Leonardo da Bricki Posted May 28, 2017 Posted May 28, 2017 (edited) Today I present to you my latest build: a motorized monster truck, still unfinished. Now Finished! Background: It was started last weekend after reading Sariel's book, "Incredible Lego Technic," which featured Crowkiller's monster truck MOC. I looked it up on his website where he had a photo of the chassis and the words "This model could easily be modified to be motorized and driven..." Now you all know what happens next... The Original: Crowkiller's excellent model is a manual 4x4x4 monster truck, with 5 link live axle suspension with diffs, a central differential, all-wheel HoG steering, a fake V8 connected to the drivetrain, and a detachable, and therefore, interchangeable, body. The Motorized Truck: The chassis length was increased by two studs in order to accommodate the two L-motors used for driving. The suspension geometry remains the same, though I will probably have to use the hard shocks... A Servo motor was added to control steering, as well as a standard AA battery box and a V2 receiver. I wanted to keep the central differential, but it would have required the body to be too wide. I also tried to incorporate the V8 engine, but the Servo motor and the steering shaft restrict the placement of gears to connect the fake V8 currently. What Is Planned: 1. A body (or two, or three, or four). 2. Reinforcement of the steering. At the moment, if I crash into anything at speed, (which happens frequently ) the front portion of the axle will bend to the side where the impact occurred. Which is not good. 3. Changing to the hard shocks, as the additional weight is already causing the suspension to depress most of the way... What Is Finished: See below what has been done. Also, LDD file instructions are available here. Photos: Wip MT side Wip MT front Wip MT under The Model Is Now Finished! Free Instructions Are Now Available! Click Here! More photos and information is on Page 2! Monster Truck Thanks for looking, feel free to give your honest opinion (anything from "I love it!" to "Why the &%#@ are you copying other people's work?!" is acceptable ) and any advice you want to. - Leonardo da Bricki Edited July 23, 2017 by Leonardo da Bricki Added instructions/photos/other junk... Quote
acidblue Posted May 29, 2017 Posted May 29, 2017 Looks great. Can't wait to see the LDD so I can try it out. Quote
1gor Posted May 30, 2017 Posted May 30, 2017 It looks interesting and very well balanced. What body do you plan to install on chassis? Quote
Leonardo da Bricki Posted May 31, 2017 Author Posted May 31, 2017 I'll have an update tomorrow, I need to finish fixing an issue with the axle bending out of shape when it crashes into something and add the change to an LDD file before I post that. @I_Igor Thanks, it is pretty well balanced, hasn't tipped over yet! No body yet, I was planning on some sort of truck-style body, maybe similar to a 2017 Ford Raptor. And maybe some sort of supercar body just for kicks. Maybe something like the BMW Z5 Concept. It was first shown in Mission Impossible 4, and I thought it looked awesome. However, I cannot build it full scale, I don't have the parts. BMW Z5 Concept Quote
1gor Posted May 31, 2017 Posted May 31, 2017 3 hours ago, Leonardo da Bricki said: I'll have an update tomorrow, I need to finish fixing an issue with the axle bending out of shape when it crashes into something and add the change to an LDD file before I post that. @I_Igor Thanks, it is pretty well balanced, hasn't tipped over yet! No body yet, I was planning on some sort of truck-style body, maybe similar to a 2017 Ford Raptor. And maybe some sort of supercar body just for kicks. Maybe something like the BMW Z5 Concept. It was first shown in Mission Impossible 4, and I thought it looked awesome. However, I cannot build it full scale, I don't have the parts. BMW Z5 Concept But for supercar you have to change tires, baloon ones are not perfect supercar tires Quote
Leonardo da Bricki Posted May 31, 2017 Author Posted May 31, 2017 Yeah, I'll try it with Unimog tires today. Hopefully they will fit. Photos and LDD coming later tonight! Quote
1gor Posted May 31, 2017 Posted May 31, 2017 3 hours ago, Leonardo da Bricki said: Yeah, I'll try it with Unimog tires today. Hopefully they will fit. Photos and LDD coming later tonight! For Unimog tires I suggest a bit longer wheelbase to prevent that model looks like Mickey Mouse car or some other cartoon vehicle Quote
Leonardo da Bricki Posted May 31, 2017 Author Posted May 31, 2017 Just now, I_Igor said: For Unimog tires I suggest a bit longer wheelbase to prevent that model looks like Mickey Mouse car or some other cartoon vehicle I don't know about that... I don't want to make it bigger. With a truck body, it should look fine. With Claas tires... Then a bigger chassis (and body) would be needed. Quote
