Posted May 18, 2017 I think I might build this MOC, I'm mostly missing cheap liftarms but I'm missing 18 dogbones Quote
agrof Posted May 18, 2017 Posted May 18, 2017 (edited) 33 minutes ago, LvdH said: Yep, I found that out quickly. Although they do exist in orange, which is close enough for me! If You can wait a bit more, than the new 60158 set might bring a solution for You (I am not sure if it is the same yellow, but looks minifig yellow): Hint: old Bionicle sets are full with black 3L pins, I bought 6-7 years ago ~9 kg Bionicle for cheap, and still live from it... many useless pieces, but tons of good one. Edited May 18, 2017 by agrof Quote
davebarrett Posted May 18, 2017 Posted May 18, 2017 (edited) On 5/18/2017 at 3:50 PM, agrof said: If You can wait a bit more, than the new 60158 set might bring a solution for You (I am not sure if it is the same yellow, but looks minifig yellow): Looks like flame orange, not yellow unfortunately. Edited May 23, 2017 by Milan Please don't quote images from the same page Quote
proran Posted May 18, 2017 Posted May 18, 2017 23 hours ago, Blakbird said: Glad to see these instructions in the hands of the public so everyone gets a chance to build this great car. I can't deny that a big part of the reason I volunteered to help with this project was selfish: I wanted to build it! I was not disappointed. I've built a LOT of Technic supercars and I can easily say this is one of my favorite. I think I can safely say it has the smoothest gear system I've ever seen. The durability is also really impressive. There won't be any parts falling off when you handle this model. Dear @Blakbird, can we expect the MOC review from you? I remember you mentioned that a couple of pages back, just wanted to let you know, there is least one more guy hoping for that . For me it is the one and only supercar MOC I would build, but I am still not sure I can afford it right now. Your MOC reviews is, probably, the best I can get. Quote
Didumos69 Posted May 18, 2017 Author Posted May 18, 2017 (edited) 40 minutes ago, agrof said: If You can wait a bit more, than the new 60158 set might bring a solution for You (I am not sure if it is the same yellow, but looks minifig yellow): 17 minutes ago, davebarrett said: Looks like flame orange, not yellow unfortunately. I thought it was flame orange too, but after seeing this image - taken by daylight - I am hopeful (source). If these small panels are yellow, I will definitely build a yellow version myself! Edited May 18, 2017 by Didumos69 Quote
Didumos69 Posted May 18, 2017 Author Posted May 18, 2017 (edited) 1 hour ago, JJ2 said: I think I might build this MOC, I'm mostly missing cheap liftarms but I'm missing 18 dogbones Great! How can you live with only 4 dogbones !? It seems like mass-production has started ... Edited May 18, 2017 by Didumos69 Quote
JJ2 Posted May 18, 2017 Posted May 18, 2017 5 hours ago, Didumos69 said: Great! How can you live with only 4 dogbones !? It seems like mass-production has started ... I don't know, I guess I just have never ordered more of them, they seem like a really useful piece Quote
muffinbrick Posted May 18, 2017 Posted May 18, 2017 You only need to buy 2 Claases for those 18 missing dogbones ;) Quote
Didumos69 Posted May 19, 2017 Author Posted May 19, 2017 9 hours ago, JJ2 said: I don't know, I guess I just have never ordered more of them, they seem like a really useful piece I use them a lot to square things. They are usually more easy to fit in than a complete 5×7 frame. Quote
Didumos69 Posted May 19, 2017 Author Posted May 19, 2017 6 hours ago, Didumos69 said: I use them a lot to square things. They are usually more easy to fit in than a complete 5×7 frame. I made some cutaways showing the complete chassis structure. Now you can see where the 22 dog-bones go . Quote
Erik Leppen Posted May 19, 2017 Posted May 19, 2017 I love how you guys just made the instructions available for free. It looks like a model I'd like to try to build. I'm curious to cheking out the solidity of everything in real life. I like the extensive use of Pythagoras 3-4-5 angles. Problem: I'm missing a few essential parts. Eight, at least (four tyres and four rims). Do there happen to be other rims/tyres that fit as well? Or do I really need the porsche rims (which I don't have)? For examle, would the tyres from the funny car 42050 fit? Or do you use all the space inside the deep rims of the Porsche? Quote
BusterHaus Posted May 19, 2017 Posted May 19, 2017 (edited) 35 minutes ago, Erik Leppen said: Or do you use all the space inside the deep rims of the Porsche? The offset on the Porsche rims is very different from the closest-sized rim 44772. The wheels stick out like a sore thumb and will probably rub against the body when turned. Their inside diameter also interferes with the brake pads. Edit: I didn't bother buying the Porsche set but I bought its wheels for this build. They are not cheap but are now one of my favorite wheels because of the deep offset. I can see them being very useful on other builds. Edited May 19, 2017 by BusterHaus Quote
