Posted March 26, 20177 yr Hello all ! Here is my WIP topic for the TC11 bot . I want to have a final mean looking bot that performs well. I chose to use tracks because with tires steering was working very poor. As for the wepons I don't know exactley what to do but there will be 2 and 1 is already done . Some front/rear shots : So far I did the front platform* that is raiseble : As for the technical aspects : -driving/steering : 2 L motors (direct drive, no gears) -lifting of the platform* : 1 M motor with 1 big liniar actuator -1 small baterrybox -2 V1 recevers -there will be 1-2 more motor/s for the other function. Placement of the motors isn't that bad so there is defenetley room for 1 more function : I am also thinking of adding another big liniar actuator for the platform* so it can get more power (speed at which it works is OK). Full armor will be made ( so far : bottom and all sides) . Any thoughts about inprooving are very welcome Please suggest a sesondary signature move (i don't want to waste a recever port). And guys , I need a name for it ! I have some which I realley like (please choose your favourite) : -Come To Papa -Arena Closer -DriverRamp(suggestion) -Your suggestion (now seryousley please suggest a good name) Edited March 26, 20177 yr by IA creations Platform instead of flipper ;)
March 26, 20177 yr Not bad, but the flipper is no flipper Its more like a ramp... Also the "Flipper" would be more stable, when you put 2 LAs on each side. Name: DrivenRamp Edit: If another bot, drives over the flipper, the tracks will just slip away. Edited March 26, 20177 yr by KikoTube
March 26, 20177 yr Author 4 minutes ago, KikoTube said: Not bad, but the flipper is no flipper Its more like a ramp... Also the "Flipper" would be more stable, when you put 2 LAs on each side. Name: DrivenRamp Edit: If another bot, drives over the flipper, the tracks will just slip away. Fixed :) I am going to insclude that name on the list . That problem could ve solved if I would have those rubber things that go indide the track holes.
March 27, 20177 yr Those are a bit costly and will increase the ground clearance half a stud. You can use silicone bands instead, like this to achieve the same:
April 10, 20177 yr Very low robot, I think it would be a great competitor to mine! Name suggestion: Ramprampage
April 10, 20177 yr @Slewentogzz that is a great name idea. i second it. maybe put a spinner at the top to damage the other bot.
April 10, 20177 yr Author Thanks for suggestin but i almost rebuilt it. I will post pics tomonrow I hope.
