Posted September 13, 20177 yr Hello everyone, My current project is the construction of a Liebherr 250 EC-B towercrane in 1:18 scale. The model is fully functional. The hoist winch is powered by one XL-Motor, the trolley winch uses one M-Motor and the slewing ring is powered by two L-Motors. All motors are controlled by an S-Brick. I have started building this model 4 months ago. Here the crane is assembled with 110 cm tower and 180 cm jib: The maximum height under hook is about 2 meters; the maximum jib length is 230 cm. The total length of the model with 230 cm jib is 330 cm. Here the crane is assembled with 150 cm tower and 230 cm jib: The crane can be disassembled into the same number of small parts as the real crane. These parts have roughly the scale measurements. Thanks to efferman´s turntable support ring the slewing ring is quite stable and rotates well (in the first video above the support ring was not attached yet, that is why the crane swings so much when it lifts or drops the load). The maximum capacity of the crane is approximately 400 grams in 2 fall-operation. But there is a second trolley and hook which allow an automatic change between 2 und 4 fall operation. The mechanism is the same as used for the real Liebherr fast erecting cranes und smaller EC-Bs. Edited September 13, 20177 yr by PistenBully 600
September 13, 20177 yr Works just fine. The Problem could be Error 60 ;) Edited September 13, 20177 yr by cookiedent
September 13, 20177 yr Author I spent the last two months in creating a climbing unit for this crane. Real tower cranes use climbing units to climb up along growing buildings during construction. The climbing unit lifts the complete upper part of the crane, including the crane head and counter jib. A hydraulic cylinder mounted at the climbing cage braces itself on a “K” shaped strut of the tower and presses the upper part of the crane upwards. This happens 5 times until there is enough space beneath the slewing ring to insert the next tower section. Here is an animation that shows the system developed by Liebherr: The climbing unit was the most difficult feature of this model. At first, with the crane in its smallest configuration with 150 cm jib, it has to lift a weight of 4.2 kilograms. The finished climbing unit has a weight of 1.8 Kilograms, so the total load that has to be lifted (including one tower section in front of the climbing unit) is around 6.5 kilograms. This load is lifted by two linear actuators, extended by strings with a tear strength of 35 kilograms. Any other string I tested has torn. The two cylinders are powered by one XL-Motor using a worm gear with 1:24 reduction. But anyway the motor has to struggle with the weight. Fortunately I found out the right dimensions of the climbing frame so that it guides the tower very well without too much friction or backlash, which is very important for the climbing process. This is because the climbing unit has to absorb all kinds of imbalance of the upper crane, which could not be adjusted by the counterweight or the position of the trolley and hook. So the climbing cage has to be very stable, too. Especially when the climbing process itself is done and the next tower section can be inserted. At this time, the climbing cage touches the tower at a length of only 15 cm. All upcoming forces have to be absorbed by this small part of the cage. But this is enough of writing – after all there was the final load capacity test with a load of 4.8 kilograms (6.7 kilograms including the climbing unit). And what shall I say? It worked! Here is a picture of the climbing cage lifting this weight: After adding some details such as walkways and a small trolley powered by 2 micro motors for inserting the tower sections, the climbing unit was finished: The lifting unit: Here is a video of the climbing process: And a video of the crane climbing back down. In real life this happens when the construction of skyscrapers is completed and the crane can be disassembled: At the moment I am improving the model and I am reducing some weight in the upper structure. The jib lost 200 grams at a length of 200 cm: All in all this is a very cool project for me and I like the result. I hope you like it, too - feel free to comment.
September 13, 20177 yr Great model and I am just in awe, especially regarding the short timeframe it took to this point! :)
September 13, 20177 yr Love it, especially how all the studded parts make it look so imposing. Do you have a link to the string you used?
September 14, 20177 yr Amazing... It huge!!! And it works great. Excellent model. 2 meters tall... That is a lot taller than I am!
September 14, 20177 yr Author Thanks! @suffocation the string is 0.15 mm fishing line. I don't have a link because I didn't buy it online. @Aleh The crane is a LTM 11200 in 1:50 scale produced by NZG: http://www.nzg.de/liebherr-ltm11200-9-5396.html
September 15, 20177 yr 11 hours ago, PistenBully 600 said: Thanks! @suffocation the string is 0.15 mm fishing line. I don't have a link because I didn't buy it online. @Aleh The crane is a LTM 11200 in 1:50 scale produced by NZG: http://www.nzg.de/liebherr-ltm11200-9-5396.html Thanks! Your Libherr 250-EC is really amazing! True stuff for any Lego or building equipment exibition!!
September 15, 20177 yr A big waow. And congratulations. Probably one on the best model I've seen these days. I'm very surprised by the stability during movement, even with a load. Very great work.
September 25, 20177 yr Author Thanks! I spent the last days optimizing the jib by reducing some more weight and making it more straight. I will let you know when there are some more news about this model, but it's mostly finished.
