It is with a little delay that I can present our Easter GBC module.
This GBC module is an evolution from this old small ring module:
(Brickshelf gallery of the old module here: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=569534 )
The module is quite simple. The wheel spins. The anti-jamming mechanism kicks in when needed and there are two inboxes to help place it optimally in a layout.
There is a compartment in the base to store fragile objects during transport and the XL motor can easily be replaced:
You can also use an M or L motor instead, should you not have an XL motor.
The flowers are tulips:
A daisy:
And a daffodil:
The design started with the head of the bunny, where I tried to make it both compact and cute:
Brickshelf gallery with more pictures (once public): http://www.brickshelf.com/cgi-bin/gallery.cgi?f=569534
On 21/4/2017 at 10:29 AM, Bob De Quatre said:
A very refreshing GBC module! I really like the bunny and the flowers :classic:
I'm a bit concerned by the speed of the ring compared to the speed of the bunny.
Thanks everyone.
Would you like the bunny to run a bit faster compared to the wheel Bob? Because I have the same feeling. I have geared it so that it didn't go too fast on high speed, but seeing that it will run on speed 1 for most of its life, I'm considering swapping the red cogs between the wheel and the bunny.
What bothers me is the difference in speed between the bunny and the wheel. Maybe speeding up a bit the bunny and slowing a bit the wheel would be a good solution.
