Sven J Posted November 4, 2017 Posted November 4, 2017 (edited) Dear AFOL trainheads, After almost six months of designing work, another five months of construction, countless bursts of temper, and being relieved of a small fortune, I am very proud to present my latest locomotive MOC. This time, it’s a 2-10-2T narrow gauge (760 mm) steam locomotive, class 600.76, of the Bulgarian State Railways (Balgarski darzhavni zheleznitsi, BDŽ). Basically an enlarged version of the German DRG Baureihe 99.73, the first five locomotives of the class were built in 1940 by BMAG (formerly L. Schwartzkopff) in Berlin for hauling all kinds of trains on the mountainous Rhodope railway from Septemvri to Dobrinishte. Delivering about 850 hp, the engines were extraordinarily powerful by the time’s standards for single-frame narrow gauge locomotives. They were so successful that the BDŽ were keen to acquire more, but after the Bulgarian Tsardom had turned into a communist republic at the end of WW II, it became almost impossible to buy industrial goods from German manufacturers. Thus another 10 engines were delivered in 1949 by Fablok in Chrzanów, Poland. These Polish-built locomotives were technically identical to the original Schwartzkopff ones, but could easily be distinguished from the first series by the combined steam/sand dome casing and the odd-looking smoke deflectors, which seem quite ridiculous on an engine with a top speed of no more than 45 km/h! From 1966 on, after new diesel locomotives had arrived at Septemvri, all class 600.76 locomotives were relocated to Cherven Bryag in northern Bulgaria. Several have survived until today, albeit most of them in desperate condition. One engine – No. 609.76, however, is in operational state (now stationed in Septemvri again) and regularly used for excursion trains. My model portrays a locomotive from the second series as it ran in the late 1960s, some years after the whole class had been equipped with compressed-air brake and supplementary oil firing. As opposed to the drawing, it therefore has a shortened right side tank (to make room for the air compressor), air reservoirs below the rear tank and an extended coal/oil bunker. The model is in accurate 1:22.5 scale except for the track gauge, which according to G-scale standard is always 45 mm regardless of the prototype’s actual value (as mentioned before, class 600.76 has 760 mm, or 33.8 mm in 1:22.5). Therefore, it matches LGB garden railway track and rolling stock. Dimensions and height of the coupling bars are designed in a way that they work with LGB link-and-pin couplers. Three PF L-motors working on the central driving axle are responsible for propulsion, with the other drivers (BBB XL) being coupled by the side rods, just as in the real thing. One BuWizz brick allows to remote-control running direction as well as speed, and serves as a power supply for the lights (separately switchable front/rear headlights, combined cab & running gear lights). The LED equipment was purchased from Brickstuff; valve gear parts and main rods were supplied by zephyr1934. The running gear layout proved to be quite a challenge. The leading and trailing axle are of the Bissell type and can swing out by 9°. Of the driving axles, the second and third one are blind, while the fourth one is slidable laterally by +/- ½ stud. With this configuration, the engine is running stably on straight track, yet also able to negotiate LGB R3 curves and switches (1195 mm radius). The model consists of more than 3200 parts and weighs about 2.2 kg. Enough said – enjoy the pictures! Some views of the engine frame. For reasons of stability, I had to fill the prototypic cutouts with trans-clear plates and bricks. You can see the steam inlet pipes running to the cylinders on the outside, as well as the exhaust pipes inside the frame, leading steam to the exhaust nozzle in the smokebox. Underneath, the brake rigging is also reproduced: The leading/trailing trucks. The tongue connecting the truck to the main frame is free from load, which means that it could be kept prototypically thin; the engine weight is supported by the axle bearings via the 4x4 tile on top. Fully detailed cab interior, including a tiltable ”Marcotty“ type firebox door and functional folding seats: Complete smokebox interior as well. The exhaust nozzle, spark arrestor, smoke stack bottom, boiler tube openings and superheater tubes are visible: Plenty of water in the side tanks: Some boiler details, among others showing the generator hidden behind the smoke deflectors: The combined oil/coal bunker can be removed to give access to the power button and the charging socket: The three magnetic switches for the lights are hidden in the rear toolbox: Posing in front of a historic BDŽ crest: The cab lettering: The lights: Some matching, albeit non-purist decoration (1:24 GAZ M20 Pobeda by Yatming, 1:22 [sic!] VAZ/Lada 2106 by Avtoprom)… A short video, showing the valve gear in motion. Note that unlike many conventional model locomotives, the valve stem is really pushed back and forth. A video of the engine pulling an LGB G-scale train will follow as soon as possible. As always, you can download the lxf file here. Also, more and much larger pictures can be found in my Bricksafe folder. Finally, I’d like to say special thanks to Sergio Monai, who with his fruitful feedback and proposals kept me stimulated to achieve the best possible result! Comments are of course most appreciated – thanks for stopping by! Best regards, Sven Edit: New video here! Edited May 6, 2018 by Tenderlok Quote
