BrickbyBrickTechnic Posted June 20, 2017 Posted June 20, 2017 (edited) Here's my latest WIP, the Ram 1500. This is mostly based on my desire to do a vehicle with 8 speeds. Ram 1500 has an 8-speed transmission in reality. The model has several functions in place already: -Steering -Drive (4x4) -Suspension (Front has positive caster angle, rear live axle) -8 speed transmission with 90-degree shift (Not done yet) Here's a picture: Drive is with 1 xl motor right now, but it will be changed to 2 as 1 does not have enough torque for gears 6, 7, and 8. Steering is with 1 m motor. The front suspension has a positive Caster angle. It was built by angling the suspension beams and securing them to the chassis. The rear axle is incredibly weak right now. PLEASE LEAVE A SUGGESTION FOR OW I CAN IMPROVE IT. Here's the gearbox up close. The entire section of the chassis is extremely dense, but the is no gear slipping when driving. Please leave a suggestion, and I will update the thread soon! Thanks for your attention. BrickbyBrickTechnic Edited June 26, 2017 by BrickbyBrickTechnic Quote
Lasse D Posted June 20, 2017 Posted June 20, 2017 Wow! That's an impressive gearbox! I would love to see some closeups/cutouts of the details. As for strength, I see that most other builders have success using a lot of the gray box frame parts in order to make a tough chassis. This might help you a lot since you have this issue. I suppose other members can share their experience with how to best construct such frames (I don't have much experience in this regard). Quote
BrickbyBrickTechnic Posted June 20, 2017 Author Posted June 20, 2017 Just now, Lasse D said: Wow! That's an impressive gearbox! I would love to see some closeups/cutouts of the details. As for strength, I see that most other builders have success using a lot of the gray box frame parts in order to make a tough chassis. This might help you a lot since you have this issue. I suppose other members can share their experience with how to best construct such frames (I don't have much experience in this regard). Thanks a lot! There's just 1 problem, and that's that I don't have many frames, and ordering doesn't come easy around here :) I'll certainly see what I can do, and provide more pics :) Quote
syclone Posted June 20, 2017 Posted June 20, 2017 (edited) 1. I see you used an illegal connection on front (angled liftarms) what makes that part of chassis to flex up. better find another solution , like making offset between top wishbone and lover wishbone. (so both aren't on same vertical axis) - see video below- 2. You steering links aren't pararell to the suspension wishbones , what will cause toe-in. -see video below- 3. Rotate the rear hubs 90 degrees (so the pinholes are on horizontal axis) , that will make for much stiffer axle I recommend you to watch Nicjasno's LPEpower series Edited June 20, 2017 by LXF Quote
Aleh Posted June 20, 2017 Posted June 20, 2017 LXF, nice constructive answer! I personally like the quality of the WIP photos.. Quote
Charbel Posted June 20, 2017 Posted June 20, 2017 2 hours ago, Lasse D said: Wow! That's an impressive gearbox! I would love to see some closeups/cutouts of the details. He actually used my gearbox : https://rebrickable.com/mocs/MOC-6829/Charbel/8-speed-sequential-gearbox-v3/ Quote
mocbuild101 Posted June 20, 2017 Posted June 20, 2017 (edited) You can easily strengthen the rear axle by swapping out the small beams with 4 9L beams per side. 10 minutes ago, Charbel said: He actually used my gearbox : https://rebrickable.com/mocs/MOC-6829/Charbel/8-speed-sequential-gearbox-v3/ I thought it looked like yours! Edited June 20, 2017 by mocbuild101 Quote
BrickbyBrickTechnic Posted June 20, 2017 Author Posted June 20, 2017 5 minutes ago, Charbel said: He actually used my gearbox : https://rebrickable.com/mocs/MOC-6829/Charbel/8-speed-sequential-gearbox-v3/ I did use your gearbox. It was the simplest design; anything I would have built would have been much more complex. Credit will be given to you in the final video. Quote
kbalage Posted June 20, 2017 Posted June 20, 2017 Nice start, I'll follow the topic as I also have plans to build a Ram at some point :) I'm curious how will you make the body. Quote