Didumos69 Posted May 19, 2017 Author Posted May 19, 2017 46 minutes ago, Erik Leppen said: I love how you guys just made the instructions available for free. It looks like a model I'd like to try to build. I'm curious to cheking out the solidity of everything in real life. I like the extensive use of Pythagoras 3-4-5 angles. Problem: I'm missing a few essential parts. Eight, at least (four tyres and four rims). Do there happen to be other rims/tyres that fit as well? Or do I really need the porsche rims (which I don't have)? For examle, would the tyres from the funny car 42050 fit? Or do you use all the space inside the deep rims of the Porsche? Thanks for your interest! 24 minutes ago, BusterHaus said: The offset on the Porsche rims is very different from the closest-sized rim 44772. The wheels stick out like a sore thumb and will probably rub against the body when turned. Their inside diameter also interferes with the brake pads. What he said. To avoid the rub you would have to use the thinnest tires, which would bring the whole model 1 stud down, which would drop the point of having 2 stud suspension travel. The brake pads could be made smaller, but the inside diameter of the closest-sized rim will probably also interfere with the anti-roll links in turns. I know the Porsche tires and rims are expensive, but maybe worthwhile as a long-term investment. For future builds, I mean. 35 minutes ago, BusterHaus said: They are not cheap but are now one of my favorite wheels because of the deep offset. I can see them being very useful on other builds. What he said. Quote
Didumos69 Posted May 19, 2017 Author Posted May 19, 2017 On 5/18/2017 at 4:15 PM, proran said: Dear @Blakbird, can we expect the MOC review from you? I remember you mentioned that a couple of pages back, just wanted to let you know, there is least one more guy hoping for that . For me it is the one and only supercar MOC I would build, but I am still not sure I can afford it right now. Your MOC reviews is, probably, the best I can get. I think @Blakbird is taking a well-deserved break . When you're in doubt you could also choose to build the chassis only and then decide whether you want to build the body too. The chassis-only version of the instructions has its own entry on Rebrickable. Quote
Blakbird Posted May 19, 2017 Posted May 19, 2017 I may do a review eventually, but at this point it is already built so I can't take build photos. I've given my overall impressions earlier in this thread. Is good car. Build it. Quote
PorkyMonster Posted May 20, 2017 Posted May 20, 2017 (edited) Just finished part 1 Spent 16 hours... Now I need to Zzz Zzzz before doing part 2 . Been a very eye-opening experience building this model... many parts were form locked properly in place, making the end result virtually indestructible, which also means it could be a major headache if there is ever a need to dismantle it. But two parts caught my attention though - (1) the two rubber-banded ends of the gear-switching mechanism - they're in-symmetrical and I don't quite like the way the ends bend when extended, and (2) the UL that attaches to the 12t half-bevel gear might pull the 3L axle out. Instruction wise, no step missing, but a number of them require cross-referencing the lxf file (e.g. steps 8 and 100), and most of them require intense staring at the screen to figure out where to put in the new pieces (but of course, nobody told me to use a 10-inch screen ), due to the viewing angle and colour. However these are rather minor issues compared to the effort put in to create the instructions in the first place! PS. I'll build a white, extremely limited edition RIGHT-HAND DRIVE version... LOL Edited May 20, 2017 by PorkyMonster Quote
Didumos69 Posted May 20, 2017 Author Posted May 20, 2017 (edited) Thanks for your report and feedback @PorkyMonster! And great to know that you're building this! Could you post some photo's 2 hours ago, PorkyMonster said: (1) the two rubber-banded ends of the gear-switching mechanism - they're in-symmetrical and I don't quite like the way the ends bend when extended, and I wasn't too happy about the in-symmetrical setup here either. The axles bend a little when extended, but the bushes holding the silicon bands don't have much space and won't allow much bending. I added the return-to-center mechanism as a last feature and it was either this or no such mechanism at all. The latter would mean you have to return the shift lever yourself after every shift, which also gives a nice feel of the shifting mechanism itself. You could try that by removing the ends where the silicon bands attach to. I decided to put the return-to-center in, because there is only very little bending despite in-symmetrical setup and it works and that was quite a thrill by itself, as it all comes very precise. 2 hours ago, PorkyMonster said: 2) the UL that attaches to the 12t half-bevel gear might pull the 3L axle out. You mean one of the universal joints that connect to the steering wheel? Eventually you will probably be handling the car using the HoG and the steering wheel will follow your operations. The steering wheel will be hard to reach and the u-joints give the steering wheel more play compared to the HoG. Despite that, I do use the steering wheel quite a lot and sofar it did not pull the axle out of the 12 half-bevel gear. I will note the minor issues with the instructions. Especially step 100 is hard to see I think. Perhaps we can improve on this. But apart from these things, what is your impression, how does the whole shifing mechanism feel? Edited May 20, 2017 by Didumos69 Quote
