Posted January 3, 20178 yr Hello Everyone, Weight: 14,450g (14.5kg) Speed: 0.8 cm/s I want to introduce my new creation; F RC Caterpillar 6120B Mining Shovel, it scale is Technic figure, and it has 8 motions are including, moving (powered by 2 XL motor), Large turnable rotate (powered by 1 XL motor), Shovel action (3 XL motor, 2 L motor), open shovel (1 M Motor) 100 % Lego Bricks and Lego Motors, No using material bricks, turnable and material structure. No using glue…. just only LEGO bricks video: https://www.facebook.com/pg/shineYucorner/videos/?ref=page_internal
January 3, 20178 yr This thing is awesome! Is the part on top of the tracks filled with Lego or is it a empty space?
January 3, 20178 yr This is unreal, just the fact that you got the whole thing to function at that size is amazing and not to mention the details, looks awesome :) we'll done.
January 3, 20178 yr Incredible creation All functions are driven locally, right? So no geartrains inside the model, only wiring? How did you achieve the weightbalancing of the superstructure?
January 3, 20178 yr is this the first HOF (hall of fame) model for 2017....? wow really looking good...
January 3, 20178 yr 45 minutes ago, wissamms said: Would it be possible to have a video? There is a video at the beginning of his post :)
January 3, 20178 yr Author 23 minutes ago, Jeroen Ottens said: Incredible creation All functions are driven locally, right? So no geartrains inside the model, only wiring? How did you achieve the weightbalancing of the superstructure? Yes no third party products, metal parts or others, just only Lego bricks and motors, i used 42055 yellow large turntable with four direction 1:3 gear and 1 xl motor, it is really more powerful for large turntable. How to balance? I always cal parts weight, the yellow body a little bit heavy than front arm. Body 5.5kg, front arm 4.8kg, crawled 3.8kg
January 3, 20178 yr Very impressive! although I am curious as to why you didn't bother, or try to hide the XL motors at the bottom? Surely they could have easily fitted into each tracked section itself? that's a LOT of 2x1 yellow grill tiles too! :)
January 3, 20178 yr 14.5 kg of plastic. I can say only one WOW!!!!!!!!!!!! How long did you build this monster? Of course, I liked it
January 3, 20178 yr 3 hours ago, Milan said: There is a video at the beginning of his post :) Oups :) Thanks!
January 3, 20178 yr This is an instant classic. I wish I had even just a shred of your talent! It's also nice to see that 2 XLs are enough to move 30 pounds of Lego - helps put things in perspective, methinks.
January 3, 20178 yr Awesome creation, but out off my leage, to expensive for me to build. And no instructions so impossible technically speaking.
January 3, 20178 yr @shineyu Did you purposefully leave the Volvo sticker on the the model, or am I missing something. BTW, VERY nice Work.
January 3, 20178 yr Author 44 minutes ago, Myers Lego Technic said: @shineyu Did you purposefully leave the Volvo sticker on the the model, or am I missing something. BTW, VERY nice Work. Oh thanks, i will remove it
January 3, 20178 yr Best creation I've seen all year haha This creation is mind blowing, It's amazing that you have build something so large but still functional.
January 3, 20178 yr Something seriously went wrong with You and Lego... luckily for us. Although I am not a fan of huge builds, but I see the challenges in it, and huge respect for Your passion! One question: how is the superstructure connected to the tracks? Is it only laying on the turntable, or is it somehow secured (= can the model lifted by the superstructure)?
January 3, 20178 yr That's a giant! What a piece of work that is! I wold have iked to see some pneumatics of LA's involved but nevertheless it's an epic build. H
January 3, 20178 yr Most impressive. Good use of the new quarter gear pieces in the bucket. Extra kudoos for 100% LEGO.
January 3, 20178 yr Wow that is fantastic especially considering it is 100% Lego. There goes the Bricklink supply for yellow 5x11 panels
January 3, 20178 yr Holy buckets (so to speak)!! I wondered when someone would use the new ring gears to their full potential, and you have certainly done so. In the slew ring, did you use something for a roller between the upper and lower ring? I also like how you use the rings to open the bucket. This model is the same subject matter as Sheo's Terex TH400 (Cat bought Terex) but at a much bigger scale. The wheels used as sprockets are awesome, the drive is smooth, and the home-built actuators are incredible. Really wonderful job.
January 3, 20178 yr Just one question: HOW?! I don't even build that big in my dreams! Incredible build, I am awed at the strength of your actuators, they aren't even bending in the photos... My mind has been blown by your work here.
