Jim Posted July 18, 2017 Author Posted July 18, 2017 1 hour ago, suffocation said: Hi Jim, do you think the track width could be any narrower without the wheels bumping into the chassis or the bodywork? At the rear without a problem. The front will need some tinkering though. Two liftarms and connectors need to be repositioned. And maybe they will hit the front "fender" (not sure how that is called). If you are redesigning the chassis anyway, you can try to apply this mod. I would love to see the result Quote
Lakop Posted July 18, 2017 Posted July 18, 2017 i'm almost tempted to buy it and make it better (not read your review yet, Jim). H Quote
Jim Posted July 18, 2017 Author Posted July 18, 2017 Just now, Horace T said: i'm almost tempted to buy it and make it better (not read your review yet, Jim). H If you don't mind the price and like to MOD a set, this is the set for you. You can have a lot of fun rebuilding this set. In that way it's more fun than a "perfect" set Quote
BrickbyBrickTechnic Posted July 18, 2017 Posted July 18, 2017 4 minutes ago, Jim said: If you don't mind the price and like to MOD a set, this is the set for you. That alone makes me want to consider buying the set! Quote
suffocation Posted July 18, 2017 Posted July 18, 2017 (edited) 54 minutes ago, Jim said: At the rear without a problem. The front will need some tinkering though. Two liftarms and connectors need to be repositioned. And maybe they will hit the front "fender" (not sure how that is called). If you are redesigning the chassis anyway, you can try to apply this mod. I would love to see the result Thanks! I guess it's easier to redesign the whole thing. This is a quick mock-up with central and rear locking diffs, high-low gearbox and live axles (notice the front diff mounted the wrong way - I've had those axles around for a while and couldn't be arsed to turn the diff around just for a mock-up). The trackwidth is narrower than 42070, whereas the wheelbase should be pretty close. (Edit: the wheels are all mounted the wrong way around, too ) Edited July 18, 2017 by suffocation Quote
schraubedrin Posted July 18, 2017 Posted July 18, 2017 Question: Wouldn't it be enough to lock the front differential to get quite a lot more truck trial capability? Quote
valenciaeric Posted July 18, 2017 Posted July 18, 2017 29 minutes ago, schraubedrin said: Question: Wouldn't it be enough to lock the front differential to get quite a lot more truck trial capability? The priority for locking would be 1) centre 2) rear 3) front Locking only the front would make it a 2wd with no steering capabilty. Locking the centre would give you min 3wd - one wheel on each axle. Quote
schraubedrin Posted July 18, 2017 Posted July 18, 2017 9 minutes ago, valenciaeric said: The priority for locking would be 1) centre 2) rear 3) front I understand the 2wd / 3wd argument. But isn't it far more probable that one wheel on one axle looses contact than one whole axle loosing contact? 14 minutes ago, valenciaeric said: no steering capabilty I've got to admit, i completely forgot about steering Quote
valenciaeric Posted July 18, 2017 Posted July 18, 2017 If one front wheel loses traction then all torque will go to that wheel with an open centre diff. If you lock the front diff then you will have less efficient steering and any slip from the rear wheels will transfer torque to them. Ideally, it is best just to eliminate the centre diff as the turning circle is so wide anyway and there are no drive shafts to break, just uni joints on the front. Quote
schraubedrin Posted July 18, 2017 Posted July 18, 2017 15 minutes ago, valenciaeric said: any slip from the rear wheels will transfer torque to them I understand. I thought that it might be improbable that both rear axles will lose grip. Anyway, thanks for this short lecture on diff locking, i quite enjoyed it Quote
Chase Rosipayla Posted July 19, 2017 Posted July 19, 2017 (edited) To Jim, Well some of us make money having fun. Edited July 20, 2017 by Chase Rosipayla Quote
Jim Posted July 20, 2017 Author Posted July 20, 2017 8 hours ago, Chase Rosipayla said: To Jim, Well some of us make money having fun. Me too, but that doesn't involve LEGO (at the most, I am saving some money) Quote
MattL600 Posted July 20, 2017 Posted July 20, 2017 Lower the whole thing, remove the outriggers, use independent suspension on all wheels and swap out the bed for 4 XL motors and a W16 engine. Maybe, we can call it a dakar truck or something. (basically a fast version without all the tow truck functions :3) Quote
Jim Posted July 20, 2017 Author Posted July 20, 2017 Just now, MattL600 said: ...remove the outriggers... Noooooooo On 18-7-2017 at 8:47 PM, suffocation said: This is a quick mock-up with central and rear locking diffs... Any progress on the chassis? Quote
MattL600 Posted July 20, 2017 Posted July 20, 2017 8 minutes ago, Jim said: Noooooooo But... 42070 hot rod? Quote
suffocation Posted July 20, 2017 Posted July 20, 2017 16 minutes ago, Jim said: Any progress on the chassis? Not yet - but I started building a new crane, which is basically the same as a design I used on another tow truck. (I have no idea why Bricksafe keeps flipping the second picture - is it because it's too penile?). Quote
jotta93 Posted July 20, 2017 Posted July 20, 2017 1 hour ago, suffocation said: Not yet - but I started building a new crane, which is basically the same as a design I used on another tow truck. (I have no idea why Bricksafe keeps flipping the second picture - is it because it's too penile?). Nice work, looking forward to this! I had the same problem with one of my photos and have already alerted Nathan to it. He's working on it (I hope) Quote
Paknaloid Posted July 28, 2017 Posted July 28, 2017 Maybe just build this instead https://rebrickable.com/mocs/MOC-8976/Ivan_M/military-recovery-truck/#info Quote
nick97 Posted July 29, 2017 Posted July 29, 2017 Hi all, As this is a mod topic, I have one for you. I the pictures you can see the HOG I've made using the second gear on the gearrack. Replacing the batteries is still possible, you only need to remove the gear. It took me about 30 minutes to build. The hardest part was removing the 3L axle with stop and placing a 4L with stop. And I had the tan gear on the wrong side, so it turns the wrong way. You are free to use it and/or improve it. Quote
Aventador2004 Posted July 29, 2017 Posted July 29, 2017 Nice! I don't think I will get this, so I can only look. Good mod. Quote
efferman Posted August 2, 2017 Posted August 2, 2017 a spring loaded suspension on the last axle to raise the groundcontact in offroad conditions Quote
efferman Posted August 4, 2017 Posted August 4, 2017 Some monkey is hanging around Closed the unfinished flatbed This gap has to be closed too strenghtened frame Quote
efferman Posted August 4, 2017 Posted August 4, 2017 A official creator set into the hall of fame? Quote
