Hi All,
I'm doing a project, and would like to inverse one of the LED's in the 8870 PF lights.
Seem to remember I saw something about this on the net long ago, but can't find it anymore - best I can find, is schematics over here.
So, the big question is: Is there any MOD so the one LED lights up at +1 and the other at -1 on the output?
Any inout is welcome.
Are you familiar with a soldering iron?
If you bypass the diode bridge and revert one of the LEDs, one of the LEDs will light up with positive/direct voltage and the other with negative/reverse voltage.
To bypass the bridge you may solder one of the ~ to the + and the other ~ to the -
Hi Alvega,
Yeah, I'm familiar with a soldering iron, just need to find one ;-)
Thanks for the hints - will see if I can figure that out. It's been a long time since I did diagram readings.. ;-)