BrickbyBrickTechnic Posted June 20, 2017 Author Posted June 20, 2017 (edited) On 6/20/2017 at 3:21 PM, kbalage said: Nice start, I'll follow the topic as I also have plans to build a Ram at some point :) I'm curious how will you make the body. So am I :) On 6/20/2017 at 1:48 PM, LXF said: 1. I see you used an illegal connection on front (angled liftarms) what makes that part of chassis to flex up. better find another solution , like making offset between top wishbone and lover wishbone. (so both aren't on same vertical axis) - see video below- 2. You steering links aren't pararell to the suspension wishbones , what will cause toe-in. -see video below- 3. Rotate the rear hubs 90 degrees (so the pinholes are on horizontal axis) , that will make for much stiffer axle I recommend you to watch Nicjasno's LPEpower series You're right, there is definitely some toe-in. These videos will come in handy, thank you! Edited June 23, 2017 by Milan Please don't quote whole block of images and text. Quote
mocbuild101 Posted June 20, 2017 Posted June 20, 2017 (edited) I made a LDD model of an example of a stronger axle: (beams are in different colours for clarity) But don't forget to add the other parts you already have made . Edited June 20, 2017 by mocbuild101 Quote
BrickbyBrickTechnic Posted June 23, 2017 Author Posted June 23, 2017 UPDATE TIME! The chassis is almost, almost complete (the only modification necessary now is the toe-in). Here are some pictures and a list of mods: -Front suspension has 2 soft shocks now (had 1 hard one before) -2xl motors power this beast instead of one allowing drive on all gears but gear 8 -rear axle rebuilt (thanks @mocbuild101 for your idea... this axle is based on it) -shifting mech finalized Thanks for tuning in! Exams are done so progress time is NOW! BrickbyBrickTechnic Quote
Didumos69 Posted June 23, 2017 Posted June 23, 2017 14 minutes ago, BrickbyBrickTechnic said: the only modification necessary now is the toe-in When you update the steering setup, please also take into account that slanted steering rods make your steering very sensitive to bumps. See this video. Quote
BrickbyBrickTechnic Posted June 23, 2017 Author Posted June 23, 2017 14 minutes ago, Didumos69 said: When you update the steering setup, please also take into account that slanted steering rods make your steering very sensitive to bumps. See this video. Thanks! I'm getting to this now, so that issue will be addressed. Quote
BrickbyBrickTechnic Posted June 24, 2017 Author Posted June 24, 2017 Modifications have been made. The steering has been modified, but I'm not too sure about the new solution. Bodywork has been added. PLEASE GIVE ME TIPS. The model will be done around Thursday of next week. Thank you. Quote
kbalage Posted June 24, 2017 Posted June 24, 2017 I'd suggest to review the hood-cabin-bed proportions, they are far from the real one. The wheels are also way too big but I assume it can be a jacked up Ram :) Quote
BrickbyBrickTechnic Posted June 24, 2017 Author Posted June 24, 2017 3 minutes ago, kbalage said: I'd suggest to review the hood-cabin-bed proportions, they are far from the real one. The wheels are also way too big but I assume it can be a jacked up Ram :) It is, in fact, a jacked-up ram :) You're completely right about the proportion, and the hood needs reworking to as it is crude. Thanks a lot @kbalage ! Quote
Aleh Posted June 29, 2017 Posted June 29, 2017 (edited) I like the chassis very much but not the body, sorry. Body itself is well enought but no similarities with the RAM. Have you printed the blueprints of the real model? It looks like even the wheelbase is too short compare to the real model. Am I'm wrong? Edited June 29, 2017 by Aleh Quote
BrickbyBrickTechnic Posted June 29, 2017 Author Posted June 29, 2017 3 hours ago, Aleh said: I like the chassis very much but not the body, sorry. Body itself is well enought but no similarities with the RAM. Have you printed the blueprints of the real model? It looks like even the wheelbase is too short compare to the real model. Am I'm wrong? Thanks for your comments. The body has been much changed since the pictures shown above. I will post them in today and you can see again how close/far it is from the ram. Quote
Aleh Posted June 29, 2017 Posted June 29, 2017 13 minutes ago, BrickbyBrickTechnic said: Thanks for your comments. The body has been much changed since the pictures shown above. I will post them in today and you can see again how close/far it is from the ram. Sure, I'm waiting with interest for the update because I like American pickups. Quote
BrickbyBrickTechnic Posted June 29, 2017 Author Posted June 29, 2017 The final update! That's right! The model is basically done! Any edits you would like to see should be put on this topic within the next 48 hours. Here are the pictures! Thanks everyone for your help and attention! BrickbyBrickTechnic Quote
Aleh Posted June 29, 2017 Posted June 29, 2017 Nice photos! Front is looking like the real Dodge! Try to add some grill maybe? Quote
offroadcreations Posted June 29, 2017 Posted June 29, 2017 Very realistic and cool! It almost looks like some extreme, totally redone MOD of 42029. Quote
