2GodBDGlory Posted April 29, 2024 Posted April 29, 2024 There's some impressive engineering going on in there! It's quite interesting how those magnets improved the accuracy so much, and the compensation for thermal expansion is pretty next-level! Quote
Davidz90 Posted April 29, 2024 Author Posted April 29, 2024 (edited) 18 minutes ago, 2GodBDGlory said: There's some impressive engineering going on in there! It's quite interesting how those magnets improved the accuracy so much, and the compensation for thermal expansion is pretty next-level! Thank you very much! Indeed, the magnets provide a huge boost in accuracy - the fact that even doubling the driving weight changes the clock speed only by ~0.02% is kind of insane. I think that actually the most difficult part was having enough patience - a good 3 days of correcting the period by few microseconds, then waiting half an hour for the pendulum to reach a steady state to evaluate the speed... Edited April 29, 2024 by Davidz90 Quote
Davidz90 Posted May 25, 2024 Author Posted May 25, 2024 Final result after one month of testing. Max error: -6/+7 seconds. And here is my newest build - a hollow clock face. Inspired by some 3D-printed clocks out there. Minute hand is fixed to one ring gear, hours hand is suspended by magnets on second ring. Now I'm thinking on how to power it. First idea was to use standard quartz mechanism out of regular wall clock, but these tend to have very little torque, just enough to move lightweight hands. Quote
Davidz90 Posted June 10, 2024 Author Posted June 10, 2024 My newest creation, takes some solutions from the last high-precision clock (like the temperature-compensated pendulum), but uses a completely different escapement design. Quote
Davidz90 Posted June 10, 2024 Author Posted June 10, 2024 Some photos and additional description: The general structure of the clock is two towers with pendulum hanging in between. This arrangement makes it relatively stable and saves a lot of material when compared to traditional grandfather clock that encloses the pendulum in a case. side The tower is 170 cm high, but pretty narrow. In fact, total cost of this clock is less than twice the price of the recent Notre Dame cathedral set. front The clock face is a plate sandwich, put under very slight tension. face Finally, the mechanism. For power, I'm using a non-Lego DC motor plugged to a phone charger. A potentiometer (blue) is used to regulate the motor torque. Motor output speed is regulated by a fan. mechanism Quote
Davidz90 Posted June 12, 2024 Author Posted June 12, 2024 I got featured on Beyond the Brick channel :) Quote
Divitis Posted June 12, 2024 Posted June 12, 2024 These models look incredible. Unfortunately I don't think I know enough about the inner working of a clock to appreciate your engineering. If were to create a Lego clock engineering for dummies sort of video, I would be certain to watch it, and possibly would help me appreciate your creations more, if not inspire me to try my hand Quote
Davidz90 Posted June 12, 2024 Author Posted June 12, 2024 24 minutes ago, Divitis said: If were to create a Lego clock engineering for dummies sort of video, I would be certain to watch it, and possibly would help me appreciate your creations more, if not inspire me to try my hand That's a cool idea! You are right, inner workings of a pendulum clock are surprisingly intricate and the physics behind them is truly fascinating. I have some plans to create a small, easy to build wall clock, with full instructions and detailed explanation of how it works. Quote
Davidz90 Posted June 17, 2024 Author Posted June 17, 2024 Here's a small but fully functional clock, with full build instructions. It is designed to be clamped to an edge of a table/shelf or hanged on a wall. Driving weight lowers by 20 cm per hour, so at typical shelf height of ~160 cm, one gets 8 hours of working time. link to the instructions: https://drive.google.com/file/d/1tbNfih7dY28Cv3CotBCrR4Pl8SmZic_Y/view?usp=sharing Quote
Bluehose Posted June 17, 2024 Posted June 17, 2024 Thank you for that ! It's small enough to have a nice housing with few pieces, this is symetrical ans doesn't look expensive ! Quote
Davidz90 Posted June 17, 2024 Author Posted June 17, 2024 6 minutes ago, Bluehose said: Thank you for that ! It's small enough to have a nice housing with few pieces, this is symetrical ans doesn't look expensive ! Thanks! Yes, compactness and low cost were my design goals here. Considered making it studless, but old school technic bricks are way more rigid with less pieces. Quote
