Question: What do you get, when you cross a tank, with a banana, a scorpion, a V8 engine, and a bunch of stud-shooters?
Answer: The Banana Scorpion! :grin:
Color scheme: Yellow, with some black and grey.
Driver: A Big Giant Banana-eating Tiger! :laugh: (this one)
Powered Functions:
  • Drive: Tank tracks - powered by 2x M-motors. (also used for steering)
  • Steering: Tank type skid steering.
  • Engine: A massive V8 - powered by a high speed motor.
  • Wacky function 1: Lifting hull mechanism - powered by M-motor.
  • Wacky function 2: High speed spinning sweeper - powered via V8.
  • Wacky function 3: The ability to tank-wheelie!!! :tongue: (with some help...)
Manual Functions: (aka: weapons)
  • Cannon: A giant cannon mounted on the end of the adjustable scorpion tail.
  • Stud-shooters: Front: 2x six-round, and 2x single-round - Rear: 4x single-round.
  • Spring-shooters: 2x rear-mounted. (can be triggered by driver)
The story of how The Banana Scorpion was built:
Spoiler
Days 1-10: Thinking of, then discarding many ideas. (including a banana monster truck, a jet powered brick, and a Yeti-mobile)
Day 11: I finally know the perfect thing to make - a banana tank!
Day 12: Built a test for the suspension, created WIP topic.
Days 13-15: Built and tried multiple types of suspension, which none of them were right for the size of tank I'm building. (including torsion bars - which were too wide - and standard tank suspension using shock absorbers - which was too long/tall)
Day 16: I abandoned the suspension after finding it was too difficult, and because had an idea of a much wackier function.
Day 17: Built a prototype of my idea, which worked, then built a more refined version.
Days 18-20: Improving scissor mechanism, trying to work out how to attach LA.
Day 21: I realized 1 LA wouldn't be strong enough, so started trying to figure out how to fit 2 LA's in such a small space.
Day 22: I worked out how to power 2 LA's with a L-motor.
Days 23-29: I made very little progress, as I had quite a lot of distractions...
Day 30: I decided it was time to start building again, and I made a fairly major design change: get rid of the LA's and motor, and save some space! (which means I completely removed the mechanism shown above, and making the lifting function manual)
Day 31: I made even more design changes (of the better kind), and changed the name accordingly. Made the concept drawing:
Day 32: Brickstormed some ideas for the revised lifting mechanism, the mouth (with not much success), and the tail.
Day 33: Put together the V10 engine, then tested it, and made a video of it. (because of it's awesome sound!)
Day 34: I realized that the engine was too long to fit in the space I had, so I changed the design, and also added two more cylinders!
Day 35: Decided to cover the outside of the tracks - to make them look better.
Day 36: Built the other side of the tank. (just a mirror of what I had already built)
Days 37+38: I started work on the motorized lifting mechanism again (it seems to work quite well!), and made a short video of it (without tank attached).
Day 39: More work on lifting mechanism - building the hull around it, fitting it between the tracks.
Day 40: Built scorpion tail (with cannon attached!), some more work on tank hull and engine. (which got shrunk back to V10 again)
Day 41: I put all the major components together (tracks, lift mechanism, engine, and tail), to see how they fitted together.
Day 42-45: Completely rebuilt hull, extended the whole tank by two studs and shrunk the engine down to V8 so I could fit in the PF receivers.
Day 46: I started to shape the hull with some slopes - to make it more like a banana, added some stud-shooters.
Day 47: I needed some parts, so I put in a Bricklink order.
Day 48: I started looking for a new driver, and found one in the form of a Tiger! (this one)
Days 49-52: Continued shaping the hull, built a spot for the driver, and added even more stud-shooters!
Day 53: I decided that I needed another wacky function, and I realized that I could use the V8 to power it, and managed to squeeze in a small spinning sweeper.
Day 54: My Bricklink order finally arrived, so I was able to finish the shaping of the hull, and rebuild the tracks - which meant I was finished building! And with that done, I took some photos...
Day 55: Filmed the videos of all the functions, and started editing them - including the removal of these two bloopers!
Day 56: More editing of the video...
Day 57: Finished the video, and uploaded it:
Day 58: Posted in entry topic - I'm finally done!!! :sweet:
Edited by mocbuild101
  • Replies 88
1 minute ago, mocbuild101 said:
Functions:
  • Drive: 2x M-motors. (also used for steering)
Your idea sounds and good and crazy but i would recommend you to ask @Jim if the skid steering is acceptable for the contest.
Agreed, but I think it is... (and I really hope so, because if it's not, I will have to change my idea again! :cry_sad:)
On ‎15‎/‎08‎/‎2017 at 5:07 PM, Jim said:
7: My Wacky needs to be able to steer. What do you mean by that?
Your vehicle needs to have functionality to change direction, so there needs to be a steering mechanism.
55 minutes ago, Superkoala said:
technically this is a tank with a steering wheel
That's great for plan B!
1 hour ago, I_Igor said:
Perhaps offer him a banana discount :roflmao:
I think the bananas might be a bit too chewy... :tongue:
You probably have natural banana and not genetically modified :wink:
When we discouss about modifications, perhaps simple steering modification would be enough. But banana tank is original idea. At the first I thought it is all about tank that uses banana as munition :roflmao:
Well I do have something like that in mind for one of my weapons, but not exactly... :smug:
...imagine if you have guests with appetite for bananas - it would be expensive banana party :laugh:
LOL! I did a half track quite recently, would be a great idea.
Would be fitting for a cannon of some sort :3
That's what I meant by what I said in the comment above, and it will have some very strange ammunition! (not bananas)
A super long poking stick? :laugh:
16 hours ago, Aventador2004 said:
you should leave it.
I'm going to stick with the normal tank design. unless @Jim does't like it, which then I would change to plan B - which is a half-track.
17 minutes ago, mocbuild101 said:
I'm going to stick with the normal tank design, unless @Jim does't like it, which then I would change to plan B - which is a half-track.
Aha you have an A model and B model - just like typical LEGO set :wink:
No, I have one model - which is what my original idea was, and I am currently building.
I checked the rules, it is allowed.
I heard you the first time... I just wanted @Jim to confirm it. (so I will PM him, and end this debate!) Done!
Edit: @Jim has confirmed that it is allowed! :grin: (so there's no need for plan B!)
Okay, update time...
I'm sorry about the lack of (any) updates, but I had some trouble making the right suspension...
Day 17 (today): Built a prototype of my idea, which worked, then built a more refined version, which you can see below. (but can you guess what it does? :smug:)
Which means... This is what I have built so far:
I know, not much... :sceptic:
8 minutes ago, mocbuild101 said:
There is no suspension anymore... only LA's :wink:
I thought that black liftarms are connected to shock(s) from the back side.
I can see that you have small battery box and nothing more...:sceptic:
17 hours ago, Jurss said:
Some banana shooter ...
I have suggested few days ago but munition would be rather expensive :laugh:
Edited by I_Igor
Yet...
I decided not to make that, as it's way too obvious... But I probably will add a cannon of some sort.
