August 9, 20177 yr Well, you're building skills are far from abysmal, as you've already surpassed the drivetrain and suspension of 42070
August 10, 20177 yr If you managed to build this chassis, you are of a wonderfully high skill level. I don't know for sure how good/bad that turning circle is, but for this monstrosity, that seems to be pretty good.
August 10, 20177 yr @suffocation IMHO this is true flagship (not flapship) for this year ...and if you could make it with black rims and gray bodywork?
August 10, 20177 yr Love it, except one thing the shocks. These are the "expensive ones" but i keep following this one. Here and on Lego Technic. Love to see how the whole moc will turn out..
August 10, 20177 yr Looking good; however I want to alert you of a possible flaw. I having made a few chassis myself, I can speak from experience that the you are better off using the 12 tooth (not the bevel) gear in almost every circumstance. Believe it or not, the knob gears are very weak because each knob, while large, is held on to the center by a relatively thin piece of plastic.
August 11, 20177 yr 3 hours ago, suffocation said: @I_Igor: I don't think I have enough DBG parts for a decent body I might go for something like the Arocs or Lucio's latest crane truck. Black and red would also look nice and aggressive but it's kind of old; furthermore, I already used that scheme on my other tow truck. White is not that bad, with red rims it could look interesting. Crane solution is really good
August 21, 20177 yr 7 hours ago, r-guo08 said: WOW, Way better than 42070. Yes true flagship for this year
