Jeroen Ottens Posted May 28, 2017 Posted May 28, 2017 That is some serious U-joint wizardry in that joint. One of the pairs is not aligned though, doesn't this give a non-uniform rotation speed? Smart move to use the 2x2 plates with 1 pinhole to attach things with. The sides do look a bit blocky, but TBH I have no idea how to improve on this, unless it is possible to build it studs up... Quote
efferman Posted May 28, 2017 Author Posted May 28, 2017 Thanks for the universal joint information. It is fixed now Quote
legolijntje Posted May 28, 2017 Posted May 28, 2017 9 hours ago, efferman said: edit: Stability is good, but iam not yet happy with the look Not happy with the looks!? It has a damn smiley! What more do you want? In all seriousness, it looks really great so far. Both from a purely aesthetic viewpoint and a technical viewpoint (still can't believe you crammed so much in there). Quote
efferman Posted June 3, 2017 Author Posted June 3, 2017 More progress.. The Bucket is not far away. Quote
ColletArrow Posted June 4, 2017 Posted June 4, 2017 Very impressive! I've been following this project from the start, it's interesting to see the design evolve slightly as it goes on. You just need to learn the controls now! Quote
efferman Posted June 4, 2017 Author Posted June 4, 2017 Thanks. The poor steering is a firmware problem and for old guys like there are no updates available Quote
Jeroen Ottens Posted June 4, 2017 Posted June 4, 2017 Looking very good! Excellent articulation. Even the blockiness of the first section of the beam is less apparent now that the whole beam is assembled. I was wondering whether it would look better if the second and third beam section are a bit higher (the yellow part I mean), so that they look a bit beefier. Or is the real life version also on the thin side? Quote
efferman Posted June 4, 2017 Author Posted June 4, 2017 Thank you very much The second section should fit the real thing in my opinion and the third section will be a bit thicker than now when i have it done. Quote
timslegos Posted June 4, 2017 Posted June 4, 2017 Smooth all around. The method you use to construct the third arm is interesting. How sturdy is it? Do you find that it can withstand a significant load? Quote
efferman Posted June 4, 2017 Author Posted June 4, 2017 It is able to digg, so it is sturdy enough. Quote
ColletArrow Posted June 10, 2017 Posted June 10, 2017 Very nice. Good to see it's happy in its work at the end ! (1:55 the smiley face is seen on the back.) It almost looks like real clay-based soil, and is a good 'scale' even; I like the doubling up of the 42055 bucket too. How nearly finished is it? Just the few off-coloured parts to replace? Quote
efferman Posted June 10, 2017 Author Posted June 10, 2017 The last section needs a bit fine tuning, but everything else is except of wrong colours done. After the exhibition next week i will do this tuning. Quote
CrazyGijs Posted June 11, 2017 Posted June 11, 2017 (edited) This is a real master piece! It's so compact and still very functional! Well done :D Edited June 11, 2017 by CrazyGijs Quote
efferman Posted June 11, 2017 Author Posted June 11, 2017 (edited) Thank you very much Edited June 11, 2017 by efferman Quote
timslegos Posted June 11, 2017 Posted June 11, 2017 Something about Liebherr's colors just translate so well to Lego models! Would you mind showing a picture with the "side" panels off the arms so we can see the inner skeleton? There must be some pretty interesting ujoint wizardry to fit all of them inside. Quote
Dennis Bosman Posted June 11, 2017 Posted June 11, 2017 Very smart! Great job how you put all LA's in the arm of the tiny excavator! It operates very good! Quote
efferman Posted June 12, 2017 Author Posted June 12, 2017 When i have done the lxf i will make a drivetrain view Quote
efferman Posted June 13, 2017 Author Posted June 13, 2017 At this weekend the excavator can be seen at Absolut Steinchen in the Hochschule Bonn-Rhein-Sieg. The Entry is free and every Fan of Lego will have his pleasure at this convention. Beside of the huge Technic section there you can see, GBC, Monorail Basic Lego and Trains. Quote
efferman Posted June 19, 2017 Author Posted June 19, 2017 It was a small but gorgeous convention and i was very surprised about the stability of the 926. Two days it was played by kids and only one weakpoint was spotted. more pictures of the convention here https://flic.kr/s/aHskXbZB27 Quote
Bricksonwheels Posted June 20, 2017 Posted June 20, 2017 Very cool! The Volvo looks great as well. Quote
efferman Posted June 20, 2017 Author Posted June 20, 2017 Thanks The lxf is done, the instruction the next Quote
