Nikolay Posted May 9, 2017 Posted May 9, 2017 (edited) Aircraft-Fighter Bomber MK.II Lego Technic [MOC] All the good time! I present to you project Fighter-Bomber. This is the final modification. Instruction: https://yadi.sk/i/kS8e8Z0e3MQAsF And: https://www.flickr.com/photos/141358259@N08/albums/72157685860317263/page3 Management of the Сab : 1. Aileron2. The Elevator3. Rudder + Control Back Rack Chassis4. Flaps5. Step Rotor6. Machine Guns7. Clear Bombs8. Armchair Сatapult 9. Landing Gear Selection10. Сabin illumination Exterior Functions : 11.Opening: a. Hood b. Lantern Cabs c.Technical Compartment d. Fuel Tanks 12. Folding the Front and Rear Rack Chassis13. Retractable Leaf Front and Rear chassis14. Index Edition Chassis15. Rocket Launch16. Folding Wings17. Landing Light The model is equipped with a m-motor to drive the rotor, turn the machine guns and the landing gear. You can do without m-motor, and activate the function by rotating the screw by hand. Subscribe to the Shannel YouTube Aircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on Flickr Aircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on Flickr Edited August 31, 2017 by Nikolay Quote
PeterF Posted May 9, 2017 Posted May 9, 2017 That is epic! The shear number of functions, at this scale, and it still looks great. TLG really should produce a 9V battery option like that. How fragile are the connections at the nose section? Quote
Nikolay Posted May 9, 2017 Author Posted May 9, 2017 1 hour ago, PeterF said: That is epic! The shear number of functions, at this scale, and it still looks great. TLG really should produce a 9V battery option like that. How fragile are the connections at the nose section? Thank you.) Yes, powerful factory batteries from LTG would be welcome, you are right. The fore is strong enough, the loaded load is kept) Aircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on FlickrAircraft-Fighter Bomber MK.II Lego Technic by Nikolay Zubov, on Flickr Quote
MangaNOID Posted May 9, 2017 Posted May 9, 2017 gorgeous plane and function packed! hardly a studs worth of hollow in the plane. is there much noticeable difference between using one 9v battery compared to the 9v battery box?... is that a silly question? Quote
teflon Posted May 9, 2017 Posted May 9, 2017 Wow. Very good. I like this technic/work-horse look of the plane. You can see the amount of functions trying to jump out. It would be super cool to see just the naked fuselage without panels. I think it is very cool how much mechanism you have in that small space. I would like to see more, all this gear-pr0n:-) Quote
1gor Posted May 9, 2017 Posted May 9, 2017 it looks at the first sight like fuselage and wings are inspired by Hellcat Quote
Jeroen Ottens Posted May 9, 2017 Posted May 9, 2017 very nice. packed with functions, lovely colourscheme and lines A bit fickly controls and semi-legal techniques, but at this scale that is unavoidable with so many functions, The propellor shaft does look a little flimsy though. Well done! Quote
evortigosa Posted May 10, 2017 Posted May 10, 2017 The plane is gorgeous! I am not a big fan of an extensive use of black bricks, but this plane have great details. Excellent lines. Good work! Is this plane based on spitfire? Quote
Seasider Posted May 10, 2017 Posted May 10, 2017 Great model, reminds me a bit of a Pilatus PC-9. Quote
Nikolay Posted May 10, 2017 Author Posted May 10, 2017 21 hours ago, MangaNOID said: gorgeous plane and function packed! hardly a studs worth of hollow in the plane. is there much noticeable difference between using one 9v battery compared to the 9v battery box?... is that a silly question? Yes, everything is packed very tightly. The issue with batteries is relevant. 9v very quickly sit down, so the main source of energy is the unit, although this is not very aesthetic. Thanks you. 21 hours ago, teflon said: Wow. Very good. I like this technic/work-horse look of the plane. You can see the amount of functions trying to jump out. It would be super cool to see just the naked fuselage without panels. I think it is very cool how much mechanism you have in that small space. I would like to see more, all this gear-pr0n:-) The fruit of a long labor, could not stop until it realized all the desired functions. Thank you. Unfortunately now the model is dismantled, the photo without panels I can do later. 20 hours ago, I_Igor said: it looks at the first sight like fuselage and wings are inspired by Hellcat There is something similar, you are right. 12 hours ago, Jeroen Ottens said: very nice. packed with functions, lovely colourscheme and lines A bit fickly controls and semi-legal techniques, but at this scale that is unavoidable with so many functions, The propellor shaft does look a little flimsy though. Well done! Thank you for useful feedback) there are unfortunately enough shortcomings. You are right, I often had to make non-standard decisions to finally solve some problems, and that something still remained imperfect. 2 hours ago, evortigosa said: The plane is gorgeous! I am not a big fan of an extensive use of black bricks, but this plane have great details. Excellent lines. Good work! Is this plane based on spitfire? I'm glad that you highly appreciated the model. Black is in my biggest quantity, I would have to depart from this practice) I was inspired by many aircraft, including a spitfire. Quote
Nikolay Posted May 10, 2017 Author Posted May 10, 2017 1 hour ago, Seasider said: Great model, reminds me a bit of a Pilatus PC-9. Pilatus PC-9 аn excellent aircraft. Thank you. Quote
1gor Posted May 10, 2017 Posted May 10, 2017 4 hours ago, Nikolay said: Yes, everything is packed very tightly. The issue with batteries is relevant. 9v very quickly sit down, so the main source of energy is the unit, although this is not very aesthetic. Thanks you. The fruit of a long labor, could not stop until it realized all the desired functions. Thank you. Unfortunately now the model is dismantled, the photo without panels I can do later. There is something similar, you are right. Thank you for useful feedback) there are unfortunately enough shortcomings. You are right, I often had to make non-standard decisions to finally solve some problems, and that something still remained imperfect. I'm glad that you highly appreciated the model. Black is in my biggest quantity, I would have to depart from this practice) I was inspired by many aircraft, including a spitfire. ...despite some similarities it is a great model Quote
Davidz90 Posted May 10, 2017 Posted May 10, 2017 So many functions :O The cabin interior is a marvel of engineering. Quote
Nikolay Posted May 12, 2017 Author Posted May 12, 2017 On 10.05.2017 at 2:37 PM, I_Igor said: ...despite some similarities it is a great model I took many ideas from different planes. On what real plane it is more similar, it's up to me not to decide) thanks for the evaluation) On 10.05.2017 at 3:08 PM, Davidz90 said: So many functions :O The cabin interior is a marvel of engineering. A technician is a cool direction! There are many possibilities to realize. Thank you) Quote
1gor Posted May 15, 2017 Posted May 15, 2017 On 5/12/2017 at 7:46 PM, Nikolay said: I took many ideas from different planes. On what real plane it is more similar, it's up to me not to decide) thanks for the evaluation) You're welcome Nikolay Quote
Nikolay Posted August 28, 2017 Author Posted August 28, 2017 Good day! The instruction is finally ready. Perhaps the assembly of the second wing will seem uncomfortable, for more I was not enough.Instruction: https://yadi.sk/i/kS8e8Z0e3MQAsF Quote
teflon Posted August 31, 2017 Posted August 31, 2017 Holly bricks. This looks quite a challenge! Thanks Nikolay for the instructions of really creative plane. Quote
