Didumos69 Posted May 13, 2017 Posted May 13, 2017 (edited) This is an attempt to start collecting gearbox designs in a single thread. To get started, feel free to add existing gearboxes, but please always add a reference to the original designer. Also be sure to add some information on designer motorized or manual sequential or direct special features like paddle shifters and number of gears, e.g. 5+R. That will also help me in making an index in the OP. Or even better, if it can not be classified along these lines from the entry here, I will not add it to the index. Thanks! Edited May 13, 2017 by Didumos69 Quote
Zerobricks Posted May 13, 2017 Posted May 13, 2017 Good idea, suspension and gearboxes is where most people start when making supercars or even offroaders. I will post some of my ideas shortly. Quote
Didumos69 Posted May 13, 2017 Author Posted May 13, 2017 (edited) Sequential AWD 4-speed gearbox with V8 fake engine designer: Didumos69 motorized or manual: manual sequential or direct: sequential special features: 4wd with central diff, one-finger shifter, incl. V8 fake engine, the gear layout is the sequential counterpart of @Attika's Smallest 4 speed 4wd gearbox? number of gears: 4-speed This gearbox is an excerpt from my rugged supercar project. The mid-console has an important role in the overall stiffness of that model. It had to be narrow as well. If you build (have built) it, you will notice it has very little torsional flex. I wanted a 4-speed sequential gearbox covering a wide range of ratios. So not something like 1:2.5 upto 1:1, but rather something like 1:3:5 upto 1:0.8. Another requirement I had, was that I didn't want red clutch gears to transfer drive on axles rotating at different RPM. This is a common practice, but from modding the Porsche I know it induces a lot of friction on the axles involved. When not engaged, red clutch gears better only make dummy rotations and not transfer drive. And finally, all had to fit underneath the engine; I didn't want the gearbox to be routed through the entire chassis. Instructions available on Rebrickable.com. Edited April 11, 2018 by Didumos69 Quote
Didumos69 Posted May 13, 2017 Author Posted May 13, 2017 15 minutes ago, Zero (Zblj) said: Good idea, suspension and gearboxes is where most people start when making supercars or even offroaders. I will post some of my ideas shortly. Great! Quote
mocbuild101 Posted May 13, 2017 Posted May 13, 2017 (edited) When I build one I will post it here, but for now, here are some from Rebrickable: http://www.rebrickable.com/mocs/MOC-1152/JaapTechnic/gearbox-6-speed-nr/ - JaapTechnic http://www.rebrickable.com/mocs/MOC-6824/MrWoo/unusual-and-compact-5r-gearbox/ - MrWoo http://www.rebrickable.com/mocs/MOC-4911/Charbel/lego-technic-8-speed-sequential-gearbox/ - Charbel http://www.rebrickable.com/mocs/MOC-6829/Charbel/8-speed-sequential-gearbox-v3/ - Charbel http://www.rebrickable.com/mocs/MOC-5234/BrickbyBrickTechnic/lego-compact-4-speed-paddle-shift-gearbox/ - BrickbybrickTechnic http://www.rebrickable.com/mocs/MOC-5565/ibessonov/sequential-rc-4-speed-dual-clutch-gearbox-with-pf-servo-motor/ - ibessonov And @Sariel has some, but I will leave them for him to post here . Edited May 13, 2017 by mocbuild101 Quote
Attika Posted May 13, 2017 Posted May 13, 2017 Cool, I'll link my ones too sometime. Thanks for creating this thread. Quote
Milan Posted May 13, 2017 Posted May 13, 2017 Guys, when you post a gearbox, try to include one picture per gearbox and some short info about it, or at least just short info. It will massively help those who are searching for specific design. Quote
Didumos69 Posted May 13, 2017 Author Posted May 13, 2017 14 minutes ago, Milan said: Guys, when you post a gearbox, try to include one picture per gearbox and some short info about it, or at least just short info. It will massively help those who are searching for specific design. Thanks, I was about to ask the same thing. Some info on designer, motorized or manual, sequential or direct, special features like paddle shifters and number of gears, e.g. 5+R, would be nice. This will also help me in making an index in the OP. Or even better, if it can not be classified along these lines from the entry here, I will not add it to the index. 39 minutes ago, Attika said: Cool, I'll link my ones too sometime. Thanks for creating this thread. Sometime? I know at least two gearboxes from your hand. I can add them if you wish? Quote
