The 42065 RC Tracked Racer is a nice canvas for modding.
I was a bit disappointed when I found that it didn't have any technic gears apart from what you find when you disassemble the motors. Technic has always been used to teach mechanics to kids, and I personally find differential drive to be a super interesting alternative to the direct drive approach.
It didn't take more than a couple of hours to stuff in a couple of differentials, so I made a little video of this mod in action:
Another obvious "MOD" is to SBrick the model. This is a ridiculously simple MOD, so I decided to document the whole process of unpacking, updating, and programming a remote using the SBrick:
I also had super high hopes for the L-motors. Perhaps this would be more interesting with a 2:1 gearing for double speed. This is how the standard direct-drive model performs with L-motors:
Next up will be a GBC-module built mostly from parts of the model. To make a plain belt drive module is not really interesting anymore, so I'm currently trying to figure out if it can be made more interesting.
Very cool modifications, the differential MOD looks good so as the L-motors and the SBrick, they all seem to work well, i am wondering if we will see a MOD of this model with RC motors and an SBrick soon, that would be great, i am looking forward for more MODs.
I made the model as well, but from my own Lego and modded the drive to 2x L motors with 1:3 speed up. It's pretty fast, but the lack of torque makes it struggle a bit on carpet at home to turn in its spot compared to direct drive L motors, but on smooth surfaces it's a lot of fun.
23 minutes ago, IA creations said:
Awesome to see interest in modding this set. I quite like your mods and can't wait for more :)
Easy way to mount the RC motors:
Not many projects use the buggy motors.  I would be very interested to see how this performs.
I will do a video in a few days. Performance are very good and it is very fast :)
I might do a separate topic if you guys want .
Edited by IA creations
That's quite possibly the most powerful 100% LEGO mod you can make. I would love to see a video as well! Looking forward to it :)
The RC motors have a tendency to overload the PF receivers. What is the normal way of overcoming this problem? Is the SBrick OK with these motors?
Edited by Lasse D
Messed up formatting.
I found a really good combination , a V2 recever + a big bb can run RC motors very good at good speeds. But the weight is too hight so if we use the train bb the weight is lower but the baterries get empty faster. Would you want a comparison ?
From what I have read, the PF receiver would turn hot and shut down when overloaded. I'm glad to hear if this isn't the case with the V2 receiver. Perhaps the weight problems can be fixed by further removing parts from the model? A comparison of the time that the model can run on the two battery sources would be nice, yes. Thanks :)
Yesterday I've built it with my son from spare parts with SBrick.
Wondered, this Racer moves very well over snow (hight 2-3 cm). Cool set!
Yeah. It works quite well, even though it is only powered with M-motors.
I was a little disappointed with the performance of the differential drive mod, so I substituted the 2 M-motors with 3 L motors :D
Hi Victor. I see you have added L-motors to the mod as well. That's a great change. Do you have a link to your original thread for reference?
  • 2 months later...
I'm really bugged how 42065 performs on my floors (panels and tiles) and would want to improve it while keeping it 100% Lego 1f609.png;) Want to add more details to the model, too (increased weight would also require increased traction to reduce thread link wear).
I did some tests with adhesive "microgum" and the performance was stellar: the threads weren't spinning in place while the turning performance wasn't hampered noticeably. But the glue was too weak and it started to fall off...
The current plan is to go 100% "legal": to buy 80 pcs. of 24375 (rubber attachment for Technic link threads). I want to use 74, 37 set in a row on each thread (and leave 6 as spares). I'd much rather see them set in an alternating fashion, but since the number is odd, at one point there would be two in line anyway. And as far as I reckon, setting them in a row will have lesser effect on turning.
What do you reckon?
@Immo - you can see the rubber attachments used in my video below, they are installed in an alternating fashion as you described. In general they have a significant effect with the climbing abilities, difference is clearly visible there. The difference in traction on the floor is noticeable with the buggy motors, it does not have much visible effect on the M or XL motors.
Not exactly as I described - the alternating fashion is not "perfect" as the number of links is odd. It triggers my obsession with order :wacko:
Believe me, you won't notice any difference :) I had to make the 4 buggy motor version one stud longer to fit everything properly therefore I had to add an extra link - you can do it on your model so the order of the universe can be restored :)
  • Jim changed the title to [MOD] 42065 RC Tracked Racer
I'm rather thinking about adding an extra link and additional pulley on top to "tighten" the whole extended thread :grin:
