GmaBlu Posted September 27, 2017 Posted September 27, 2017 I may be posting in the wrong place and if I am I apologize. I'm a grandma with a Winter Village that lured me into Lego. I had it at work as a kids therapist for 2 years but it outgrew my office and has a spot at home now. Lots of children play with it from Thanksgiving to New Years. They run the trains, and build their families out of minifigs so it is more strong than elegant. Three years ago I saw some pretty cool ski lifts online and I want one: https://www.youtube.com/watch?v=QnJ2M1iKt40 https://www.youtube.com/watch?v=tIZ5WkQp-Uo https://www.youtube.com/watch?v=fSwdposR3Sk and went a little nuts on bricklink buying what I thought I might need. Last year I copied the seats from twigman's non operational warming hut. https://www.eurobricks.com/forum/index.php?/forums/topic/49952-winter-village-ski-lift-and-warming-hut/ Then I stayed intimidated and did nothing until last week. I copied the Friends ski lift which is pretty worthless for what I want and then I built an ugly fortress. Then I went online and learned as much as I could about how real ski lifts work. I bought Sariel's book and built a better tower that doesn't pop off the hill as easily. I finally uploaded my first pix ever to flickr hoping someone here can help me. https://www.flickr.com/photos/143898716@N08/ I tried twine, drapery cord, and yarn to drive my bullwheels but all are too slippery and if I tighten them I collapse my towers. Also my motor needs to be geared down but I'm not understanding enough. I let kids crash trains but I want this to work well before they get their hands on the remote. There is a local LUG but I have to Take care of my Dad on the weekend it meets. I would appreciate any advice. Thanks, Karen Quote
TechnicRCRacer Posted September 27, 2017 Posted September 27, 2017 (edited) A nice project to make a ski lift! Here is what I can come up with in five minutes (more later): Possibly use two smooth tread motorbike wheels horizontally stacked to add grip onto the string in the center. I also noticed on skyways, the hook that holds the top of the gondola sticks out to the side like this: (Sorry if pic is too big, will fix soon) Hope this helps! TechnicRCRacer Edited September 27, 2017 by TechnicRCRacer Quote
GmaBlu Posted September 27, 2017 Author Posted September 27, 2017 (edited) Thanks. Makes sense. 4 of Part 88516 Tire 94.2mm D. x 22mm Motorcycle Racing Tread ordered. Edited September 27, 2017 by GmaBlu Quote
dagupa Posted September 27, 2017 Posted September 27, 2017 (edited) Hello. First at all, I'm not a Native English Speaker and this is a fairly technical discussion so I'm going to use a lot of pictures. Tension is the key in every ski lift so you have to deal with it. If you pay attention to the videos that you posted as examples they deal with this problem in very "convenient ways". This guy uses a string: This guy just made the entire structure like a "paper clip" around the wall: As I understood, you have two problems: 1. Your main towers collapse when tension is applied to the string. 2. The string slips around the plastic rim. I guess you are connecting the motor to one of those motorbike rims. Well, your towers seem very sturdy, so I assumed that when you say "collapse", you mean that they just "pop up" from the baseplate. If that is correct there are two things you can do to make them stay in place. 1. The obvious: Put more technic bricks that connect your tower to your baseplate. 2. Relieve some of the horizontal tension by placing diagonal beams between your tower and the baseplate. According to the pythagorean theorem you can use a 21 diagonal when your base and height are 15x15. The longer the structure, the more resistance to tension. You can also place a secondary tower that helps to "support" some of the vertical component of the force. Tension 1 and Tension 2 are the same, but the Secondary Tower helps with the force "down to the ground" that the cables exerts due to the level difference between the two stations. HUGE DISCLAIMER: I use Tension and Force like they are synonyms, they are not, but it helps to explain what's going on here. Now, About the string. If you don't what the string to slip, don't change the string, change the wheel. Note that in the videos they use tires, which are made from rubber. Rubber coefficient of friction is a much greater that the coefficient of plastic. You may want to use two wheels one above the other to keep the string in place. Again, I assumed you are connecting the motor to one of those wheels. There are other ways to transfer mechanical movement to the string but using a big horizontal wheel at the end is how many of the real Sky Lifts works. I hope this helps you Edited September 27, 2017 by dagupa Quote
