Posted March 20, 20177 yr For a moc I was Planning I tried making it in LDD (first time using it). I finished the chassis but I really have only 90% of the parts. I'm looking for an alternative build for the part https://www.bricklink.com/v2/catalog/catalogitem.page?P=6571&ccName=4543367#T=C&C=11 which can be used with or without https://www.bricklink.com/v2/catalog/catalogitem.page?P=57515&idColor=85#T=C&C=85 . The moc I'm building is a small suv so I want suspension On it. I tried building my own with my parts but I failed.
March 20, 20177 yr Have you considered this part? In case you wish to have driven axle the following part could be used.
March 20, 20177 yr There are few options for suspension arms and spindles, though only very few exist in LDD. SO, what is the exact issue you're facing: What parts exist in LDD? ... or what options are there in real life?
March 20, 20177 yr Author https://www.bricklink.com/v2/catalog/catalogitem.page?P=15460#T=P&C=85 I already have about 6 of those but Is there a way to fix some axles on to it then my issue is solved the model I built is in mid scale and im using This wheel https://www.bricklink.com/v2/catalog/catalogitem.page?P=56145&idColor=34#T=C&C=34. 52 minutes ago, DrJB said: There are few options for suspension arms and spindles, though only very few exist in LDD. SO, what is the exact issue you're facing: What parts exist in LDD? ... or what options are there in real life? What options are there In real life I found this http://www.moc-pages.com/moc.php/320971 and it seems that that the red steering model's steering hub seems to be interesting so I will try it. Since I have the parts.
March 20, 20177 yr For 'spring' suspensions, there are few parts as shown below. It all depends on how long ago you started buying lego and how many parts you have collected. Some parts came up in single or few sets (e.g 8448, 8466) and are more difficult to get. The whole list is here: https://www.bricklink.com/catalogList.asp?catType=P&catString=141 Edited March 20, 20177 yr by DrJB
March 21, 20177 yr Author 18 hours ago, DrJB said: For 'spring' suspensions, there are few parts as shown below. It all depends on how long ago you started buying lego and how many parts you have collected. Some parts came up in single or few sets (e.g 8448, 8466) and are more difficult to get. The whole list is here: https://www.bricklink.com/catalogList.asp?catType=P&catString=141 I know that there are a lot of parts for my needs but I needed a solution without buying amything and I finally found one. So I want to close this discussion. Edited March 21, 20177 yr by Milan Removed quoted images.
