Posted May 23, 20177 yr I made a big truck with 4 xl's(driving), 1 servo(steering) and1 m(uplifting trunk). I'm using 2 battery boxes. and have 2 V2 receivers. Will this work? What setup should I use?
May 23, 20177 yr Depending on where each component is located, the setup will vary, but the ideal setup would be: 1st battery box with 1 receiver connected to 2 XLs and 1 servo 2nd battery box with 1 receiver connected to 2 XLs and 1 M-motor This way, the power drain is about even on both battery boxes.
May 23, 20177 yr Author 32 minutes ago, Leonardo da Bricki said: Depending on where each component is located, the setup will vary, but the ideal setup would be: 1st battery box with 1 receiver connected to 2 XLs and 1 servo 2nd battery box with 1 receiver connected to 2 XLs and 1 M-motor This way, the power drain is about even on both battery boxes. Ok and do I have to press 2 buttons on the remote control to use 4 xl's? Do I need to add a receiver to use 4 xl's with one button?
May 23, 20177 yr You can build a lever between both remotes to control two different sticks at the same time. Edited May 23, 20177 yr by LXF
May 24, 20177 yr Author Ok, is it possible to to connect one battery box to a V1 and a V2? And is there a limit to the amount of motors I can connect with one receiver?
May 24, 20177 yr @itoero There's no limit, but if many motors are connected, if one stalls slightly the whole receiver will kick in overheating protection. Yes ,you can connect as many PF components to one battery box as you wish , but the batterry box also has overheating protection, so it would be better to use two battery boxes if possible.