1gor Posted May 31, 2017 Posted May 31, 2017 (edited) 3 minutes ago, Leonardo da Bricki said: I don't know about that... I don't want to make it bigger. With a truck body, it should look fine. With Claas tires... Then a bigger chassis (and body) would be needed. When you install different tires you'll make decision which tires will be the best and based on this go for optimal bodywork... as far as I see Unimog tires are good if there will be an offroader or (as you allready mentioned) truck (probably mean pick-up) bodywork Edited May 31, 2017 by I_Igor Quote
Leonardo da Bricki Posted May 31, 2017 Author Posted May 31, 2017 Update time! I have fixed the issues with the steering, both of flexing and of slack (for the most part...). If any of you geniuses out there want to add something about eliminating slack, it would be greatly appreciated. I have added Unimog tires, instead of the 81mm tires. I must say, I think this looks a lot better. And they don't hit anything when steered! WIP MT side WIP MT angle WIP MT front The white rubber bands were added to help control some of the slack, which works, but only to a certain extent. Also, I have the LDD file for the chassis here. Please feel free to give any advice, comments, or criticism you want. Thanks for looking! - Leonardo da Bricki Quote
1gor Posted June 1, 2017 Posted June 1, 2017 9 hours ago, Leonardo da Bricki said: Update time! I have fixed the issues with the steering, both of flexing and of slack (for the most part...). If any of you geniuses out there want to add something about eliminating slack, it would be greatly appreciated. I have added Unimog tires, instead of the 81mm tires. I must say, I think this looks a lot better. And they don't hit anything when steered! WIP MT side WIP MT angle WIP MT front The white rubber bands were added to help control some of the slack, which works, but only to a certain extent. Also, I have the LDD file for the chassis here. Please feel free to give any advice, comments, or criticism you want. Thanks for looking! - Leonardo da Bricki Leo, Perhaps you can use idea from Unimog; here yellow beam - like it was shown before on some eurobricks topic... I had similar problem on my Unimog and only beams could help me to make it sturdy enough Perhaps you can see it on this image of my model I hope it is useful (cant see LDD file due to limited resourced on my computer...) Quote
Leonardo da Bricki Posted June 1, 2017 Author Posted June 1, 2017 Thanks, Igor! I was already starting another axle with something like this, but there is so little space to do so... I'll try to finish it and get some photos up tonight. Quote
1gor Posted June 1, 2017 Posted June 1, 2017 You're welcome. I'm also trying to make some gearbox development for my Unimog U423 to make e-motor to look like fuel tank. But I won't publish them so soon. In comprisson to some builders here I'm slow as a sloth Quote
Leonardo da Bricki Posted June 2, 2017 Author Posted June 2, 2017 Today's update: 1. I have modified the axles so that there is a single tie rod now, which reduced some of the slack. I changed the rubber bands position to help with the remaining slack, but there is not much of a noticeable affect; the model still curves one way or the other while driving... Therefore, I will be removing them shortly... I don't know what else to do to reduce the slack (there is a LOT) because it results from needing to have the steering geared down... Any advice? 2. I will update the LDD file tomorrow. 3. I have started the supercar body, but I will need to place at least one Bricklink order, so I will probably switch over to the truck-style body for the time being... Photos: WIP MT axle f Sorry, not the best photo, but you can see the changes to the steering rod, as well as the front rubber band. WIP MT axle r Here you can see the second rubber band, which exerts the same amount of force, holding the axle in a centered position... When not driving and without wheels... Please give any advice, comments, criticism, etc. you want to. Thanks for looking! - Leonardo da Bricki Quote
1gor Posted June 2, 2017 Posted June 2, 2017 (edited) 12 hours ago, Leonardo da Bricki said: Today's update: 1. I have modified the axles so that there is a single tie rod now, which reduced some of the slack. I changed the rubber bands position to help with the remaining slack, but there is not much of a noticeable affect; the model still curves one way or the other while driving... Therefore, I will be removing them shortly... I don't know what else to do to reduce the slack (there is a LOT) because it results from needing to have the steering geared down... Any advice? 2. I will update the LDD file tomorrow. 3. I have started the supercar body, but I will need to place at least one Bricklink order, so I will probably switch over to the truck-style body for the time being... Photos: WIP MT axle f Sorry, not the best photo, but you can see the changes to the steering rod, as well as the front rubber band. WIP MT axle r Here you can see the second rubber band, which exerts the same amount of force, holding the axle in a centered position... When not driving and without wheels... Please give any advice, comments, criticism, etc. you want to. Thanks for looking! - Leonardo da Bricki Leo, I'll try to make some prototype over weekend and perhaps then we will be smarter... Edited June 2, 2017 by I_Igor Quote