October 3, 20177 yr Author Hi, here are some pictures of the erection of the Liebherr 250 EC-B with 147 cm tower and 200 cm jib (in reality this are 26 m tower and 35 m jib, so it's a quite small configuration. The maximum tower heigth and jib length are 70 m). Tower and crane head were already installed: Then the counter jib was mounted: Because of the weight of the counter jib, it tilted quite a little: Then the jib and 2 counterweight blocks were attached: After reeving the hook, the crane is ready for any lifting operation. I hope you like this short report.
November 9, 20177 yr Amazing MOC!! :) This is the most realistic Lego model of a tower crane so far that I have met! I can see You are a tower crane- and a ropeway fan too, just like I am. :) Cool!
November 10, 20177 yr Oh wow, I don't think I've ever seen a Lego tower crane with a functional climbing frame before, and the automatic switching between falls of rope is brilliant. Keep up the great work. do you think you could post an LDD file for the hook block with the auto switching? I'd really like to see how that mechanism works. Edited November 10, 20177 yr by Saberwing40k
December 20, 20177 yr Author On 10.11.2017 at 1:22 AM, Saberwing40k said: Oh wow, I don't think I've ever seen a Lego tower crane with a functional climbing frame before, and the automatic switching between falls of rope is brilliant. Keep up the great work. do you think you could post an LDD file for the hook block with the auto switching? I'd really like to see how that mechanism works. Hi, At first sorry for the late answer. I didn't check this topic for too long. I don't have a lxf of this mechanism yet. But here you can see a video of how it works at a real crane: I just rebuilt this mechanism with Lego. I hope the video helps you. Otherwise let me know.
October 5, 20195 yr Author There have been some updates to the crane this year and I want to show you these. In april I assembled the crane outdoors with a jib length of 2 meters and an overall length of 3 meters. For the first time I assembled the crane with an overall heigth of 290 cm.
October 5, 20195 yr Author Since may I am optimizing and rebuilding the crane. First I built a new hook block an trolley. Their measurements fit to the scale measurements of the real crane. In addition they have less weight now, what is good for the crane performance. Next I optimized the jib. This means that the connection points between the liftarms along the top of the jib and the technic bricks along the ground sides of the jib became smaller and less heavy by this. I also changed the profile and lattice work of some jib sections in order to make the jib more straight. Befor this modification the maximum usable jib length was 200 cm. During a former test with a 230 cm long jib it bended quite a lot and the end of the jib hang quite down. But because of the mentioned improvements the "standard long jib" configuration for work and exibitions increased to 240 cm jib. With this lengt the jib is still perfectly straight and the crane needs less counterweigth than the early version with 230 cm jib. The new maximum jib length is 270 cm - as much as my Liebherr 280 EC-H with tower top and pendant bars has. But the jib of the 250 EC-B is even much more straight. So this modifications brought a hugh benefit to the size and performance of the crane. In the next step I built a complete new crane head with the slewing ring and "tower top". The slewing ring is now 100% built of lego and the slewing speed was decreased using a 1:3 gearing before the worm gear which turns the turntable. This decreased the slewing speed to a very nice speed range from a fine-positioning slow speed up to a quite fast but good controlable and scale top speed. Here are some pictures which show the crane after this first improvements at the ABSolutSteinchen exibition in june. The crane was assembled with 240 cm jib (340 cm total length) and a heigth of 211 cm. It worked a lot at during the exibition and it was a lot of fun operating it and sleving overhead the other exibitors :D First a picture of the new crane head: Here are three videos of the crane during the exibition: Edited October 5, 20195 yr by PistenBully 600
October 5, 20195 yr Author The next point to improve was the hook assembly for changing the number of falls of rope. The old mechanism worked quite fine but it was big, heavy and did not look the most realistic. So I rebuilt the trolley and hook block in order to make it look more realistic and to decrease the size. Also the changing operation is much more smoothe now. Two fall of rope mode for light loads: Four fall of rope mode for heavy loads: Trolley in working position (red flaps point downwards) : Trolley in switching position (red flaps are pushed apart to indicate that the switching process is working properly and to indicate the end of the switching process - just like the real crane's mechanism: And a video showing the switching process:
October 6, 20195 yr Author During the last days I developed a new counter jib using the Lego Digital Designer. The aim was to make it more straight, to reduce the weight and to make it look much more like the real counter jib. The new counter jib is build out of usual bricks and plates - instead of technic bricks - to create a much better look. Unfortunately the new jib is one part, both the old jib and the real counter jib consist of two parts which can be taken apart for more compact transport loads. But this was not possible for the new counter jib because I wanted it to be straight and in addition a possible connecting point would not be easy to realize with the new building technique. The new hoisting winch drum has the scale measurements and is driven by a L-motor. The drum itself has an integrated planetary gear with 1:4 reduction to increase the load capacity of the crane. During the next weeks I want to collect all the needed bricks to build the counter jib in real. I hope it will be as stabile and strong as needed. I think the final design meets the real counterjib quite good - what do you think? Here is a picture of the real one for comparison (the upper crane); source the old counter jib: The new version: The real hoisting winch drum uses the old turntables. But these are no separate parts in LDD.
