Posted May 15, 20177 yr Hi everyone! I am facing quite a difficulty: I want to build an oval-shaped building (here is the base piece), but the problem is that I don't know which tiling method I should use in order to create the floor. Should I use round 1 x1 quarter ones or other round tiles ? The U-shape bugs me. Please give me your impressions. If needed, some photographs (taken from an iPhone, sorry if the quality is not perfect) in order to catch the angles of the piece. Edited May 15, 20177 yr by Morangxs
May 16, 20177 yr Does the floor have to be at floor level? One thing you can do is place some spacers at the base and lift the floor up slightly to help when it comes to tiling. Although as with all curved interiors, square edged tiles will not tile perfectly to the edges.
May 16, 20177 yr Author 9 hours ago, MAB said: Does the floor have to be at floor level? One thing you can do is place some spacers at the base and lift the floor up slightly to help when it comes to tiling. Although as with all curved interiors, square edged tiles will not tile perfectly to the edges. I haven't really thought about it, but I guess it's not mandatory. Anyway, I'll try to find the perfect match!
May 18, 20177 yr you could make a nice flat floor by making a semi circle with bricks and curved slopes, studs not on top.
May 19, 20177 yr 4 hours ago, Nantucketdink said: you could make a nice flat floor by making a semi circle with bricks and curved slopes, studs not on top. This would be the nicest looking solution if you are able to have the floor a brick thick.
May 20, 20177 yr There is a new 2x2 macaroni tile piece. You could use 2 of those in conjunction with straight tiles and see how it looks flush mounted. You might be able to raise the tiles up so they overlap that roof(floor) piece for a nice finished look too. You would have to use a couple of the pie slice tiles inside of the macaroni tiles of course i just discovered there is a 4x4 macaroni tile. Didn't realize that even existed. That won't work for you, but good info to know. Thanks for making me look at bl.