Leonardo da Bricki Posted June 2, 2017 Author Posted June 2, 2017 At this point, I don't plan on changing the axle design any more, it is still fun to drive, you just have to correct it once in a while... I am just gonna focus on the bodies for now. Quote
1gor Posted June 2, 2017 Posted June 2, 2017 1 hour ago, Leonardo da Bricki said: At this point, I don't plan on changing the axle design any more, it is still fun to drive, you just have to correct it once in a while... I am just gonna focus on the bodies for now. Ok, then I'll mind my own business Quote
Leonardo da Bricki Posted June 3, 2017 Author Posted June 3, 2017 Today's Update! I have started the supercar bodywork, and it is coming along pretty good. So far, it is just a frame to figure out the size and shaping, but I figured out how to make the doors, I will use one of the Bionicle joints to make it open in this scale. For the blue streak, I have the small panel, and I will probably add some 3mm or pneumatic tubing to finish it. Photos will come tomorrow, I don't have a good light currently. Not to mention my camera battery is dead. @I_Igor You are welcome to mod my monster truck in any way, feel free to post the changes here, or you can PM me whatever changes you make, if you want to share them. I will happily brainstorm over the weekend on this issue, but that may fit better in the Axle Collection Thread than in this topic for the moment. Quote
Leonardo da Bricki Posted June 3, 2017 Author Posted June 3, 2017 A Small Update: More will come later, but for now, I have updated the LDD file. Quote
Leonardo da Bricki Posted June 18, 2017 Author Posted June 18, 2017 A Small Update: 1. I apologize for not keeping this thread updated over the last 2 weeks. I was busy job-hunting, but I did successfully land a job, so I have time to continue this project! 2. I will have some photos up later tonight of the truck body, but because of some real-life car troubles, I no longer have funding for the parts I would need for my planned supercar body. Maybe in the future! 3. An LDD file for this body has been started and is being updated as I build, I hope to make it availible later this week! Quote
Aventador2004 Posted June 18, 2017 Posted June 18, 2017 23 minutes ago, Leonardo da Bricki said: A Small Update: 1. I apologize for not keeping this thread updated over the last 2 weeks. I was busy job-hunting, but I did successfully land a job, so I have time to continue this project! 2. I will have some photos up later tonight of the truck body, but because of some real-life car troubles, I no longer have funding for the parts I would need for my planned supercar body. Maybe in the future! 3. An LDD file for this body has been started and is being updated as I build, I hope to make it availible later this week! Congrats on New job! Good to hear you still have time to build in your hobby. Quote
Leonardo da Bricki Posted June 20, 2017 Author Posted June 20, 2017 Tonight's Update: 1. The body: It is gonna be a bit more Jeep-like in shape than I had wanted, but it looks good so far, IMO... What do you guys think? 2. LDD: The LDD file is in progress, I will upload it as soon as I can, hopefully by Wednesday. 3. A Question: does anyone have, or know of, a good design for an air intake? I want to put one on, but have not made one that looks good... Photos: I apologize, these are a bit bright... WIP MT body s WIP MT body rq @Aventador2004 I will ALWAYS have time for Lego! More coming soon! Please give C&C! Thanks! - Leonardo da Bricki Quote
Leonardo da Bricki Posted July 3, 2017 Author Posted July 3, 2017 Today's Update: 1. An apology: I am very sorry, I have not updated this thread for the last two weeks. So I will remedy that issue. 2. The body: It is almost finished! Just the hood, lights, grill and bumper are left. And a bit of the rollcage. Hopefully within a few days it will be complete. 3. The LDD: The bodywork file is updated to the current, but incomplete body. I will update it once the body has been finished. The files are here. Photos: WIP MT rq The back is the most finished part, but there will be bars between the roof and rear. WIP MT Top Top view is just another perspective to show the shaping. Another update will come tomorrow or Tuesday! Please give C&C, and thanks for looking! - Leonardo da Bricki Quote
suffocation Posted July 3, 2017 Posted July 3, 2017 I like it - it looks nice and solid. Looking forward to a video. (Oh, and as a lover of everything Tuscan, I think that "Leonardo da Bricki" is the coolest nickname ever). Quote
Leonardo da Bricki Posted July 4, 2017 Author Posted July 4, 2017 4 hours ago, suffocation said: I like it - it looks nice and solid. Looking forward to a video. (Oh, and as a lover of everything Tuscan, I think that "Leonardo da Bricki" is the coolest nickname ever). It is really solid and quite sturdy. And I plan to reinforce it still more. I may make a video of the chassis this week, and hopefully, one of the finished model later next week. Thank you, I am rather proud of thinking it up! Quote