GmaBlu Posted September 28, 2017 Author Posted September 28, 2017 Wow! Thanks. I will try these suggestions. Quote
1963maniac Posted September 29, 2017 Posted September 29, 2017 (edited) About the gearing down, Put a small gear on the motor and a larger gear to turn your bullwheels. Check Sariel's book about gearing down. Post some pics of your drive mechanism so we can help with it further. Check this out... http://curvetube.com/LEGO_Technic_detachable_gondola-Final_version_by_PG52_[HD]/9xm2VeHWkKQ.video PG52 is a great designer! Edited September 29, 2017 by 1963maniac additions Quote
TechnicRCRacer Posted September 29, 2017 Posted September 29, 2017 I will try building some proof of concept models tonight to help you out. I haven't built a ski lift before, but I'll try! Quote
GmaBlu Posted October 1, 2017 Author Posted October 1, 2017 Wow! Thanks! I'm less overwhelmed and more excited. I ordered gears like that. I hope they come soon. Quote
PG52 Posted October 1, 2017 Posted October 1, 2017 Hi ! First of all, sorry for my english, it's not my native language :) I have to say that your winter village looks awesome ! So much detail, and something that makes it even more beautiful : it has hills ! Really like it :) You want to make a fixed grip ski lift, which I'm not specialized in at all (I'm much more in detachable and technical stuff), but I might have some advice which can be applied to fixed grip lifts. Even though I was never able to make any working properly... About the problem you have with tightening the cable, you have the chance to work on a diorama on which you can attach things on. On such a small-sized lift, a solution could be to make a structure underneath the landscape which would link together both up and downhill station, and also the towers. That way, the only limit for tightening the cable would be the rigidity of the structure. About the towers, what you can do first is link together both sides of the top part of the tower (I think the right word is "shelves" or "schieves"... Can't find it) : basically, as you did, both sides can curve independantly but you can fix them on an axle that runs across the tower to get more rigidity. Then, using the following principle for mounting the towers can help : the more tightened the cable is, the more stable the tower will be. For this type of "support" tower, as soon as the ground is solid, you don't need any foundation for it. Fixing it using classic lego should work well. The more wheels you have one the towers, the more fluidly the grips will pass them, but the more alignment problems you may have. 4 wheels on each side is usually a good compromise ; 8 is useful if you have a big angle to make. You can also use 6 wheels, usually works well and not as big as the 8-wheels one but it is a little more complex (it's like a 8-wheel one where you replace one of the "4" by a "2"). 1 or 2 wheels is too few, it will never work fluently. 3 is useless if they are on a straight line : you must always have them articulated so that they curve naturally when the cable is on, and also for the grip to pass them correctly. The best minimum is 4, if you really can't use 4 or if it is only to stabilize the cable (almost no angle to make) then use a 2-wheel one, but articulate it :) About the stations you made, there is a problem : when the grip passes on the return wheel, it needs to be outside of the cable loop. But you mounted the wheel alignments on the outside, which can't work. Basically the shape of a fixed grip is like this : The stations are only the combination of an horizontal return wheel and a tower :) About the cable slipping on the return wheels, instead of using only rims, you could also use big motorcycle wheels like these ones : [Part 88517c02] Wheel 75mm D. x 17mm Motorcycle with Black Tire 100.6mm D. Motorcycle (88517 / 11957) Image source : Bricklink.com The "grips" on the tire are big enough to guide the cable properly, it never slips, and it is also quite thin so no big aesthetic problem. I usually use 1 mm and 1.5 mm nylon string, which work really well with these wheels. Hope that helps :) Quote
dagupa Posted October 8, 2017 Posted October 8, 2017 (edited) I've been working on this for a couple of days. I think a chairlift would be a nice addition to my Lego City, which is very small BTW. I come up with this prototype. It works fine and it's really simple and easy to build. I'll be posting instructions and photos of the real model sometime soon Edited October 12, 2017 by dagupa Quote
