Posted September 23, 20177 yr Hello. Are there any differences between Azog from SDCC 2013 and Azog from the set 7914? thank you for your help. Edited September 23, 20177 yr by Dolce
September 24, 20177 yr No. I'm pretty sure they're identical. I don't think Azog was listed as an exclusive... same way Bard the Bowman wasn't the following year.
September 24, 20177 yr Author But someone told me that they are different colour. Is it true? Edited September 24, 20177 yr by Dolce
October 27, 20177 yr Hey man! Yes there is a difference, and no, it's not the color, they're the same color. Their mouths are different. The Azog from SDDC 2013 has a relatively closed mouth, the Azog from 7914 has an open mouth, sort of screaming, mad. I would highly recommend 7914 as I have it, and it was a blast to build a mess around with. But if you just want to Azog figure and not the exclusive, Bard, Eagle, Thorin and other stuff in 7914 get the SDDC. Hope this helps! Tyndale
November 8, 20177 yr On 27/10/2017 at 5:19 PM, Tyndale said: Hey man! Yes there is a difference, and no, it's not the color, they're the same color. Their mouths are different. The Azog from SDDC 2013 has a relatively closed mouth, the Azog from 7914 has an open mouth, sort of screaming, mad. I would highly recommend 7914 as I have it, and it was a blast to build a mess around with. But if you just want to Azog figure and not the exclusive, Bard, Eagle, Thorin and other stuff in 7914 get the SDDC. Hope this helps! Tyndale This is not correct. There are two Azog minifigures, but they are both available in regular retail sets. The first one (with closed mouth) was in the SDCC 2013 set but then also appeared in exactly the same form in 79014, released later in 2013. This set also has Radagast, Gandalf, Orcs, Necromancer, etc. The second one (with open mouth) was in 79017, from 2014 and this is the set with Bard, Thorin, Dain, etc. I wouldn't buy the SDCC one if you just wanted the figure - you are really paying for the packaging. It goes for multiple $100s (about $800 on BL currently).
November 14, 20177 yr Oh my bad sorry for misleading you. But yes I would not get the SDDC, just save up and then buy it when you can, the big one I mean. And thanks for correcting me MAB. Tyndale
