the imperial reporter Posted September 16, 2017 Posted September 16, 2017 I recently Purchased a Bulk of old Bionicle and I it came with one of the Inika Swords. I put in new batteries and it worked, but how do you turn it off? The Batteries were quite expensive and i would hate to waste them. Quote
VBBN Posted September 16, 2017 Posted September 16, 2017 The sword should turn off itself. Normally when you push the button, the sword will start with a slow strobe effect, then move to a fast strobe effect, slow down again and end. Should only be lasting 7-10 seconds tops. If it's not turning off, it's possible it was put together incorrectly in a way that the button is constantly being pressed down or perhaps the batteries are in there in a janky way? Quote
Foxw Posted September 16, 2017 Posted September 16, 2017 i ran into this one a "lot" inka sword before. likely it's a short on the board, disassemble, pull the black part out , take a soft head eraser, and clean the contact on the board should fix it if its just corrosion Quote
THELEGION818 Posted January 10, 2024 Posted January 10, 2024 On 9/17/2017 at 9:00 PM, the imperial reporter said: Thanks Hello my friend I have the same problem but I dont know how to fix it, I tried to clean the led with the eraser but still doesnt turn off after 10 sec. How did you fix it? Thanks in advance On 9/17/2017 at 12:23 AM, Foxw said: i ran into this one a "lot" inka sword before. likely it's a short on the board, disassemble, pull the black part out , take a soft head eraser, and clean the contact on the board should fix it if its just corrosion Hello my friend I have the same problem but I dont know how to fix it, I tried to clean the led with the eraser but still doesnt turn off after 10 sec. How did you fix it? Thanks in advance Quote
