Posted December 4, 20168 yr Hello, I have been recently wondering "How can I make fast air with my pneumatic pumps" I have built a fully functioning, belt driven system which turns the pump at a hell of a speed already, it can go even faster by adding a smaller pulley, but I didn't incase the pump got caught up and snapped. I was filling my air tank up with it, the pressure got so good the pipe popped off the air tank, it filled within 3 seconds, with a small grey pump. I have produced this setup out of a powerful RC motor and meccano and a thick belt and 2 pulleys. I had drilled a hole into a flat circul and attached it to a shaft as an offset gear which drives the pump. If anyones interested, I will take a picture.
December 4, 20168 yr Hello. It is nice to hear that you have made very efficient pump, but modifing LEGO pieces is not something that I like. Also, it is good to post some pictures when you want to show us something. Also, welcome to Eurobricks :)
December 4, 20168 yr Author 1 hour ago, M_longer said: Hello. It is nice to hear that you have made very efficient pump, but modifing LEGO pieces is not something that I like. Also, it is good to post some pictures when you want to show us something. Also, welcome to Eurobricks :) Who said anything about modifying Lego pieces?, I have not touched the lego pump in anyway, my Meccano piece is the part I modified to work with the pump, pump Is untouched
