Posted May 28, 20177 yr GRID D4. An Advanced Command Post of the Erotema Army in the middle of a forest area. Mushrooms, trees and grass cover a dark gray land. 1 by green helmet spanish AFOL, en Flickr The crew of a new Rocket Launcher Tank has been called to the HQ tent. 2 by green helmet spanish AFOL, en Flickr As a polite crew they are, asking permission is the first thing they do. 3 by green helmet spanish AFOL, en Flickr And the Officer in charge lets them in. 4 by green helmet spanish AFOL, en Flickr Another view of the Command Post. 5 by green helmet spanish AFOL, en Flickr Inside the tent... 6 by green helmet spanish AFOL, en Flickr And the orders are given soon... 7 by green helmet spanish AFOL, en Flickr Other views of the rocket launcher. 8 by green helmet spanish AFOL, en Flickr 9 by green helmet spanish AFOL, en Flickr The real thing is that I have been inspired on the US MLRS, because I refused to reuse -again- the SPH hull for another build in the same campaign, but it would have worked too. This design lacks the aft drive sprocket and there is a stud separating the 3rd and 4th wheels. This is a classical Christie drivetrain without support rollers. A remotely-operated .50 HMG on the roof provides light defense against infantry. The launcher has 12 cells, each of them capable of storing any missile or rocket up to 600 mm (approx, 2 studs are 68 cms) in diameter and 4 meters in length (approx). There is another version with 48 rockets. You´ll see it soon... Enjoy!
May 30, 20177 yr Very nice MLRS type vechicle. You are building a very strong artillery for your country
June 2, 20177 yr It's a powerfull MLRS and a good build. The bone detail adds to the feeling of beeing in the middle of a forrest. Good job!
June 6, 20177 yr You've Been Awarded (2) Point(s): Judges Comments (not all judges comment): Baseplate is clearly being recycled now, so this will affect your originality score. The MLRS is quite good. Looks like you nailed the proportions on it. The automated 50 seemed a little bit goofy to me, but that's just a preference thing. Next build should feature a completely new landscape, your capable of doing something great as we've seen. Stick with it! Would like some more views of the missle launcher, looks like a good build, unfortunately, we can only see two top views, both of which are very similar! And that base you are building on...you made a few changes from your previous side build, but not enough. I see trees relocated and a few plates adjusted, but the spacing with the tiles looks to be almost identical in spots, which tells me you are reusing the same build scenery. You can Update your AAR Post with your points to keep track. Thanks for Playing!