Sariel Posted May 13, 2017 Posted May 13, 2017 Here's the best one of mine, 4 speeds + remote sequential shifting with a stepper: Quote
Attika Posted May 13, 2017 Posted May 13, 2017 2 minutes ago, Didumos69 said: Sometime? I know at least two gearboxes from your hand. I can add them if you wish? As it is a thread under your management and you have more experience shaping topics I'd be honored if you do it for me. Not to mention it is shaping up to be a busy weekend that is why I could not make a specific timing on it. Two of my gearboxes have their own topics here and there is one under the 8880 evo too. Thank you in advance. Quote
mocbuild101 Posted May 13, 2017 Posted May 13, 2017 43 minutes ago, Milan said: Guys, when you post a gearbox, try to include one picture per gearbox and some short info about it, or at least just short info. It will massively help those who are searching for specific design. Okay, I added Images at 100px wide. Quote
Rudivdk Posted May 13, 2017 Posted May 13, 2017 (edited) Here is my contribution: designer: Rudivdk Manually operated Direct operation special features: single pivot point for gearstick, linkage to gearbox, fits in 3studs wide center console number of gears: 5 forward, neutral and reverse I was inspired by Thirdwigg's 6speed gearbox from his Cadillac ATS supersedan, Crowkillers 4speed gearbox from his Asassin X19 and the 5+R gearbox from Nathanaël Kuipers' Predator. Ended up mixing them all with some inspiration from the 42054 Claas steering mode selector as well. Here's some vids (apologies for noob quality...) Gearbox in action Shifter linkage system in action Instructions PDF Edited May 20, 2017 by Rudivdk Updated instructions Quote
Leviathan Posted May 13, 2017 Posted May 13, 2017 (edited) I'm proud of my last version of the DCT (dual clutch) gearbox with 7 speeds. PFS and manual version. I will publish more information soon, make a new video and instructions. Designer : Levihathan Motorized by 2 RC motors and 1 XL for the shifter. Manual version switchable Sequential Dual Clutch, speeds sequence, AWD or FWD/RWD, differential bridge inside 7 speeds and Reverse Highly inspired by Sheepo's gearboxes. I learned a lot with frenches designers like NLF77 or Durian. This is a working version, compact and very reliable. Stay tune, I'm on the way to make a new video :) This is two to see the previous version in action, and a quick video to watch main features on this version. New one : https://www.youtube.com/watch?v=lWTlnuMJZl0 Previous one : https://www.youtube.com/watch?v=tRqLCK8UyzA Thanks :) Edited May 14, 2017 by Leviathan Quote
Kumbbl Posted May 14, 2017 Posted May 14, 2017 (edited) 12 hours ago, Rudivdk said: Here is my contribution: designer: Rudivdk Manually operated Direct operation special features: single pivot point for gearstick, linkage to gearbox, fits in 3studs wide center console number of gears: 5 forward, neutral and reverse I was inspired by Thirdwigg's 6speed gearbox from his Cadillac ATS supersedan, Crowkillers 4speed gearbox from his Asassin X19 and the 5+R gearbox from Nathanaël Kuipers' Predator. Ended up mixing them all with some inspiration from the 42054 Claas steering mode selector as well. Here's some vids (apologies for noob quality...) Gearbox in action Shifter linkage system in action Wow! Best non-Sequential-gearbox-shifter ever seen - because the most realistic one concerning driver-operation - the true successor of 8880-shifter with 5+R... this one and Didumous' sequential one are my favorites... top notch Edited May 14, 2017 by Milan Please don't quote images from the same page Quote
mocbuild101 Posted May 14, 2017 Posted May 14, 2017 12 hours ago, Rudivdk said: Here is my contribution: designer: Rudivdk Manually operated Direct operation special features: single pivot point for gearstick, linkage to gearbox, fits in 3studs wide center console number of gears: 5 forward, neutral and reverse I was inspired by Thirdwigg's 6speed gearbox from his Cadillac ATS supersedan, Crowkillers 4speed gearbox from his Asassin X19 and the 5+R gearbox from Nathanaël Kuipers' Predator. Ended up mixing them all with some inspiration from the 42054 Claas steering mode selector as well. Here's some vids (apologies for noob quality...) Gearbox in action Shifter linkage system in action Nice! Do you have instructions for this? Quote
