josszo Posted June 5, 2017 Author Posted June 5, 2017 (edited) The compressor unit. One is in the front of the bus, one is in the rear: (there is an "M" motor behind this unit) The entire bus: Edited June 5, 2017 by josszo Quote
SpaceJoey86 Posted June 5, 2017 Posted June 5, 2017 This is a brilliant build, I just wish you had built it as a PF vehicle without any pneumatics (I hate pneumatics). But otherwise it is amazing! Quote
josszo Posted June 5, 2017 Author Posted June 5, 2017 Later, I will build a full PF articulated bus, a trolleybus in red color :) Quote
SpaceJoey86 Posted June 6, 2017 Posted June 6, 2017 21 hours ago, josszo said: Later, I will build a full PF articulated bus, a trolleybus in red color :) Great, that sounds like a brilliant build Quote
BrickbyBrickTechnic Posted June 22, 2017 Posted June 22, 2017 (edited) This will be beautiful when it's done. Keep building, can't wait! Edited June 22, 2017 by BrickbyBrickTechnic Quote
josszo Posted June 23, 2017 Author Posted June 23, 2017 I'm happy, that lot of people follow my project. Nowdays I don't have lot of free time, but I will end this project within 1-2 months. Quote
brickless_kiwi Posted June 26, 2017 Posted June 26, 2017 It's an impressive build certainly one I'm following Quote
1gor Posted June 26, 2017 Posted June 26, 2017 @josszo I assume that you have some Aces in your sleeve so you're driving arround in public Ikarus 280 Articulated Bus to see if you missed something to improove your masterpiece Just take all the time that you need to finish model. You can not force the Art... Quote
josszo Posted June 27, 2017 Author Posted June 27, 2017 I need to develop a working articulated unit. Do you know anybody, who have ever made a working articulated unit? I need only the outer body, that is flexible and can follow the 3axle motion. If i need develop a new one, i think can make it with a lot of rubber liftarm 1x2 technic elements. Quote
1gor Posted June 27, 2017 Posted June 27, 2017 @josszo , perhaps this could help (it is articulated tractor...) Quote
ColletArrow Posted June 27, 2017 Posted June 27, 2017 @I_Igor I think @josszo means the flexible corridor connection between the halves of the bus, not the actual hinge. @josszo I have not seen such a connection achieved in LEGO at any scale, but as you say a system with rubber connectors may work. I'm thinking about systems employed in 1:76 scale model trains, which can use alternating fixed and flexible 'layers' forming a very thick sandwich; the central-most 'layers' can slide past each other somewhat, enabling the whole connection to remain fairly close but move enough to permit tight corners. What is the sharpest corner you hope the bus will be able to take? Alternatively, you could create a rigid corridor, that at each end slides and pivots on a single pin (probably one at her top and one at the bottom) fixed in each of the main bus's body sections. It would not be as realistic as a flexible corridor, but may work more reliably and with less friction. I'm not entirely sure. Quote
josszo Posted June 28, 2017 Author Posted June 28, 2017 Yes, I need the flexible corridor. The maximum turning angle is about 60 degree. Quote
kbalage Posted June 28, 2017 Posted June 28, 2017 You can see some ideas if you look around, here are a couple of them: https://ideas.lego.com/projects/575ddb57-0068-452f-90e2-7828a007b784 https://www.flickr.com/photos/thisani/12858464413 http://www.moc-pages.com/moc.php/349750 The last one look pretty ok for me if you can scale it up Quote
josszo Posted June 28, 2017 Author Posted June 28, 2017 Thank you guys. I will inform you, if I have developed any new things. :) Quote
1gor Posted June 28, 2017 Posted June 28, 2017 1 hour ago, josszo said: Thank you guys. I will inform you, if I have developed any new things. :) We'll follow it Quote
josszo Posted July 9, 2017 Author Posted July 9, 2017 I have did a first version of a working articulated unit. It is a little part of the whole unit, but it works. Need a little developing, but it can be good. (Sorry the bad quality) Quote
1gor Posted July 17, 2017 Posted July 17, 2017 Well, well you need roof, I don't think passengers would like to be driven in convertible in any weather. Nice progress. This bus will need licence to be used when finished - it is allready huge even with 62.4 tires... Quote
josszo Posted July 17, 2017 Author Posted July 17, 2017 (edited) I was in trouble, because I needed to use white 2length technic connectors to the windows, and doors. But Lego never made it in white color. So I have bought 100 pieces from this: The item is very rare, and very expensive. I have bought 100 pieces for 30EUR. Nowadays it costs on bricklink 1-2EUR/pcs So, project is go on. My plan was, I make black window frames into the doors, but in the earlier model it was not the best choice. I used this to install the frame, but the centre of this is larger, than any simple technic connector: There was more friction, and sometimes cannot open the doors, get stucked. Maybe i use doors without black frames :( Yes, it is very huge :) Edited July 17, 2017 by josszo Quote
josszo Posted July 20, 2017 Author Posted July 20, 2017 I have done the 4 doors, and the windows. The outfit is great. I will do pictures later. Quote
1gor Posted July 20, 2017 Posted July 20, 2017 On 7/17/2017 at 11:42 PM, josszo said: I was in trouble, because I needed to use white 2length technic connectors to the windows, and doors. But Lego never made it in white color. So I have bought 100 pieces from this: The item is very rare, and very expensive. I have bought 100 pieces for 30EUR. Nowadays it costs on bricklink 1-2EUR/pcs. Even sets containing this part in white were not cheap and above that they didn't have much of that parts included Quote
KikoTube Posted November 5, 2017 Posted November 5, 2017 Hello! What a great Project! I hope it will still be finished! Quote
josszo Posted November 6, 2017 Author Posted November 6, 2017 It was some delay, but I'm working again on the bus. Roof is under construction now, and maybe I will done before the end of the year. :) Quote