Davidz90 Posted June 25, 2024 Author Posted June 25, 2024 Next creation. For this one, I combined Lego with a little woodworking to make something in a more modern style. 1 It uses the same mechanism as my recent mini-clock. Due to longer, heavier pendulum, it is more accurate - up to 30 seconds/day. 2 The whole thing is fixed to a wooden board by simply driving screws through Technic holes and into the wood. 3 Link to a video: Quote
Davidz90 Posted June 26, 2024 Author Posted June 26, 2024 For anyone interested, here's a link to instructions: https://drive.google.com/file/d/1F0I6FHT8jyRJfaDp8Td_nGbjcEde0Jnu/view?usp=sharing Given the amount of requests for instructions, tutorials and explanations, I'm considering writing some sort of a book on the subject of Lego clocks. There's too much stuff to cram it into a series of videos. It would cover not only the engineering topics and various Lego escapement designs, but also the physics of pendulum clock. However, I'm not sure if that wouldn't be too niche? Quote
howitzer Posted June 26, 2024 Posted June 26, 2024 48 minutes ago, Davidz90 said: For anyone interested, here's a link to instructions: https://drive.google.com/file/d/1F0I6FHT8jyRJfaDp8Td_nGbjcEde0Jnu/view?usp=sharing Given the amount of requests for instructions, tutorials and explanations, I'm considering writing some sort of a book on the subject of Lego clocks. There's too much stuff to cram it into a series of videos. It would cover not only the engineering topics and various Lego escapement designs, but also the physics of pendulum clock. However, I'm not sure if that wouldn't be too niche? That's definitely a niche, so I don't expect there's much money to be made at that. I personally would certainly be interested in reading a bit about Lego clocks but not sure if I'd be interested enough to buy a book about them... Quote
Davidz90 Posted June 26, 2024 Author Posted June 26, 2024 3 minutes ago, howitzer said: not sure if I'd be interested enough to buy a book about them... Oh, I don't intend on selling it. It will be free. Quote
howitzer Posted June 26, 2024 Posted June 26, 2024 6 minutes ago, Davidz90 said: Oh, I don't intend on selling it. It will be free. In that case, if you think you can spare the time and effort, I would highly recommend and appreciate it. Quote
Davidz90 Posted June 29, 2024 Author Posted June 29, 2024 So, I started writing the book. Part of it is discussion of various escapement types and small, easy to build examples of them. Here's showcase of the first four, each of them under 50 pieces: Quote
lcvisser Posted June 29, 2024 Posted June 29, 2024 This is very cool! I love the slow motion shots, it makes it so clear how they work. Following with interest! Quote
Davidz90 Posted July 9, 2024 Author Posted July 9, 2024 Second part of small escapement demonstrations: Quote
Davidz90 Posted October 28, 2024 Author Posted October 28, 2024 (edited) A new, large project in progress. A clock tower that will have 4 faces with various functions. Right now, regular time and striking mechanism are finished. I managed to make pipe chime with pretty good sound. The idea to encode 1,2..12 strikes in a chain is not new, my improvement is a triggering mechanism that needs a very little force and is not grabbing the chain directly to stop. More details here: Finally, the chime is one of the set of four, which will be used for Westminster chimes (the same melody that Big Ben makes) Edited October 28, 2024 by Davidz90 Quote
Davidz90 Posted November 3, 2024 Author Posted November 3, 2024 My new, large project is complete! Clock tower with 3 faces featuring striking mechanism, world time, moon phase indicator and calendar. Quote
lcvisser Posted November 5, 2024 Posted November 5, 2024 Very impressive, as usual! Do you keep all your blocks assembled or are they reused? I see at least one big one in the background. Quote
Davidz90 Posted November 5, 2024 Author Posted November 5, 2024 1 hour ago, lcvisser said: Do you keep all your blocks assembled or are they reused? They are reused. I have 4 clocks in total: the ones in the photo, one red (the one with 19 functions) and one black (accuracy world record). Red one will probably get a rebuild next :) Quote
LegoTT Posted November 5, 2024 Posted November 5, 2024 I will order these bricks and offer them with your pdf in a nice box to my nephew for Christmas. Quote
Davidz90 Posted November 5, 2024 Author Posted November 5, 2024 5 hours ago, LegoTT said: I will order these bricks and offer them with your pdf in a nice box to my nephew for Christmas. Awesome! Which one, exactly? The black and white one has been built recently by one person, with transparent backing instead of wood, and it looks better than mine . Quote
