Here’s my new little MOC:
I wanted a small MOC, using the container truck 42024 wheels. But I also wanted that the vehicle was not been done a lot. So I chose the reach stacker, not very famous.
And TLC steal my idea
I wanted a quite good design, "better than reality". (the real vehicle is not very nice ^^) I think the style of the real model is here. :classic:
Functions are :
  • Steering
  • 3 cylinders fake engine
  • Lifting arm
  • Extending arm
  • Clamp, to catch the container
Steering is very simple. A "rack" is activated by a crank.
Fake engine is activated by only one wheel.  (not enough space to put a differential).
The arm is controlled by 2 LA. You can torn the 2 sides of the axle, soi t’s easier to move the arm.
The arm extension is very simple: there s just a 8t on a rack. It is braked by an other 8t with a pin with friction.
It can be extended quite far.
To catch the container, a clamp is closed on it.
Do you know what element was the more difficult to do? The container! It was difficult to find the limit between weight and full design. :laugh:
I’m working on building instructions. I took screenshots on LDD and I’m assembling they on Photoshop. I though this idea would have been faster than a specialized software, but I’m not sure now. ^^'
I don’t know when they will be finished.
10 hours ago, legosamigos said:
I think that the gripper should be rotated as extra function :wink:
Second that. Very nice little model you've got there, like the simple functionality of it. Don't know if I would want to build it, I like to build the bigger ones out there. But it is very good.
That's a really nice little model!  The clamp mechanism is particularly interesting.
It looks like a huge amount of work to make instructions this way.  You might want to look into LDraw+LPub - I think that ends up more efficient after the initial learning curve.
A bit on the small side for my personal taste, but cool little model anyways.
Thanks for the comments!
I didn't add the rotation of the clamp because I think it's not very useful on this model, and it's very difficult to insert (not enough space and too heavy: the stacker will be going to fall).
It was the objective. A simple little MOC. :classic:
Very nice little MOC, clean design and functions.
I second that instructions this way seems to be a lot of work. LDraw and LPub would be faster, although there is a learning curve the first time, but worth it.
Stud.io could be another interesting option once it is released (beta is promising)
Yes, so I didn't finished with my idea, I just assembled the screenshots on a PDF file. That is less good, but don't want to spend more time on this MOC. :hmpf_bad:
http://rebrickable.com/mocs/Anto/reach-stacker
Edited by Anto
Thanks a lot anyway, it's great that you took the time to share the instructions already. It is a lot of work to put together.
I saw your MOC on Rebrickable today and had a look at the PDF, the pictures are very clear and it looks good :thumbup:
