Gunman Posted September 29, 2017 Posted September 29, 2017 Hello there guys :) As titles says, atm I am using pov ray 3.7 to render files exported from Ldview. During Ldview I have transparent background checked, and also at pov ray file I have #declare LDXFloor = 0; I used to be able to export PNGs with trans background at past, but now I think it needs a tweak, as I have used previous files I had exported and now they come out with white background. Can you please help me? In wiki I found this: Quote Note: In version 3.7 alpha handling for image file output has changed. Effectively, the background now requires a filter or transmit value in order for alpha transparency to work properly. Any help appreciated Quote
papacharly Posted October 2, 2017 Posted October 2, 2017 Did you already gave a try to the following? Clear the pov-ray command line. Then add +fn +ua: +fn generates png file output +ua generates transparent background For my pov-ray 3.7 it works fine. Hope, it works the same way on your system. regards papacharly Quote
Gunman Posted October 3, 2017 Author Posted October 3, 2017 thanks a lot for the help mate, I got it working just adding to the povray.ini the following: Output_Alpha=True thanks a lot again :) Quote
