This modular pizzeria was inspired by set Modular Building set number 10246: Detective Office while the delivery van was mostly taken from Teenage Mutant Ninja Turtles set 79104: Shellraiser street chase. The building levels lift off like a modular but it lacks modular building pins, a base-plate and is not the proper size. (being 18 studs square after all) Each building section has various details, and even the van has a lift-away roof with space for two pizzas in the rear heater unit.
The front of the model without the delivery van. Instead of the van you could potentially use set 71910, Scarecrow Special Delivery. (with the fear gas toxin stuff and Scarecrow figure removed, of course!)
The rear of the building is kinda plain.
The lower level features two tables, a counter, a opening pizza oven and stairs to the second floor.
The second floor features four tables with nine chairs and the top of the staircase. The outside of this floor has a neon sign above the front door on the lower level.
The van has seating for one driver figure and space for two pizzas in the rear heating compartment.
The roof and windscreen of the van lift away to get at the drivers seat, and all four doors open up. (two driver's doors in front, two for the heater unit in the back)
Here is the entire model together. The LDD file for the van and building is available here, if you want to build this for yourself. Bot models can be built in real life, but won't be built by me for a while... too much going on elsewhere in my life right now!
As usual, Comments, Questions, and Complaints are always welcome!