Feuer Zug Posted November 4, 2017 Posted November 4, 2017 Blimey, that's a fantastic prototype. Every detail is well planned and executed. The frame, smoke box, Everything! You have built a great MOC and should be proud. Quote
Daedalus304 Posted November 4, 2017 Posted November 4, 2017 Incredible model, absolutely amazing level of detail. All your models have been great, but it seems like you've managed to outdo yourself here! Quote
zephyr1934 Posted November 5, 2017 Posted November 5, 2017 This model has friggin boiler tubes!!??!!? And complete brake rigging? And piping to the cylinders? And the most complete valve gear I've seen? And did you see that backhead... not a thing missing that I can spot? Then there are the extensive lighting system... WOW! That is the most amazing lego locomotive I've seen in a long time. Quote
Steamdemon Posted November 5, 2017 Posted November 5, 2017 I think you deserve a mention on the front page. That detailed cab. Really well done with the wiring, nice and clean. Also, love the fact that you have a very detailed water tank and combi bunker, which hides the charging port. Very well done! Quote
monai Posted November 5, 2017 Posted November 5, 2017 (edited) Dear Sven your creation is revealing not only your Lego skillness but also your great railway culture. You go over the normal playful passion for Lego (always necessary) and reach a museum documentation quality. I'm honored to be considered a friend in this cultural passion. with my best regards Sergio Monai Edited November 5, 2017 by monai Quote
marbleman Posted November 5, 2017 Posted November 5, 2017 It really shock me. This isn't Lego, it's artwork. Words cannot express my worship to you. Quote
LEGO Train 12 Volts Posted November 5, 2017 Posted November 5, 2017 Wow Tenderlok, I think this is the most beautiful locomotive of your collection ...the problem is that your collection was already the best of all! You astonished us with a level of details that makes your masterpiece something that goes beyond the simple lego brick ...this time you've overcome yourself! What can I said of that cab? It looks like a real cab! I'm worried about you've spent a lot of money but I'm grateful to you for sharing this project with us.Now I'm afraid that your next locomotive will take a long time to be realized! Last but not least the Walschaerts valve makes the steam engine even more complex and realistic! Correct also the graphic fonts you've used! Quote
ColletArrow Posted November 5, 2017 Posted November 5, 2017 This is incredible, as ever from a master train builder... the details are stunning. I can't wait to see it in action. 4 hours ago, Steamdemon said: I think you deserve a mention on the front page. Definitely. @Jim, could you make this happen, please? Quote
JopieK Posted November 5, 2017 Posted November 5, 2017 11 hours ago, zephyr1934 said: This model has friggin boiler tubes!!??!!? And complete brake rigging? And piping to the cylinders? And the most complete valve gear I've seen? And did you see that backhead... not a thing missing that I can spot? Then there are the extensive lighting system... WOW! That is the most amazing lego locomotive I've seen in a long time. I totally agree :) (Also to all the above comments ;)) Quote
LEGO Train 12 Volts Posted November 5, 2017 Posted November 5, 2017 I'm noticing (only now) that the front hatch of the boiler opening has the cable for the front lighting ...you're definitely sick! Quote
Sven J Posted November 5, 2017 Author Posted November 5, 2017 (edited) A thousand thanks to all of you for your compliments! I’m very happy that you like my model. 20 hours ago, Feuer Zug said: You have built a great MOC and should be proud. Indeed I am… @monai Sergio, did you notice that the cab doors do open this time? (Though it needs some force to close them again.) 4 hours ago, LEGO Train 12 Volts said: I'm worried about you've spent a lot of money [...]Now I'm afraid that your next locomotive will take a long time to be realized! [...] Correct also the graphic fonts you've used! To item 1: I suppose you’re right – it’s incredible how expensive especially some of the green parts are. But new ideas are already forming. To item 2: Of course… 16 minutes ago, LEGO Train 12 Volts said: I'm noticing (only now) that the front hatch of the boiler opening has the cable for the front lighting ...you're definitely sick! Yes, that’s how it is on the real engine (see e.g. here). I’ll take it as a compliment… @JopieK Thank you for featuring my model on the front page! That’s a great honour. Thanks also to @Steamdemon and @ColletArrow for proposing the model for the front page. As for the promised video: When I started to make it this afternoon, I found that I had forgotten to recharge the BuWizz… Now that charging is finished, it’s already too dark for decent motion pictures. For the photos, I used exposure times up to 8 seconds, but obviously that’s not possible for making videos. So I think it won’t be until one of the next weekends that I can show you my beauty hauling a train – I apologise for that delay. Edited November 5, 2017 by Tenderlok typo Quote
