Hi,
I present you my version of the suttle of Kylo Ren.
It's not an UCS (some details are differents) but it correspond to the idea that I have of this ship : a black shadow.
I kept the sytem to open the cockpit at the front and the back, but I didn't worked inside yet. At the begining, wings could be vertical, but considering the weight of wings, I have to change and they are fixed (but it's only to display in my dedicated room)
Complete album flickr of this MOC : https://www.flickr.com/photos/138759056@N05/albums/72157687270801021
37763566372_16ef7cfece_c.jpgIMG_20171019_175236
23942595778_e5d800aefd_c.jpgIMG_20171019_175013
23942590308_a1ed1c3256_c.jpgIMG_20171019_175203
37763568892_789690bd3c_c.jpgIMG_20171019_175101
37763574302_d1e3bd2c1a_c.jpgIMG_20171019_174854
37763571872_39b327a43a_c.jpgIMG_20171019_175026
23942593308_034b5f944b_c.jpgIMG_20171019_175051
37763564302_b93164978f_c.jpgIMG_20171019_175328
37763565432_0d12217962_c.jpgIMG_20171019_175306
23942602588_a7740d679a_c.jpgIMG_20171019_175738
23942603508_5f487e64f3_c.jpgIMG_20171019_175643
23942605038_a689939ce6_c.jpgIMG_20171019_175546
23942607398_10a373c7bc_c.jpgIMG_20171019_175505
23942614898_099f26023d_c.jpgIMG_20171019_175343
23942600598_fa8cb9cab1_c.jpgIMG_20171019_175844
37763576152_a839cf2b5c_c.jpgIMG_20171019_175922
Edited by syrhilla
Wow, awesome build here this looks super clean, great contrast between snot and studs!
Ellis.
Wonderful build well done my friend. Love the total black look.
The wings seem to bend from the pics. Or is just me?
4 minutes ago, vded said:
Magnifique construction bien fait mon ami. Aimez le look noir total.
Les ailes semblent se plier des photos. Ou est-ce juste moi?
Thanks,
No, Perhaps some plates are misplaced after moving for the pictures. At the begining wings bent, but after, I used a structure in technic bricks avoid it.
Edited by syrhilla
This is by far the best rendition of the shuttle that I've seen. It's absolutely beautiful.
Edited by TheBrickLord
That looks really sleek. I love the cabin section it almost looks like a living being.
How many parts are holding the wings at that angle? Do you think they may warp after  while?
Regardless, it looks fantastic, you should try to post how you did it. I am sure some folks will like to homage this build.
6 hours ago, Japanbuilder said:
Cela semble vraiment élégant. J'aime la section de la cabine, il ressemble presque à un être vivant.
Combien de pièces maintiennent les ailes à cet angle? Pensez-vous qu'ils peuvent se déformer après?
Quoi qu'il en soit, il semble fantastique, vous devriez essayer de poster comment vous l'avez fait. Je suis sûr que certaines personnes aimeront rendre hommage à cette construction.
Thanks,
Sorry for my description, my english is bad.
For one wing, there is two liftarm and two liftarm bent, firmly attached on the wing (and a technic brick strucure inside the wing) and on the cockpit.
I think that it is sustainable, because I can take the ship by the wing (but you can really play with it). The plates are the weak link, because they are attached by two tenons in general. I prioritize the structure, not the surface. Time will tell me.
I'm not at home for 15 days, so I can't take other pictures (and I didn't work on LDD), and my english is too bad to describe precisely the technics. But when I will return, I try to take pictures of inside structures.
Looks really nice, great lego work, but designwise (not your fault of course) it still looks rediculous
  • 4 weeks later...
  • 2 months later...
A little update of this MOC. I added Red LEds :
(sorry for the quality but I can not better capture the light of the leds .....)
And with no flash or other lights :
On 30/01/2018 at 1:30 AM, HopsonMatt said:
What was your method for making the wings plated on both sides
I use this technic :
(to have a brick height, exactly, that separate the plates, which corresponds to technic bricks that consolidate wings )
