What could a brick separator do other than separating Lego bricks? Make it into a Transport Terminal!
Design:
V-shape shelter design provide shade and shield Lego minifigures from rain, and yet provides sufficient clearance for the all Lego city trains and buses. 2-way train platform design allows for trains to travel in 2 directions.
Playability:
Transport Terminal provides flexibility in switching play between train or bus station. When the platform is removed, train structure turns into a bus station. They also can be connected with one another to form a longer train/bus station. This meets the need for a longer platform when multiple trains cars are connected. As illustrated in the pictures, several modules can be connected via 3 x connecting pins at black base frame and 2 x technic liftarm on the brick separators at the module ends.
Hope this gives you some ideas on how to use up your brick separators. Everything is awesome! :)
https://ideas.lego.com/projects/168723
Multiple modules can be connected together via connecting pins at train station struction frame
Top are joined by technic liftarm piece when multiple modules are connected for longer platforms
Top can be removed, and turns into a bus station.
Edited by darkhorse00
This is really brilliant and healthy unconventional.The orange works pretty well for a public-transport colour and with the clean design. :classic: :thumbup:
Edited by Littleworlds
attempt to turn the post into proper English!
That´s probably the nicest use of the brick seperator I´ve ever seen.
Also the fact that one can easily turn this into a bus station instead of an passenger terminal is genious and  could brilliantly easy be an official LEGO set.
Greatly excecuted as well, look´s awesome.
Yeah love it ! :wub:
KlodsBrik.
18 hours ago, Capparezza said:
Clever, very clever indeed :thumbup:
18 hours ago, peedeejay said:
Probably the best usage of brick seperators I've seen! :)
18 hours ago, Gongoro73 said:
Agree. Is just perfect. Well done.
18 hours ago, makoy said:
I always admire clever use of brick separators. Cheers! :grin:
17 hours ago, jus1973 said:
 Very clever.  I had used them as roof trusses in a modular arcade, but this beats that hands down.
KlodsBrik.
Thank you for the awesome comments and likes, guys! Will continue to build more moc.
16 hours ago, Fenestra said:
I love this! Great idea and due to the parts can probably be bricklinked pretty cheap!
You are right! For the first time, I have run out of brick separators. :)
On ‎23‎/‎2‎/‎2017 at 3:53 PM, Mariano said:
Fantanstic job. Very clever use of the brick separators.
Bus/train station is a great idea.
On ‎23‎/‎2‎/‎2017 at 7:39 PM, jalemac34 said:
Super idea, very smart
On ‎23‎/‎2‎/‎2017 at 11:48 PM, Feuer Zug said:
Ingenious, love it.
14 hours ago, Bart said:
Thats a first time i've seen a brick separator used as a brick. I like it.
Thank you for the awesome comments and support!
On ‎26‎/‎2‎/‎2017 at 4:15 AM, Gunman said:
So awesome Idea and execution here :wub:
On ‎26‎/‎2‎/‎2017 at 0:12 AM, LEGO Train 12 Volts said:
Wow very original!
The orange looks fantastic here! :wub:
Thank you for the likes! Feel free to use the idea for your trains!. :)
Would love to use this idea for a bus stop, problem is all my brick breakers have damaged ends ;) Plates stacked together in PAB cups wreak havoc on them...
Edited by NewTown
added more
20 hours ago, Edgarama said:
Yet another reason EB needs a like button.
i actually CHEERED out loud! (YEAH!!!) when I saw this.
VERY well done!!!
Thanks for the likes! :) Cheers!
As everyone else has said, a clever simple design and great use of brick seperators. It would be interesting to see a large transport hub which integrates this Modular design. Just a stroke of genius, the sort of clean simple design that makes you wonder why nobody thought of using them in this way before.
Hi! Yes me too, I really love how it works, but on a bigger scale, I'd have to see it again.. How about a train station with 2 Horizon Express, would you make it "just" longer or would you add more details? Many thanks again for sharing, looks great!
I love the modularity between bus station and train station! Do you have a bus station 'docking point' build somewhere in your city that has a similar connection point to the train base?