GmaBlu Posted October 9, 2017 Author Posted October 9, 2017 Thanks. This looks great. I will post pix when my parts come! Thanks again! Dagupa, what is the BrickLink id number for that wheel and tire? Thanks, GmaBlu Quote
dagupa Posted October 9, 2017 Posted October 9, 2017 21 hours ago, GmaBlu said: Thanks. This looks great. I will post pix when my parts come! Thanks again! Dagupa, what is the BrickLink id number for that wheel and tire? Thanks, GmaBlu Lego Tyre 81.6 x 36 R Bricklink id: x1825 This tire is actually important because the diameter and the “grips” are what keep the cable aligned. Also, this rubber has a greater coefficient of friction than the Lego motorcycle tyres. Lego Wheel 56 x 34 Bricklink id: 44772 or 15038 This is basically a standard rim. The return wheel (the one with no tire) is the same that you already have (Lego Motorcycle Wheel) Full inventory and instructions will be available in a couple of days on rebrickable.com I recommended this site, it’s very useful for Lego builders. You are welcome. I enjoyed building this. A little more complicated than I initially thought. It was fun, though. Quote
dagupa Posted October 12, 2017 Posted October 12, 2017 (edited) I finished the video and the instructions. Some Information: I used a string that is a little bit elastic. There are two types of knots that I tried for securing the chairs. Both perform different and if you are interested in building this, you may want to try both and see which one suits your setup best. I don't recommend to tight the string too much, but I think that depends on the kind of string you are using. I guess you'll have to experiment. BTW, this ski lift can be mounted on a flat surface, too. There are instructions for both assemblies: Flat and inclined ground. Instructions available at http://shop.dagupa.net I submitted the inventory to rebrickable today. Usually takes a couple of days for them to approve new MOCs That's all for now. I hope you enjoy this moc. I may try to build something bigger and fancier. Edited October 12, 2017 by dagupa Quote
GmaBlu Posted October 14, 2017 Author Posted October 14, 2017 I have tomorrow off and will be trying to get this mostly built with what I have. I hope I have ordered correct parts and will get it running when they come. Thank you for you smart brain and hard work! Quote
GmaBlu Posted October 31, 2017 Author Posted October 31, 2017 I got the right rim but the wrong tire so I have reordered on bricklink. The wrong tire will drive the string but pops off as soon as it has a load. It looks like it will work perfectly when I have he right tire. Quote
1963maniac Posted November 22, 2017 Posted November 22, 2017 Did you get your ski lift finished? Wondering how you are doing? Quote
GmaBlu Posted December 9, 2017 Author Posted December 9, 2017 My son, his wife, and their 3 year old twins came to stay with us for 3 weeks prior to moving to Europe. They slept in my Lego room so I haven't done anything except cover it with a sheet. The only Lego I have done is Advent calendars with them and take them to Phoenix Lego Discovery. We had a blast there. They just left yesterday for Luxembourg. I hope to time my visit to them for a big Lego show. The ski lift is working beautifully but it is not tall enough. The minifig skiers smack into the trees. On my day off next week I plan to built a tecnic truss base and hide that with snow mountain. I hope to post pix soon. Thanks to dagupa, PG52, 1963maniac and TechnicRCRacer for your help. Quote
TechnicRCRacer Posted December 10, 2017 Posted December 10, 2017 Can’t wait to see it! I have always wanted to build an amusement park style ride, but every time I try it ends up way too big. Quote
dagupa Posted December 12, 2017 Posted December 12, 2017 I hope to see some pictures. Did you change the color scheme to fit your village? Quote
XG BC Posted February 22, 2019 Posted February 22, 2019 @dagupa I've built your chairlift design but i've modified it to work using this ontop of this as a bullweel it was quite a challenge but in the end it all came together pretty nicely. XG BC Quote
skier0224 Posted May 19, 2019 Posted May 19, 2019 I am working on a ski resort myself, and the problems with the string slipping on the bullwheels has happened to me too. I fixed it, and the problems I found were the material for the string and the chair weight to steepness ratio. the steeper the slope, the harder it will be to carry the chairs, so I recommend either decreasing the slope or making the chairs lighter. Also, put rubber liners on the bullwheels, using either LEGO parts or rubber bands. Quote
coinoperator Posted May 19, 2019 Posted May 19, 2019 For the bullwheel 24121 comes to my mind.. But the slipping cord will be more problematic. Quote