Didumos69 Posted May 14, 2017 Author Posted May 14, 2017 4 speed 4wd gearbox with lockable diff designer: Attika motorized or manual: manual sequential or direct: direct special features: 4wd with lockable central diff number of gears: 4-speed 4 Speed 4WD Sequential Gearbox designer: Attika motorized or manual: manual, can be motorized sequential or direct: sequential special features: 4wd with central diff number of gears: 4-speed Smallest 4 speed 4wd gearbox? designer: Attika motorized or manual: manual sequential or direct: direct special features: 4wd with central diff, the gear layout is the non-sequential counterpart of @Didumos69's Sequential AWD 4-speed gearbox number of gears: 4-speed Quote
Rudivdk Posted May 14, 2017 Posted May 14, 2017 @mocbuild101 yes coming up, will raise a new thread once done Quote
mocbuild101 Posted May 14, 2017 Posted May 14, 2017 Wow @Attika, those gearboxes are amazingly compact! 40 minutes ago, Rudivdk said: yes coming up, will raise a new thread once done Great! I will keep an eye out for it, I'm very interested in building the shifting mechanism . Quote
Attika Posted May 14, 2017 Posted May 14, 2017 @Didumos69 Thank you for posting them. @mocbuild101 Thanks, I like to build in small scale, there wasn't many gearbox on the "market" in this size. Just filled the gap. Quote
Aventador2004 Posted May 31, 2017 Posted May 31, 2017 (edited) 2 speed + park Designer: @Aventador2004 RC or manual. manual shift lever. it's first gear ratios can be swapped from 3:1 to 5:3. 2 speeds + park. This gearbox is my first small, all my own idea gearbox designed for my air pocket supercar. It has two toward speeds that can have their gear ratios changed to fit your needs. The second special feature is a parking brake integrated into the system, while still being very small and sacrificing nothing but time to think of it. The gearbox doesn't have a video yet, but I will make one with the finished supercar. The yellow is to engine, LBG 7l axle is from wheels. Instructions here, and if you build it, feel free to use it your moc, (with a small credit to me of course). http://bricksafe.com/pages/aventador2014/2-speedpark Edited May 31, 2017 by Aventador2004 Added input Quote
Splat Posted June 3, 2017 Posted June 3, 2017 designer: Splat motorized or manual: Motorized (but could also be manual) sequential or direct: Sequential (using linear actuator) special features: can be changed to more or less gears number of gears: 3 Speed + Neutral + PTO more info: Eurobricks Topic -------- designer: Splat motorized or manual: Motorized (but could also be manual) sequential or direct: Sequential (using worm gears) special features: can be changed to more or less gears number of gears: 6 Speed + Reverse Quote
Alex Ilea Posted July 17, 2017 Posted July 17, 2017 On 14.05.2017 at 1:09 PM, Rudivdk said: @mocbuild101 yes coming up, will raise a new thread once done. Quote
mocbuild101 Posted August 31, 2017 Posted August 31, 2017 Found a gearbox amongst some older EB topics: Designer: @Rage_Hobbit Number of Gears: 4 Gear Ratio Spread: 5:1 - 1:1 Transmission Type: Dual-Sequential (manual) Synchronized? Yes Instructions? Yes (LDD file) Quote
1963maniac Posted October 21, 2018 Posted October 21, 2018 (edited) On 5/13/2017 at 3:36 PM, Rudivdk said: Here is my contribution: designer: Rudivdk Manually operated Direct operation special features: single pivot point for gearstick, linkage to gearbox, fits in 3studs wide center console number of gears: 5 forward, neutral and reverse I was inspired by Thirdwigg's 6speed gearbox from his Cadillac ATS supersedan, Crowkillers 4speed gearbox from his Asassin X19 and the 5+R gearbox from Nathanaël Kuipers' Predator. Ended up mixing them all with some inspiration from the 42054 Claas steering mode selector as well. Here's some vids (apologies for noob quality...) Gearbox in action Shifter linkage system in action Instructions PDF That gearstick mechanism is totally awesome!!!!!! I wish I had found this a long time ago. I'm blown away!! This is the only one of these I've seen that actually works!!! And, you posted the BI. THANK YOU!!! I'm building this today. Do you have any digital files of this, LDRAW, LDD, Stud.io, etc? Edited November 26, 2018 by 1963maniac Question Quote
