Posted February 1, 20178 yr Hi all. I'm currently making a moc with some small sets. But I wanted to make some extended outriggers but the parts in the sets I'm using don't have 1x13 gear racks and the 1x7 gear racks are already used (which are anyways a bit too short). Is there an good way of making extendable outriggers without a gear rack?
February 1, 20178 yr Author I'm making a truck similar to 8258. I'm using the sets 42053,42040,42035 and 42047. These sets have most of the things I need. For the gear racks I don't want to use the ones from my arocs cause I only want use these sets. Folding outriggers would work fine only on the back of the truck.
February 1, 20178 yr Given the parts available, you could probably pull off something with a basic linkage system.
