Posted March 13, 20177 yr Hey all, I present to you my TC11 entry in progress It is called Fire Fighter because it has fire stickers on it It has tracks for easy drive and steering The blades at the side are for defend and as weapon. (I won't tell my signature move as it isn't build yet.) This vehicle is 45 studs long, 29 studs wide(without blades) and about 16 studs high. As for the discussion about the size, I find my vehicle quite big. So 45x45x45 is big enough to me Edited March 13, 20177 yr by nick97
March 13, 20177 yr I like how low it is, seems very hard to flip over. And yeah, it is quite big, and there is still lots of space left! 15 studs on the sides, and a lot of room to go up and mount signature move device!
March 13, 20177 yr 11 minutes ago, Milan said: I like how low it is Wait to see mine It looks very good ,love those blades on the sides
March 13, 20177 yr after seing this and the bison, count me in you may have competion Edited April 1, 20177 yr by Aventador2004
March 13, 20177 yr Nicely done. The only concern I would have is that the tracks typically do not generate enough friction. As such, maybe some rubber inserts (as those that came in the EV3 Extension Set) might help here.
March 13, 20177 yr Woohooo, this thing looks massive and mean! Lucky situation, that we use LEGO parts, those blades would show no mercy for tires in the metal reality. Or alternative: Edited March 13, 20177 yr by agrof
March 13, 20177 yr 3 minutes ago, agrof said: Woohooo, this thing looks massive and mean! Lucky situation, that we use LEGO parts, those blades would show no mercy for tires in the metal reality. Or alternative: exactly what I was going to suggest. https://www.bricklink.com/v2/catalog/catalogitem.page?P=24375&idColor=11#T=S&C=11&O={"color":11
March 13, 20177 yr Author Thanks everybody! Good you like it 3 minutes ago, DrJB said: Nicely done. The only concern I would have is that the tracks typically do not generate enough friction. As such, maybe some rubber inserts (as those that came in the EV3 Extension Set) might help here. I haven't had problems with tracks before so I try without these rubbers inserts(and I do not have them;)
March 15, 20177 yr That is one good looking robot. i see our robots have a few things in common - tracks, i first tried with wheels. 2 connected to a motor and 1 swivel wheel. But that didnt work so i have a chassis with tracks. - i had cages around the wheels and i'm ppb going to do that as well around my tracks. and maybe front&rear sides. It makes it look sturdy and i''m sure it protects the robot a lot. I hope we don't have the same signature move.
April 6, 20177 yr Author Hey all, Here is finally some progress as I finally had some time last week to build. The yellow part is part of my special move, but it isn't finished yet. After that I need some finetuning to make it look a bit better. A picture of my controller can be found here: http://bricksafe.com/pages/nick97/tc11 Hope you like it
