Alasdair Ryan Posted April 24, 2017 Posted April 24, 2017 (edited) Here are some example bar pieces you could try (just to break up the front window). Edited April 24, 2017 by Alasdair Ryan Quote
efferman Posted April 24, 2017 Author Posted April 24, 2017 now i understand. thanks for your suggestion Quote
legolijntje Posted April 26, 2017 Posted April 26, 2017 Just noticed this topic and I have to see that looks really nice! But, I have a weak spot for excavators anyway Although, there was one thing I was wondering while looking through all your images: where will you put all the cables? Will there even be enough space for that? Quote
efferman Posted April 26, 2017 Author Posted April 26, 2017 I hope there will be enough space for cables. The first Bunch of pieces is ordered. at the end of the next week i will see problems or not Quote
efferman Posted April 29, 2017 Author Posted April 29, 2017 (edited) The first parts are arrived. the cables seem to fit. edit: holy moly, that is tight Edited April 29, 2017 by efferman Quote
Alasdair Ryan Posted April 29, 2017 Posted April 29, 2017 One of those receivers does not look very secure,German engineering is failing. Quote
Alasdair Ryan Posted April 29, 2017 Posted April 29, 2017 I guess so.Although I think I would of left if squint, just for a laugh. See that middle cable that is higher than the rest(two cables),you could keep it down level with the rest by using a small extension cable to the receiver port instead of the motor cables. Quote
efferman Posted April 29, 2017 Author Posted April 29, 2017 That is no problem, because there is a cover above. Check the earlier ldd screens. Quote
efferman Posted April 30, 2017 Author Posted April 30, 2017 First Sketch of the undercarriage does somebody knows a part which can replace the half pin and fits in the hole at the bevel gear? Quote
Kit Fisto Posted April 30, 2017 Posted April 30, 2017 (edited) Replace black 1 x 2 plates with this: Then use this(4L): I think it`ll allow the gear to spin freely, but not 100% sure Edited April 30, 2017 by Kit Fisto Quote
efferman Posted April 30, 2017 Author Posted April 30, 2017 Thanks for your suggestion. A idea for the hole under the Bevel gear to hold the slopes not only with one pin? Quote
Kit Fisto Posted April 30, 2017 Posted April 30, 2017 (edited) Yes, if it works, it`ll hold both upper and lower slopes and won`t touch the gear.So, the half-pins are not needed(1 x 1 plates are connected via bar 4l, going from the top to the bottom of the black bracket part). Edited April 30, 2017 by Kit Fisto Quote
efferman Posted April 30, 2017 Author Posted April 30, 2017 (edited) I have replaced a half pin, with a half pin with bar. pretty similar to yours edit: it is wedding Time Edited April 30, 2017 by efferman Quote
efferman Posted April 30, 2017 Author Posted April 30, 2017 This feels really good when someone like you praise about mye own work. Thank you very much. Quote
technicbuilder Posted April 30, 2017 Posted April 30, 2017 Hello , I'am following this building proces from the beginning ,this is gonne be a real master piece ,and one of the most detailled excavators i have ever seen, build with Lego parts . In my daily job i'am working at Hyundai excavators ,and this one from Lego (Ok it's a Liebherr )is comming really close to the reallity . Keep up the good work . Quote
dikkie klijn Posted April 30, 2017 Posted April 30, 2017 It seems we are witness of another great scale modeler coming to be! Curious though, do you test the mechanical elements before you engineer them in ldd? Or is it all based on experience? Quote
efferman Posted May 1, 2017 Author Posted May 1, 2017 (edited) My Experience is in the most times enough to build in ldd. But when it comes to the real build there are often small changes to reduce the part amount or to raise the stiffness. Edited May 1, 2017 by efferman Quote
2LegoOrNot2Lego... Posted May 4, 2017 Posted May 4, 2017 This is getting somewhere for sure! Great progress on an equal build. To me it seems like the main boom isn't lowering enough. Could this be true? Quote
efferman Posted May 4, 2017 Author Posted May 4, 2017 The moving range is far away from to be enough. To be close to the real thing i would need actuators with the double length. And brickbuilt actuators are far to thick. But transport position is possible, so it is ok for me. Quote
efferman Posted May 5, 2017 Author Posted May 5, 2017 Some Parts have arrived. The dark bluish gray parts are placeholders. Quote
efferman Posted May 6, 2017 Author Posted May 6, 2017 The boom is really tricky and hopefully not to fragile. If not, a Monoblock boom is what i have to do. Quote
Dafgek81 Posted May 6, 2017 Posted May 6, 2017 This is looking amazing so far, big fan of your work Effe!!!!!!! Quote
