Thank you very much.
the stability is with small changes acceptable. The moving range not really. it seems i have to play around with the mounting points.
Edit:
Edited by efferman
  • Replies 133
Thanks! This is probably the moc with the highest density i have ever built. Actually iam waiting for the correct dimensions of the boom, which i have asked from Liebherr.
edit: small test
Edited by efferman
Your work is very inspiring and make it look like child's play. Wait, you actually asked the manufacturer to send you detailed information about the design? What was the premise on which you sent the email. Did you mention that you were making a LEGO model? I seriously hope that you get a response!
One small observation, The 1x3 tile adjacent to the fake drive sprocket looks like it will just fall off as it is only held on by one stud. You might consider replacing it with a 2x3 tile, if possible.
In the mail to liebherr i have asked for the dimensions of the boom and they responded very quickly. Unfortunately it needs time to make the drawings available. The boom prototype which i have built was only a guess on dimensions.
The tile us indeed a weak point, but unfortunately the spur wheel below would collide with a 2x3 tile.
Here are the changes on the seat to improve the stabillitiy. The Seat with the 2x4 tile is the modified one.
A new weekend, and time to Build at a tricky place. The universal joints get to work properly will be hard
Time to fill up the lipo
Seems the hard job is done
edit: Stability is good, but iam not yet happy with the look
Edited by efferman
