BrickbyBrickTechnic Posted July 13, 2017 Posted July 13, 2017 (edited) Here's a vehicle that I believe has never been done in Technic before: An airport catering truck. This MOC intends to combine pneumatic and power functions. Here are the functions I have planned: -4 outriggers (PF) -Drive (PF) -Lifting the container (Pneumatic) -Opening front door (Pneumatic) -Opening rear door (Pneumatic) -Suspension, steering, fake engine Here's what I have so far: BTW, it is (loosely) based on this real truck: Leave some comments please! I need suggestions for battery box placement and gearbox reinforcement. Thanks! BrickbyBrickTechnic Edited July 17, 2017 by BrickbyBrickTechnic Quote
Paknaloid Posted July 13, 2017 Posted July 13, 2017 (edited) . Edited January 4, 2018 by Paknaloid Quote
1gor Posted July 13, 2017 Posted July 13, 2017 I see some solutions inspired by arocs, but very nice effort and it is always good refreshment when you see unusual model. @Paknaloid battery could fit there but it had to be rotated to 90 degrees and then it would not be shaped like in truck image...but good thinking Quote
BrickbyBrickTechnic Posted July 13, 2017 Author Posted July 13, 2017 47 minutes ago, I_Igor said: @Paknaloid battery could fit there but it had to be rotated to 90 degrees and then it would not be shaped like in truck image...but good thinking I actually do have an idea regarding this, as you will see tomorrow. @Paknaloid good suggestion :) Quote
1gor Posted July 13, 2017 Posted July 13, 2017 20 minutes ago, BrickbyBrickTechnic said: I actually do have an idea regarding this, as you will see tomorrow. @Paknaloid good suggestion :) Well "see" you tomorrow , but it could turn out interesting project.... Quote
1gor Posted July 13, 2017 Posted July 13, 2017 28 minutes ago, Paknaloid said: I suppose also if your build works out, it wouldn't be a huge stretch to use similar chassis to make a US style front loading garbage truck, something like I really like Technic MOCs of utilitarian everyday vehicles, they are a nice balance to all the amazing supercars that are built Completely agree on both comments Quote
Void_S Posted July 13, 2017 Posted July 13, 2017 6 hours ago, BrickbyBrickTechnic said: Here's a vehicle that I believe has never been done in Technic before: An airport catering truck. Well... It has done actually, B model of 8109 set, an "Airport Catering Truck" But it significantly differs from your project - an Americal-style longnose cabin and just a flat platform, with no any apparels for unloading form the from side, so I'm looking forward to see how your project goes. It looks very promising Quote
BrickbyBrickTechnic Posted July 14, 2017 Author Posted July 14, 2017 4 hours ago, I_Igor said: I see some solutions inspired by arocs The axles are inspired by the 42043. 2 hours ago, Void_S said: Well... It has done actually, B model of 8109 set, an "Airport Catering Truck" Ah yes, the 8109 b model... suffered from a condition called "severe lack of functions" ;) 3 hours ago, Paknaloid said: it wouldn't be a huge stretch to use similar chassis to make a US style front loading garbage truck That's a good idea... you got the gear inside my head to start turning :) Quote
BrickbyBrickTechnic Posted July 14, 2017 Author Posted July 14, 2017 Update time! Progress has been made! The cabin and some fenders are added and the position of the motor is changed. I have some questions for whoever's reading this... -After looking at the pictures, is the cabin too small? -How can I cover the front bumper with 1/2 thick beams? It's not really working out. Here are the pictures: Slide for the container: That's it for now! More progress later! BrickbyBrickTechnic Quote
Paknaloid Posted July 14, 2017 Posted July 14, 2017 (edited) . Edited January 4, 2018 by Paknaloid Quote
BrickbyBrickTechnic Posted July 14, 2017 Author Posted July 14, 2017 51 minutes ago, Paknaloid said: Oh wow, that's looking great! I don't think I was expecting the cabin to be so attractive, especially as the real life truck is quite ugly! my comments: will the position of the beacon lights interfere with the front loading of the containers? Would it work with smaller beacons, or is that the HOG a la the Arocs? edit: just realised the HOG is behind the lights... the windscreen could probably be made even taller by removing the liftarm a above the front panel, that would maybe make it look more like the real life trick, but could also make it uglier...I suppose it also depends how tall the main container body will be - as long as it isn't too massively out of proportion to the cabin it maybe won't matter same with cabin - if you extended it forward by one or two studs it'd maybe look more realistic but less attractive For the front bumper, would it work if you placed a 9l while liftarm on its side, insert a few 0.5l pins, then you could attach extra lights or grilles where the 1x2 white perpendiculars are now, and a 1x5 flat white tile across the middle for the licence plate? I can sort of picture it in my head but find it hard to describe, and can't really tell if it'd work or not... I'll give all of these a try- thank you! Quote