Asper Posted November 5, 2017 Posted November 5, 2017 Wonderful! Incredible level of detail! Great! Quote
bonox Posted November 5, 2017 Posted November 5, 2017 (edited) truly outstanding work; the detail is extraordinary. Surely it's a shoe-in for the scale model sub-forum? It's in need of more locomotives! Edited November 5, 2017 by bonox Quote
Toastie Posted November 5, 2017 Posted November 5, 2017 Beyond believe, simply beyond believe. Generally speaking, it appears as it if is much tougher to capture any kind of detail, look and feel, when reducing to 6-, or even 4-wide scales. The larger the scale, the more LEGO pieces blend in. Generally speaking ... BUT: The degree of detailing in your models is going way behind "generally speaking". First of all: Larger scale models become heavy and certainly stability becomes rapidly an issue. You not only solved that problem - you kept the "lightness" (if there could be any when talking about a steam engine - but I always have the impression that real world steam engines have some appearance of lightness ...) - and all your LEGO models are actually reliably running on track. But even further: Detailing on your models is breathtaking. You are building large scale models - but you push the limits of LEGO beyond believe in this regard. This is the most beautiful LEGO steam engine I have seen. I also believe that this should be cross-posted in the "LEGO Scale Modeling" Forum. For sure. Congratulations, Tenderlok. Or as I have learned in this forum: Tipping hat, slight nod ... All the best, Thorsten Quote
Sven J Posted November 5, 2017 Author Posted November 5, 2017 Thank you so much, Asper, bonox, asomemegablox and Toastie! 28 minutes ago, Toastie said: [...] You not only solved that problem - you kept the "lightness" (if there could be any when talking about a steam engine - but I always have the impression that real world steam engines have some appearance of lightness ...) [...] Definitely there's a kind of lightness in the appearance of steam locomotives. That’s why it’s extremely important to me to render the gap between boiler and frame correctly – although of course it would be much easier to stabilize the boiler with bricks underneath. Also, the frame itself should look as light as possible, I think. As for the Scale Modeling Forum: Personally, I would prefer the model to stay in the Train Tech Forum. Simply because I presume that it’s easier to find for the train enthusiasts here – maybe they don’t visit the Scale Modeling Forum too often. Quote
Hod Carrier Posted November 6, 2017 Posted November 6, 2017 @Tenderlok That's a very interesting prototype, but please can you post some photos of your model for comparison purposes. Thanks. Quote
monai Posted November 6, 2017 Posted November 6, 2017 23 hours ago, Tenderlok said: Sergio, did you notice that the cab doors do open this time? (Though it needs some force to close them again.) Yes I did, (finally) you got it. I wonder if the use of an alternative battery box has helped? is it possibe that spaing the space for receiver could make easier to model the cab? Sergio Quote
Sven J Posted November 6, 2017 Author Posted November 6, 2017 4 hours ago, Hod Carrier said: @Tenderlok That's a very interesting prototype, but please can you post some photos of your model for comparison purposes. Thanks. That's a very nice comment. You made my day - thanks a lot for that! 8 minutes ago, monai said: [...] I wonder if the use of an alternative battery box has helped? is it possibe that spaing the space for receiver could make easier to model the cab? [...] As a rule, yes. In this case, however, I presume that the rear bunker is large enough to hide a genuine LEGO battery box + receiver. I chose the BuWizz because it allows a more precise control and, especially, because the LEGO elements would not have been able to power 3 L-motors. Quote
ReplicaOfLife Posted November 6, 2017 Posted November 6, 2017 Phenomenal. I don't know what else to say. Quote
RemcoRohaan Posted November 6, 2017 Posted November 6, 2017 Absolutely amazing model! Many compliments! And this was after seeing the picture on the Frontpage; now seeing the functionalities makes it even more special. Keep it up! Rds, Remco Quote
_Oceanblue_ Posted November 7, 2017 Posted November 7, 2017 Tenderlok, superb job. Well done. Proud of seeing a national history train as a Lego Masterpiece. Quote
Duq Posted November 8, 2017 Posted November 8, 2017 On 11/5/2017 at 2:32 AM, zephyr1934 said: WOW! That is the most amazing lego locomotive I've seen in a long time. That is the most amazing lego locomotive I've seen in a long time. You are in a league of your own with this one. The amount of detail you've crammed into this model is mindboggling... You mention magnetic switches. Where did they come from and how do they work? Quote
harnbak Posted November 8, 2017 Posted November 8, 2017 Astonishing details and beautiful as a whole Quote
