Today i have searched for inspiration and found this
quelle liebherr
Long Talk, short back, there is really small place available in the 19wide scale (1:16,7). So my excavator base has to be smaller again. This is what is done at this time.
hopefulliy it works
Edited by efferman
  • Replies 133
I always love following your builds, you are a very inspiring creator!  I have tried building excavators in the past and never succeed, I can never get them very compact to where it looks like an excavator.
I am seeing 5 motors, but only 4 outputs, is the 5th motor for rotation? Also, will have have the motors for drive built into the tracks?
I would guess the battery box will be on the bottom like more LEGO model that it.
  • Jim changed the title to [MOC] R 926 Compact
hi effe,
i had a close look at your LDD file.
The way you manage to pass through the turntable is just brillant!
waiting for next step :)
Dont forget to post it.
Mine has now the "ventilation mesh" for the engine Bay.
Now the probably hardest thing: a double curved shape
edit:
Edited by efferman
Thanks. With the use of two Sbricks it would be easier. With standard receivers i had a loss of one channel because the parts on the corner needs to much space
Been following this build on Flickr for a while, it's amazing how much you're squeezing into a tight space. Can't wait to see it start to take shape with real bricks!
It really is starting to take shape:thumbup:
That is a lot of SNOT in that cabine, but it does look a little fragile indeed. Especially the black parts will move the moment you touch them I'm afraid.
a bar piece instead of the antenna?
Edit²
the uppercarriage seems to be done
Edited by efferman
pictures added