Leonardo da Bricki Posted July 14, 2017 Posted July 14, 2017 Comparing the photos to your build, I think the cab should probably be one stud taller. This is a nicely different build, I like the way it is coming along so far. Quote
1gor Posted July 14, 2017 Posted July 14, 2017 Model is starting to look very good. For front bumper - I do not know if there is dark bluish gray liftarm 1 x 7 thin... Quote
LEGO Train 12 Volts Posted July 14, 2017 Posted July 14, 2017 Wow I love this kind of truck ...very original idea! I'm waiting for your final masterpiece! Quote
BrickbyBrickTechnic Posted July 14, 2017 Author Posted July 14, 2017 3 hours ago, Leonardo da Bricki said: Comparing the photos to your build, I think the cab should probably be one stud taller. I made it a stud taller, and longer as well. I'll post the pictures tomorrow. 23 minutes ago, I_Igor said: Model is starting to look very good. For front bumper - I do not know if there is dark bluish gray liftarm 1 x 7 thin... I figured the bumper out, but thanks for the suggestion! 21 minutes ago, LEGO Train 12 Volts said: Wow I love this kind of truck ...very original idea! I'm waiting for your final masterpiece! Thanks alot! Quote
BrickbyBrickTechnic Posted July 15, 2017 Author Posted July 15, 2017 UPDATE TIME! The project is nearing completion, so if you want to add some suggestions PLEASE do that so I can implement them. Progress: -Chassis (Mostly) done, everything is in place -Spot for BB found -Cab made 1 stud longer and taller -Container mostly finished, all functions in place Here are the pictures! Unfortunately, I will have to cover the sides of the container with paper, but at least I will get to draw a nice logo :) What do I still have to do? -Finalise and reinforce container and chassis -Add interior to cabin Suggestions PLEASE! This may be your last chance as the MOC is close to done. Thanks! BrickbyBrickTechnic Quote
Paknaloid Posted July 15, 2017 Posted July 15, 2017 It just looks better and better. That spot for the battery is exactly what I was thinking. Are you going to post a video of the functions when it is complete? Quote
BrickbyBrickTechnic Posted July 15, 2017 Author Posted July 15, 2017 3 hours ago, Paknaloid said: It just looks better and better. That spot for the battery is exactly what I was thinking. Are you going to post a video of the functions when it is complete? Of Course! That should be coming out in a few days. Quote
TechnicRCRacer Posted July 15, 2017 Posted July 15, 2017 You are building this fast! One thing: Paper? Can you not add panels to the side? (Sorry, purism overload) Very cool model and looks very fun! Quote
BrickbyBrickTechnic Posted July 15, 2017 Author Posted July 15, 2017 1 hour ago, TechnicRCRacer said: You are building this fast! One thing: Paper? Can you not add panels to the side? (Sorry, purism overload) Very cool model and looks very fun! I'm a purist myself but the actuators already struggle to lift the container. Panels are lots of weight, and besides I don't have enough panels. I'll draw a nice logo on the paper as well ;) Quote
Erik Leppen Posted July 15, 2017 Posted July 15, 2017 I think paper is a good idea here. (I consider myself very purist ;) ). Panels are very ugly for such large flat surfaces because of all the holes and stripes and other texture (but that's my personal taste). And paper is super lightweight. The best purist solution would be to use 8x16 tiles, but I don't think they exist in white. You could maybe also print a nice logo. Quote
1gor Posted July 15, 2017 Posted July 15, 2017 2 hours ago, BrickbyBrickTechnic said: I'm a purist myself but the actuators already struggle to lift the container. Panels are lots of weight, and besides I don't have enough panels. I'll draw a nice logo on the paper as well ;) Nice progress and good solution for front bumper. Because of weight I try not to use pneumatic so often, but ther look more realistic that actuators and you can slip pneumatic hoses wherever you want. For interior seats you can use two of this parts https://www.bricklink.com/v2/catalog/catalogitem.page?P=24116&idColor=85 Quote
BrickbyBrickTechnic Posted July 16, 2017 Author Posted July 16, 2017 6 hours ago, Erik Leppen said: I think paper is a good idea here. (I consider myself very purist ;) ). Panels are very ugly for such large flat surfaces because of all the holes and stripes and other texture (but that's my personal taste). And paper is super lightweight. The best purist solution would be to use 8x16 tiles, but I don't think they exist in white. You could maybe also print a nice logo. I will be drawing the logo. You'll see, it'll look great ;) Quote
