Just a quick 30 minute LUG speed-build that I liked enough to take pictures of and post. One of the main things I wanted to try with this build was the transition from tan to dark tan on the edges of the path, to give the impression of slush.
A Mitgardian trapper goes for a walk in the early morning, after a freshly fallen snow.
More pictures on Brickbuilt
Thanks for looking, C&C welcome :classic:
Small, but well done.  The lavender leaves play into the cold atmosphere.  Not sure that the dark tan to tan transition makes much of a difference at this size... for a large path, it might be more visible!
Neat build on a small footprint! The tree is nice, though a bit spare (but I guess a tree in Mitgardia in winter is unlikely to be lush). The path does show wetness well, though I would suspect that melting snow would moisten the whole thing and not just the edges.
Nice little snowy scene. The use of colours is really good (lavender and tan are complementary colours).
Thanks Kai, glad you like it. I agree that the transition would be easier to see on a bigger path.
Thanks HQ! Coming from a place that gets snow regularly,  I would have to disagree about the path though; the middle is not as moist/slushy as the edges generally speaking. :wink:
12 hours ago, TitusV said:
Very Nice, LJ! I love the lavender leaves, they work great! :wub:
Thanks Titus!
42 minutes ago, Leonardo da Bricki said:
Well done, the small scene looks great. The idea of slush is nice, but might be more accurate on a well-traveled main road.
Thanks Leonardo! Though slush is going to occur on all paths, not just the main ones :classic:
Thank you :classic:
I grew up in a snowy area, so I know, too, but on a path that small the whole thing would probably be mud unless it was a path used so often that the center was dried out; it would also depend on the season and whether the snow was actively melting (like in springtime--then it's all just mud) or in the frozen depths of winter (then it might just be a bit wet on the edges like you show). So I guess it really depends on the time of year. Either way, I still like your build!
Nice one John, its amazing what you have managed to fit into such a small area. The dark to light tan path is a brilliant idea and I hope to see it expanded upon. Great tree :thumbup:
Very nice!  I like the light purple and white leaves mixed.  I think my favorite is the addition of flowers and white pieces to the light brown brush.  Great job!
Good point, which I shall keep in mind for the future. Thanks! :classic:
On 3/5/2017 at 7:16 PM, Merc4Hire said:
Most excellent vignette! I like the cold atmosphere you captured. The pathway and the tree are nicely detailed.
Thank you, it was quite enjoyable to build.
Thanks Maestro, you probably will see this in a bigger build at some point :classic:
On 3/6/2017 at 3:08 PM, Legofin2012 said:
A very nice little build, the tree is particularly pretty! The path transition is a good idea, and I look forward to seeing it used on a larger scale :classic:
Thanks Legofin!
On 3/11/2017 at 8:42 AM, soccerkid6 said:
That is a lovely 30 minute build! Great use of color, and the path texture works nicely :thumbup:
Thanks Isaac :classic:
Thanks, adding snow to bushes is something I like to do. :classic:
